CAT 2950 - Monitoring port
CanEHdian
How can I setup a port for monitoring that will enable the probe to not only listen for traffic, but also to send it to another PC on the LAN for analysis?
Thanks in advance,
Al
ablenner
My limited experience suggests that if you set up SPAN monitoring (config-if#port monitor ) the port doing the monitoring remains active. So you can use the probe to send as well as receive data. Dis-entangling the probe traffic from the monitored traffic at the other end might be interesting.
I've never actually tried this; others may be able to comment.
