Can't add public IP address to inside interface
matt.slaga
Level 4
Level 4
I am trying to use the PIX strictly as a firewall (no NAT). However, when I attempt to add an inside ip address to ethernet 1 (for example 12.x.x.65 255.255.255.192) it errors out with "Interface inside ip address or netmask not valid". I've got the outside interface with say 12.150.0.1/28 and DMZ with 12.150.0.17/28 and Ethernet3 hosts with 12.x.x.129/25 without any errors. Any ideas?
Pix 7.1(2), PIX 515E
Interestingly enough, I rebooted the PIX and was still unable to add the ip address. I added another IP address to the interface and was then able to change it to the above address without an error. Just in case anyone else runs into this.
a.kiprawih
Level 7
Level 7
Could it be due to address/subnet allocation?
Subnet ID Subnet Mask Valid Addresses Bcast Add
*Inside : 10.150.0.64 255.255.255.192/26 10.150.0.65 to 10.150.0.126 10.150.0.127
Outside : 10.150.0.0 255.255.255.240/28 10.150.0.1 to 10.150.0.14 10.150.0.15
DMZ : 10.150.0.16 255.255.255.240/28 10.150.0.17 to 10.150.0.30 10.150.0.31
E3 : 10.150.0.128 255.255.255.128/25 10.150.0.129 to 10.150.0.254 10.150.0.255
1st Block of /28:
1. 10.150.0.0 255.255.255.240 10.150.0.1 to 10.150.0.14 10.150.0.15 - used for Outside
2. 10.150.0.16 255.255.255.240 10.150.0.17 to 10.150.0.30 10.150.0.31 - used for DMZ
*available for Inside:
3. 10.150.0.32 255.255.255.240 10.150.0.33 to 10.150.0.46 10.150.0.47
4. 10.150.0.48 255.255.255.240 10.150.0.49 to 10.150.0.62 10.150.0.63
5. 10.150.0.64 255.255.255.240 10.150.0.65 to 10.150.0.78 10.150.0.79
6. 10.150.0.80 255.255.255.240 10.150.0.81 to 10.150.0.94 10.150.0.95
7. 10.150.0.96 255.255.255.240 10.150.0.97 to 10.150.0.110 10.150.0.111
8. 10.150.0.112 255.255.255.240 10.150.0.113 to 10.150.0.126 10.150.0.127
9. 10.150.0.128 255.255.255.240 10.150.0.129 to 10.150.0.142 10.150.0.143
2nd Block of /28:
1. 10.150.0.128 255.255.255.128 10.150.0.129 to 10.150.0.254 10.150.0.255 - used for E3 range
Rgds,
AK
It worked, I just had to enter another ip address first, then I was able to change it. Smells like a bug.
a.kiprawih
Level 7
Level 7
Maybe you should report it, as it'll really help others with similar issue.. :)
Rgds,
AK
