05-12-2004 11:13 PM - edited 03-09-2019 07:21 AM
I got an instruction from the cisco website on how to install PDM. I got the following error
pixfirewall# copy tftp://192.168.1.254/pdm-301.bin flash:
copying tftp://192.168.1.254/pdm-301.bin to flash:image
Received 3126944 bytes
No PIX image found in downloaded file
Image not installed
pixfirewall#
Can anyone help me on this?
pixfirewall# sh flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1925176
file 1: origin: 1966080 length:3005
file 2: origin: 0 length:0
file 3: origin: 2097152 length:3126944
file 4: origin: 0 length:0
file 5: origin: 8257536 length:308
pixfirewall#
pixfirewall# sh ver
Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 19-Mar-03 11:49 by morlee
pixfirewall up 36 days 2 hours
Hardware: PIX-506E, 32 MB RAM, CPU Pentium II 300 MHz
Flash E28F640J3 @ 0x300, 8MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is XXX irq 10
1: ethernet1: address is XXX, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: XXX
Running Activation Key: XXXX
Configuration last modified by enable_15 at 15:17:20.642 UTC Thu May 13 2004
pixfirewall#
Solved! Go to Solution.
05-13-2004 12:55 AM
For running PDM from your desktop, two commands are required.
http server enable
http 192.168.1.X 255.255.255.255 inside
PDM is a bookkeeping command, not used to mention the PC who can run PDM.
One more point, it has to the https://192.168.1.1
Give the above mentioned commands and it will work fine.
05-12-2004 11:20 PM
You need to use the following command
copy tftp://192.168.1.254/pdm-301.bin flash:pdm
flash:pdm parameter should be mentioned otherwise it will be taken as FW image
05-13-2004 12:30 AM
Regarding my previous upload to the pIX, did it fill the flash memory? Im afraid the flash memory might get full. And also, the show flash command is a bit difficult to understand unlike the show flash command in routers.
I was able to download the file,
saying PDM file installed.
Follow up,
how come I cannot access the pdm?
http://192.168.1.1 the address of pix
even though i put in
pix(config)# pdm location 192.168.1.X 255.255.255.255 inside <--ip of my desktop
Any more commands that I lack? JVM already installed in my pC
RJ
05-13-2004 12:55 AM
http server enable
05-13-2004 01:24 AM
Thanks alot, It solved my problem. Btw, do you know
some Useful cisco links where I can study about useful administration commands for the PIX? CLI commands?
Rj
