pathping utility and intervlan routing
Pathping is a good utility available in windows. It shows hop by hop statistics.
But in my network, we have inter vlan routing using 6509. The problem is that I m not getting the response time for next hops from my 6509. pathping shows 100% packet drop for each hop after inter vlan routing. But network connectivity is there, I can PING to remote site.
If I do the pathping from same vlan to the same remote site it shows proper result, hop by hop response and actual packet loss.
What should I do on 6509 so that I can get the proper result of pathping, for pinging to another vlan (inter vlan routing).
glsagredo
Do you have access-lists configured on your 6509 denying packets to a certain vlan?
I dont have any access list for that VLAN.
