How can I tell what a privilege level is allowed to do
jameskuder
We had an engineer that setup a custom privilege level some time back. As far as I know, it is still there. How can I verify what that specific level is allowed to do? How can I add to it or remove things from it?
The configuration currently has a set of local usernames and the devices is set to use those local usernames and their configured privilege level (all currently "15" = full admin privileges) for authentication and authorization per the following lines:
username disaster privilege 15 secret 5 <removed>
username svc-kiwi privilege 15 secret 5 <removed>
username admjkude privilege 15 secret 5 <removed>
username admprime privilege 15 secret 5 <removed>
username svc-prime privilege 15 secret 5 <removed>
username admpsing privilege 15 secret 5 <removed>
username admkgen privilege 15 secret 5 <removed>
username admtmcco privilege 15 secret 5 <removed>
aaa new-model
aaa authentication login default local line enable
aaa authorization console
aaa authorization exec default local
If any new users were defined with a lower privilege level (say "3" or "4") they would be restricted to the commands that appear in the following section of the config file:
privilege interface level 3 duplex
privilege interface level 3 speed
privilege interface level 4 power inline never
privilege interface level 4 power inline static
privilege interface level 4 power inline auto
privilege interface level 4 power inline consumption
privilege interface level 3 shutdown
privilege interface level 4 ip address
privilege interface level 3 switchport
privilege interface level 3 description
privilege configure level 3 interface
privilege configure level 4 ip domain-name
privilege configure level 4 clock summer-time
privilege configure level 4 clock timezone
privilege configure level 4 hostname
privilege exec level 4 copy running-config startup-config
privilege exec level 4 crypto
privilege exec level 4 tclquit
privilege exec level 4 connect
privilege exec level 4 telnet
privilege exec level 4 mtrace
privilege exec level 4 mstat
privilege exec level 4 mrinfo
privilege exec level 4 tunnel
privilege exec level 4 access-enable
privilege exec level 4 power
privilege exec level 4 enable
privilege exec level 15 disable
privilege exec level 3 configure terminal
privilege exec level 4 resume
privilege exec level 4 name-connection
privilege exec level 4 disconnect
privilege exec level 4 reload
privilege exec level 4 terminal
privilege exec level 3 show startup-config
privilege exec level 3 show running-config
privilege exec level 4 show interfaces
privilege exec level 4 set
privilege exec level 4 lock
privilege exec level 4 logout
privilege exec level 3 clear counters
privilege exec level 4 clear
6 Replies 6
Philip D'Ath
Can you show us all the aaa, privilege and parser lines?
How do I get that info?
You can capture everything with a "show tech-support"?
HBSEASWIP38#sh tech-support
------------------ show clock ------------------
.07:05:11.036 PST Wed Jan 13 2016
------------------ show version ------------------
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
HBSEASWIP38 uptime is 13 weeks, 3 days, 5 hours, 15 minutes
Uptime for this control processor is 13 weeks, 3 days, 5 hours, 18 minutes
System returned to ROM by reload at 06:21:32 PDT Wed Mar 25 2015
System restarted at 02:49:45 PDT Sun Oct 11 2015
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1832X15V
1 Virtual Ethernet interface
208 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
257008K bytes of Crash Files at crashinfo:.
257008K bytes of Crash Files at crashinfo-2:.
1550272K bytes of Flash at flash:.
1550272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of  at webui:.
257008K bytes of Crash Files at crashinfo-3:.
1550272K bytes of Flash at flash-3:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-3:.
Base Ethernet MAC Address          : f0:9e:63:dc:2a:00
Motherboard Assembly Number        : 73-14442-09
Motherboard Serial Number          : FOC18319BBU
Model Revision Number              : M0
Motherboard Revision Number        : A0
Model Number                       : WS-C3850-48P
System Serial Number               : FOC1832X15V
Switch Ports Model              SW Version        SW Image              Mode
     1 56    WS-C3850-48P       03.02.03.SE       cat3k_caa-universalk9 INSTALL
     2 56    WS-C3850-48P       03.02.03.SE       cat3k_caa-universalk9 INSTALL
     3 56    WS-C3850-48P       03.02.03.SE       cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime                      : 13 weeks, 3 days, 5 hours, 19 minutes
Base Ethernet MAC Address          : f0:9e:63:43:95:00
Motherboard Serial Number          : FOC18319BZ9
System Serial Number               : FOC1832U143
Switch 03
Switch uptime                      : 13 weeks, 3 days, 5 hours, 16 minutes
Base Ethernet MAC Address          : f0:9e:63:dc:a3:80
Motherboard Serial Number          : FOC18323YL0
System Serial Number               : FCW1832C11U
Configuration register is 0x102
------------------ show running-config ------------------
Building configuration...
Current configuration : 59300 bytes
! Last configuration change at 09:43:21 PST Tue Jan 12 2016 by admjkude
! NVRAM config last updated at 09:43:08 PST Tue Jan 12 2016 by admjkude
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
service sequence-numbers
no service dhcp
hostname HBSEASWIP38
boot-start-marker
boot system switch all flash:cat3k_caa-universalk9.SPA.03.02.02.SE.150-1.EX2.bin
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 16000
logging console critical
enable secret 5 <removed>
aaa new-model
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
switch 1 provision ws-c3850-48p
switch 2 provision ws-c3850-48p
switch 3 provision ws-c3850-48p
switch 4 provision ws-c3850-48p
no ip source-route
no ip gratuitous-arps
no ip domain-lookup
ip domain-name CSB.COM
ip device tracking
qos wireless-default-untrust
table-map policed-dscp
 map from 0 to 8
 map from 10 to 8
 map from 18 to 8
 map from 24 to 8
 map from 46 to 8
 default copy
crypto pki trustpoint TP-self-signed-3186893184
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3186893184
 revocation-check none
 rsakeypair TP-self-signed-3186893184
crypto pki certificate chain TP-self-signed-3186893184
errdisable recovery cause channel-misconfig (STP)
errdisable recovery interval 30
diagnostic bootup level minimal
archive
 log config
  logging enable
  logging size 200
  notify syslog contenttype plaintext
  hidekeys
identity policy webauth-global-inactive
 inactivity-timer 3600
spanning-tree mode rapid-pvst
spanning-tree vlan 1-1001 priority 61440
redundancy
 mode sso
ip ssh time-out 20
ip ssh authentication-retries 5
ip ssh logging events
ip ssh version 2
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
  match  dscp af41  af42  af43
  match cos  4
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
  match  dscp af11  af12  af13
  match cos  1
class-map match-any AutoQos-4.0-Output-Priority-Queue
  match  dscp cs4  cs5  ef
  match cos  5
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
  match  dscp af31  af32  af33
class-map match-any AutoQos-4.0-Voip-Data-CiscoPhone-Class
  match cos  5
class-map match-any AutoQos-4.0-Voip-Signal-CiscoPhone-Class
  match cos  3
class-map match-any non-client-nrt-class
  match non-client-nrt
class-map match-any AutoQos-4.0-Default-Class
  match access-group name AutoQos-4.0-Acl-Default
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
  match  dscp af21  af22  af23
  match cos  2
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
  match  dscp cs1
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
  match  dscp cs2  cs3  cs6  cs7
  match cos  3
policy-map port_child_policy
 class non-client-nrt-class
    bandwidth remaining ratio 10
policy-map AutoQos-4.0-Output-Policy
 class AutoQos-4.0-Output-Priority-Queue
    priority level 1 percent 30
 class AutoQos-4.0-Output-Control-Mgmt-Queue
    bandwidth remaining percent 10
    queue-limit dscp  cs2 percent 80
    queue-limit dscp  cs3 percent 90
    queue-limit dscp  cs6 percent 100
    queue-limit dscp  cs7 percent 100
    queue-buffers ratio 10
 class AutoQos-4.0-Output-Multimedia-Conf-Queue
 class AutoQos-4.0-Output-Trans-Data-Queue
 class AutoQos-4.0-Output-Bulk-Data-Queue
    bandwidth remaining percent 4
 class AutoQos-4.0-Output-Scavenger-Queue
 class AutoQos-4.0-Output-Multimedia-Strm-Queue
 class class-default
    bandwidth remaining percent 25
    queue-buffers ratio 25
policy-map AutoQos-4.0-CiscoPhone-Input-Policy
 class AutoQos-4.0-Voip-Data-CiscoPhone-Class
   set dscp ef
    police cir 128000 bc 8000
      conform-action transmit
      exceed-action set-dscp-transmit dscp table policed-dscp
 class AutoQos-4.0-Voip-Signal-CiscoPhone-Class
   set dscp cs3
    police cir 32000 bc 8000
 class AutoQos-4.0-Default-Class
   set dscp default
interface Port-channel1
 description Trunk
 switchport trunk pruning vlan none
 switchport mode trunk
 switchport nonegotiate
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
interface GigabitEthernet1/0/1
 switchport access vlan 999
 switchport voice vlan 385
 switchport priority extend trust
 speed 100
 duplex full
 trust device cisco-phone
 auto qos voip cisco-phone
 spanning-tree portfast
 service-policy input AutoQos-4.0-CiscoPhone-Input-Policy
 service-policy output AutoQos-4.0-Output-Policy
interface GigabitEthernet1/0/2
 switchport access vlan 380
 speed 100
 duplex full
interface GigabitEthernet1/0/3
 speed 100
 duplex full
interface GigabitEthernet1/0/4
 speed 100
 duplex full
interface GigabitEthernet1/0/5
 speed 100
 duplex full
interface GigabitEthernet1/0/6
 speed 100
 duplex full
interface GigabitEthernet1/0/7
 speed 100
 duplex full
interface GigabitEthernet1/0/8
 speed 100
 duplex full
interface GigabitEthernet1/0/9
 speed 100
 duplex full
interface GigabitEthernet1/0/10
 speed 100
 duplex full
interface GigabitEthernet1/0/11
 speed 100
 duplex full
interface GigabitEthernet1/0/12
 speed 100
 duplex full
interface GigabitEthernet1/0/13
 speed 100
 duplex full
interface GigabitEthernet1/0/14
 speed 100
 duplex full
interface GigabitEthernet1/0/15
 speed 100
 duplex full
interface GigabitEthernet1/0/16
 speed 100
 duplex full
interface GigabitEthernet1/0/17
 speed 100
 duplex full
interface GigabitEthernet1/0/18
 speed 100
 duplex full
interface GigabitEthernet1/0/19
 speed 100
 duplex full
interface GigabitEthernet1/0/20
 speed 100
 duplex full
interface GigabitEthernet1/0/21
 speed 100
 duplex full
interface GigabitEthernet1/0/22
 speed 100
 duplex full
interface GigabitEthernet1/0/23
 speed 100
 duplex full
interface GigabitEthernet1/0/24
 speed 100
 duplex full
interface GigabitEthernet1/0/25
 speed 100
 duplex full
interface GigabitEthernet1/0/26
 speed 100
 duplex full
interface GigabitEthernet1/0/27
 speed 100
 duplex full
interface GigabitEthernet1/0/28
 speed 100
 duplex full
interface GigabitEthernet1/0/29
 speed 100
 duplex full
interface GigabitEthernet1/0/30
 speed 100
 duplex full
interface GigabitEthernet1/0/31
 speed 100
 duplex full
interface GigabitEthernet1/0/32
 speed 100
 duplex full
interface GigabitEthernet1/0/33
 speed 100
 duplex full
interface GigabitEthernet1/0/34
 speed 100
 duplex full
interface GigabitEthernet1/0/35
 speed 100
 duplex full
interface GigabitEthernet1/0/36
 speed 100
 duplex full
interface GigabitEthernet1/0/37
 speed 100
 duplex full
interface GigabitEthernet1/0/38
 speed 100
 duplex full
interface GigabitEthernet1/0/39
 speed 100
 duplex full
interface GigabitEthernet1/0/40
 speed 100
 duplex full
interface GigabitEthernet1/0/41
 speed 100
 duplex full
interface GigabitEthernet1/0/42
 speed 100
 duplex full
interface GigabitEthernet1/0/43
 speed 100
 duplex full
interface GigabitEthernet1/0/44
 speed 100
 duplex full
interface GigabitEthernet1/0/45
 speed 100
 duplex full
interface GigabitEthernet1/0/46
 speed 100
 duplex full
interface GigabitEthernet1/0/47
 speed 100
 duplex full
interface GigabitEthernet1/0/48
 speed 100
 duplex full
interface GigabitEthernet1/1/1
 description Trunk to 19th Floor Core
 channel-group 1 mode active
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
 switchport mode access
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
 speed 100
 duplex full
interface GigabitEthernet2/0/3
 speed 100
 duplex full
interface GigabitEthernet2/0/4
 speed 100
 duplex full
interface GigabitEthernet2/0/5
 speed 100
 duplex full
interface GigabitEthernet2/0/6
 speed 100
 duplex full
interface GigabitEthernet2/0/7
 speed 100
 duplex full
interface GigabitEthernet2/0/8
 speed 100
 duplex full
interface GigabitEthernet2/0/9
 speed 100
 duplex full
interface GigabitEthernet2/0/10
 speed 100
 duplex full
interface GigabitEthernet2/0/11
 speed 100
 duplex full
interface GigabitEthernet2/0/12
 speed 100
 duplex full
interface GigabitEthernet2/0/13
 speed 100
 duplex full
interface GigabitEthernet2/0/14
 speed 100
 duplex full
interface GigabitEthernet2/0/15
 speed 100
 duplex full
interface GigabitEthernet2/0/16
 speed 100
 duplex full
interface GigabitEthernet2/0/17
 speed 100
 duplex full
interface GigabitEthernet2/0/18
 speed 100
 duplex full
interface GigabitEthernet2/0/19
 speed 100
 duplex full
interface GigabitEthernet2/0/20
 speed 100
 duplex full
interface GigabitEthernet2/0/21
 speed 100
 duplex full
interface GigabitEthernet2/0/22
 speed 100
 duplex full
interface GigabitEthernet2/0/23
 speed 100
 duplex full
interface GigabitEthernet2/0/24
 speed 100
 duplex full
interface GigabitEthernet2/0/25
 speed 100
 duplex full
interface GigabitEthernet2/0/26
 speed 100
 duplex full
interface GigabitEthernet2/0/27
 speed 100
 duplex full
interface GigabitEthernet2/0/28
 speed 100
 duplex full
interface GigabitEthernet2/0/29
 speed 100
 duplex full
interface GigabitEthernet2/0/30
 speed 100
 duplex full
interface GigabitEthernet2/0/31
 speed 100
 duplex full
interface GigabitEthernet2/0/32
 speed 100
 duplex full
interface GigabitEthernet2/0/33
 speed 100
 duplex full
interface GigabitEthernet2/0/34
 speed 100
 duplex full
interface GigabitEthernet2/0/35
 speed 100
 duplex full
interface GigabitEthernet2/0/36
 speed 100
 duplex full
interface GigabitEthernet2/0/37
 speed 100
 duplex full
interface GigabitEthernet2/0/38
 speed 100
 duplex full
interface GigabitEthernet2/0/39
 speed 100
 duplex full
interface GigabitEthernet2/0/40
 speed 100
 duplex full
interface GigabitEthernet2/0/41
 speed 100
 duplex full
interface GigabitEthernet2/0/42
 speed 100
 duplex full
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
 speed 100
 duplex full
interface GigabitEthernet2/0/45
 speed 100
 duplex full
interface GigabitEthernet2/0/46
 speed 100
 duplex full
interface GigabitEthernet2/0/47
 speed 100
 duplex full
interface GigabitEthernet2/0/48
 speed 100
 duplex full
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface GigabitEthernet3/0/1
 description WAP
interface GigabitEthernet3/0/2
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/3
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/4
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/5
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/6
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/7
 description WAP
 speed 1000
 duplex full
interface GigabitEthernet3/0/8
 speed 100
 duplex full
interface GigabitEthernet3/0/9
 speed 100
 duplex full
interface GigabitEthernet3/0/10
 speed 100
 duplex full
interface GigabitEthernet3/0/11
 speed 100
 duplex full
interface GigabitEthernet3/0/12
 speed 100
 duplex full
interface GigabitEthernet3/0/13
 speed 100
 duplex full
interface GigabitEthernet3/0/14
 speed 100
 duplex full
interface GigabitEthernet3/0/15
 speed 100
 duplex full
interface GigabitEthernet3/0/16
 speed 100
 duplex full
interface GigabitEthernet3/0/17
 speed 100
 duplex full
interface GigabitEthernet3/0/18
 speed 100
 duplex full
interface GigabitEthernet3/0/19
 speed 100
 duplex full
interface GigabitEthernet3/0/20
 speed 100
 duplex full
interface GigabitEthernet3/0/21
 speed 100
 duplex full
interface GigabitEthernet3/0/22
 speed 100
 duplex full
interface GigabitEthernet3/0/23
 speed 100
 duplex full
interface GigabitEthernet3/0/24
 speed 100
 duplex full
interface GigabitEthernet3/0/25
 speed 100
 duplex full
interface GigabitEthernet3/0/26
 speed 100
 duplex full
interface GigabitEthernet3/0/27
 speed 100
 duplex full
interface GigabitEthernet3/0/28
 speed 100
 duplex full
interface GigabitEthernet3/0/29
 speed 100
 duplex full
interface GigabitEthernet3/0/30
 speed 100
 duplex full
interface GigabitEthernet3/0/31
 speed 100
 duplex full
interface GigabitEthernet3/0/32
 speed 100
 duplex full
interface GigabitEthernet3/0/33
 speed 100
 duplex full
interface GigabitEthernet3/0/34
 speed 100
 duplex full
interface GigabitEthernet3/0/35
 speed 100
 duplex full
interface GigabitEthernet3/0/36
 speed 100
 duplex full
interface GigabitEthernet3/0/37
 speed 100
 duplex full
interface GigabitEthernet3/0/38
 speed 100
 duplex full
interface GigabitEthernet3/0/39
 speed 100
 duplex full
interface GigabitEthernet3/0/40
 speed 100
 duplex full
interface GigabitEthernet3/0/41
 speed 100
 duplex full
interface GigabitEthernet3/0/42
 speed 100
 duplex full
interface GigabitEthernet3/0/43
 speed 100
 duplex full
