05-21-2007 08:15 AM - edited 03-09-2019 06:01 PM
Hi All,
I have a new requirement and as per the attached diagram I need to set up two gre tunnels to the same destination with two different throughput i.e. site A and Site B will have a tunnel with 768 Kbps for voice and 256 Kbps for data.
Lets say subnet x.x.x.x for voice and y.y.y.y for data.I need help in getting the best out of a 3640 running 12.0 and another 7200 vxr running 12.0(13). Please give some inputs.
Thanks in advance
subra4u
05-21-2007 08:27 PM
If you are sure that you are not going to use more than 256K for voice then you can configure the same way you have posted out here and configure rate-limit on both the tunnels for the maximum allowed bandwidth so that they dont choke the whole bandwidth available over the main link..
For configuring rate-limit you can refer the below link ...
regds
05-23-2007 12:14 AM
Hi Prem,
Thanks for the Immediate Response, We are planning to have Voice for 768 Kbps but as for as the tunnel goes it will be like a data packet between our own custom developed servers.
Thanks & Regards
05-23-2007 03:49 AM
There are some possibilities for voip and data over tunnels.
1) IF the packets pre-tunnel are marked (DSCP, IP precedence) then the GRE headers will also get the same markings. You can then setup a policy on the physical interface towards the internet to prioritize voip.
2) You could use "qos pre-classify" on both routers - newer IOS required though afaik.
3) use one tunnel and a nested policy.
Why do you need two tunnels?
regards, Martin
