Problem in DFM
mustafa.mail
Level 3
Level 3
I am using DFM with ciscoworks but I have a list of problem in DFM can you help me.
(1) In Monitor Console I found the messages with different times then the NMS.
(2) I am changing the threshold, but still I got messages from Previous threshold values.
(3) I Have a lot of cisco devies; I can't able to setup fragmentation threshold properly. I changed lot of values but still I got lot of messages regarding fragmentation threshold.
Thanks.
rmushtaq
Level 11
Level 11
For Fragmentation related issues (if on switches), download and install the DFM 1.1 IDS 1.1.2 patch from CCO which has the fix for this along with the device support of several new devices in DFM. For other issues above, have a look at: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dfm_faq.htm first.
I am from South Africa - just recently installed LMS. I am also experiencing the same issue , OperationalException , ErrorException , PerformanceException ,
InCharge Domain : DFM Switch 10.1.1.7 ResourceException - System is
experiencing resource problems, e.g., CPU or memory problems. I have checked the switches , all 4006 and 6506's - mem and flash is 100% OK- no issues with mem/flash/cpu etc. Please advise what can be done or what causes this errors - I had a look at the doc , but still cannot resolve
If you haven't installed the DFM 1.1 IDS 1.1.2 patch from CCO, you should install that first which will fix lot of these issues with DFM. You can get it from the CCO Software Center under the CW2000 section.