interface GigabitEthernet3/0/44
 speed 100
 duplex full
interface GigabitEthernet3/0/45
 speed 100
 duplex full
interface GigabitEthernet3/0/46
 speed 100
 duplex full
interface GigabitEthernet3/0/47
 speed 100
 duplex full
interface GigabitEthernet3/0/48
 speed 100
 duplex full
interface GigabitEthernet3/1/1
interface GigabitEthernet3/1/2
interface GigabitEthernet3/1/3
interface GigabitEthernet3/1/4
interface TenGigabitEthernet3/1/1
interface TenGigabitEthernet3/1/2
interface TenGigabitEthernet3/1/3
interface TenGigabitEthernet3/1/4
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/3
interface GigabitEthernet4/0/4
interface GigabitEthernet4/0/5
interface GigabitEthernet4/0/6
interface GigabitEthernet4/0/7
interface GigabitEthernet4/0/8
interface GigabitEthernet4/0/9
interface GigabitEthernet4/0/10
interface GigabitEthernet4/0/11
interface GigabitEthernet4/0/12
interface GigabitEthernet4/0/13
interface GigabitEthernet4/0/14
interface GigabitEthernet4/0/15
interface GigabitEthernet4/0/16
interface GigabitEthernet4/0/17
interface GigabitEthernet4/0/18
interface GigabitEthernet4/0/19
interface GigabitEthernet4/0/20
interface GigabitEthernet4/0/21
interface GigabitEthernet4/0/22
interface GigabitEthernet4/0/23
interface GigabitEthernet4/0/24
interface GigabitEthernet4/0/25
interface GigabitEthernet4/0/26
interface GigabitEthernet4/0/27
interface GigabitEthernet4/0/28
interface GigabitEthernet4/0/29
interface GigabitEthernet4/0/30
interface GigabitEthernet4/0/31
interface GigabitEthernet4/0/32
interface GigabitEthernet4/0/33
interface GigabitEthernet4/0/34
interface GigabitEthernet4/0/35
interface GigabitEthernet4/0/36
interface GigabitEthernet4/0/37
interface GigabitEthernet4/0/38
interface GigabitEthernet4/0/39
interface GigabitEthernet4/0/40
interface GigabitEthernet4/0/41
interface GigabitEthernet4/0/42
interface GigabitEthernet4/0/43
interface GigabitEthernet4/0/44
interface GigabitEthernet4/0/45
interface GigabitEthernet4/0/46
interface GigabitEthernet4/0/47
interface GigabitEthernet4/0/48
interface GigabitEthernet4/1/1
interface GigabitEthernet4/1/2
interface GigabitEthernet4/1/3
interface GigabitEthernet4/1/4
interface TenGigabitEthernet4/1/1
interface TenGigabitEthernet4/1/2
interface TenGigabitEthernet4/1/3
interface TenGigabitEthernet4/1/4
interface Vlan1
 description Switch Mgmt
 ip address 10.1.1.38 255.255.255.0
ip default-gateway 10.1.1.1
no ip http server
ip http authentication local
ip http secure-server
ip access-list extended AutoQos-4.0-Acl-Default
 permit ip any any
ip sla enable reaction-alerts
logging history size 500
logging history informational
logging origin-id hostname
logging 10.1.1.123
logging 10.1.5.239
access-list 1 permit 10.10.20.14
access-list 1 permit 10.10.20.15
access-list 1 permit 10.10.20.90
access-list 1 permit 10.1.5.239
access-list 1 deny   any log
access-list 2 permit 10.2.0.0 0.0.0.255
access-list 2 permit 10.1.5.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.10.0.0 0.0.255.255
access-list 2 permit 10.20.0.0 0.0.255.255
access-list 2 deny   any log
snmp-server community <removed> RO 1
snmp-server community <removed> RW 1
snmp-server location Home Office
snmp-server contact netadmin@homestreet.com
snmp-server enable traps license
snmp-server enable traps config
snmp-server enable traps errdisable
snmp-server host 10.10.20.11 <removed>
snmp-server host 10.10.20.14 <removed>
snmp-server host 10.10.20.15 <removed>
snmp-server host 10.10.20.90 <removed>
snmp-server host 10.1.5.239 version 2c <removed>
privilege log_config level 4 logging
banner motd ^C
WARNING!!!  Unauthorized use of this system may subject you to criminal prosecution and penalties.
^C
line con 0
 exec-timeout 15 0
 timeout login response 90
 password 7 <removed>
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class 2 in
 exec-timeout 15 0
 privilege level 15
 logging synchronous
 length 0
 transport input ssh
line vty 5 15
 access-class 2 in
 exec-timeout 15 0
 privilege level 15
 logging synchronous
 transport input ssh
ntp server 10.20.5.10
ntp server 10.10.5.12
ntp server 10.10.5.21 prefer
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
ap dot11 5ghz rrm channel dca 161
ap group default-group
end
------------------ show stacks ------------------
Minimum process stacks:
 Free/Size   Name
17312/18000  IPC Zone Manager
17424/18000  NGWC DTLS SPI PROCESS
30072/36000  IOSd shutdown SPI init process
12104/18000  QEMU CI platform comm process
11944/18000  QEMU CI oir process
29352/36000  CHKPT IOSd SPI process
11336/18000  reregister_flags
16176/18000  OIRLIB-SENDCB-THREAD
17424/18000  ISSU Infra API Delayed Registration Process
12120/18000  IOSd dbflags client process
17424/18000  CDP BLOB
22784/24000  MRIB IPv4 Init Process
14384/18000  MGMT VRF Process
12200/18000  diag n3k spi Init
15936/18000  EEM Shell Director
12248/18000  SPI PLOGD SERVER process
12104/18000  MgmtE HA role reg
30184/36000  OSINFO SPI process
30168/36000  SPI CAPWAP process
12120/18000  NGWC WCM SPI Client Register Process
12264/18000  External HTTP App Handler process
12200/18000  FTS conf server process
30072/36000  ISSU IOSd client init process
12200/18000  QoS TAM SPI Helper
35424/36000  ISSU IOSd ce image MIB update process
12152/18000  RSMP Init
12216/18000  TACTIC Nova Server Init
10984/18000  pr session thread
17312/18000  event session thread
16560/18000  diag n3k oir event
13536/18000  MgmtE relay server response
15200/18000  cl session thread
23168/24000  DHCPD Receive
17296/18000  stp_change_tree_type
33000/36000  IOSd LIIN config
17264/18000  SPAN Subsystem
17120/18000  LACP Protocol
70656/72000  EEM Auto Registration Proc
17152/18000  SASL MAIN
14144/15000  LIM WAVL
20416/21000  cdp init process
17072/18000  RADIUS INITCONFIG
23184/24000  HTTP SSL PKI CERTIFICATE CREATE PROC
18296/33000  Init
11560/15000  Rom Random Update Process
17296/18000  URPF stats
15328/18000  IPC ISSU Versioning Process
13872/18000  IPC ISSU Receive Process
16048/18000  RTTY Client Registration
14272/18000  IfIndex Bulk Sync
15008/18000  RFS RF Platform Sync Process
15248/18000  CONFIG SYNC ISSU NEGOTIATION PROCESS
14192/18000  CONFIG SYNC PLATFORM SYNC PROCESS
16144/18000  NG3K OIR PLATFORM SYNC PROCESS
16160/18000  NG3K SES PLATFORM SYNC PROCESS
17344/18000  PM RF Process
14704/18000  snmp_issu_process
14256/18000  SNMP MIB Platform Sync
17184/18000  SNMP Platform per-sec Job
16352/18000  Tableid HA Bulk Sync
19088/24000  RF Send Bulk Sync ExtProgTimer
22560/24000  RFSS_server_action
22480/24000  RFSS worker process
15856/18000  RF Network sendbulk
15904/18000  NG3K OIR BULK SYNC PROCESS
15952/18000  NGWC FEC BULK SYNC PROCESS
16480/18000  MATM HA Bulksync Process
17184/18000  SNMP Bulk per-sec Job
16304/18000  ARP HA RF Timer Extension
15888/18000  Call home Bulk Sync Timer
15664/18000  NGWC ILP Bulksync Process
16096/18000  SMI HA Bulk Sync Process
16144/18000  IGMPSN HA Bulk Sync
16304/18000  IGMPSN HA RF timer process
15904/18000  MLDSN HA Bulk Sync
16304/18000  MLDSN HA RF timer process
16144/18000  Online Diag Bulk Sync Timer
15488/18000  SNMP MIB Bulk Sync
16528/18000  CONFIG SYNC VERIFICATION
17424/18000  IP SLAs Deferred Schedule Processor
13904/24000  SSH Process
Interrupt level stacks:
Level    Called Unused/Size  Name
  2           0 253392/262144  Network Interrupt
  3           0 248712/262144  Aux Thread
------------------ show interfaces ------------------
Vlan1 is up, line protocol is up
  Hardware is Ethernet SVI, address is f09e.63dc.2a47 (bia f09e.63dc.2a47)
  Description: Switch Mgmt
  Internet address is 10.1.1.38/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 70000 bits/sec, 43 packets/sec
  5 minute output rate 14000 bits/sec, 7 packets/sec
     147484605 packets input, 3421599172 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     35835756 packets output, 1173347609 bytes, 0 underruns
     0 output errors, 2 interface resets
     0 unknown protocol drops
GigabitEthernet0/0 is down, line protocol is down
  Hardware is RP management port, address is f09e.63dc.2a00 (bia f09e.63dc.2a00)
  Keepalive set (10 sec)
  Unknown, Unknown, link type is auto, media type is 100BaseTX
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a01 (bia f09e.63dc.2a01)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 13w0d, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
     16080 packets input, 2160144 bytes, 0 no buffer
     Received 4014 broadcasts (1390 multicasts)
     0 watchdog, 1390 multicast, 0 pause input
     25158 packets output, 8433342 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     2462 unknown protocol drops
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a02 (bia f09e.63dc.2a02)
  Last input 00:00:13, output never, output hang never
  5 minute output rate 3000 bits/sec, 4 packets/sec
     10756967 packets input, 2263983938 bytes, 0 no buffer
     Received 318816 broadcasts (300329 multicasts)
     0 watchdog, 300329 multicast, 0 pause input
     33118579 packets output, 3416832544 bytes, 0 underruns
     8102 unknown protocol drops
GigabitEthernet1/0/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a03 (bia f09e.63dc.2a03)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
     Received 0 broadcasts (0 multicasts)
GigabitEthernet1/0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a04 (bia f09e.63dc.2a04)
  Last input 00:00:22, output never, output hang never
     1745770 packets input, 354761907 bytes, 0 no buffer
     Received 5085 broadcasts (1488 multicasts)
     21009 input errors, 21009 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1488 multicast, 0 pause input
     23960168 packets output, 449038634 bytes, 0 underruns
GigabitEthernet1/0/5 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a05 (bia f09e.63dc.2a05)
  Last input 00:00:11, output never, output hang never
  5 minute input rate 65000 bits/sec, 16 packets/sec
  5 minute output rate 178000 bits/sec, 32 packets/sec
     191048075 packets input, 2735691076 bytes, 0 no buffer
     Received 407308 broadcasts (407152 multicasts)
     912485 input errors, 912485 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 407152 multicast, 0 pause input
     415717419 packets output, 3525558601 bytes, 0 underruns
     144 unknown protocol drops
GigabitEthernet1/0/6 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a06 (bia f09e.63dc.2a06)
GigabitEthernet1/0/7 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a07 (bia f09e.63dc.2a07)
  Last input 00:00:06, output never, output hang never
     12759360 packets input, 2978059862 bytes, 0 no buffer
     Received 339802 broadcasts (302543 multicasts)
     0 watchdog, 302543 multicast, 0 pause input
     34248196 packets output, 1595831880 bytes, 0 underruns
     25542 unknown protocol drops
GigabitEthernet1/0/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a08 (bia f09e.63dc.2a08)
  Last input 00:00:04, output never, output hang never
     14086549 packets input, 320547726 bytes, 0 no buffer
     Received 165489 broadcasts (151495 multicasts)
     475 input errors, 475 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 151495 multicast, 0 pause input
     25377393 packets output, 477717535 bytes, 0 underruns
     7079 unknown protocol drops
GigabitEthernet1/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a09 (bia f09e.63dc.2a09)
  Last input 00:00:19, output never, output hang never
     41354710 packets input, 3606676831 bytes, 0 no buffer
     Received 502857 broadcasts (323226 multicasts)
     0 watchdog, 323226 multicast, 0 pause input
     95079844 packets output, 476734398 bytes, 0 underruns
     167838 unknown protocol drops
GigabitEthernet1/0/10 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0a (bia f09e.63dc.2a0a)
  5 minute input rate 2000 bits/sec, 1 packets/sec
  5 minute output rate 4000 bits/sec, 5 packets/sec
     95696347 packets input, 3151537018 bytes, 0 no buffer
     Received 407357 broadcasts (407214 multicasts)
     549576 input errors, 549576 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 407214 multicast, 0 pause input
     322171583 packets output, 638175635 bytes, 0 underruns
     132 unknown protocol drops
GigabitEthernet1/0/11 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0b (bia f09e.63dc.2a0b)
GigabitEthernet1/0/12 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0c (bia f09e.63dc.2a0c)
  Last input 00:00:02, output never, output hang never
     2929713 packets input, 543827009 bytes, 0 no buffer
     Received 253311 broadcasts (245277 multicasts)
     0 watchdog, 245277 multicast, 0 pause input
     20944226 packets output, 2926893522 bytes, 0 underruns
     3384 unknown protocol drops
GigabitEthernet1/0/13 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0d (bia f09e.63dc.2a0d)
  5 minute output rate 3000 bits/sec, 3 packets/sec
     16779185 packets input, 331201850 bytes, 0 no buffer
     Received 458324 broadcasts (273267 multicasts)
     7 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 273267 multicast, 0 pause input
     35272817 packets output, 3509193062 bytes, 0 underruns
     155897 unknown protocol drops
GigabitEthernet1/0/14 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0e (bia f09e.63dc.2a0e)
  Last input 06:52:10, output never, output hang never
     12440043 packets input, 2572664093 bytes, 0 no buffer
     Received 138121 broadcasts (134502 multicasts)
     0 watchdog, 134502 multicast, 0 pause input
     32720889 packets output, 382504178 bytes, 0 underruns
GigabitEthernet1/0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a0f (bia f09e.63dc.2a0f)
  Last input 00:00:20, output never, output hang never
  5 minute output rate 2000 bits/sec, 3 packets/sec
     511380 packets input, 32754590 bytes, 0 no buffer
     Received 1007 broadcasts (3 multicasts)
     10 input errors, 10 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3 multicast, 0 pause input
     21454310 packets output, 2329687574 bytes, 0 underruns
GigabitEthernet1/0/16 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a10 (bia f09e.63dc.2a10)
  Last input 00:00:14, output never, output hang never
     1477392 packets input, 151071327 bytes, 0 no buffer
     Received 274675 broadcasts (271264 multicasts)
     0 watchdog, 271264 multicast, 0 pause input
     21778034 packets output, 2228711151 bytes, 0 underruns
     3 unknown protocol drops
GigabitEthernet1/0/17 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a11 (bia f09e.63dc.2a11)
     8081305 packets input, 1376741886 bytes, 0 no buffer
     Received 347599 broadcasts (319609 multicasts)
     0 watchdog, 319609 multicast, 0 pause input
     28199595 packets output, 2167557928 bytes, 0 underruns
     15244 unknown protocol drops
GigabitEthernet1/0/18 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a12 (bia f09e.63dc.2a12)
  Last input 00:00:10, output never, output hang never
     2232547 packets input, 444198848 bytes, 0 no buffer
     Received 336523 broadcasts (313011 multicasts)
     0 watchdog, 313011 multicast, 0 pause input
     22449628 packets output, 2658991445 bytes, 0 underruns
     14137 unknown protocol drops
GigabitEthernet1/0/19 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a13 (bia f09e.63dc.2a13)
GigabitEthernet1/0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a14 (bia f09e.63dc.2a14)
  Last input 00:00:09, output never, output hang never
     20409639 packets input, 1235417015 bytes, 0 no buffer
     Received 387704 broadcasts (349459 multicasts)
     0 watchdog, 349459 multicast, 0 pause input
     43698381 packets output, 1803189511 bytes, 0 underruns
     25355 unknown protocol drops
GigabitEthernet1/0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a15 (bia f09e.63dc.2a15)
GigabitEthernet1/0/22 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a16 (bia f09e.63dc.2a16)
     5621426 packets input, 1253682198 bytes, 0 no buffer
     Received 400250 broadcasts (342218 multicasts)
     0 watchdog, 342218 multicast, 0 pause input
     26162806 packets output, 1220216988 bytes, 0 underruns
     45472 unknown protocol drops
GigabitEthernet1/0/23 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a17 (bia f09e.63dc.2a17)
  Last input 00:00:01, output never, output hang never
     2615809 packets input, 546912380 bytes, 0 no buffer
     Received 22793 broadcasts (20862 multicasts)
     1739 input errors, 1739 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 20862 multicast, 0 pause input
     5516234 packets output, 848930263 bytes, 0 underruns
     6 unknown protocol drops
GigabitEthernet1/0/24 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a18 (bia f09e.63dc.2a18)
GigabitEthernet1/0/25 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a19 (bia f09e.63dc.2a19)
  Last input 00:00:07, output never, output hang never
     15916310 packets input, 3494364816 bytes, 0 no buffer
     Received 356568 broadcasts (323668 multicasts)
     0 watchdog, 323668 multicast, 0 pause input
     38445519 packets output, 3999865358 bytes, 0 underruns
     19280 unknown protocol drops
GigabitEthernet1/0/26 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1a (bia f09e.63dc.2a1a)
GigabitEthernet1/0/27 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1b (bia f09e.63dc.2a1b)
     16616552 packets input, 3871705495 bytes, 0 no buffer
     Received 348037 broadcasts (316260 multicasts)
