ACL for Flooding attack
ikizoo4
Hello
i have basic questions. if want to trace ICMP and UDP flooding attack, how can i configure router serial interface?
access-list 101 permit icmp any any echo log-input
access-list 101 permit icmp any any echo-rely log-input
access-list 101 permit udp any any eq echo log-input
access-list 101 permit udp any eq echo any log-input
is this good enough or any more detail way for this.
thanks all
spremkumar
Level 9
Level 9
hi
are you trying to block the icmp and udp traffic or you want them to be blocked ?
as per your config lines if you bind the same or apply the same on the serial interface it will by default deny/block all the other traffic like tcp etc., leaving except udp,icmp coz of the default deny statement at the end of all the access-lists.
so try to modify the ACLs accordingly ...
find the link which will be useful to harden the security ..
http://www.cisco.com/warp/public/707/21.html
regds
hi thanks for responding,,,
i knew defualt deny,,,
of course permit ip any any is gonna be.
what I am asking is how to log a udp/icmp attacking.
any more detail ACL is possible ?
Here is a link to a docs that talks about tracing and logging attacks. Hope this is what you are looking for.
Go to tracing section
http://www.cisco.com/warp/public/707/22.pdf
http://www.cisco.com/warp/public/707/22.html
