Crypto command not recognised :(
gregcox1979
Hi all,
I have instruction for configuring a VPN between my Cisco 2503 and 2514 routers but have fallen at the first hurdle ! The crypto command is not recognised. I am using IOS 12.3(5b). Does this support crypto ? Do I have to enable it somehow ?
Thanks very much for your time
Greg
johnd2310
Level 8
Level 8
Hi Greg,
The problem is you are not running crypto images. You need crypto images for your routers.
John
**Please rate posts you find helpful**