     0 watchdog, 316260 multicast, 0 pause input
     39077168 packets output, 4051833387 bytes, 0 underruns
     19627 unknown protocol drops
GigabitEthernet1/0/28 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1c (bia f09e.63dc.2a1c)
  Last input 00:00:18, output never, output hang never
     16303491 packets input, 3913175581 bytes, 0 no buffer
     Received 402030 broadcasts (361883 multicasts)
     0 watchdog, 361883 multicast, 0 pause input
     39046071 packets output, 1806410409 bytes, 0 underruns
     26503 unknown protocol drops
GigabitEthernet1/0/29 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1d (bia f09e.63dc.2a1d)
     24306279 packets input, 1367280322 bytes, 0 no buffer
     Received 366021 broadcasts (330042 multicasts)
     0 watchdog, 330042 multicast, 0 pause input
     54070316 packets output, 2428640152 bytes, 0 underruns
     21854 unknown protocol drops
GigabitEthernet1/0/30 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1e (bia f09e.63dc.2a1e)
  Last input 00:00:16, output never, output hang never
     11782389 packets input, 2378408126 bytes, 0 no buffer
     Received 375005 broadcasts (333203 multicasts)
     0 watchdog, 333203 multicast, 0 pause input
     33819517 packets output, 1370337564 bytes, 0 underruns
     25715 unknown protocol drops
GigabitEthernet1/0/31 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a1f (bia f09e.63dc.2a1f)
     9251742 packets input, 2544799800 bytes, 0 no buffer
     Received 375633 broadcasts (348614 multicasts)
     0 watchdog, 348614 multicast, 0 pause input
     30711440 packets output, 272109248 bytes, 0 underruns
     13525 unknown protocol drops
GigabitEthernet1/0/32 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a20 (bia f09e.63dc.2a20)
     6842935 packets input, 1386794645 bytes, 0 no buffer
     Received 338082 broadcasts (311998 multicasts)
     0 watchdog, 311998 multicast, 0 pause input
     28287446 packets output, 3162189183 bytes, 0 underruns
     14585 unknown protocol drops
GigabitEthernet1/0/33 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a21 (bia f09e.63dc.2a21)
  Last input 00:00:26, output never, output hang never
     3230603 packets input, 491838998 bytes, 0 no buffer
     Received 286330 broadcasts (278731 multicasts)
     0 watchdog, 278731 multicast, 0 pause input
     24291582 packets output, 724983704 bytes, 0 underruns
     2961 unknown protocol drops
GigabitEthernet1/0/34 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a22 (bia f09e.63dc.2a22)
     15240217 packets input, 39362594 bytes, 0 no buffer
     Received 363064 broadcasts (328191 multicasts)
     0 watchdog, 328191 multicast, 0 pause input
     37870443 packets output, 1176603763 bytes, 0 underruns
     19416 unknown protocol drops
GigabitEthernet1/0/35 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a23 (bia f09e.63dc.2a23)
     20604818 packets input, 1173539529 bytes, 0 no buffer
     Received 374456 broadcasts (332992 multicasts)
     0 watchdog, 332992 multicast, 0 pause input
     43411479 packets output, 2664011691 bytes, 0 underruns
     27200 unknown protocol drops
GigabitEthernet1/0/36 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a24 (bia f09e.63dc.2a24)
  5 minute input rate 41000 bits/sec, 23 packets/sec
  5 minute output rate 162000 bits/sec, 28 packets/sec
     104081627 packets input, 3965093890 bytes, 0 no buffer
     Received 364398 broadcasts (339411 multicasts)
     0 watchdog, 339411 multicast, 0 pause input
     128512309 packets output, 788716461 bytes, 0 underruns
     9073 unknown protocol drops
GigabitEthernet1/0/37 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a25 (bia f09e.63dc.2a25)
     1477302 packets input, 151068041 bytes, 0 no buffer
     Received 274677 broadcasts (271258 multicasts)
     0 watchdog, 271258 multicast, 0 pause input
     21777958 packets output, 2228728432 bytes, 0 underruns
GigabitEthernet1/0/38 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a26 (bia f09e.63dc.2a26)
     20866033 packets output, 2160744974 bytes, 0 underruns
GigabitEthernet1/0/39 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a27 (bia f09e.63dc.2a27)
  Last input 00:00:27, output never, output hang never
     18489807 packets input, 731751342 bytes, 0 no buffer
     Received 552789 broadcasts (414407 multicasts)
     0 watchdog, 414407 multicast, 0 pause input
     42518769 packets output, 3273865164 bytes, 0 underruns
     108784 unknown protocol drops
GigabitEthernet1/0/40 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a28 (bia f09e.63dc.2a28)
  Last input 00:00:05, output never, output hang never
  5 minute input rate 196000 bits/sec, 21 packets/sec
  5 minute output rate 63000 bits/sec, 25 packets/sec
     15379444 packets input, 919786980 bytes, 0 no buffer
     Received 652919 broadcasts (500599 multicasts)
     0 watchdog, 500599 multicast, 0 pause input
     36470149 packets output, 3433901843 bytes, 0 underruns
     106971 unknown protocol drops
GigabitEthernet1/0/41 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a29 (bia f09e.63dc.2a29)
  5 minute input rate 22000 bits/sec, 14 packets/sec
  5 minute output rate 127000 bits/sec, 18 packets/sec
     16238078 packets input, 441928971 bytes, 0 no buffer
     Received 371851 broadcasts (333674 multicasts)
     0 watchdog, 333674 multicast, 0 pause input
     39159974 packets output, 3101312798 bytes, 0 underruns
     23394 unknown protocol drops
GigabitEthernet1/0/42 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2a (bia f09e.63dc.2a2a)
  Last input 00:00:03, output never, output hang never
     20121530 packets input, 655686807 bytes, 0 no buffer
     Received 399740 broadcasts (345501 multicasts)
     0 watchdog, 345501 multicast, 0 pause input
     41583909 packets output, 2382436716 bytes, 0 underruns
     35944 unknown protocol drops
GigabitEthernet1/0/43 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2b (bia f09e.63dc.2a2b)
     403229 packets input, 149577010 bytes, 0 no buffer
     Received 7400 broadcasts (1572 multicasts)
     29397 input errors, 29397 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1572 multicast, 0 pause input
     13079381 packets output, 2698177996 bytes, 0 underruns
GigabitEthernet1/0/44 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2c (bia f09e.63dc.2a2c)
     3381205 packets input, 403780853 bytes, 0 no buffer
     Received 286818 broadcasts (279068 multicasts)
     0 watchdog, 279068 multicast, 0 pause input
     23666677 packets output, 3573791519 bytes, 0 underruns
     2780 unknown protocol drops
GigabitEthernet1/0/45 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2d (bia f09e.63dc.2a2d)
  5 minute output rate 221000 bits/sec, 17 packets/sec
     1180819 packets input, 81818758 bytes, 0 no buffer
     Received 50851 broadcasts (39649 multicasts)
     544 input errors, 544 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 39649 multicast, 0 pause input
     22504265 packets output, 3931821682 bytes, 0 underruns
GigabitEthernet1/0/46 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2e (bia f09e.63dc.2a2e)
  Last input 00:00:12, output never, output hang never
     6326144 packets input, 2015644784 bytes, 0 no buffer
     Received 327917 broadcasts (307489 multicasts)
     0 watchdog, 307489 multicast, 0 pause input
     27504777 packets output, 2672066848 bytes, 0 underruns
     10234 unknown protocol drops
GigabitEthernet1/0/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a2f (bia f09e.63dc.2a2f)
     8109267 packets input, 1887366061 bytes, 0 no buffer
     Received 352114 broadcasts (322026 multicasts)
     0 watchdog, 322026 multicast, 0 pause input
     28162399 packets output, 1072181533 bytes, 0 underruns
     16155 unknown protocol drops
GigabitEthernet1/0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a30 (bia f09e.63dc.2a30)
     20192721 packets input, 1304911193 bytes, 0 no buffer
     Received 193848 broadcasts (146233 multicasts)
     82 input errors, 82 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 146233 multicast, 0 pause input
     42856076 packets output, 3722659372 bytes, 0 underruns
     9061 unknown protocol drops
GigabitEthernet1/1/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a31 (bia f09e.63dc.2a31)
  Description: Trunk to 19th Floor Core
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  5 minute input rate 973000 bits/sec, 279 packets/sec
  5 minute output rate 334000 bits/sec, 87 packets/sec
     3776344496 packets input, 3457611659 bytes, 0 no buffer
     Received 335655190 broadcasts (221462698 multicasts)
     0 watchdog, 221462698 multicast, 0 pause input
     944158119 packets output, 1419605155 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     14133390 unknown protocol drops
GigabitEthernet1/1/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a32 (bia f09e.63dc.2a32)
  5 minute input rate 96000 bits/sec, 34 packets/sec
  5 minute output rate 210000 bits/sec, 116 packets/sec
     280605299 packets input, 3729147342 bytes, 0 no buffer
     Received 68642113 broadcasts (34731349 multicasts)
     0 watchdog, 34731349 multicast, 0 pause input
     1357148574 packets output, 4196454721 bytes, 0 underruns
     14277410 unknown protocol drops
GigabitEthernet1/1/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a33 (bia f09e.63dc.2a33)
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
GigabitEthernet1/1/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.2a34 (bia f09e.63dc.2a34)
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
  Hardware is not present
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.2a35 (bia f09e.63dc.2a35)
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.2a36 (bia f09e.63dc.2a36)
TenGigabitEthernet1/1/3 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.2a37 (bia f09e.63dc.2a37)
TenGigabitEthernet1/1/4 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.2a38 (bia f09e.63dc.2a38)
GigabitEthernet2/0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9501 (bia f09e.6343.9501)
  Last input 6w0d, output never, output hang never
     671 packets input, 166926 bytes, 0 no buffer
     Received 26 broadcasts (16 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 16 multicast, 0 pause input
     678 packets output, 164994 bytes, 0 underruns
GigabitEthernet2/0/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9502 (bia f09e.6343.9502)
GigabitEthernet2/0/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9503 (bia f09e.6343.9503)
GigabitEthernet2/0/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9504 (bia f09e.6343.9504)
GigabitEthernet2/0/5 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9505 (bia f09e.6343.9505)
GigabitEthernet2/0/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9506 (bia f09e.6343.9506)
     3579428 packets input, 218557193 bytes, 0 no buffer
     Received 5796 broadcasts (41 multicasts)
     689745 input errors, 689745 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 41 multicast, 1 pause input
     32802260 packets output, 2828965235 bytes, 0 underruns
GigabitEthernet2/0/7 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9507 (bia f09e.6343.9507)
GigabitEthernet2/0/8 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9508 (bia f09e.6343.9508)
GigabitEthernet2/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9509 (bia f09e.6343.9509)
     20406643 packets input, 1763294461 bytes, 0 no buffer
     Received 362268 broadcasts (324362 multicasts)
     0 watchdog, 324362 multicast, 0 pause input
     43483006 packets output, 887419917 bytes, 0 underruns
     23982 unknown protocol drops
GigabitEthernet2/0/10 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.950a (bia f09e.6343.950a)
GigabitEthernet2/0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.950b (bia f09e.6343.950b)
     1581417 packets input, 174014391 bytes, 0 no buffer
     Received 274710 broadcasts (271260 multicasts)
     0 watchdog, 271260 multicast, 0 pause input
     21881533 packets output, 2251683246 bytes, 0 underruns
     39 unknown protocol drops
GigabitEthernet2/0/12 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.950c (bia f09e.6343.950c)
     626425 packets input, 48291768 bytes, 0 no buffer
     Received 71028 broadcasts (63886 multicasts)
     55 input errors, 55 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 63886 multicast, 0 pause input
     21641688 packets output, 2679733216 bytes, 0 underruns
GigabitEthernet2/0/13 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.950d (bia f09e.6343.950d)
     17130819 packets input, 3432374357 bytes, 0 no buffer
     Received 318953 broadcasts (301164 multicasts)
     0 watchdog, 301164 multicast, 0 pause input
     38235283 packets output, 1085574130 bytes, 0 underruns
     9339 unknown protocol drops
GigabitEthernet2/0/14 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.950e (bia f09e.6343.950e)
  Last input 15:14:28, output never, output hang never
     1150905 packets input, 600176159 bytes, 0 no buffer
     Received 14612 broadcasts (9842 multicasts)
     39935 input errors, 39935 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 9842 multicast, 0 pause input
     2540234 packets output, 993612523 bytes, 0 underruns
     2674 unknown protocol drops
GigabitEthernet2/0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.950f (bia f09e.6343.950f)
     16811642 packets input, 3482926228 bytes, 0 no buffer
     Received 439843 broadcasts (370291 multicasts)
     0 watchdog, 370291 multicast, 0 pause input
     41335901 packets output, 902821871 bytes, 0 underruns
     48283 unknown protocol drops
GigabitEthernet2/0/16 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9510 (bia f09e.6343.9510)
GigabitEthernet2/0/17 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9511 (bia f09e.6343.9511)
     9301872 packets input, 1848010647 bytes, 0 no buffer
     Received 149000 broadcasts (135673 multicasts)
     6566 input errors, 6566 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 135673 multicast, 0 pause input
     29680902 packets output, 3969608827 bytes, 0 underruns
GigabitEthernet2/0/18 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9512 (bia f09e.6343.9512)
  Last input 9w0d, output never, output hang never
     11335134 packets input, 2341906081 bytes, 0 no buffer
     Received 63319 broadcasts (55182 multicasts)
     3430 input errors, 3430 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 55182 multicast, 0 pause input
     16349654 packets output, 3691401768 bytes, 0 underruns
     4671 unknown protocol drops
GigabitEthernet2/0/19 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9513 (bia f09e.6343.9513)
     18041747 packets input, 3480593229 bytes, 0 no buffer
     Received 350967 broadcasts (320858 multicasts)
     0 watchdog, 320858 multicast, 0 pause input
     39170691 packets output, 302463192 bytes, 0 underruns
     17581 unknown protocol drops
GigabitEthernet2/0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9514 (bia f09e.6343.9514)
     13918538 packets input, 3379325890 bytes, 0 no buffer
     Received 347621 broadcasts (315745 multicasts)
     0 watchdog, 315745 multicast, 0 pause input
     37220284 packets output, 1845818446 bytes, 0 underruns
     20087 unknown protocol drops
GigabitEthernet2/0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9515 (bia f09e.6343.9515)
     reliability 254/255, txload 1/255, rxload 1/255
  Last input 7w0d, output never, output hang never
     267870 packets input, 285546158 bytes, 0 no buffer
     Received 4596 broadcasts (3544 multicasts)
     3805 input errors, 3805 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3544 multicast, 0 pause input
     1107806 packets output, 227695755 bytes, 0 underruns
     860 unknown protocol drops
GigabitEthernet2/0/22 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9516 (bia f09e.6343.9516)
GigabitEthernet2/0/23 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9517 (bia f09e.6343.9517)
GigabitEthernet2/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9518 (bia f09e.6343.9518)
  Last input 00:00:08, output never, output hang never
     20126971 packets input, 4111105996 bytes, 0 no buffer
     Received 347809 broadcasts (322273 multicasts)
     0 watchdog, 322273 multicast, 0 pause input
     40223173 packets output, 4007248305 bytes, 0 underruns
     12917 unknown protocol drops
GigabitEthernet2/0/25 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9519 (bia f09e.6343.9519)
GigabitEthernet2/0/26 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.951a (bia f09e.6343.951a)
     28616324 packets input, 3082726016 bytes, 0 no buffer
     Received 348937 broadcasts (314795 multicasts)
     0 watchdog, 314795 multicast, 0 pause input
     52641568 packets output, 3945102352 bytes, 0 underruns
     23338 unknown protocol drops
GigabitEthernet2/0/27 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.951b (bia f09e.6343.951b)
GigabitEthernet2/0/28 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.951c (bia f09e.6343.951c)
  5 minute input rate 56000 bits/sec, 21 packets/sec
  5 minute output rate 33000 bits/sec, 21 packets/sec
     8766519 packets input, 2378410013 bytes, 0 no buffer
     Received 320079 broadcasts (298910 multicasts)
     0 watchdog, 298910 multicast, 0 pause input
