Flash Partitioning
vincent-n
Level 3
Level 3
The flash on one of my router was partitioned into 2 partition by my pre-decessor and now I wanted to de-partition it into one single partition. The current config is:
partition flash 2 4 8
and I would guess that by issuing the command:
no partition flash 2 4 8
will give me back one partition. The question is does anyone know of any issue that I have to watch out for when repartitioning? Thanks.
thisisshanky
Level 11
Level 11
i would say, first before doing anything else, back up any files on flash(including IOS image and saved configs) on to a tftp server, and then play with the partitions.
I think when you give no partition command, the file system in flash will be completely erased.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thisisshanky
Level 11
Level 11
Sankar Nair
I've already done all that. Saved configs and IOS. Thanks for your feedback.
