rx_soft_overflow_err on Fast Ethernet interface
vaniello
I am seeing input errors on a Fast Ethernet interface on my 3725 router
running IOS version 12.3(17a):
100204623 packets input, 1244960943 bytes
Received 2913690 broadcasts, 0 runts, 0 giants, 0 throttles
33006 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
I am also seeing the "rx_soft_overflow_err" driver counter increase on the
same Fast Ethernet interface:
Number of Transmitter Hang = 0
tx_more_col_err= 0 tx_one_col_err= 0
tx_exc_collision_err= 0 tx_late_collision_err= 0
tx_underrun_err= 0 tx_error_intr= 0
rx_soft_overflow_err= 39622 rx_overflow_err= 0
I believe the two problems are related, but I am not sure of the best way to
go about troubleshooting the problem. Can anyone provide insight into what
the problem may be and how to correct it?
Thanks.
V/
Prashanth Krishnappa
"rx_soft_overflow_err" indicates, the interface in question is seeing incoming packet rate is greater than what the router can handle. I would suspect bursts of traffic causing this. Check on whats connected to this interface and for traffic rates when the error is incrementing.
