FMC Deployment failed due to connectivity issues with the device or device is not responding
HakamAbd79366
Hi Team,
I cannot config or update policy with FMC (FTD FPR4100). When i update policy and want to save and deploy,
this error show
" deployment failed due to connectivity issues with the device or device is not responding. if problem persists after retrying later, contact cisco tac "
Kindly advise what i need to do.
Thanks.
What version of FMC and FTD are you running?
Ensure you have connectivity between the FTD and FMC by taking a packet capture. From the CLI of the FTD use the command "capture-traffic" and filter on "-n port 8305", you should see communication to/from the FMC. If not check there is not another firewall in the path blocking this communication.
Hi Rob Ingram,
Thanks for reply..
FTD System version: 4.0(1.140)
FMC Operating System Version 6.2.2
You meant doing ssh FTD use the command "capture-traffic" ? I don't see  this command at CLI FTD.  last time I reset FTD and connect back to FMC, and its Okay for three day. and same issue happen again. Before this happen, I configure interface channel. But when I tried to enable port and deploy, its Failed.
 Kindly assist .
