04-06-2001 06:14 AM - edited 03-08-2019 08:08 PM
How do I assign ports to a vlan? Can I assign a fastethernet port to more than one vlan? I have already created the new vlan.
04-12-2001 01:10 PM
The focus of this forum is Security however there are a number of professionals online who may be able to assist you.
We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response, you may wish to review our resources at the online Technical Assistance Center (www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at www.cisco.com/tac/caseopen
If anyone else in the forum can provide assistance, please reply to this thread.
Thank you for posting.
04-22-2001 06:31 AM
Does this link helps you ?
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35xu/scg/kivlan.htm
04-24-2001 09:07 PM
You can definetly assign the fast ethernet port to more than one VLAN provided it is a trunk port or Q-Port, which is used for forwarding the traffic to diffrent VLANS based on the Tagging.
I believe the URL given in the other reply should provide you with the sufficient information.
05-05-2001 07:18 PM
hi sknorr,
i think 3548 is a stackable.. IOS based switching solution from cisco.. to assign a port to a vlan.. u have to first go that fastethernet int.. and give following command
int fa0\1
switchport access vlan
to make a port in more than one vlan
int fa0/1
switchport mode multi
switchport vlan multi 1,2
will make fa0/1 in vlans 1 and 2
hope this is helpful to u
my email is shanky@37.com