     29753574 packets output, 2086783071 bytes, 0 underruns
     12569 unknown protocol drops
GigabitEthernet2/0/29 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.951d (bia f09e.6343.951d)
  Last input 6w2d, output never, output hang never
     9228327 packets input, 1834728023 bytes, 0 no buffer
     Received 88193 broadcasts (80964 multicasts)
     109 input errors, 109 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 80964 multicast, 0 pause input
     20338234 packets output, 4293979098 bytes, 0 underruns
     3648 unknown protocol drops
GigabitEthernet2/0/30 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.951e (bia f09e.6343.951e)
GigabitEthernet2/0/31 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.951f (bia f09e.6343.951f)
  Last input 00:00:24, output never, output hang never
     582286 packets input, 45857210 bytes, 0 no buffer
     Received 77364 broadcasts (69440 multicasts)
     6 input errors, 6 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 69440 multicast, 0 pause input
     21626694 packets output, 2708765341 bytes, 0 underruns
GigabitEthernet2/0/32 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9520 (bia f09e.6343.9520)
  Last input 00:00:25, output never, output hang never
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 4000 bits/sec, 6 packets/sec
     18314770 packets input, 262339217 bytes, 0 no buffer
     Received 206664 broadcasts (161140 multicasts)
     62 input errors, 62 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 161140 multicast, 0 pause input
     39945737 packets output, 3384092158 bytes, 0 underruns
     13513 unknown protocol drops
GigabitEthernet2/0/33 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9521 (bia f09e.6343.9521)
     26407584 packets input, 2517812676 bytes, 0 no buffer
     Received 465767 broadcasts (429383 multicasts)
     0 watchdog, 429383 multicast, 0 pause input
     50195201 packets output, 215509315 bytes, 0 underruns
     23600 unknown protocol drops
GigabitEthernet2/0/34 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9522 (bia f09e.6343.9522)
  5 minute input rate 11000 bits/sec, 9 packets/sec
  5 minute output rate 13000 bits/sec, 11 packets/sec
     23033215 packets input, 784099796 bytes, 0 no buffer
     Received 462664 broadcasts (432624 multicasts)
     0 watchdog, 432624 multicast, 0 pause input
     41137588 packets output, 1058041828 bytes, 0 underruns
     23803 unknown protocol drops
GigabitEthernet2/0/35 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9523 (bia f09e.6343.9523)
     28392040 packets input, 284655321 bytes, 0 no buffer
     Received 1254402 broadcasts (311225 multicasts)
     0 watchdog, 311225 multicast, 0 pause input
     49749891 packets output, 2770970009 bytes, 0 underruns
     922328 unknown protocol drops
GigabitEthernet2/0/36 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9524 (bia f09e.6343.9524)
     8195396 packets input, 1959466655 bytes, 0 no buffer
     Received 326603 broadcasts (305717 multicasts)
     0 watchdog, 305717 multicast, 0 pause input
     29034003 packets output, 1456949913 bytes, 0 underruns
     12941 unknown protocol drops
GigabitEthernet2/0/37 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9525 (bia f09e.6343.9525)
     620131 packets input, 49267185 bytes, 0 no buffer
     Received 83362 broadcasts (74955 multicasts)
     8 input errors, 8 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 74955 multicast, 0 pause input
     21578012 packets output, 2592191047 bytes, 0 underruns
GigabitEthernet2/0/38 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9526 (bia f09e.6343.9526)
     606076 packets input, 47441757 bytes, 0 no buffer
     Received 75650 broadcasts (73810 multicasts)
     47 input errors, 47 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 73810 multicast, 0 pause input
     21526736 packets output, 2535894936 bytes, 0 underruns
GigabitEthernet2/0/39 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9527 (bia f09e.6343.9527)
     499583 packets input, 82451319 bytes, 0 no buffer
     Received 14713 broadcasts (13532 multicasts)
     751 input errors, 751 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 13532 multicast, 0 pause input
     21260699 packets output, 2213356604 bytes, 0 underruns
     404 unknown protocol drops
GigabitEthernet2/0/40 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9528 (bia f09e.6343.9528)
     672891 packets input, 62728323 bytes, 0 no buffer
     Received 82188 broadcasts (74519 multicasts)
     1109 input errors, 1109 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 74519 multicast, 0 pause input
     21778273 packets output, 2891205000 bytes, 0 underruns
GigabitEthernet2/0/41 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9529 (bia f09e.6343.9529)
  Last input 8w5d, output never, output hang never
     6612594 packets input, 1374604325 bytes, 0 no buffer
     Received 4597 broadcasts (3167 multicasts)
     8226 input errors, 8226 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 3167 multicast, 0 pause input
     2944803 packets output, 665571182 bytes, 0 underruns
     999 unknown protocol drops
GigabitEthernet2/0/42 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.952a (bia f09e.6343.952a)
     3805756 packets input, 829500747 bytes, 0 no buffer
     Received 134255 broadcasts (134252 multicasts)
     0 watchdog, 134252 multicast, 0 pause input
     24405034 packets output, 2953241461 bytes, 0 underruns
GigabitEthernet2/0/43 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.952b (bia f09e.6343.952b)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
     10850323 packets input, 2240256148 bytes, 0 no buffer
     Received 116395 broadcasts (105899 multicasts)
     8183 input errors, 8183 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 105899 multicast, 0 pause input
     27421062 packets output, 3976409244 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
GigabitEthernet2/0/44 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.952c (bia f09e.6343.952c)
     34804831 packets input, 1306233728 bytes, 0 no buffer
     Received 417384 broadcasts (332139 multicasts)
     0 watchdog, 332139 multicast, 0 pause input
     60187931 packets output, 869290604 bytes, 0 underruns
     46170 unknown protocol drops
GigabitEthernet2/0/45 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.952d (bia f09e.6343.952d)
  Last input 5w1d, output never, output hang never
     612065 packets input, 146476699 bytes, 0 no buffer
     Received 61434 broadcasts (57981 multicasts)
     2852 input errors, 2852 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 57981 multicast, 0 pause input
     9964362 packets output, 1228245221 bytes, 0 underruns
     3355 unknown protocol drops
GigabitEthernet2/0/46 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.952e (bia f09e.6343.952e)
  Last input 00:00:15, output never, output hang never
     1491965 packets input, 154352866 bytes, 0 no buffer
     Received 274686 broadcasts (271265 multicasts)
     0 watchdog, 271265 multicast, 0 pause input
     21793181 packets output, 2232114958 bytes, 0 underruns
GigabitEthernet2/0/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.952f (bia f09e.6343.952f)
  Last input 00:00:23, output never, output hang never
     15944230 packets input, 262971951 bytes, 0 no buffer
     Received 327670 broadcasts (307178 multicasts)
     0 watchdog, 307178 multicast, 0 pause input
     39115982 packets output, 2299860470 bytes, 0 underruns
     8619 unknown protocol drops
GigabitEthernet2/0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.6343.9530 (bia f09e.6343.9530)
     16168252 packets input, 3546662302 bytes, 0 no buffer
     Received 337438 broadcasts (309569 multicasts)
     0 watchdog, 309569 multicast, 0 pause input
     37054825 packets output, 3482124718 bytes, 0 underruns
     15733 unknown protocol drops
GigabitEthernet2/1/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9531 (bia f09e.6343.9531)
GigabitEthernet2/1/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9532 (bia f09e.6343.9532)
GigabitEthernet2/1/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9533 (bia f09e.6343.9533)
GigabitEthernet2/1/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.6343.9534 (bia f09e.6343.9534)
TenGigabitEthernet2/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.6343.9535 (bia f09e.6343.9535)
TenGigabitEthernet2/1/2 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.6343.9536 (bia f09e.6343.9536)
TenGigabitEthernet2/1/3 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.6343.9537 (bia f09e.6343.9537)
TenGigabitEthernet2/1/4 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.6343.9538 (bia f09e.6343.9538)
GigabitEthernet3/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a381 (bia f09e.63dc.a381)
  Description: WAP
  5 minute input rate 5000 bits/sec, 1 packets/sec
  5 minute output rate 37000 bits/sec, 20 packets/sec
     105111032 packets input, 3211646888 bytes, 0 no buffer
     Received 407424 broadcasts (407281 multicasts)
     0 watchdog, 407281 multicast, 0 pause input
     308279840 packets output, 371337021 bytes, 0 underruns
GigabitEthernet3/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a382 (bia f09e.63dc.a382)
  Description: WAP
  5 minute input rate 4000 bits/sec, 3 packets/sec
  5 minute output rate 9000 bits/sec, 7 packets/sec
     31260524 packets input, 527147186 bytes, 0 no buffer
     Received 407518 broadcasts (407375 multicasts)
     0 watchdog, 407375 multicast, 0 pause input
     122986883 packets output, 1610142886 bytes, 0 underruns
GigabitEthernet3/0/3 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a383 (bia f09e.63dc.a383)
  Description: WAP
  5 minute input rate 3000 bits/sec, 2 packets/sec
     38239760 packets input, 93063955 bytes, 0 no buffer
     Received 407426 broadcasts (407283 multicasts)
     0 watchdog, 407283 multicast, 0 pause input
     162473987 packets output, 4073414372 bytes, 0 underruns
GigabitEthernet3/0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a384 (bia f09e.63dc.a384)
  Description: WAP
  5 minute output rate 27000 bits/sec, 19 packets/sec
     83503778 packets input, 3482791204 bytes, 0 no buffer
     Received 407433 broadcasts (407290 multicasts)
     0 watchdog, 407290 multicast, 0 pause input
     275262537 packets output, 1481113555 bytes, 0 underruns
GigabitEthernet3/0/5 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a385 (bia f09e.63dc.a385)
  Description: WAP
GigabitEthernet3/0/6 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a386 (bia f09e.63dc.a386)
  Description: WAP
GigabitEthernet3/0/7 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a387 (bia f09e.63dc.a387)
  Description: WAP
  Last input 22:47:14, output never, output hang never
     107312477 packets input, 3858676243 bytes, 0 no buffer
     Received 403416 broadcasts (403259 multicasts)
     0 watchdog, 403259 multicast, 0 pause input
     309226677 packets output, 3733106863 bytes, 0 underruns
GigabitEthernet3/0/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a388 (bia f09e.63dc.a388)
     18339114 packets input, 98313613 bytes, 0 no buffer
     Received 739450 broadcasts (569037 multicasts)
     0 watchdog, 569037 multicast, 0 pause input
     39753919 packets output, 827247497 bytes, 0 underruns
     122625 unknown protocol drops
GigabitEthernet3/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a389 (bia f09e.63dc.a389)
     32759784 packets input, 3903234960 bytes, 0 no buffer
     Received 487397 broadcasts (323093 multicasts)
     0 watchdog, 323093 multicast, 0 pause input
     54535782 packets output, 2777347578 bytes, 0 underruns
     152503 unknown protocol drops
GigabitEthernet3/0/10 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38a (bia f09e.63dc.a38a)
     18345721 packets input, 4158395998 bytes, 0 no buffer
     Received 500430 broadcasts (321336 multicasts)
     0 watchdog, 321336 multicast, 0 pause input
     39215778 packets output, 1050931624 bytes, 0 underruns
     167529 unknown protocol drops
GigabitEthernet3/0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38b (bia f09e.63dc.a38b)
  5 minute output rate 6000 bits/sec, 7 packets/sec
     6028490 packets input, 1630067633 bytes, 0 no buffer
     Received 261577 broadcasts (177457 multicasts)
     2015 input errors, 2015 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 177457 multicast, 0 pause input
     47395497 packets output, 4029758762 bytes, 0 underruns
GigabitEthernet3/0/12 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38c (bia f09e.63dc.a38c)
     19577813 packets input, 847557515 bytes, 0 no buffer
     Received 513158 broadcasts (324275 multicasts)
     0 watchdog, 324275 multicast, 0 pause input
     41317696 packets output, 1467046456 bytes, 0 underruns
     176670 unknown protocol drops
GigabitEthernet3/0/13 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38d (bia f09e.63dc.a38d)
     6654035 packets input, 1632907387 bytes, 0 no buffer
     Received 302929 broadcasts (287931 multicasts)
     0 watchdog, 287931 multicast, 0 pause input
     27582976 packets output, 1078310954 bytes, 0 underruns
     8524 unknown protocol drops
GigabitEthernet3/0/14 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38e (bia f09e.63dc.a38e)
  5 minute input rate 51000 bits/sec, 32 packets/sec
  5 minute output rate 60000 bits/sec, 34 packets/sec
     12107716 packets input, 2672299556 bytes, 0 no buffer
     Received 441327 broadcasts (311656 multicasts)
     0 watchdog, 311656 multicast, 0 pause input
     33301276 packets output, 482219488 bytes, 0 underruns
     118268 unknown protocol drops
GigabitEthernet3/0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a38f (bia f09e.63dc.a38f)
     13109669 packets input, 1688090262 bytes, 0 no buffer
     Received 339215 broadcasts (309160 multicasts)
     0 watchdog, 309160 multicast, 0 pause input
     34905502 packets output, 1906240385 bytes, 0 underruns
     19530 unknown protocol drops
GigabitEthernet3/0/16 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a390 (bia f09e.63dc.a390)
  Last input 1w0d, output never, output hang never
     12267885 packets input, 2099669315 bytes, 0 no buffer
     Received 181436 broadcasts (132324 multicasts)
     6971 input errors, 6971 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 132324 multicast, 0 pause input
     37344601 packets output, 3802557424 bytes, 0 underruns
     21928 unknown protocol drops
GigabitEthernet3/0/17 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a391 (bia f09e.63dc.a391)
     10176233 packets input, 2282431942 bytes, 0 no buffer
     Received 433744 broadcasts (375135 multicasts)
     0 watchdog, 375135 multicast, 0 pause input
     30295129 packets output, 546924067 bytes, 0 underruns
     39362 unknown protocol drops
GigabitEthernet3/0/18 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a392 (bia f09e.63dc.a392)
     18821959 packets input, 59766291 bytes, 0 no buffer
     Received 397037 broadcasts (351447 multicasts)
     0 watchdog, 351447 multicast, 0 pause input
     42532197 packets output, 2988401764 bytes, 0 underruns
     32413 unknown protocol drops
GigabitEthernet3/0/19 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a393 (bia f09e.63dc.a393)
     7011959 packets input, 1556172389 bytes, 0 no buffer
     Received 220420 broadcasts (210492 multicasts)
     0 watchdog, 210492 multicast, 0 pause input
     29264178 packets output, 31389166 bytes, 0 underruns
     4295 unknown protocol drops
GigabitEthernet3/0/20 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a394 (bia f09e.63dc.a394)
     21162791 packets input, 2298050538 bytes, 0 no buffer
     Received 355796 broadcasts (325645 multicasts)
     0 watchdog, 325645 multicast, 0 pause input
     45375044 packets output, 2959962377 bytes, 0 underruns
     13157 unknown protocol drops
GigabitEthernet3/0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a395 (bia f09e.63dc.a395)
GigabitEthernet3/0/22 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a396 (bia f09e.63dc.a396)
GigabitEthernet3/0/23 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a397 (bia f09e.63dc.a397)
  Last input 20:59:34, output never, output hang never
     729981 packets input, 75806590 bytes, 0 no buffer
     Received 146809 broadcasts (121101 multicasts)
     44 input errors, 44 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 121101 multicast, 0 pause input
     9509649 packets output, 994377568 bytes, 0 underruns
     290 unknown protocol drops
GigabitEthernet3/0/24 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a398 (bia f09e.63dc.a398)
GigabitEthernet3/0/25 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a399 (bia f09e.63dc.a399)
GigabitEthernet3/0/26 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39a (bia f09e.63dc.a39a)
  5 minute input rate 23000 bits/sec, 15 packets/sec
  5 minute output rate 45000 bits/sec, 21 packets/sec
     41842780 packets input, 1834380958 bytes, 0 no buffer
     Received 577430 broadcasts (332480 multicasts)
     0 watchdog, 332480 multicast, 0 pause input
     96595704 packets output, 2759957336 bytes, 0 underruns
GigabitEthernet3/0/27 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39b (bia f09e.63dc.a39b)
