Cat6500 PCMCIA Flash card formatting issue
klaudia
Hi there,
I am having an issue here with formatting this card. When I enter 'format slot0: bootflash:catxxx' (the catos file name),it starts formatting, but terminates with the following error:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters):
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Unknown device mfg id (5d.75.ffffffea)error = -1
Format device slot0 failed (unspecified error)Console> (enable)
Can anybody help me on this one, please?
Klaudia
8 Replies 8
Prashanth Krishnappa
Is this a 64M flash card? If so, do you have the required ROMMON 7.1(1)?
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/78_13488.htm#147722
Paste outputs of sh mod and sh ver
yes, there is the required ROMMON version.
Console> (enable) sh ver
WS-C6006 Software, Version NmpSW: 7.3(1)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Jul 8 2002, 16:10:20
System Bootstrap Version: 7.1(1)
Hardware Version: 2.0 Model: WS-C6006 Serial #: TBA04110480
PS1 Module: WS-CAC-1000W Serial #: ACP04050173
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0745PBZY Hw : 4.4
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.3(1)
Sw1: 7.3(1)
WS-F6K-PFC2 SAL0745PA7V Hw : 3.4
15 1 WS-F6K-MSFC2 SAL0744P3RQ Hw : 2.5
Fw : 12.1(13)E11
Sw : 12.1(13)E11
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 262144K 65272K 196872K 32768K 7617K 25151K 512K 257K 255K
yes, it is a 64MB flash card
Can you just issue a "format slot0:"
yes, I have tried this simple form, but it requires some volume ID and I have no idea where to get it from...all I have found was that it is accessible by issuing the command: show flash m/device: filesys I cannot type in 'show flash 1/slot0: filesys', since the memory card in slot0 is not recongnized yet...but without supplying the volume ID the formatting terminates. I really don;t know how to proceed...
You can just press enter when it asks for volume entry. If it still fails, I would suspect it to be a bad flash card
Actually, that was the very first thing I have tried and this is the output I have got:
Console> (enable) format slot0:
That's why I went on to specify the CatOS, but it didn't help either.
My bad..(need more coffee:)
For 64M flash card, you need to use it as "disk0" instead of slot0: Can you try issuing"format disk0:"
Good idea, I'm gonna have one, too :)
I have tried it just yet, and the output is exactly the same as with the 'slot0:' command :( I have tried with as well as without specifying the bootflash image...
