Trunk between 2600 and 2950 with IOS
bpotschien
Hi there,
I want a dot1q trunk between a 2600 router IOS 12.1 (18) and a 2950 switch IOS 12.1 (22)EA1.
Here is the config of the router:
interface FastEthernet0/0
speed 100
full-duplex
interface FastEthernet0/0.1
description to_switch
ip address 1.1.1.1 255.255.255.0
encapsulation dot1Q 1
no ip redirects
and here the switch config:
interface FastEthernet0/24
description Uplink_to_Router
switchport mode trunk
speed 100
duplex full
The VTP status of the switch:
VTP Version : 2
Configuration Revision : 5
Maximum VLANs supported locally : 250
Number of existing VLANs : 5
VTP Operating Mode : Client
VTP Domain Name : STRING
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
The trunk does not work! The router does not recieve any trunk packets. The arp cache of the router is "incomplete" related to the switch mac address...
The vlan database on the switch shows the following:
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
Backup CRF Mode: Disabled
Remote SPAN VLAN: No
This is amazing because of the DOT1Q trunk!
Can anyone help?
Thank a lot
take a look here: http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
In your router your must specify the native vlan used on your switch.
MB
11 Replies 11
the switch defaults to an ISL trunk. You need to specify that it is a DOT1Q trunk:
--> switchport trunk encapsulation dot1q
speed 100
duplex full
HTH,
GP
GP,
I thought 2950's do not support ISL. They do only 802.1q.
Bjoern
What does a "show int fa0/24 switchport" show on the switch. Does it show the trunk status as up ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
MB
Kevin Dorrell
Level 10
Level 10
This seems very strange to me. Are you sure it is a 2950-12? It seems to be behaving more like a 2912XL. AFAIK, 2950 does not support ISL because of a hardware limitation - something to do with the ASICs. OTOH, 2912XL did default to ISL.
Kevin Dorrell
Luxembourg
no it's the normal output of a "show current" in the vlan database. Can we have a "show interface trunk"?
Thanks for the answers.
Here is the "sh interfaces fastEthernet 0/24 switchport":
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
And a "show ver" from the Switch:
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA1.bin"
cisco WS-C2950C-24 (RC32300) processor (revision Q0) with 20873K bytes of memory.
Processor board ID FOC0841W3V4
Last reset from system-reset
Running Enhanced Image
26 FastEthernet/IEEE 802.3 interface(s)
And from the router:
IOS (tm) C2600 Software (C2600-D-M), Version 12.1(18), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Mon 02-Dec-02 23:49 by kellythw
Image text-base: 0x80008088, data-base: 0x80958980
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
VIERCKT3 uptime is 17 hours, 35 minutes
System returned to ROM by reload
System image file is "flash:c2600-d-mz.121-18.bin"
cisco 2620XM (MPC860) processor (revision 0x100) with 26624K/6144K bytes of memory.
Processor board ID JAD07030RU8 (373713317)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
1 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
It is strange that the switch does not have a command to set the enc protocol. The "show interface switchport" shows dot1q, but in "vlan database" it says isl?!?!
Thank you for help
An idea:
Do I have to create the vlans on the switch database?
In the moment there are only the vlan 1 and some 100x vlans.
Does the router know that the native vlan is 1? (encap dot1q 1)
"It is strange that the switch does not have a command to set the enc protocol."
No it's normal since the 2950 only support dot1q for trunking.
bpotschien
Well, here is the solution:
http://www.cisco.com/warp/public/473/50.shtml
It is a bug in the IOS version 12.1 (18). The encap dot1q 1 NATIVE is missing in the command stack!
So you have to put the management vlan on the physical interface, not the subinterface.
Correct router config:
speed 100
full-duplex
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 20.20.20.1 255.255.255.0
The correct switch config:
description Uplink Router
speed 100
duplex full
Thanks for the help!
Bjoern
pourvahabi
hi
i think you have to configure trunk on both side
and also compelete configuration i mean trunk options.
example:
interface fastethernet 0/1
switch mode trunk
switch trunk encap 802.1q
switch port trunk native vlan 10
other side
interf fast ether net 0/24
swtch port mode trunk
switch trunk enca 802.1q
switch port trunk nativ vlan 10
