Need some help with Source Routing Translation Bridging!!
willianp
Hi All,
I am trying to acess an mainframe with SNA emulation from a ethernet network conected to a token-ring network with a Cisco 2600 router. the configuration of the router is this:
Building configuration...
Current configuration : 2590 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname "Router"
ip subnet-zero
no ip domain-lookup
call rsvp-sync
source-bridge ring-group 10
source-bridge transparent 10 11 1 1
interface Ethernet0/0
ip address 9.179.90.7 255.255.255.0
full-duplex
bridge-group 1
interface TokenRing0/0
ip address 9.179.144.128 255.255.240.0
ring-speed 16
source-bridge 1 1 10
source-bridge spanning
ip classless
ip route 0.0.0.0 0.0.0.0 9.179.144.1
ip http server
ip pim bidir-enable
bridge 1 protocol ieee
dial-peer cor custom
Router#
I am using Personal Communicator to emulate SNA via TCPIP, I tried with both mac adresss (normal, inverted), but with no sucess...
Show bridge shows the mac from the Mainframe that I am trying to acess:
0200.8806.9820 forward RingGroup10 0 28 0
Anyone knows what can be missing ?
Willian
lgijssel
Level 9
Level 9
First of all I would suggest that you add the command multiring ip on the TR interface.
