Suspending a telnet session using MINICOM (Ctrl+Shif+6,x)???
jefforsi
I'm using Linux machines to configure Cisco routers, then I use MINICOM to do this... so... when I try to suspend a telnet session using Ctrl+Shif+6, x.... the minicom don't understand this sequence.... I tried to change the terminal emulation to ANSI, etc... but without sucess....
How can I suspend a telnet session on MINICOM???
Are there another good terminal emulation software to use on LINUX???
Thanks...
Jefferson
minie
Level 4
Level 4
Not sure about minicom, but many terminal software use Ctrl+6 instead of Ctro_Shift+6. Try Ctrl+6, x.
Ming
Hello Ming....
Your help is very helpfull.....
Thanks...
