Problem in backup..
mustafa.mail
Level 3
Level 3
I am using NMS 2.0 on solaries 2.8. I am also using HP Open view on same system. when I am trying to backup the database through ciscoworks, It's gives me following error:
Backup to '/tmp/' started at: 2002/06/23 16:16:25
avail=4594824
Archiving the contents of the following directories into /tmp//0/cmf/filebackup.tar
/opt/CSCOpx/etc/users
/opt/CSCOpx/etc/cwsi/users
/opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet/cwpass
/opt/CSCOpx/etc/cwsi/ANIServer.properties
/opt/CSCOpx/etc/cwsi/anisnmp.conf
tar: /opt/CSCOpx/etc/users/test/user.preferences: Permission denied
tar: /opt/CSCOpx/etc/users/test/2.xml: Permission denied
tar: /opt/CSCOpx/etc/users/test/1298.xml: Permission denied
tar: /opt/CSCOpx/etc/users/test/1507.xml: Permission denied
tar: /opt/CSCOpx/etc/users/test/379.xml: Permission denied
tar: /opt/CSCOpx/etc/users/test/392.xml: Permission denied
tar: /opt/CSCOpx/etc/users/test/4.xml: Permission denied
ERROR(359): Cannot create or back up tar file. Backup cancelled. Verify that you have write-access to this directory.
Backup failed: 2002/06/23 16:16:25
Also when I am trying to integrate this ciscoworks system with windows ciscoworks, It's also gives me the error that user doesn't have a sufficient rights.
I am not much familiar with solaries, so please help me to fixed these rights issues.
Thanks.
rmushtaq
Level 11
Level 11
The Error message above indicates that the target directory where you're trying to do the backup does not have the proper permissions. Make sure that you the read-write permisions on the target directory.
I give the rights to all the user but sitll the same message came..
The error is due to the insufficient/incorrect permissions to the backup location/director and NOT with the users.
srkannan
Community Member
you are using /tmp as the backup target directory. Make sure
1. 'casuser' has write permission to this directory.
2. make sure /tmp is not symbolically linked to /var/tmp
correct :
# cd /
# ls -l|grep tmp
drwxrwxrwx 13 root other 1422 Jun 26 16:11 tmp
incorrect:
lrwxrwxrwx 13 root other 1422 Jun 26 16:11 tmp -> /var/tmp
