Enabling Compression?
will.conklin
Community Member
What should the command look like to configure compression for a point-to-point frame relay connection on a 3640 router?
a.manosca
Level 8
Level 8
It probably depends on what type of compression you need. Here's one reference:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a0080087d01.html
Sorry I wasn't more specific, I was looking for TCP/IP compression on a serial interface using a 3640 router running IOS 12.2, the reference you provided was very helpful.
