authenticating a switch through radius?
baselzind
Level 6
Level 6
customer have a radius server and he would like to use it to authenticate access to a switch , i did the below
aaa new-model
radius-server host 1.1.1.1 auth-port 1812 acct-port 1813
radius-server key cisco
aaa authentication login default group radius
what would i need to write under the line vty 0 15? is it "login authentication radius?
do i need this command? ip radius source-interface VlanXX?
am i missing anymore commands?
6 Replies 6
Muhammad Awais Khan
Under the line vty 0 15, you have to add below:
Login authentication default
radius source-interface VlanXX is required only if you have reachability only from certain vlan SVI or interfaces. With this command, all the radius communication from this switch will be initiated from the selected interface.
Your config seems to be good enough to run aaa on the device using radius.
Also, you can test your radius server using ' test aaa group .... ' command from exec mode.
i believe i can add "login local" under "line con 0" to assign logging through console link to local users correct?
Under "aaa new-model" use command "aaa authentication login console local" for console as local login
Please rate for helpful post
Yes you are correct. It will override the default group radius.
Actually when you define aaa authentication login default group radius , it will make all the default authentication methods to all vty and console lines as pointed by @Pawan Raut  also.
If you want to override the default, you can goto the line and put different authentication method
So If you put login local under line con 0, it wi use local database.
Adding to @Pawan Raut there are multiple methods to achieve the same task. Both will work actually
Ref: https://www.cisco.com/c/en/us/support/docs/security-vpn/terminal-access-controller-access-control-system-tacacs-/10384-security.html
Pawan Raut
Level 4
Level 4
Hi, No need to "login authentication radius"  under line vty as you have already defined it under aaa new-model. If your switch has two or more layer3 interface (SVI) then you should define the source interface for radius or it is always good practice to define the source interface.
aa new-model
