Cisco 678 Flash Problem
gdepetro
While flashing a 678, during flash it seemed to lock and a red led is on inside the case. Router is now not accessible from Hyperterminal. Anyway to get it back into debug mode?
check this link, scroll down to page 4 of the PDF document, it talks about the procedure to reset the 678 to factory defaults:
Cisco 678 Configuration
http://www.webguyinternet.com/dsl/CiscoSetup.pdf
HTH,
Georg
Thanks for the reply. We have tried this procedure. The red led light that is on is in the case on the circuit board. It is not the Alarm light. Most forums I have checked said this means the router is dead.
Is there any other procedure to try? Thanks
