Excessive CRC and frame errors on a FA interface
jpmcauley
I have a 3620 connected to a 10/100 switch. I am getting excessive input errors on the fast ethernet interface of the router. Here is what my output shows when I show the interface stats:
5 minute input rate 89000 bits/sec, 39 packets/sec
5 minute output rate 497000 bits/sec, 51 packets/sec
65163 packets input, 16481170 bytes
Received 29 broadcasts, 0 runts, 0 giants, 0 throttles
95 input errors, 95 CRC, 53 frame, 0 overrun, 0 ignored
0 watchdog
85029 packets output, 85804553 bytes, 0 underruns
0 lost carrier, 0 no carrier
I have done everything I know to do to eliminate these errors. I have replaced the switch, manually set the speed, manually set the duplex and replaced the cable from the router to the switch. I am still getting the errors increase at a rate of about 100 errors every 15 minutes. What other things could I try here? One other note, I have other routers connected to this same switch and those routers show no errors.
glen.grant
How is the speed and duplex set on the router , basically if you hardcode the router port then you have to hardcode the switchport , if it's auto on the router then it has to be auto on the switch. If this doesn't get rid of it then you have to look at the possibility of a hardware problem .
please past your full interface output that will be better and check port speed and duplex and hardcode it on switch also.
thanks
