Cisco Umbrella and Internal Web Sites
msanclimenti
I am evaluating Cisco Umbrella for enterprise and AnyConnect users. Currently, the customer has a WSA solution but wants to go to a cloud solution. I can use Umbrella for users allowing access to external web sites, such as Cisco, Google, Microsoft, etc and block unworthy and dangerous sites according to the customer's security policy. How does Umbrella work with internal websites. The customer has internal websites and partner websites that users need to access. Thanks.
balaji.bandi
Personally Umbrealla can not replace WSA for sure in terms of Web content filtering.
look some comparision here :
https://www.trustradius.com/compare-products/cisco-ironport-vs-cisco-umbrella
If you looking more of cloud solution, worth looking NGFW / with AMP.
BB
Rahul Govindan
As a part of the Umbrella deployment, you specify your internal domains on the dashboard. Internal domains are resolved by your own DNS server (whether a Roaming Client or Virtual appliance deployment), while external domains are resolved using Umbrella.
https://docs.umbrella.com/deployment-umbrella/docs/appx-d-internal-domains