GigabitEthernet3/0/28 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39c (bia f09e.63dc.a39c)
GigabitEthernet3/0/29 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39d (bia f09e.63dc.a39d)
     29654033 packets input, 885200771 bytes, 0 no buffer
     Received 370044 broadcasts (332950 multicasts)
     0 watchdog, 332950 multicast, 0 pause input
     60904098 packets output, 845767502 bytes, 0 underruns
     21175 unknown protocol drops
GigabitEthernet3/0/30 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39e (bia f09e.63dc.a39e)
GigabitEthernet3/0/31 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a39f (bia f09e.63dc.a39f)
     32391440 packets input, 2247334816 bytes, 0 no buffer
     Received 356288 broadcasts (330662 multicasts)
     0 watchdog, 330662 multicast, 0 pause input
     69386211 packets output, 4097967081 bytes, 0 underruns
     13347 unknown protocol drops
GigabitEthernet3/0/32 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a0 (bia f09e.63dc.a3a0)
  Last input 00:00:17, output never, output hang never
     192908724 packets input, 483618215 bytes, 0 no buffer
     Received 400166 broadcasts (332018 multicasts)
     0 watchdog, 332018 multicast, 0 pause input
     197858218 packets output, 194470807 bytes, 0 underruns
     52827 unknown protocol drops
GigabitEthernet3/0/33 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a1 (bia f09e.63dc.a3a1)
GigabitEthernet3/0/34 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a2 (bia f09e.63dc.a3a2)
     16942366 packets input, 1610688811 bytes, 0 no buffer
     Received 355994 broadcasts (323306 multicasts)
     0 watchdog, 323306 multicast, 0 pause input
     39103735 packets output, 2219181340 bytes, 0 underruns
     17399 unknown protocol drops
GigabitEthernet3/0/35 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a3 (bia f09e.63dc.a3a3)
     19270241 packets input, 1894838176 bytes, 0 no buffer
     Received 303892 broadcasts (293369 multicasts)
     0 watchdog, 293369 multicast, 0 pause input
     40453590 packets output, 1411984383 bytes, 0 underruns
     4461 unknown protocol drops
GigabitEthernet3/0/36 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a4 (bia f09e.63dc.a3a4)
     9794487 packets input, 2026163434 bytes, 0 no buffer
     Received 296601 broadcasts (283503 multicasts)
     0 watchdog, 283503 multicast, 0 pause input
     34818975 packets output, 1381209118 bytes, 0 underruns
     6729 unknown protocol drops
GigabitEthernet3/0/37 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a5 (bia f09e.63dc.a3a5)
     711105 packets input, 55094300 bytes, 0 no buffer
     Received 83213 broadcasts (74630 multicasts)
     17 input errors, 17 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 74630 multicast, 0 pause input
     24043996 packets output, 2036889382 bytes, 0 underruns
     12 unknown protocol drops
GigabitEthernet3/0/38 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a6 (bia f09e.63dc.a3a6)
     17112081 packets input, 1786890851 bytes, 0 no buffer
     Received 357540 broadcasts (327478 multicasts)
     0 watchdog, 327478 multicast, 0 pause input
     43269622 packets output, 3507702960 bytes, 0 underruns
     14942 unknown protocol drops
GigabitEthernet3/0/39 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a7 (bia f09e.63dc.a3a7)
GigabitEthernet3/0/40 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a8 (bia f09e.63dc.a3a8)
     6517610 packets input, 2059454125 bytes, 0 no buffer
     Received 424244 broadcasts (374590 multicasts)
     0 watchdog, 374590 multicast, 0 pause input
     26802629 packets output, 403546448 bytes, 0 underruns
     31170 unknown protocol drops
GigabitEthernet3/0/41 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3a9 (bia f09e.63dc.a3a9)
  Last input 1w6d, output never, output hang never
     75237939 packets input, 1468593908 bytes, 0 no buffer
     Received 156119 broadcasts (135282 multicasts)
     4575 input errors, 4575 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 135282 multicast, 0 pause input
     79193675 packets output, 1018632573 bytes, 0 underruns
     17282 unknown protocol drops
GigabitEthernet3/0/42 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3aa (bia f09e.63dc.a3aa)
     17059310 packets input, 3589136963 bytes, 0 no buffer
     Received 368763 broadcasts (322509 multicasts)
     0 watchdog, 322509 multicast, 0 pause input
     41477904 packets output, 1075515132 bytes, 0 underruns
     32291 unknown protocol drops
GigabitEthernet3/0/43 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3ab (bia f09e.63dc.a3ab)
     3546216 packets input, 845627288 bytes, 0 no buffer
     Received 225329 broadcasts (215938 multicasts)
     0 watchdog, 215938 multicast, 0 pause input
     24416829 packets output, 98873331 bytes, 0 underruns
     4558 unknown protocol drops
GigabitEthernet3/0/44 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3ac (bia f09e.63dc.a3ac)
     40753002 packets input, 515376780 bytes, 0 no buffer
     Received 384937 broadcasts (349843 multicasts)
     0 watchdog, 349843 multicast, 0 pause input
     70787847 packets output, 808553844 bytes, 0 underruns
     22645 unknown protocol drops
GigabitEthernet3/0/45 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3ad (bia f09e.63dc.a3ad)
     1342304 packets input, 443591604 bytes, 0 no buffer
     Received 87072 broadcasts (80632 multicasts)
     0 watchdog, 80632 multicast, 0 pause input
     6660996 packets output, 1215095379 bytes, 0 underruns
     3508 unknown protocol drops
GigabitEthernet3/0/46 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3ae (bia f09e.63dc.a3ae)
     43619582 packets input, 1334487874 bytes, 0 no buffer
     Received 350344 broadcasts (319820 multicasts)
     0 watchdog, 319820 multicast, 0 pause input
     87619669 packets output, 577788983 bytes, 0 underruns
     18018 unknown protocol drops
GigabitEthernet3/0/47 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3af (bia f09e.63dc.a3af)
  5 minute input rate 9000 bits/sec, 4 packets/sec
  5 minute output rate 51000 bits/sec, 32 packets/sec
     6207178 packets input, 1759280049 bytes, 0 no buffer
     Received 113170 broadcasts (70433 multicasts)
     16798 input errors, 16798 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 70433 multicast, 0 pause input
     15126773 packets output, 2906622075 bytes, 0 underruns
     36696 unknown protocol drops
GigabitEthernet3/0/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3b0 (bia f09e.63dc.a3b0)
     36840709 packets input, 696511096 bytes, 0 no buffer
     Received 401157 broadcasts (367185 multicasts)
     0 watchdog, 367185 multicast, 0 pause input
     70928116 packets output, 3603284361 bytes, 0 underruns
     20312 unknown protocol drops
GigabitEthernet3/1/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3b1 (bia f09e.63dc.a3b1)
GigabitEthernet3/1/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3b2 (bia f09e.63dc.a3b2)
GigabitEthernet3/1/3 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3b3 (bia f09e.63dc.a3b3)
GigabitEthernet3/1/4 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is f09e.63dc.a3b4 (bia f09e.63dc.a3b4)
TenGigabitEthernet3/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.a3b5 (bia f09e.63dc.a3b5)
TenGigabitEthernet3/1/2 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.a3b6 (bia f09e.63dc.a3b6)
TenGigabitEthernet3/1/3 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.a3b7 (bia f09e.63dc.a3b7)
TenGigabitEthernet3/1/4 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is f09e.63dc.a3b8 (bia f09e.63dc.a3b8)
GigabitEthernet4/0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 0000.0000.0000 (bia 0000.0000.0000)
GigabitEthernet4/0/2 is down, line protocol is down (notconnect)
GigabitEthernet4/0/3 is down, line protocol is down (notconnect)
GigabitEthernet4/0/4 is down, line protocol is down (notconnect)
GigabitEthernet4/0/5 is down, line protocol is down (notconnect)
GigabitEthernet4/0/6 is down, line protocol is down (notconnect)
GigabitEthernet4/0/7 is down, line protocol is down (notconnect)
GigabitEthernet4/0/8 is down, line protocol is down (notconnect)
GigabitEthernet4/0/9 is down, line protocol is down (notconnect)
GigabitEthernet4/0/10 is down, line protocol is down (notconnect)
GigabitEthernet4/0/11 is down, line protocol is down (notconnect)
GigabitEthernet4/0/12 is down, line protocol is down (notconnect)
GigabitEthernet4/0/13 is down, line protocol is down (notconnect)
GigabitEthernet4/0/14 is down, line protocol is down (notconnect)
GigabitEthernet4/0/15 is down, line protocol is down (notconnect)
GigabitEthernet4/0/16 is down, line protocol is down (notconnect)
GigabitEthernet4/0/17 is down, line protocol is down (notconnect)
GigabitEthernet4/0/18 is down, line protocol is down (notconnect)
GigabitEthernet4/0/19 is down, line protocol is down (notconnect)
GigabitEthernet4/0/20 is down, line protocol is down (notconnect)
GigabitEthernet4/0/21 is down, line protocol is down (notconnect)
GigabitEthernet4/0/22 is down, line protocol is down (notconnect)
GigabitEthernet4/0/23 is down, line protocol is down (notconnect)
GigabitEthernet4/0/24 is down, line protocol is down (notconnect)
GigabitEthernet4/0/25 is down, line protocol is down (notconnect)
GigabitEthernet4/0/26 is down, line protocol is down (notconnect)
GigabitEthernet4/0/27 is down, line protocol is down (notconnect)
GigabitEthernet4/0/28 is down, line protocol is down (notconnect)
GigabitEthernet4/0/29 is down, line protocol is down (notconnect)
GigabitEthernet4/0/30 is down, line protocol is down (notconnect)
GigabitEthernet4/0/31 is down, line protocol is down (notconnect)
GigabitEthernet4/0/32 is down, line protocol is down (notconnect)
GigabitEthernet4/0/33 is down, line protocol is down (notconnect)
GigabitEthernet4/0/34 is down, line protocol is down (notconnect)
GigabitEthernet4/0/35 is down, line protocol is down (notconnect)
GigabitEthernet4/0/36 is down, line protocol is down (notconnect)
GigabitEthernet4/0/37 is down, line protocol is down (notconnect)
GigabitEthernet4/0/38 is down, line protocol is down (notconnect)
GigabitEthernet4/0/39 is down, line protocol is down (notconnect)
GigabitEthernet4/0/40 is down, line protocol is down (notconnect)
GigabitEthernet4/0/41 is down, line protocol is down (notconnect)
GigabitEthernet4/0/42 is down, line protocol is down (notconnect)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
GigabitEthernet4/0/43 is down, line protocol is down (notconnect)
GigabitEthernet4/0/44 is down, line protocol is down (notconnect)
GigabitEthernet4/0/45 is down, line protocol is down (notconnect)
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
GigabitEthernet4/0/46 is down, line protocol is down (notconnect)
GigabitEthernet4/0/47 is down, line protocol is down (notconnect)
GigabitEthernet4/0/48 is down, line protocol is down (notconnect)
GigabitEthernet4/1/1 is down, line protocol is down (notconnect)
GigabitEthernet4/1/2 is down, line protocol is down (notconnect)
GigabitEthernet4/1/3 is down, line protocol is down (notconnect)
  Keepalive set (10 sec)
GigabitEthernet4/1/4 is down, line protocol is down (notconnect)
TenGigabitEthernet4/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is 0000.0000.0000 (bia 0000.0000.0000)
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
TenGigabitEthernet4/1/2 is down, line protocol is down (notconnect)
TenGigabitEthernet4/1/3 is down, line protocol is down (notconnect)
TenGigabitEthernet4/1/4 is down, line protocol is down (notconnect)
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is f09e.63dc.2a31 (bia f09e.63dc.2a31)
  Description: Trunk
  MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/1/1 Gi1/1/2
  Last input 00:00:00, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 1076000 bits/sec, 315 packets/sec
  5 minute output rate 546000 bits/sec, 201 packets/sec
     4056949795 packets input, 2891791705 bytes, 0 no buffer
     Received 404297303 broadcasts (256194047 multicasts)
     0 watchdog, 256194047 multicast, 0 pause input
     2301306693 packets output, 1321092580 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
------------------ show interfaces history ------------------
------------------ show controllers ------------------
Transmit                  GigabitEthernet1/0/1          Receive
      8433342 Total bytes                     2160144 Total bytes
        13240 Unicast frames                    12066 Unicast frames
      7490843 Unicast bytes                   1674613 Unicast bytes
        11339 Multicast frames                   1390 Multicast frames
       882395 Multicast bytes                  197391 Multicast bytes
          579 Broadcast frames                   2624 Broadcast frames
        60104 Broadcast bytes                  288140 Broadcast bytes
            0 System FCS error frames               0 IpgViolation frames
            0 MacUnderrun frames                    0 MacOverrun frames
            0 Pause frames                          0 Pause frames
            0 Cos 0 Pause frames                    0 Cos 0 Pause frames
            0 Cos 1 Pause frames                    0 Cos 1 Pause frames
            0 Cos 2 Pause frames                    0 Cos 2 Pause frames
            0 Cos 3 Pause frames                    0 Cos 3 Pause frames
            0 Cos 4 Pause frames                    0 Cos 4 Pause frames
            0 Cos 5 Pause frames                    0 Cos 5 Pause frames
            0 Cos 6 Pause frames                    0 Cos 6 Pause frames
            0 Cos 7 Pause frames                    0 Cos 7 Pause frames
            0 Oam frames                            0 OamProcessed frames
            0 Oam frames                            0 OamDropped frames
         4320 Minimum size frames                4291 Minimum size frames
        13445 65 to 127 byte frames              8973 65 to 127 byte frames
         1979 128 to 255 byte frames             1142 128 to 255 byte frames
          951 256 to 511 byte frames              787 256 to 511 byte frames
          138 512 to 1023 byte frames             823 512 to 1023 byte frames
         4268 1024 to 1518 byte frames             64 1024 to 1518 byte frames
           57 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 2048 to 4095 byte frames              0 2048 to 4095 byte frames
            0 4096 to 8191 byte frames              0 4096 to 8191 byte frames
            0 8192 to 16383 byte frames             0 8192 to 16383 byte frames
            0 16384 to 32767 byte frame             0 16384 to 32767 byte frame
            0 > 32768 byte frames                   0 > 32768 byte frames
            0 Late collision frames                 0 SymbolErr frames
            0 Excess Defer frames                   0 Collision fragments
            0 Good (1 coll) frames                  0 ValidUnderSize frames
            0 Good (>1 coll) frames                 0 InvalidOverSize frames
            0 Deferred frames                       0 ValidOverSize frames
            0 Gold frames dropped                   0 FcsErr frames
            0 Gold frames truncated
            0 Gold frames successful
            0 1 collision frames
            0 2 collision frames
            0 3 collision frames
            0 4 collision frames
            0 5 collision frames
            0 6 collision frames
            0 7 collision frames
            0 8 collision frames
            0 9 collision frames
            0 10 collision frames
            0 11 collision frames
            0 12 collision frames
            0 13 collision frames
            0 14 collision frames
            0 15 collision frames
            0 Excess collision frames
LAST UPDATE 2590 msecs AGO
Transmit                  GigabitEthernet1/0/2          Receive
  12006767136 Total bytes                  2263983938 Total bytes
     14158112 Unicast frames                 10438151 Unicast frames
   9986879368 Unicast bytes                2197982877 Unicast bytes
     14227607 Multicast frames                 300329 Multicast frames
   1528767530 Multicast bytes                64089329 Multicast bytes
      4732860 Broadcast frames                  18487 Broadcast frames
    491120238 Broadcast bytes                 1911732 Broadcast bytes
      4047021 Minimum size frames             3932131 Minimum size frames
     14776550 65 to 127 byte frames           1973744 65 to 127 byte frames
      7674434 128 to 255 byte frames          3611107 128 to 255 byte frames
       625733 256 to 511 byte frames           508595 256 to 511 byte frames
       200919 512 to 1023 byte frames          189131 512 to 1023 byte frames
      5793865 1024 to 1518 byte frames         542259 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/3          Receive
            0 Total bytes                           0 Total bytes
            0 Unicast frames                        0 Unicast frames
            0 Unicast bytes                         0 Unicast bytes
            0 Multicast frames                      0 Multicast frames
            0 Multicast bytes                       0 Multicast bytes
            0 Broadcast frames                      0 Broadcast frames
            0 Broadcast bytes                       0 Broadcast bytes
