Catalyst 4500: bad inline power and other problem related to inline power
r-marchetti
I've a catalyst4500 with some IP Phones attached and I got some errors like the following:
Jul 14 08:26:49: %ILPOWER-5-ILPOWER_POWER_DENY: Interface Fa5/15: inline power denied
Jul 14 08:26:50: %C4K_IOSMODPORTMAN-6-POWERSUPPLYOUTPUTINCREASED: Power supply 2 output has increased
Jul 14 08:26:50: %C4K_CHASSIS-4-INLINEPOWERRESTORED: Resuming normal phone operation since inline power has been restored
Jul 14 08:26:55: %C4K_IOSMODPORTMAN-6-INLINEPOWEROK: Inline power within limits: Module status changed to 'Ok'
Jul 14 08:26:55: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X4248-RJ45V S/N: JAE1014Z8Z4 Hw: 3.1) is online
Jul 14 08:26:55: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 5 (WS-X4248-RJ45V S/N: JAE1014Z8YP Hw: 3.1) is online
Jul 14 08:27:00: %C4K_IOSMODPORTMAN-4-POWERSUPPLYOUTPUTDECREASED: Power supply 2 output has decreased
Jul 14 08:27:00: %C4K_IOSMODPORTMAN-6-INLINEPOWERSUPPLYGOOD: Inline power from power supply 2 is Ok
Jul 14 08:27:00: %C4K_CHASSIS-3-MIXINPOWERDETECTED: Power supplies in the chassis are of different types (AC/DC) or wattage
Jul 14 08:27:05: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 2 has failed or been turned off
Jul 14 08:27:05: %C4K_IOSMODPORTMAN-4-POWERSUPPLYFANBAD: Fan of power supply 2 has failed
Jul 14 08:27:05: %C4K_IOSMODPORTMAN-4-INLINEPOWERSUPPLYBAD: Inline power from power supply 2 has failed or been turned off
Jul 14 08:27:10: %C4K_IOSMODPORTMAN-6-POWERSUPPLYGOOD: Power supply 2 is okay
Jul 14 08:27:10: %C4K_IOSMODPORTMAN-6-POWERSUPPLYFANGOOD: Fan of power supply 2 is okay
Jul 14 08:27:10: %C4K_IOSMODPORTMAN-6-INLINEPOWERSUPPLYGOOD: Inline power from power supply 2 is Ok
Jul 14 08:27:15: %C4K_IOSMODPORTMAN-4-INLINEPOWERSUPPLYBAD: Inline power from power supply 2 has failed or been turned off
but from the show power I can see:
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good bad/off
PS2-1 220V good
PS2-2 220V good
so the 2 Power Supply are ok, but one is considered "bad". Why? Do you have any ideas?
Second strange thing is that with only PS1 some phones don't receive inline power and this is not correct because the power consumption is less than the maximum provided of the only PS1. Any ideas?
Best regards
Roberto
jackyoung
Level 6
Level 6
The second PS seems to be failure, you better claim the RMA or ask the vendor to replace it.
If you have only one PS, the total supported IP phone w/ inline power will be decreased due to lower power of power supply provided.
Try to use below tool from Cisco to calculate the required power / PS.
http://tools.cisco.com/cpc/
Hope this helps.
diduarte
it looks was hitting several bugs. You can, re-seat the power supply and check the status of the light. if is green is a cosmetic issue. Below you can see information about the bugs might hit the switch. If issue persist a replacement is needed.
Frequent Fan Alarm: Fan of power supply 1 has failed
CSCut87080
CSCso67729
%ILPOWER-5-ILPOWER_POWER_DENY: Interface Gi2/33: inline power denied
On ports with POE devices connected.
