My customer is using WebEX meeting center via proxy server.
Therefore, destination port number of WebEX packet is 8080.
In this case, Is this packet discriminable by flow metadata?
Mitsuhiro
Solved! Go to Solution.
Hi Mitsuhiro,
If a proxy server is in the path between the WebEx meeting client and the WebEx Data Center. The flows between the client and proxy server will be represented by flow metadata. From the proxy server to the WebEx data center the flows will not be represented by flow metadata. For proxy traversal there would need to be integration within the proxy (think of something similar to a metadata ALG) for metadata.
[PC]-------[proxy]-----Internet----[WebEx DC]
[PC] to [proxy] will be covered for metadata.
[proxy] to [WebEx DC] is currently not covered by metadata.
In a non-proxy situation (eg. the video flow below), the metadata coverage would be between the [PC] and up to the NAT/FW.
In the example below, the proxy server is 10.81.74.42 port 9090. The client is 10.4.9.12. There are 4 flows that are represented (control, data, data and video). The video traffic is UDP traffic and directly going to the Internet without going via a proxy. In other instances the video flow itself might have gone via the proxy server.
3009R1-BB0206#show metadata flow table
Flow To From Protocol DPort SPort Ingress Egress SSRC
7 10.81.74.42 10.4.9.12 TCP 9090 38319 Gi1/0 Gi0/1 0
5 10.81.74.42 10.4.9.12 TCP 9090 38313 Gi1/0 Gi0/1 0
6 10.81.74.42 10.4.9.12 TCP 9090 38315 Gi1/0 Gi0/1 0
8 64.68.119.235 10.4.9.12 UDP 9000 63300 Gi1/0 Gi0/1 0
3009R1-BB0206#show metadata flow local-flow-id 5
To From Protocol SPort DPort Ingress I/F Egress I/F
10.81.74.42 10.4.9.12 TCP 38313 9090 GigabitEthernet1/0 GigabitEthernet0/1
Metadata Attributes :
Application Tag : 414 ()
Application Group : webex-group
Application Vendor : Cisco Systems, Inc.
Application Category : voice-video
Application Sub Category : control-and-signaling
Application Device Class : desktop-conferencing
Application Media Type : data
Unknown Identifier (147) : [ 00 00 00 06 ]
Unknown Identifier (148) : [ 00 00 00 06 ]
Unknown Identifier (150) : [ 00 00 00 02 ]
Application Name : webex-meeting
Application Version : T27
End Point Model : webex-meeting client - data
Matched filters :
Direction: IN:
Direction: OUT:
3009R1-BB0206#show metadata flow local-flow-id 6
10.81.74.42 10.4.9.12 TCP 38315 9090 GigabitEthernet1/0 GigabitEthernet0/1
Matched filters :
Direction: IN:
Direction: OUT:
3009R1-BB0206#show metadata flow local-flow-id 7
10.81.74.42 10.4.9.12 TCP 38319 9090 GigabitEthernet1/0 GigabitEthernet0/1
Application Media Type : control
Application Version : t27
End Point Model : webex-meeting client - control
Unknown Identifier (147) : [ 00 00 00 0A ]
Unknown Identifier (149) : [ 00 00 00 0A ]
Matched filters :
Direction: IN:
Direction: OUT:
3009R1-BB0206#show metadata flow local-flow-id 8
64.68.119.235 10.4.9.12 UDP 63300 9000 GigabitEthernet1/0 GigabitEthernet0/1
Application Sub Category : voice-video-chat-collaboration
Application Media Type : video
End Point Model : webex-meeting client - video
Unknown Identifier (147) : [ 00 00 00 05 ]
Unknown Identifier (148) : [ 00 00 00 02 ]
Unknown Identifier (150) : [ 00 00 00 01 ]
Matched filters :
Direction: IN:
Direction: OUT:
How does metadata recognize the flow of WebEX?
Any comments would be really appreciated
Mitsuhiro
Hi Mitsuhiro,
Please let me paraphrase your question just so I can understand the inquiry.
"How do metadata consumers recognize a webex flow?"
On one hand Metadata consumers are network devices that can uses metadata attributes for a purpose; for example CP3L can be used build a QoS policy against learned Metadata attriburtes. In this example, class maps can be configured to match on an application's metadata attributes.
On the other hand, when there are consumers there will be producers. In flow metadata's case, an example producers would be webex client with MSI. The metadata flow enabled webex endpoint announces a metadata signaling message that carries information such as the flow's 5-tuple information and other descriptive flow attributes. In this example, the webex metadata producer will announce into the network metadata attributes of the webex session.
regards,
Eric
Hi Mitsuro,
Webex session thru a proxy server on a specific port number does not affect the metadata attributes of the webex flow. Metadata flow signaling messages that carry metadata attributes are transported with IP protocol 46. To ensure end to end propagation of the application metadata attributes, IP protocol 46 packets must be permited.
regards,
Eric
Hi Mitsuhiro,
Matched filters :
Direction: IN:
Direction: OUT:
Matched filters :
Direction: IN:
Direction: OUT:
Matched filters :
Direction: IN:
Direction: OUT:
Matched filters :
Direction: IN:
Direction: OUT:
