etherchannel with other vendors
larry.skinner
Is it possible to etherchannel between Cisco 6500 Switches & 3Com 3300's
lgijssel
Level 9
Level 9
Etherchanneling is a Cisco-development, and therefore found primarily on Cisco devices. Other vendors may implement this feature as well but as far as I know there is no common standard for it.
Probably you'd better check the documentation from 3Com.
I know that HP supports Etherchannels on its 4000 series.
With other vendors, I do not have that experience.
Many Thanks
Prashanth Krishnappa
We now support LACP(IEEE 802.3ad) which is an IEEE standard in newer CAT OS/IOS
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_1/conf_gd/channel.htm#xtocid25
http://www.cisco.com/warp/public/473/126.html
If 3Com supports LACP, you should be able to use this as channeling protocol
