Cisco 2901 router Fan issue
Muhammad Talha
Router Fan speed is too high but environment shows normal can any one guide
SYSTEM POWER SUPPLY STATUS
 Internal Power Supply  Type: AC
 Internal Power Supply  12V Output Status: Normal
 External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
 Fan 1 OK, Low speed setting
 Fan 2 OK, Low speed setting
 Fan 3 OK, Low speed setting
 Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
 Intake Left temperature: 23 Celsius, Normal
 Intake Right temperature: 21 Celsius, Normal
 Exhaust Left temperature: 26 Celsius, Normal
 Exhaust Right temperature: 25 Celsius, Normal
 CPU temperature: 50 Celsius, Normal
 Power Supply Unit temperature: 43 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
 Battery OK (checked at power up)
SYSTEM POWER
 Motherboard Components Power consumption = 74.8 WPower consumption =
 ISM 0.0 WPower consumption =
 NM/SM slot 1 3.8 W
 Total System Power consumption is: 78.6 W
 Environmental information last updated 00:00:18 ago
SYSTEM FAN STATUS
 Fan 1 OK, fan level 1, Low speed setting, 11546 RPM, 40% PWM
 Fan 2 OK, fan level 1, Low speed setting, 5175 RPM, 40% PWM
 Fan 3 OK, fan level 1, Low speed setting, 5018 RPM, 40% PWM
 Fan 4 OK, fan level 1, Low speed setting, 5153 RPM, 40% PWM
 CPU temperature: 49 Celsius, Normal
SYSTEM ALARMS SETTINGS
 Fan tray removal or multi fan failure results in warning
 CPU Warning Over Temperature Alarm = 90C
 CPU Critical Over Temperature Alarm = 110C
 Intake Left Abnormal Temperature Alarm = 45C
 Intake Left Over Temperature Alarm = 57C
 Intake Right Abnormal Temperature Alarm = 45C
 Intake Right Over Temperature Alarm = 57C
 Exhaust Left Over Temperature Alarm = 75C
 Exhaust Right Over Temperature Alarm = 75C
 Power Supply Unit Over Temperature Alarm = 80C
 Power Supply Unit Over Critical Temperature Alarm = 95C
SYSTEM VOLTAGES
 12V voltage = 12.434 V, Normal
 5V voltage = 5.146 V, Normal
 3.3V voltage = 3.322 V, Normal
 2.5V voltage = 2.502 V, Normal
 1.8V voltage = 1.822 V, Normal
 1.2V voltage = 1.199 V, Normal
 ASIC voltage = 1.044 V, Normal
 CPU Core voltage = 1.213 V, Normal
SYSTEM POWER
 NM/SM slot 1 3.8 W
 Environmental information last updated 00:00:27 ago
ENVIRONMENTAL STRESS EVENTS
Critical Temperature: Maxium = 0
                      Total Duration = 0
 Exceed Fan Tray Removal Time: Maximum Time= 0
                               Total Time = 0
Total MCU access error count: 0
The RPM for Fan 1 is high but it does not seem to be an issue from the looks of it -
Are both the ISR running the same IOS ? Do you see any buffered warning messages if you do "show logg" ?
R0g22
How do you know that it is too high ?
By comparing noise of 2 2901 router on the same rack..slightly high fan speed
Hi Nipun,
I doesn't see any buffered msgs in logs, See in attached snap. Also PTCL router are running on 15.2 IOS while cybernet router is on 15.5.
