Bookmark
Subscribe
542
1841 AIM module question
dtushing123
Level 3
Level 3
What is the difference between the onboard VPN module and adding an AIM module to an 1841 ?
If I do not install an AIM module I get
Cisco 1841 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FTX1127W1AH
2 FastEthernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Modules
If I install the AIM I get the AIM light lit and the following
1 terminal line
2 Virtual Private Network (VPN) Modules
Therefore I am wondering do I even need to add the AIM card to this router or is one built in ?
Darren
Brandon Buffin
Darren,
The 1841 does have an onboard crypto accelerator. Depending on the model of AIM, it can offer some or all of the following additional benefits:
IPPCP Hardware Acceleration
IPv6 IPSec
Cisco IOS WebVPN or SSL VPN
Cisco IOS Secure Multicast
See Table 1 of the following link.
http://www.cisco.com/en/US/products/ps5853/products_qanda_item0900aecd80516d81.shtml
The AIM-VPN/SSL also offloads termination of SSL tunnels from the router CPU. See the note below Table 1 in the link above.
Hope this helps. If so, please rate the post.
Brandon
