04-11-2001 01:07 PM - edited 03-08-2019 08:09 PM
I was planning out a new computer installation with a customer. The customer indicated that they had purchased the newest CISCO Switches and that they would like to have both NIC in one computer use the same IP. I have not encountered this before. What is this technology called and is there a pointer to some documentation regarding it? Prior to this discussion, the customer had indicated that the NIC would be on different subnets. This new requirement kind of caught me unaware. If the switch supports it, I don't see an issue in setting it up that way. Conmputer hardware consists of multiple RS/6000.
04-12-2001 03:39 AM
Not sure why they would want to do this, but if it is to increase throughput, certainly on Sun Solaris you can use trunking to aggregate bandwidth from server to switch. Have a look at
http://www.sun.com/products-n-solutions/hw/networking/connectivity/suntrunking/trunking.html
Not sure about RS6000 though ...
Andy
05-03-2001 12:37 PM
Hi!
Yes Catalyst Switches do support a feature called trunking with which you can do this.
the command id set trunk module/ports on
Regds
Rajesh
