3640 - digimodem - bri - UDP - Remote control & Logon scripts
MarkMus
Can anyone help with this probably pathetic question?
I have dial in users logging on with local cached profiles. They are authenticated by the router. I am unable to see their computer on the network using "Remote Control" software. This uses udp packets on a single port to browse the network. Also the antivirus is not updating and the logon scripts are not working, I guess, because of udp.
How can I enable UDP safely without giving the facility to the world coming in through the internet?
Thank you
mljohnson
Level 4
Level 4
I'm not sure I understand the topology....async users dial into the 3640, authenticate locally, get an IP address, and (I suppose) have some sort of connectivity. As long as an IP address is negotiated, UDP should work fine; unless you have access-lists specified, all IP data should pass. You may want to confirm if it's only UDP traffic that fails, or if it's all traffic. If it's the latter it's likely the cisco; if it's the former it could be anything else.
Here is my config can you help?....only udp is not working
***#sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ***
enable secret ***
enable password ***
username ** password **
"and so On"
modem country mica united-kingdom
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
isdn voice-call-failure 0
interface Loopback0
ip address 192.***.***.1 255.255.255.0
no ip directed-broadcast
interface Ethernet0/0
description connected to EthernetLAN
ip nat inside
no keepalive
interface BRI1/0
description connected to ***,***,***,Internet
no ip address
ip nat inside
encapsulation ppp
dialer pool-member 1
isdn incoming-voice modem
ppp authentication chap callin
interface BRI1/1
no ip address
ip nat inside
encapsulation ppp
interface BRI1/2
no ip address
ip nat inside
encapsulation ppp
interface BRI1/3
no ip address
ip nat inside
encapsulation ppp
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
peer default ip address pool default
no cdp enable
ppp authentication chap pap
group-range 65 70
interface Dialer1
description connected to remote_one
ip unnumbered Ethernet0/0
ip nat inside
encapsulation ppp
no ip split-horizon
dialer remote-name ***
dialer pool 1
dialer idle-timeout 180
dialer hold-queue 10
dialer load-threshold 200 outbound
dialer-group 1
no cdp enable
interface Dialer2
description connected to remote2
ip nat inside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
no cdp enable
interface Dialer3
description connected to remote3
ip nat inside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
no cdp enable
interface Dialer4
description connected to Internet
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer idle-timeout 240
dialer string 9***
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname ***
ppp chap password ***
interface Dialer5
ip nat inside
encapsulation ppp
no ip split-horizon
dialer remote-name remote
dialer pool 1
dialer-group 1
no cdp enable
ip local pool default 192.***.***.10 192.***.***.40
ip nat inside source list 1 interface Dialer4 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer4
ip route 192.***.***.0 255.255.255.0 192.***.***.1
ip route 192.***.***.1 255.255.255.255 Dialer1
ip route 192.***.***.1 255.255.255.255 Dialer2
ip route 192.***.***.1 255.255.255.255 Dialer3
no ip http server
access-list 1 permit 192.***.***.0 0.0.0.255 "LAN"
access-list 1 permit 192.***.***.0 0.0.0.255 "Dialer1"
access-list 1 permit 192.***.***.0 0.0.0.255 "Dialer2"
access-list 1 permit 192.***.***.0 0.0.0.255 "Dialer3"
access-list 1 permit 192.***.***.0 0.0.0.255 "Def pool"
dialer-list 1 protocol ip permit
snmp-server engineID local *************
snmp-server community public RO
banner motd
line con 0
exec-timeout 0 0
password
login
transport input none
line 65 70
autoselect during-login
autoselect ppp
login local
modem InOut
line aux 0
line vty 0 4
password
login
end
