DMZ won't pass RADIUS traffic to inside
luckymace
I just setup a Cisco 1121 Aironet WAP to work with WPA authenticating to a MS
IAS server,(RADIUS). It works fine, clients can authenticate, access internet,
etc.
I moved the access point to the DMZ on PIX 515E and added nat statments and ACL
for dmz to inside.
Now the clients cannot authenticate to the RADIUS server. I am getting an error
message:
4|Jan 04 1993 13:23:11|106023: Deny udp src dmz:192.168.200.2/1645 dst
inside:10.0.4.20/1645 by access-group "DMZ_TO_INSIDE"
This does not make any since, because my ACL opens ports 1645 and 1646 to the
RADIUS server. See below:
access-list DMZ_TO_INSIDE remark Allow ping from DMZ to INSIDE
access-list DMZ_TO_INSIDE extended permit icmp 192.168.200.0 255.255.255.0
access-list DMZ_TO_INSIDE extended permit udp host 192.168.200.2 host
192.168.200.3 eq radius
192.168.200.3 eq radius-acct
access-group DMZ_TO_INSIDE in interface dmz
static (dmz,outside) 65.223.51.72 192.168.200.2 netmask 255.255.255.255
static (inside,dmz) 192.168.200.3 10.0.4.20 netmask 255.255.255.255
static (inside,dmz) 192.168.200.4 10.0.4.21 netmask 255.255.255.255
I have been working on this for 4 hours with no progress. I tried opening all
traffic from to-from the dmz and rebuilt the WAP setup, rebuilt the IAS client
entry, etc.
Any help would be greatly appreciated.
Thanks in advance.
Lucky Mace
rsmith
Level 3
Level 3
It looks like your WAP is still trying to access the Radius server by its physical address, not the translated address in the DMZ. Look into that config, and change the Radius server to 192.168.200.3, it should work then.
