I have two locations with a single 3640 in each location, the locations are connected by a pair (for redundency) of MCI PIP Frame-Relay circuits running IETF encapsulation. Is there any type of compression (similar to PPP compression) that can be used on IETF encapsulated circuits to increase throughput?
If you are running voice traffic you can also use traffic shaping by assigning a map class and using rtp priority. Let me know if you need an example of the above
Listen: https://smarturl.it/CCRS9E25 Follow us: twitter.com/ciscochampions
With applications and users everywhere, the networks are now, more than ever, being tasked with delivering consistent protection while providing an exceptional user exper...
view more
Listen: https://smarturl.it/CCRS9E24 Follow us: https://twitter.com/CiscoChampion
Cisco Radio Aware Routing addresses several of the challenges faced when merging IP routing and radio communications in mobile networks, especially those exhibiti...
view more
Listen: https://smarturl.it/CCRS9E23 Follow us: https://twitter.com/CiscoChampion The Wi-Fi 6E Catalyst 9136 access point takes advantage of the 6-GHz band to produce a network that is more reliable and secure, with higher throughput, more ...
view more
When moving from OSPFv2 to OSPFv3, there are many changes in the format of the LSAs Type, but the most known changes are: IP prefix informations are no longer carried in Type-1 LSA and Type-2 LSA, new LSAs Type 8 and 9 are added to carry these prefixes.
L...
view more