            0 Minimum size frames                   0 Minimum size frames
            0 65 to 127 byte frames                 0 65 to 127 byte frames
            0 128 to 255 byte frames                0 128 to 255 byte frames
            0 256 to 511 byte frames                0 256 to 511 byte frames
            0 512 to 1023 byte frames               0 512 to 1023 byte frames
            0 1024 to 1518 byte frames              0 1024 to 1518 byte frames
            0 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 8140735350 msecs AGO
Transmit                  GigabitEthernet1/0/4          Receive
   4744005930 Total bytes                   354761907 Total bytes
      4595450 Unicast frames                  1740685 Unicast frames
   2682375470 Unicast bytes                 354274971 Unicast bytes
     14565767 Multicast frames                   1488 Multicast frames
   1563574653 Multicast bytes                  256010 Multicast bytes
      4798951 Broadcast frames                   3597 Broadcast frames
    498055807 Broadcast bytes                  230926 Broadcast bytes
      3267751 Minimum size frames              677863 Minimum size frames
     13538246 65 to 127 byte frames             11174 65 to 127 byte frames
      5274846 128 to 255 byte frames          1012240 128 to 255 byte frames
       323101 256 to 511 byte frames             3482 256 to 511 byte frames
        25589 512 to 1023 byte frames            7845 512 to 1023 byte frames
      1530635 1024 to 1518 byte frames          54175 1024 to 1518 byte frames
            0 Gold frames dropped               21009 FcsErr frames
LAST UPDATE 2600 msecs AGO
Transmit                  GigabitEthernet1/0/5          Receive
 312763203913 Total bytes                 49980331332 Total bytes
    396485670 Unicast frames                190640767 Unicast frames
 310717544508 Unicast bytes               49913082563 Unicast bytes
     14429315 Multicast frames                 407152 Multicast frames
   1547402205 Multicast bytes                67227409 Multicast bytes
      4802434 Broadcast frames                    156 Broadcast frames
    498257200 Broadcast bytes                   21360 Broadcast bytes
      3124118 Minimum size frames              581054 Minimum size frames
     22394163 65 to 127 byte frames          10053464 65 to 127 byte frames
    186271350 128 to 255 byte frames        149223562 128 to 255 byte frames
     26315237 256 to 511 byte frames         14169521 256 to 511 byte frames
      3983443 512 to 1023 byte frames         4480188 512 to 1023 byte frames
    173629108 1024 to 1518 byte frames       13452771 1024 to 1518 byte frames
            0 Gold frames dropped              912485 FcsErr frames
LAST UPDATE 2660 msecs AGO
Transmit                  GigabitEthernet1/0/6          Receive
LAST UPDATE 8140735410 msecs AGO
Transmit                  GigabitEthernet1/0/7          Receive
  10185766472 Total bytes                  2978059862 Total bytes
     15257172 Unicast frames                 12419558 Unicast frames
   8161816900 Unicast bytes                2909828210 Unicast bytes
     14258716 Multicast frames                 302543 Multicast frames
   1532812973 Multicast bytes                64431347 Multicast bytes
      4732308 Broadcast frames                  37259 Broadcast frames
    491136599 Broadcast bytes                 3800305 Broadcast bytes
      5314218 Minimum size frames             4053589 Minimum size frames
     15135783 65 to 127 byte frames           2671891 65 to 127 byte frames
      8351749 128 to 255 byte frames          4243624 128 to 255 byte frames
       680035 256 to 511 byte frames           638385 256 to 511 byte frames
       469403 512 to 1023 byte frames          272154 512 to 1023 byte frames
      4296942 1024 to 1518 byte frames         879717 1024 to 1518 byte frames
           66 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 2670 msecs AGO
Transmit                  GigabitEthernet1/0/8          Receive
  13362619423 Total bytes                  4615515022 Total bytes
     16406664 Unicast frames                 13921060 Unicast frames
  12403118122 Unicast bytes                4582246699 Unicast bytes
      6742029 Multicast frames                 151495 Multicast frames
    728011538 Multicast bytes                31764609 Multicast bytes
      2228700 Broadcast frames                  13994 Broadcast frames
    231489763 Broadcast bytes                 1503714 Broadcast bytes
      3589801 Minimum size frames             5300731 Minimum size frames
      7936265 65 to 127 byte frames           2713689 65 to 127 byte frames
      5201731 128 to 255 byte frames          2606086 128 to 255 byte frames
       749183 256 to 511 byte frames          1104151 256 to 511 byte frames
       363529 512 to 1023 byte frames          395170 512 to 1023 byte frames
      7536827 1024 to 1518 byte frames        1967196 1024 to 1518 byte frames
           57 1519 to 2047 byte frames              1 1519 to 2047 byte frames
            0 Gold frames dropped                 475 FcsErr frames
Transmit                  GigabitEthernet1/0/9          Receive
 103555949502 Total bytes                  3606676831 Total bytes
     75939141 Unicast frames                 40851853 Unicast frames
 101519547477 Unicast bytes                3521259090 Unicast bytes
     14517484 Multicast frames                 323226 Multicast frames
   1555653590 Multicast bytes                67851147 Multicast bytes
      4623219 Broadcast frames                 179631 Broadcast frames
    480748435 Broadcast bytes                17566594 Broadcast bytes
      4176782 Minimum size frames            36702667 Minimum size frames
     16170609 65 to 127 byte frames           2501653 65 to 127 byte frames
      5569226 128 to 255 byte frames          1023804 128 to 255 byte frames
       984074 256 to 511 byte frames           486025 256 to 511 byte frames
       814429 512 to 1023 byte frames          245471 512 to 1023 byte frames
     67364667 1024 to 1518 byte frames         395090 1024 to 1518 byte frames
LAST UPDATE 2680 msecs AGO
Transmit                  GigabitEthernet1/0/10                 Receive
 146667063699 Total bytes                 28921340794 Total bytes
    302939732 Unicast frames                 95288990 Unicast frames
 144621282134 Unicast bytes               28854079357 Unicast bytes
     14429394 Multicast frames                 407214 Multicast frames
   1547523521 Multicast bytes                67241321 Multicast bytes
      4802457 Broadcast frames                    143 Broadcast frames
    498258044 Broadcast bytes                   20116 Broadcast bytes
      3125141 Minimum size frames              516199 Minimum size frames
     22479440 65 to 127 byte frames           9822573 65 to 127 byte frames
    205601633 128 to 255 byte frames         63197315 128 to 255 byte frames
     25911298 256 to 511 byte frames         10442555 256 to 511 byte frames
      4159701 512 to 1023 byte frames         3829770 512 to 1023 byte frames
     60894370 1024 to 1518 byte frames        8437511 1024 to 1518 byte frames
            0 Gold frames dropped              549576 FcsErr frames
Transmit                  GigabitEthernet1/0/11                 Receive
LAST UPDATE 8140735440 msecs AGO
Transmit                  GigabitEthernet1/0/12                 Receive
   2926893522 Total bytes                   543827009 Total bytes
      3885751 Unicast frames                  2676402 Unicast frames
   1111888563 Unicast bytes                 489490894 Unicast bytes
     12805083 Multicast frames                 245277 Multicast frames
   1374720079 Multicast bytes                53567924 Multicast bytes
      4253392 Broadcast frames                   8034 Broadcast frames
    440284880 Broadcast bytes                  768191 Broadcast bytes
      2484306 Minimum size frames              348182 Minimum size frames
     12771314 65 to 127 byte frames           1118330 65 to 127 byte frames
      4887607 128 to 255 byte frames          1210630 128 to 255 byte frames
       312523 256 to 511 byte frames           155587 256 to 511 byte frames
        33196 512 to 1023 byte frames           14555 512 to 1023 byte frames
       455209 1024 to 1518 byte frames          82429 1024 to 1518 byte frames
           71 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 2690 msecs AGO
Transmit                  GigabitEthernet1/0/13                 Receive
  16394094950 Total bytes                  4626169146 Total bytes
     20217790 Unicast frames                 16320861 Unicast frames
  14803425313 Unicast bytes                4563734750 Unicast bytes
     11388470 Multicast frames                 273267 Multicast frames
   1212492684 Multicast bytes                42480543 Multicast bytes
      3666557 Broadcast frames                 185057 Broadcast frames
    378176953 Broadcast bytes                19953853 Broadcast bytes
      6287778 Minimum size frames             7246990 Minimum size frames
     12763208 65 to 127 byte frames           2812234 65 to 127 byte frames
      5204213 128 to 255 byte frames          2803813 128 to 255 byte frames
      1615973 256 to 511 byte frames          1402869 256 to 511 byte frames
       773595 512 to 1023 byte frames          911436 512 to 1023 byte frames
      8628050 1024 to 1518 byte frames        1601850 1024 to 1518 byte frames
            0 Gold frames dropped                   7 FcsErr frames
LAST UPDATE 1680 msecs AGO
Transmit                  GigabitEthernet1/0/14                 Receive
   4677471474 Total bytes                  2572664093 Total bytes
     13526750 Unicast frames                 12301922 Unicast frames
   2633978761 Unicast bytes                2551382906 Unicast bytes
     14441200 Multicast frames                 134502 Multicast frames
   1550363002 Multicast bytes                20981035 Multicast bytes
      4752939 Broadcast frames                   3619 Broadcast frames
    493129711 Broadcast bytes                  300152 Broadcast bytes
      2713501 Minimum size frames                   0 Minimum size frames
     14309307 65 to 127 byte frames           1186776 65 to 127 byte frames
     15355946 128 to 255 byte frames         11252999 128 to 255 byte frames
       319312 256 to 511 byte frames               21 256 to 511 byte frames
        16968 512 to 1023 byte frames             237 512 to 1023 byte frames
         5855 1024 to 1518 byte frames             10 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/15                 Receive
   2329687574 Total bytes                    32754590 Total bytes
      2086274 Unicast frames                   510373 Unicast frames
    267706179 Unicast bytes                  32690096 Unicast bytes
     14566175 Multicast frames                      3 Multicast frames
   1563726482 Multicast bytes                     238 Multicast bytes
      4801861 Broadcast frames                   1004 Broadcast frames
    498254913 Broadcast bytes                   64256 Broadcast bytes
      3228378 Minimum size frames              510075 Minimum size frames
     13525659 65 to 127 byte frames              1315 65 to 127 byte frames
      4265410 128 to 255 byte frames                0 128 to 255 byte frames
       322668 256 to 511 byte frames                0 256 to 511 byte frames
        17421 512 to 1023 byte frames               0 512 to 1023 byte frames
        94774 1024 to 1518 byte frames              0 1024 to 1518 byte frames
            0 Gold frames dropped                  10 FcsErr frames
LAST UPDATE 1690 msecs AGO
Transmit                  GigabitEthernet1/0/16                 Receive
   2228711151 Total bytes                   151071327 Total bytes
      2412432 Unicast frames                  1202717 Unicast frames
    166907297 Unicast bytes                  91167562 Unicast bytes
     14566164 Multicast frames                 271264 Multicast frames
   1563721969 Multicast bytes                59671243 Multicast bytes
      4799438 Broadcast frames                   3411 Broadcast frames
    498081885 Broadcast bytes                  232522 Broadcast bytes
      2731790 Minimum size frames                   0 Minimum size frames
     14436955 65 to 127 byte frames           1206042 65 to 127 byte frames
      4265062 128 to 255 byte frames           135696 128 to 255 byte frames
       322584 256 to 511 byte frames           135640 256 to 511 byte frames
        17166 512 to 1023 byte frames               6 512 to 1023 byte frames
         4420 1024 to 1518 byte frames              8 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/17                 Receive
   6462525224 Total bytes                  1376741886 Total bytes
      8904038 Unicast frames                  7733706 Unicast frames
   4411229848 Unicast bytes                1306124376 Unicast bytes
     14520701 Multicast frames                 319609 Multicast frames
   1555948463 Multicast bytes                67650304 Multicast bytes
      4774856 Broadcast frames                  27990 Broadcast frames
    495346913 Broadcast bytes                 2967206 Broadcast bytes
      5057837 Minimum size frames             2139163 Minimum size frames
     14920840 65 to 127 byte frames           3986488 65 to 127 byte frames
      5038975 128 to 255 byte frames          1068667 128 to 255 byte frames
       553346 256 to 511 byte frames           406033 256 to 511 byte frames
       132435 512 to 1023 byte frames          110993 512 to 1023 byte frames
      2496046 1024 to 1518 byte frames         369961 1024 to 1518 byte frames
          116 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 1700 msecs AGO
Transmit                  GigabitEthernet1/0/18                 Receive
   2658991445 Total bytes                   444198848 Total bytes
      3143082 Unicast frames                  1896024 Unicast frames
    605312557 Unicast bytes                 375971031 Unicast bytes
     14527210 Multicast frames                 313011 Multicast frames
   1557717466 Multicast bytes                65874928 Multicast bytes
      4779336 Broadcast frames                  23512 Broadcast frames
    495961422 Broadcast bytes                 2352889 Broadcast bytes
      2934069 Minimum size frames              268821 Minimum size frames
     14503878 65 to 127 byte frames           1335620 65 to 127 byte frames
      4382087 128 to 255 byte frames           294491 128 to 255 byte frames
       349260 256 to 511 byte frames           180741 256 to 511 byte frames
        31074 512 to 1023 byte frames           13751 512 to 1023 byte frames
       249203 1024 to 1518 byte frames         139123 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/19                 Receive
LAST UPDATE 8140735480 msecs AGO
Transmit                  GigabitEthernet1/0/20                 Receive
  18983058695 Total bytes                  5530384311 Total bytes
     24441188 Unicast frames                 20021935 Unicast frames
  16936470012 Unicast bytes                5454936003 Unicast bytes
     14492590 Multicast frames                 349459 Multicast frames
   1552159156 Multicast bytes                71563496 Multicast bytes
      4764603 Broadcast frames                  38245 Broadcast frames
    494429527 Broadcast bytes                 3884812 Broadcast bytes
      5118541 Minimum size frames             6210281 Minimum size frames
     15677133 65 to 127 byte frames           2740784 65 to 127 byte frames
      9573685 128 to 255 byte frames          5604146 128 to 255 byte frames
      2917622 256 to 511 byte frames          3466239 256 to 511 byte frames
       952483 512 to 1023 byte frames          928088 512 to 1023 byte frames
      9458860 1024 to 1518 byte frames        1460101 1024 to 1518 byte frames
LAST UPDATE 1710 msecs AGO
Transmit                  GigabitEthernet1/0/21                 Receive
LAST UPDATE 8140735540 msecs AGO
Transmit                  GigabitEthernet1/0/22                 Receive
   5515184284 Total bytes                  1253682198 Total bytes
      6917938 Unicast frames                  5221176 Unicast frames
   3469182439 Unicast bytes                1177625137 Unicast bytes
     14500052 Multicast frames                 342218 Multicast frames
   1553533648 Multicast bytes                70210947 Multicast bytes
      4744816 Broadcast frames                  58032 Broadcast frames
    492468197 Broadcast bytes                 5846114 Broadcast bytes
      3376423 Minimum size frames             1537121 Minimum size frames
     14717783 65 to 127 byte frames           1537970 65 to 127 byte frames
      5429713 128 to 255 byte frames          1489510 128 to 255 byte frames
       566951 256 to 511 byte frames           633005 256 to 511 byte frames
       195599 512 to 1023 byte frames           94715 512 to 1023 byte frames
      1876280 1024 to 1518 byte frames         329105 1024 to 1518 byte frames
LAST UPDATE 1770 msecs AGO
Transmit                  GigabitEthernet1/0/23                 Receive
    848930263 Total bytes                   546912380 Total bytes
      2693083 Unicast frames                  2593016 Unicast frames
    550889157 Unicast bytes                 543854388 Unicast bytes
