2950 Layer 2 problem
elisaabad
Hello! I'm trying to replace a Windows Server using a 2821 router.
INITIAL SITUATION
Server --- 2950 --- router
- Server: 10.0.6.230/24
- Router: 10.0.6.10/24
- The router interface can be pinged from the server
FINAL SITUATION
2821 --- 2950 --- router
- 2821 int vlan200: 10.0.6.230/24
- 2821 int fa1/15: no ip address, switchport access vlan 200
- The router interface can't be pinged from the 2821
WHAT I HAVE SEEN DURING THE PROBLEM
The physical layer link to the switch seems ok.
I can see the 2950 switch with a "sh cdp neighbors"
I can see the router's mac in vlan200 with a "show arp"
I think the problem could be related to the 2950 arp or mac-address table but I can't access the 2950 nor the remote router.
Any idea of what is going on? Thanks!!
smothuku
Level 7
Level 7
Hi ,
Can you paste the config of 2821 and router..Is there anything configured on 2950 switch...
Satish
Hello, I don't manage the 2950 switch nor the remote router. I can only check the 2821 and I think everything is ok in my configuration.
This is the config in the 2821:
version 12.4
ip cef
interface GigabitEthernet0/0
ip address 192.168.0.1 255.255.255.0
interface FastEthernet1/15
interface GigabitEthernet1/0
switchport access vlan 100
interface Vlan100
ip address 172.16.0.3 255.255.255.192
ip virtual-reassembly
interface Vlan200
ip address 10.0.6.230 255.255.255.0
ip route 0.0.0.0 0.0.0.0 172.16.0.1
ip route 10.0.0.0 255.0.0.0 10.0.6.10
Can you do an extended ping from the fa1/15 interface? For extended ping type ping on the command prompt. for Extended commands answer "y" and then give the source interface as FastEthernet1/15.example shown below. Please do tell us the result.
ping
Protocol [ip]:
Target IP address: 10.0.6.10
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: FastEthernet1/15
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.0.6.10, timeou
Packet sent with a ...
I will try the change again on monday so I will make this test then.
I'm thinking about sticky ARP in the 2950 would be likely to cause this problem... will let you know after monday.
