Bookmark
Subscribe
473
OSPF for unequal cost load sharing?
haljouhi
I know that OSPF does not support unequal cost loadsharing or unequal load balancing - is there any way to accomplish this on a Cisco router?
I need to migrate to an open standards Routing Protocol solution - currently running EIGRP to load balance 75/25 of my traffic on two links.
If you could reply to my email:f_suleman@hotmail.com that would be great.
Gilles Dufour
I don't think there is any way to do this. You will have to make the 2 links equal or only one of them will be used.
MPLS/TE will do this with OSPF as the RP, but that's probably overkill.
Russ