      2152643 Multicast frames                  20862 Multicast frames
    228778824 Multicast bytes                 2930066 Multicast bytes
       670508 Broadcast frames                   1931 Broadcast frames
     69262282 Broadcast bytes                  127926 Broadcast bytes
       330976 Minimum size frames              133367 Minimum size frames
      2155454 65 to 127 byte frames             83670 65 to 127 byte frames
      2974732 128 to 255 byte frames          2399357 128 to 255 byte frames
        51128 256 to 511 byte frames               12 256 to 511 byte frames
         3160 512 to 1023 byte frames            1122 512 to 1023 byte frames
          757 1024 to 1518 byte frames             16 1024 to 1518 byte frames
           27 1519 to 2047 byte frames              4 1519 to 2047 byte frames
            0 Gold frames dropped                1739 FcsErr frames
LAST UPDATE 1780 msecs AGO
Transmit                  GigabitEthernet1/0/24                 Receive
LAST UPDATE 8140735550 msecs AGO
Transmit                  GigabitEthernet1/0/25                 Receive
  12589801719 Total bytes                  3494364902 Total bytes
     19157475 Unicast frames                 15559743 Unicast frames
  10539351209 Unicast bytes                3422770257 Unicast bytes
     14518111 Multicast frames                 323668 Multicast frames
   1555524065 Multicast bytes                68206971 Multicast bytes
      4769949 Broadcast frames                  32900 Broadcast frames
    494926445 Broadcast bytes                 3387674 Broadcast bytes
      4294453 Minimum size frames             3933655 Minimum size frames
     15188750 65 to 127 byte frames           1976693 65 to 127 byte frames
     12473207 128 to 255 byte frames          8334718 128 to 255 byte frames
       833014 256 to 511 byte frames           871453 256 to 511 byte frames
       275680 512 to 1023 byte frames          210047 512 to 1023 byte frames
      5380365 1024 to 1518 byte frames         589745 1024 to 1518 byte frames
LAST UPDATE 780 msecs AGO
Transmit                  GigabitEthernet1/0/26                 Receive
LAST UPDATE 8140735570 msecs AGO
Transmit                  GigabitEthernet1/0/27                 Receive
  12641769828 Total bytes                  3871705791 Total bytes
     19781561 Unicast frames                 16268518 Unicast frames
  10590227639 Unicast bytes                3801287339 Unicast bytes
     14524550 Multicast frames                 316260 Multicast frames
   1556587153 Multicast bytes                67058821 Multicast bytes
      4771074 Broadcast frames                  31778 Broadcast frames
    494955036 Broadcast bytes                 3359631 Broadcast bytes
      4489227 Minimum size frames             4170028 Minimum size frames
     15146608 65 to 127 byte frames           1921815 65 to 127 byte frames
     13078668 128 to 255 byte frames          8890202 128 to 255 byte frames
       739926 256 to 511 byte frames           548187 256 to 511 byte frames
       280530 512 to 1023 byte frames          283800 512 to 1023 byte frames
      5342169 1024 to 1518 byte frames         802524 1024 to 1518 byte frames
LAST UPDATE 790 msecs AGO
Transmit                  GigabitEthernet1/0/28                 Receive
  14691313992 Total bytes                  3913175581 Total bytes
     19803224 Unicast frames                 15901461 Unicast frames
  12646924558 Unicast bytes                3835524407 Unicast bytes
     14480157 Multicast frames                 361883 Multicast frames
   1550188368 Multicast bytes                73537573 Multicast bytes
      4762705 Broadcast frames                  40147 Broadcast frames
    494201066 Broadcast bytes                 4113601 Broadcast bytes
      5119286 Minimum size frames             5209636 Minimum size frames
     15358051 65 to 127 byte frames           2502757 65 to 127 byte frames
     10226007 128 to 255 byte frames          6257222 128 to 255 byte frames
       908911 256 to 511 byte frames           908144 256 to 511 byte frames
       437702 512 to 1023 byte frames          403745 512 to 1023 byte frames
      6996070 1024 to 1518 byte frames        1021987 1024 to 1518 byte frames
           59 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 800 msecs AGO
Transmit                  GigabitEthernet1/0/29                 Receive
  36788380301 Total bytes                  5662247778 Total bytes
     34794611 Unicast frames                 23940260 Unicast frames
  34740360830 Unicast bytes                5588674371 Unicast bytes
     14509174 Multicast frames                 330042 Multicast frames
   1553724134 Multicast bytes                69618886 Multicast bytes
      4766547 Broadcast frames                  35979 Broadcast frames
    494295337 Broadcast bytes                 3954521 Broadcast bytes
      6617434 Minimum size frames            14832057 Minimum size frames
     16192851 65 to 127 byte frames           3041326 65 to 127 byte frames
      6781495 128 to 255 byte frames          2078680 128 to 255 byte frames
      1657703 256 to 511 byte frames          1428386 256 to 511 byte frames
       937769 512 to 1023 byte frames          790253 512 to 1023 byte frames
     21883023 1024 to 1518 byte frames        2135579 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/30                 Receive
   9960273851 Total bytes                  2378408126 Total bytes
     14550245 Unicast frames                 11407384 Unicast frames
   7912446343 Unicast bytes                2304238030 Unicast bytes
     14508240 Multicast frames                 333203 Multicast frames
   1553907803 Multicast bytes                69775557 Multicast bytes
      4761047 Broadcast frames                  41802 Broadcast frames
    493919705 Broadcast bytes                 4394539 Broadcast bytes
      4419125 Minimum size frames             3616798 Minimum size frames
     15060027 65 to 127 byte frames           1983648 65 to 127 byte frames
      9267223 128 to 255 byte frames          5098638 128 to 255 byte frames
       679632 256 to 511 byte frames           435091 256 to 511 byte frames
       231463 512 to 1023 byte frames          214230 512 to 1023 byte frames
      4162005 1024 to 1518 byte frames         433984 1024 to 1518 byte frames
LAST UPDATE 810 msecs AGO
Transmit                  GigabitEthernet1/0/31                 Receive
   8862045535 Total bytes                  2544799800 Total bytes
     11443963 Unicast frames                  8876109 Unicast frames
   6815095564 Unicast bytes                2469832912 Unicast bytes
     14491661 Multicast frames                 348614 Multicast frames
   1551339806 Multicast bytes                72262713 Multicast bytes
      4775831 Broadcast frames                  27019 Broadcast frames
    495610165 Broadcast bytes                 2704175 Broadcast bytes
      4157012 Minimum size frames             3005721 Minimum size frames
     14915650 65 to 127 byte frames           1720828 65 to 127 byte frames
      6868754 128 to 255 byte frames          2794931 128 to 255 byte frames
       780155 256 to 511 byte frames           596809 256 to 511 byte frames
       201768 512 to 1023 byte frames          270515 512 to 1023 byte frames
      3788059 1024 to 1518 byte frames         862938 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/32                 Receive
   7457158174 Total bytes                  1386794645 Total bytes
      8982460 Unicast frames                  6504853 Unicast frames
   5404196607 Unicast bytes                1317843471 Unicast bytes
     14528234 Multicast frames                 311998 Multicast frames
   1557384815 Multicast bytes                66213490 Multicast bytes
      4776767 Broadcast frames                  26084 Broadcast frames
    495576752 Broadcast bytes                 2737684 Broadcast bytes
      3648596 Minimum size frames             2401272 Minimum size frames
     14855859 65 to 127 byte frames           1622743 65 to 127 byte frames
      5949253 128 to 255 byte frames          1829584 128 to 255 byte frames
       604132 256 to 511 byte frames           504456 256 to 511 byte frames
       163855 512 to 1023 byte frames          151373 512 to 1023 byte frames
      3065691 1024 to 1518 byte frames         333507 1024 to 1518 byte frames
           75 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 820 msecs AGO
Transmit                  GigabitEthernet1/0/33                 Receive
   5019952769 Total bytes                   491839084 Total bytes
      4937236 Unicast frames                  2944274 Unicast frames
   2959772795 Unicast bytes                 430275977 Unicast bytes
     14559107 Multicast frames                 278731 Multicast frames
   1562553518 Multicast bytes                60874373 Multicast bytes
      4795255 Broadcast frames                   7599 Broadcast frames
    497626456 Broadcast bytes                  688734 Broadcast bytes
      2964151 Minimum size frames             1104732 Minimum size frames
     14537401 65 to 127 byte frames           1347170 65 to 127 byte frames
      4567676 128 to 255 byte frames           428866 128 to 255 byte frames
       397841 256 to 511 byte frames           204722 256 to 511 byte frames
        56848 512 to 1023 byte frames           43537 512 to 1023 byte frames
      1767588 1024 to 1518 byte frames         101577 1024 to 1518 byte frames
           93 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet1/0/34                 Receive
  14061507420 Total bytes                  4334330262 Total bytes
     18590442 Unicast frames                 14877154 Unicast frames
  12012529820 Unicast bytes                4261398010 Unicast bytes
     14512186 Multicast frames                 328192 Multicast frames
   1554390722 Multicast bytes                69218346 Multicast bytes
      4767831 Broadcast frames                  34873 Broadcast frames
    494586878 Broadcast bytes                 3713906 Broadcast bytes
      4470731 Minimum size frames             4479963 Minimum size frames
     15254917 65 to 127 byte frames           1844431 65 to 127 byte frames
     10313772 128 to 255 byte frames          6375562 128 to 255 byte frames
       861855 256 to 511 byte frames           853515 256 to 511 byte frames
       298253 512 to 1023 byte frames          296619 512 to 1023 byte frames
      6670778 1024 to 1518 byte frames        1390129 1024 to 1518 byte frames
          153 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet1/0/35                 Receive
  15548915274 Total bytes                  5468506825 Total bytes
     24141311 Unicast frames                 20230362 Unicast frames
  13500986346 Unicast bytes                5394402503 Unicast bytes
     14508793 Multicast frames                 332992 Multicast frames
   1553876475 Multicast bytes                69841585 Multicast bytes
      4761390 Broadcast frames                  41464 Broadcast frames
    494052453 Broadcast bytes                 4262737 Broadcast bytes
      4658148 Minimum size frames             4918757 Minimum size frames
     15624735 65 to 127 byte frames           2173983 65 to 127 byte frames
     14742347 128 to 255 byte frames         10203248 128 to 255 byte frames
       968249 256 to 511 byte frames          1497029 256 to 511 byte frames
       485097 512 to 1023 byte frames          378811 512 to 1023 byte frames
      6932861 1024 to 1518 byte frames        1432990 1024 to 1518 byte frames
LAST UPDATE 830 msecs AGO
Transmit                  GigabitEthernet1/0/36                 Receive
  39443430515 Total bytes                 25439933844 Total bytes
    109230991 Unicast frames                103717242 Unicast frames
  37394845238 Unicast bytes               25366414004 Unicast bytes
     14503479 Multicast frames                 339413 Multicast frames
   1552867145 Multicast bytes                70922878 Multicast bytes
      4777866 Broadcast frames                  24987 Broadcast frames
    495718132 Broadcast bytes                 2596962 Broadcast bytes
      4992448 Minimum size frames             7769857 Minimum size frames
     15891285 65 to 127 byte frames           2190304 65 to 127 byte frames
     92102942 128 to 255 byte frames         60768777 128 to 255 byte frames
      1238862 256 to 511 byte frames         31511781 256 to 511 byte frames
       568191 512 to 1023 byte frames          667441 512 to 1023 byte frames
     13718551 1024 to 1518 byte frames        1173482 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/37                 Receive
   2228728432 Total bytes                   151068041 Total bytes
      2412359 Unicast frames                  1202625 Unicast frames
    166910238 Unicast bytes                  91164516 Unicast bytes
     14566170 Multicast frames                 271258 Multicast frames
   1563737126 Multicast bytes                59669923 Multicast bytes
      4799429 Broadcast frames                   3419 Broadcast frames
    498081068 Broadcast bytes                  233602 Broadcast bytes
     14436869 65 to 127 byte frames           1205943 65 to 127 byte frames
      4265038 128 to 255 byte frames           135703 128 to 255 byte frames
       322592 256 to 511 byte frames           135638 256 to 511 byte frames
        17173 512 to 1023 byte frames               9 512 to 1023 byte frames
         4430 1024 to 1518 byte frames              9 1024 to 1518 byte frames
LAST UPDATE 4870 msecs AGO
Transmit                  GigabitEthernet1/0/38                 Receive
   2160744974 Total bytes                           0 Total bytes
      1496998 Unicast frames                        0 Unicast frames
     98694265 Unicast bytes                         0 Unicast bytes
     14566175 Multicast frames                      0 Multicast frames
   1563732242 Multicast bytes                       0 Multicast bytes
      4802860 Broadcast frames                      0 Broadcast frames
    498318467 Broadcast bytes                       0 Broadcast bytes
      2731794 Minimum size frames                   0 Minimum size frames
     13525190 65 to 127 byte frames                 0 65 to 127 byte frames
      4264955 128 to 255 byte frames                0 128 to 255 byte frames
       322515 256 to 511 byte frames                0 256 to 511 byte frames
        17150 512 to 1023 byte frames               0 512 to 1023 byte frames
         4429 1024 to 1518 byte frames              0 1024 to 1518 byte frames
LAST UPDATE 4930 msecs AGO
Transmit                  GigabitEthernet1/0/39                 Receive
  20453734348 Total bytes                  5026718638 Total bytes
     23412526 Unicast frames                 17937018 Unicast frames
  18422896251 Unicast bytes                4934614211 Unicast bytes
     14441778 Multicast frames                 414407 Multicast frames
   1546101185 Multicast bytes                78526916 Multicast bytes
      4664465 Broadcast frames                 138382 Broadcast frames
    484736912 Broadcast bytes                13577511 Broadcast bytes
      4645564 Minimum size frames             6920938 Minimum size frames
     16007280 65 to 127 byte frames           2194711 65 to 127 byte frames
      9275352 128 to 255 byte frames          5557742 128 to 255 byte frames
      1175865 256 to 511 byte frames          1489786 256 to 511 byte frames
       455766 512 to 1023 byte frames          736827 512 to 1023 byte frames
     10958885 1024 to 1518 byte frames        1589803 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/40                 Receive
  12023836435 Total bytes                  5214754276 Total bytes
     17430472 Unicast frames                 14726525 Unicast frames
  10004558914 Unicast bytes                5108916546 Unicast bytes
     14389149 Multicast frames                 500599 Multicast frames
   1536769105 Multicast bytes                90031476 Multicast bytes
      4650528 Broadcast frames                 152320 Broadcast frames
    482508416 Broadcast bytes                15806254 Broadcast bytes
      4641435 Minimum size frames             4100183 Minimum size frames
     15853355 65 to 127 byte frames           2370159 65 to 127 byte frames
      9195701 128 to 255 byte frames          5471910 128 to 255 byte frames
       980401 256 to 511 byte frames          1061182 256 to 511 byte frames
       357398 512 to 1023 byte frames          293013 512 to 1023 byte frames
      5441791 1024 to 1518 byte frames        2082997 1024 to 1518 byte frames
           68 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 4940 msecs AGO
Transmit                  GigabitEthernet1/0/41                 Receive
  15986214686 Total bytes                  4736896267 Total bytes
     19887397 Unicast frames                 15866227 Unicast frames
  13938046793 Unicast bytes                4663048743 Unicast bytes
     14507907 Multicast frames                 333674 Multicast frames
   1553743691 Multicast bytes                69957152 Multicast bytes
      4764670 Broadcast frames                  38177 Broadcast frames
    494424202 Broadcast bytes                 3890372 Broadcast bytes
      4822011 Minimum size frames             5203201 Minimum size frames
