CS-MARS does not respond.
andrea.meconi
Level 2
Level 2
Hi.
I'm using a MARS 20 with software 6.0.3.
Sometimes I need to reset the appliance because it does not respond!
Any ideas!?
Thanks.
Andrea
joe.favia
Hi, Have you tried accessing the appliance by connecting via the serial cable? If you can then you could verify the overall status (PNSTATUS) and the log (PNLOG). Saluti, Joseph
Hello Joseph and many thanks for your help.
The appliance doesn't respond using console cable too!
Regards.
Andrea
