help to activate username into https://
ejllantino
I one problem, I cannot use the https:// in order to connect the pix 515 console. I already create username with password with privilege 15 ((username sold password xxxxx encrypted privilege 15))
but when I use the Explorer to open the console it said incorrect login. Help pls
soldier
bfl1
Did you configure PDM to use a specific authentication?
Try this command:
config t
aaa authentication http console LOCAL
This will force the PDM to authenticate off the local user database.
