%MLS_STAT-DFC4-4-IP_CSUM_ERR: IP checksum errors
rlortiz
I have a customer with a Cisco Catalyst 6509 and saw the following error message in the log file:
I found a similar error message in the Cisco website:
%MLS_STAT-4-IP_CSUM_ERR: IP checksum errors
It stated to do a SHOW MLS STATISTICS and look for relevant information, which I have below. There was no action or reference to what should be done next:
Statistics for Earl in Module 4
L2 Forwarding Engine
Total packets Switched : 28959640064
L3 Forwarding Engine
Total Packets Bridged : 9763643935
Total Packets FIB Switched : 13023412786
Total Packets ACL Routed : 0
Total Packets Netflow Switched : 0
Total Mcast Packets Switched/Routed : 21397778
Total ip packets with TOS changed : 0
Total ip packets with COS changed : 0
Total non ip packets COS changed : 0
Total packets dropped by ACL : 27211
Total packets dropped by Policing : 0
Total Unicast RPF failed packets : 0
Errors
MAC/IP length inconsistencies : 0
Short IP packets received : 0
IP header checksum errors : 309
MAC/IPX length inconsistencies : 0
Short IPX packets received : 0
As you can see, the IP header checksum errors were from the Earl in Module 4.
Here is some information I got from a SHOW TECH:
Mod Ports Card Type Model Serial No.
4 16 Pure SFM-mode 16 port 1000mb GBIC WS-X6816-GBIC SAD054205J2
Mod MAC addresses Hw Fw Sw Status
4 00d0.c0d6.fb94 to 00d0.c0d6.fba3 1.1 12.1(5r)E1 12.1(13)E4, Ok
Mod Sub-Module Model Serial Hw Status
4 Distributed Forwarding Card WS-F6K-DFC SAD0540050S 2.0 Ok
Online Diagnostic Result for Module 4 : PASS
Online Diagnostic Level when Module 4 came up = Minimal
Test Results: (. = Pass, F = Fail, U = Unknown)
1 . TestGBICIntegrity :
Port 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
U U U U U U U U U U U U U U U U
Switchport: Enabled
Administrative Mode: dynamic desirable
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: 1,38,60,76,1002-1005
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
What is the best action plan, at this point? Do we need to replace Module 4?
Any help would be appreciated
Rich
raymong
Level 4
Level 4
The error message that you are receiving is saying that the switch forwarding engine is receiving an IP-packet which has an invalid checksum, therefore the packet was dropped. In older code we just used to silently drop the packet and count it in the forwarding engine stats.
The only thing you have to be concerned about is that there is a device which is sending these bad packets (possibly due to bad nic driver, nic driver bug (or) bad application etc..). Unfortunately, our forwarding engine doesn't keep track of the source-ip of the device which is sending these bad packets. The only way to detect these devices is to put a sniffer and track it down to a particular source.
Is it possible to get these packets out to a SPAN destination (then I could
run tcpdump which would tell me about invalid checksums), or will they be
dropped before SPAN takes place?
