Disconnect pppoe
p.bottaro
I'm not able to disconnect the adsl line from a 501 pix.
The command
clear vpdn [group|interface|tunnel|username]
does not go.
Can you help me ?
raymong
Level 4
Level 4
Do you get any error messages when you enter the clear vpdn command? What command are you entering exactly?
ajagadee
What is the mode from which you are trying to clear. Make sure that you are in the config mode and also if possible post the error message that you are getting.
Arul
Yes, I am in configure terminal mode, and I get no errors.
And the adsl line stays up.
