How to enable RSTP
omal
Can someone please explain how to enable RSTP in the switch (Let's say in 2950 switch).
Or do you have RSTP running in now-a-days switches?
Thanks in advance!
Chris.
Bobby Thekkekandam
Hi Chris,
The command to enable it is "spanning-tree mode rapid-pvst
This and other config requirements for RSTP are documented here:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swstp.htm
HTH,
Bobby
mail4ramsay
Cisco switches by default run PVST+ (Per VLAN Spanning Tree+) which is compatible with 802.1d STP.  Most newer switches support PVST+, Rapid-PVST+ & MST.  With IOS-based switches you can check what version you are running with the command 'show spanning-tree summary':
switch#show spanning-tree summary
Switch is in rapid-pvst mode
<<<< Output Omitted >>>
switch#
To change the STP mode use the global configuration command 'spanning-tree mode XXX':
switch(config)#spanning-tree mode ?
  mst         Multiple spanning tree mode
  pvst        Per-Vlan spanning tree mode
  rapid-pvst  Per-Vlan rapid spanning tree mode
Switch(config)#spanning-tree mode rapid-pvst
Joseph W. Doherty
The other posters have shown how to enable rapid-STP, but on a 2950, depending on the "age" of the IOS, it might not offer rapid-STP as a feature.
