Catalyst 2948G-GE-TX web management?
syves
Dear all
I have just purchaced a Catalyst 2948G_GE-TX switch.
Is there a HTTP management software for this switch similar to the 3500 series switches?
Yves
Prashanth Krishnappa
Yes..If you have Cisco View Capable image. Check to see if you have it. The image name would have letters "cv" in the file name. Example: cat4000-cv.8-4-1-GLX.bin
CAT OS file can be downloaded from
http://www.cisco.com/cgi-bin/tablebuild.pl/cat4000
Once you have the CV capable image, the following page should help
http://www.cisco.com/warp/public/473/105_15954.shtml
