HelP: DS3 coax cable needed
ccatindig
Hi!
I need immediate help with a particular coax cable between a MGX and a Cisco 3845 router. The router has a NM-1A-T3/E3 network module (most likely since the label that the guys onsite saw at the back of the router says 1A-T3.
The MGX meanwhile has a AXSME-16T3E3 front card and a SMB 8TE (?) back card, based on what our client said. There is presently a miniBNC-to-BNC coax cable connecting the MGX to the 3845, muck like the picture below. There are CRC errors on the ATM interface and the client would like to replace this cable. Unfortunately, I cannot find the exact Cisco cable for this. Please, can someone help me?
I can be contacted by email at conrado.catindig@dimensiondata.com
Thanks in advance.
Noel Catindig
paolo bevilacqua
Most likely errors are caused by the circuit, not the cable.
There is no need to use a Cisco cable, any cable can be used.
Hi Paolo.
Thanks. Is this Cisco's corresponding coax cable product?
15454-CA-HDBNC-30=         Cable assy, Mini-BNC to unterm (BNC provided), 735A, 30ft
Again, please read my answer above.
