access dmz from inside
acristofari
hello
sorry but i have a problem
i have a pix firewall 515 with 3 interface inside dmz and outside
inside 10.34.10.0
dmz 192.168.1.0
outside 151.x.x.x
i need to reach from inside the dmz client and opposite, without nat, and the dmz to get internet with nat.
I configured
nat (dmz) 2 192.168.1.0 255.255.255.0 0 0
global (outside) 2 151.x.x.1
access-list dmz_inside_in line 1 permit ip 192.168.1.0 255.255.255.0 any
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
I don't reach the host from inside to dmz and opposite
5 Replies 5
Terry Pattinson
if you don't want NAT use the special 0 NAT group
nat (inside) 0 192.168.1.0 255.255.255.0
This disables the NAT process.
When going from a higher (inside) to lower (dmz) interface, you don't - by default - need to specify an ACL. Of course, your acl doesn't actually do anything unless you apply it.
HTH,
Terry
thanks
but i need use nat for internet from dmz,
and don't use nat from dmz to inside.
Do the following :
static 10.34.10.0 10.34.10.0 netmask 255.255.255.0
Static REAL-IP-Address 192.168.1.5 netmask 255.255.255.255
I hope this is helpful!
I think this document will help you.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806745b8.shtml
Plz. rate if it does!
Abd Alqader
grant.maynard
Level 4
Level 4
The old rule used to be "high security -> low = nat+global, low -> high = static+ACL", although it gets more confusing when you have more interfaces and don't always want to NAT.
A traffic flow is always source->destination and therefore only involves two interfaces. So think of your traffic as being flows between two interfaces. Here we have two flows: when dmz accesses internet dmz=high, internet=low; when dmz accesses inside, inside=high, dmz=low. Therefore you're needing nat+global for the dmz->internet, and static for dmz->inside.
You have the correct lines to NAT your internet access:
nat (dmz) 2 192.168.1.0 255.255.255.0 0 100
The next line allows inside IPs to be visible to dmz (you still need ACL to permit traffic):
static (inside,dmz) 10.34.10.0 10.34.10.0 netmask 255.255.255.0
guru's, what if, in this exact situation, i want to NAT the source addresses of traffic coming from DMZ to inside? Is that possible?
And what actually happens when you reverse the interfaces in the static line?
Like: static (DMZ,inside) x.x.x.x x.x.x.x netmask x.x.x.x
