876W router problems
Velos-itnet
Hi I am trying to configure a Cisco 876W router as the following.
Vlan1 ip address 10.17.64.1
I have set up a dhcp pool for this which works fine. The problem is I want the wireless network to be an extension of this VLAN and to assign addresses from this DHCP pool but I cant seem to get them to talk to each other.
interface Tunnel1
description GRE tunnel to *****
ip address 172.100.2.2 255.255.255.252
keepalive 10 3
tunnel source Loopback0
tunnel destination 172.100.1.1
crypto map cryptmap
interface Loopback1
description "Management Loopback Interface"
ip address 10.17.71.254 255.255.255.255
interface Loopback0
description Tunnel end-point
ip address 172.100.1.2 255.255.255.255
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
ip address 10.17.66.1 255.255.255.0
broadcast-key change 900
ssid ********
authentication open eap eap_methods
authentication network-eap eap_methods
accounting acct_methods
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description $FW_INSIDE$
ip address 192.168.0.1 255.255.255.0 secondary
ip address 10.17.64.1 255.255.255.0
ip tcp adjust-mss 1452
ip policy route-map clear-df
balajitvk
Level 4
Level 4
Have a try by allowing vlan 1 in radio interface and also giving ip helper-address command in vlan 1(if you are having separate dhcp server.)
Rgs
After having gone through the same problem, I belive the solution is this:
bridge irb
no ip address
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
bridge 1 protocol ieee
bridge 1 route ip
