Need to UPgrade Flash Memory ?
moonviewingjp
If Cisco 3845 has following 2 Flash Memory,
-31360K bytes of ATA System CompactFlash (Read/Write) <------- 32MB Internal CompactFlash Memory  installed
-31360K bytes of ATA Slot0 CompactFlash (Read/Write)  <--------- 32MB External CompactFlash Memory  installed
Can I install IOS which require Flash Memory 64MB on 32MB Flash ×2 ?
or Should I upgrade to Compact Flash 64MB from either 32MB ?
paolo bevilacqua
Please do not open duplicate threads in multiple forums.
This question is completely different from my previous question.Please read it carefully.
Leo Laohoo
Are you sure this is not a 3700 router because I don't recall the 3800 having an internal and external CF.
I'd recommend you upgrade to a bigger CF.  The 3700 and 3800 will support CF up to 2Gb.  Format the CF first before loading anything into it.