     15865382 65 to 127 byte frames           2109737 65 to 127 byte frames
      8766668 128 to 255 byte frames          5557026 128 to 255 byte frames
      1072844 256 to 511 byte frames          1276950 256 to 511 byte frames
       560318 512 to 1023 byte frames          398276 512 to 1023 byte frames
      8072694 1024 to 1518 byte frames        1692888 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/42                 Receive
  15267338604 Total bytes                  4950654103 Total bytes
     22338955 Unicast frames                 19721790 Unicast frames
  13222877258 Unicast bytes                4873082404 Unicast bytes
     14496345 Multicast frames                 345501 Multicast frames
   1551721704 Multicast bytes                71996671 Multicast bytes
      4748609 Broadcast frames                  54239 Broadcast frames
    492739642 Broadcast bytes                 5575028 Broadcast bytes
      5913388 Minimum size frames             5335549 Minimum size frames
     15587302 65 to 127 byte frames           4115454 65 to 127 byte frames
     11064935 128 to 255 byte frames          6827955 128 to 255 byte frames
      1313818 256 to 511 byte frames          2078173 256 to 511 byte frames
       474520 512 to 1023 byte frames          408152 512 to 1023 byte frames
      7229879 1024 to 1518 byte frames        1356247 1024 to 1518 byte frames
           67 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 4950 msecs AGO
Transmit                  GigabitEthernet1/0/43                 Receive
   2698177996 Total bytes                   149577010 Total bytes
      1736056 Unicast frames                   395829 Unicast frames
   1369709102 Unicast bytes                 148418986 Unicast bytes
      7699652 Multicast frames                   1572 Multicast frames
    941733068 Multicast bytes                  785032 Multicast bytes
      3643673 Broadcast frames                   5828 Broadcast frames
    386735826 Broadcast bytes                  372992 Broadcast bytes
      1696264 Minimum size frames              322911 Minimum size frames
      6875100 65 to 127 byte frames              8896 65 to 127 byte frames
      3410051 128 to 255 byte frames             2731 128 to 255 byte frames
       213183 256 to 511 byte frames             5690 256 to 511 byte frames
        20110 512 to 1023 byte frames           13167 512 to 1023 byte frames
       864673 1024 to 1518 byte frames          79231 1024 to 1518 byte frames
            0 Gold frames dropped               29397 FcsErr frames
Transmit                  GigabitEthernet1/0/44                 Receive
   3573791519 Total bytes                   403780853 Total bytes
      4312695 Unicast frames                  3094387 Unicast frames
   1513686155 Unicast bytes                 342124396 Unicast bytes
     14558884 Multicast frames                 279068 Multicast frames
   1562511081 Multicast bytes                60936070 Multicast bytes
      4795098 Broadcast frames                   7750 Broadcast frames
    497594283 Broadcast bytes                  720387 Broadcast bytes
      3421101 Minimum size frames              574584 Minimum size frames
     14573146 65 to 127 byte frames           2217549 65 to 127 byte frames
      4446335 128 to 255 byte frames           282009 128 to 255 byte frames
       370173 256 to 511 byte frames           236564 256 to 511 byte frames
        37827 512 to 1023 byte frames           23881 512 to 1023 byte frames
       818038 1024 to 1518 byte frames          46618 1024 to 1518 byte frames
LAST UPDATE 4960 msecs AGO
Transmit                  GigabitEthernet1/0/45                 Receive
   3931821682 Total bytes                    81818758 Total bytes
      3186073 Unicast frames                  1129968 Unicast frames
   1875992464 Unicast bytes                  75595723 Unicast bytes
     14526529 Multicast frames                  39649 Multicast frames
   1558227180 Multicast bytes                 5506107 Multicast bytes
      4791663 Broadcast frames                  11202 Broadcast frames
    497602038 Broadcast bytes                  716928 Broadcast bytes
      3243758 Minimum size frames             1122620 Minimum size frames
     13539675 65 to 127 byte frames             14558 65 to 127 byte frames
      4226240 128 to 255 byte frames            40523 128 to 255 byte frames
       322540 256 to 511 byte frames             2053 256 to 511 byte frames
        23368 512 to 1023 byte frames             155 512 to 1023 byte frames
      1148684 1024 to 1518 byte frames           1454 1024 to 1518 byte frames
            0 Gold frames dropped                 544 FcsErr frames
Transmit                  GigabitEthernet1/0/46                 Receive
   6967034144 Total bytes                  2015644784 Total bytes
      8190573 Unicast frames                  5998227 Unicast frames
   4913409447 Unicast bytes                1947418210 Unicast bytes
     14531833 Multicast frames                 307489 Multicast frames
   1557320916 Multicast bytes                66220889 Multicast bytes
      4782371 Broadcast frames                  20428 Broadcast frames
    496303781 Broadcast bytes                 2005685 Broadcast bytes
      3735830 Minimum size frames             2272265 Minimum size frames
     15230413 65 to 127 byte frames           1893194 65 to 127 byte frames
      4988626 128 to 255 byte frames           739558 128 to 255 byte frames
       535764 256 to 511 byte frames           391330 256 to 511 byte frames
       146026 512 to 1023 byte frames          114354 512 to 1023 byte frames
      2867993 1024 to 1518 byte frames         915443 1024 to 1518 byte frames
          125 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 4970 msecs AGO
Transmit                  GigabitEthernet1/0/47                 Receive
   5367148829 Total bytes                  1887366061 Total bytes
      8870854 Unicast frames                  7757153 Unicast frames
   3316340433 Unicast bytes                1816204523 Unicast bytes
     14518785 Multicast frames                 322026 Multicast frames
   1555691087 Multicast bytes                67964177 Multicast bytes
      4772760 Broadcast frames                  30088 Broadcast frames
    495117309 Broadcast bytes                 3197361 Broadcast bytes
      4521864 Minimum size frames             1718468 Minimum size frames
     14887869 65 to 127 byte frames           2841455 65 to 127 byte frames
      6432014 128 to 255 byte frames          1848482 128 to 255 byte frames
       612047 256 to 511 byte frames          1034726 256 to 511 byte frames
       108142 512 to 1023 byte frames          138629 512 to 1023 byte frames
      1600406 1024 to 1518 byte frames         527507 1024 to 1518 byte frames
Transmit                  GigabitEthernet1/0/48                 Receive
  12312593964 Total bytes                  5599878489 Total bytes
     23559779 Unicast frames                 19998873 Unicast frames
  10258849178 Unicast bytes                5565138466 Unicast bytes
     14541157 Multicast frames                 146233 Multicast frames
   1559171867 Multicast bytes                31006429 Multicast bytes
      4755140 Broadcast frames                  47615 Broadcast frames
    494572919 Broadcast bytes                 3733594 Broadcast bytes
     13352453 Minimum size frames            11863173 Minimum size frames
     15922917 65 to 127 byte frames           1726338 65 to 127 byte frames
      7017952 128 to 255 byte frames          2903537 128 to 255 byte frames
       693606 256 to 511 byte frames           527509 256 to 511 byte frames
       253756 512 to 1023 byte frames          937866 512 to 1023 byte frames
      5615344 1024 to 1518 byte frames        2234380 1024 to 1518 byte frames
           48 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 Gold frames dropped                  82 FcsErr frames
Transmit                  GigabitEthernet1/1/1          Receive
 276297512099 Total bytes               2266905376651 Total bytes
    939197119 Unicast frames               3440689306 Unicast frames
 275520900603 Unicast bytes             2239030622671 Unicast bytes
      3628863 Multicast frames              221462698 Multicast frames
    610941818 Multicast bytes             18745133777 Multicast bytes
      1332137 Broadcast frames              114192492 Broadcast frames
    165669678 Broadcast bytes              9129620203 Broadcast bytes
      2637456 Minimum size frames            13942679 Minimum size frames
    397344599 65 to 127 byte frames         823575207 65 to 127 byte frames
    360851366 128 to 255 byte frames       1514854235 128 to 255 byte frames
     63145347 256 to 511 byte frames        178941800 256 to 511 byte frames
     25774950 512 to 1023 byte frames        48879276 512 to 1023 byte frames
     17628677 1024 to 1518 byte frames      331001347 1024 to 1518 byte frames
     76775724 1519 to 2047 byte frames      865149952 1519 to 2047 byte frames
LAST UPDATE 3990 msecs AGO
Transmit                  GigabitEthernet1/1/2          Receive
 442283118913 Total bytes                 81038558670 Total bytes
   1350346380 Unicast frames                211963186 Unicast frames
 441404045539 Unicast bytes               72105583298 Unicast bytes
      3171777 Multicast frames               34731349 Multicast frames
    527362934 Multicast bytes              5490184370 Multicast bytes
      3630417 Broadcast frames               33910764 Broadcast frames
    351710440 Broadcast bytes              3442791002 Broadcast bytes
     15158401 Minimum size frames             2334390 Minimum size frames
    420956691 65 to 127 byte frames         127925591 65 to 127 byte frames
    530800789 128 to 255 byte frames        111615405 128 to 255 byte frames
     91933367 256 to 511 byte frames          5853073 256 to 511 byte frames
    182833827 512 to 1023 byte frames         1375550 512 to 1023 byte frames
     26072468 1024 to 1518 byte frames        4878669 1024 to 1518 byte frames
     89393031 1519 to 2047 byte frames       26622621 1519 to 2047 byte frames
Transmit                  GigabitEthernet1/1/3          Receive
LAST UPDATE 8140735730 msecs AGO
Transmit                  GigabitEthernet1/1/4          Receive
Transmit                  GigabitEthernet2/0/1          Receive
       164994 Total bytes                      166926 Total bytes
          657 Unicast frames                      645 Unicast frames
       161384 Unicast bytes                    164028 Unicast bytes
           15 Multicast frames                     16 Multicast frames
         2911 Multicast bytes                    1597 Multicast bytes
            6 Broadcast frames                     10 Broadcast frames
          699 Broadcast bytes                    1301 Broadcast bytes
          127 Minimum size frames                 121 Minimum size frames
           61 65 to 127 byte frames                65 65 to 127 byte frames
          375 128 to 255 byte frames              196 128 to 255 byte frames
           78 256 to 511 byte frames              251 256 to 511 byte frames
           16 512 to 1023 byte frames              20 512 to 1023 byte frames
           21 1024 to 1518 byte frames             19 1024 to 1518 byte frames
            0 Gold frames dropped                   1 FcsErr frames
LAST UPDATE 4530 msecs AGO
Transmit                  GigabitEthernet2/0/2          Receive
LAST UPDATE 8140735740 msecs AGO
Transmit                  GigabitEthernet2/0/3          Receive
LAST UPDATE 8140735800 msecs AGO
Transmit                  GigabitEthernet2/0/4          Receive
Transmit                  GigabitEthernet2/0/5          Receive
LAST UPDATE 8140735810 msecs AGO
Transmit                  GigabitEthernet2/0/6          Receive
  15713867123 Total bytes                  4513524489 Total bytes
     13438819 Unicast frames                  3573632 Unicast frames
  13652233777 Unicast bytes                4513135527 Unicast bytes
     14566307 Multicast frames                     41 Multicast frames
   1563679518 Multicast bytes                   20642 Multicast bytes
      4797134 Broadcast frames                   5755 Broadcast frames
    497953828 Broadcast bytes                  368320 Broadcast bytes
            0 Pause frames                          1 Pause frames
      5840465 Minimum size frames              968919 Minimum size frames
     13531746 65 to 127 byte frames             38069 65 to 127 byte frames
      4266816 128 to 255 byte frames            62850 128 to 255 byte frames
       323960 256 to 511 byte frames           130121 256 to 511 byte frames
        65571 512 to 1023 byte frames          283622 512 to 1023 byte frames
      8773702 1024 to 1518 byte frames        2784270 1024 to 1518 byte frames
            0 1519 to 2047 byte frames           1323 1519 to 2047 byte frames
            0 Gold frames dropped              689745 FcsErr frames
LAST UPDATE 4600 msecs AGO
Transmit                  GigabitEthernet2/0/7          Receive
LAST UPDATE 8140735820 msecs AGO
Transmit                  GigabitEthernet2/0/8          Receive
Transmit                  GigabitEthernet2/0/9          Receive
  18067289101 Total bytes                  6058261757 Total bytes
     24201087 Unicast frames                 20044375 Unicast frames
  16018327176 Unicast bytes                5985354691 Unicast bytes
     14516979 Multicast frames                 324362 Multicast frames
   1554642997 Multicast bytes                68910093 Multicast bytes
      4764940 Broadcast frames                  37906 Broadcast frames
    494318928 Broadcast bytes                 3996973 Broadcast bytes
      5545887 Minimum size frames             6232710 Minimum size frames
     15313410 65 to 127 byte frames           2515909 65 to 127 byte frames
     12257072 128 to 255 byte frames          8180219 128 to 255 byte frames
       925508 256 to 511 byte frames          1043830 256 to 511 byte frames
       574502 512 to 1023 byte frames          289643 512 to 1023 byte frames
      8866570 1024 to 1518 byte frames        2144332 1024 to 1518 byte frames
LAST UPDATE 4620 msecs AGO
Transmit                  GigabitEthernet2/0/10                 Receive
LAST UPDATE 8140735830 msecs AGO
Transmit                  GigabitEthernet2/0/11                 Receive
   2251683246 Total bytes                   174014391 Total bytes
      2515803 Unicast frames                  1306707 Unicast frames
    189808279 Unicast bytes                 114104030 Unicast bytes
     14566307 Multicast frames                 271260 Multicast frames
   1563796965 Multicast bytes                59670363 Multicast bytes
      4799423 Broadcast frames                   3450 Broadcast frames
    498078002 Broadcast bytes                  239998 Broadcast bytes
      2731792 Minimum size frames                   0 Minimum size frames
     14437960 65 to 127 byte frames           1207374 65 to 127 byte frames
      4367374 128 to 255 byte frames           238345 128 to 255 byte frames
       322625 256 to 511 byte frames           135644 256 to 511 byte frames
        17216 512 to 1023 byte frames               8 512 to 1023 byte frames
         4455 1024 to 1518 byte frames             46 1024 to 1518 byte frames
          111 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 4630 msecs AGO
Transmit                  GigabitEthernet2/0/12                 Receive
   2679733216 Total bytes                    48291768 Total bytes
      2343729 Unicast frames                   555397 Unicast frames
    627439979 Unicast bytes                  38516187 Unicast bytes
     14502292 Multicast frames                  63886 Multicast frames
   1554439945 Multicast bytes                 9314719 Multicast bytes
      4795667 Broadcast frames                   7142 Broadcast frames
    497853292 Broadcast bytes                  460862 Broadcast bytes
      3235567 Minimum size frames              550974 Minimum size frames
     13533670 65 to 127 byte frames              7881 65 to 127 byte frames
      4201657 128 to 255 byte frames            64303 128 to 255 byte frames
       322534 256 to 511 byte frames             1638 256 to 511 byte frames
        18837 512 to 1023 byte frames              76 512 to 1023 byte frames
       329423 1024 to 1518 byte frames           1608 1024 to 1518 byte frames
            0 Gold frames dropped                  55 FcsErr frames
Transmit                  GigabitEthernet2/0/13                 Receive
   9675508722 Total bytes                  3432374357 Total bytes
     18910850 Unicast frames                 16811866 Unicast frames
   7619851148 Unicast bytes                3366068926 Unicast bytes
     14539366 Multicast frames                 301164 Multicast frames
   1559061636 Multicast bytes                64584917 Multicast bytes
      4785067 Broadcast frames                  17789 Broadcast frames
    496595938 Broadcast bytes                 1720514 Broadcast bytes
      5150473 Minimum size frames             2992548 Minimum size frames
     15313409 65 to 127 byte frames           3809447 65 to 127 byte frames
     13407433 128 to 255 byte frames          9125297 128 to 255 byte frames
       796046 256 to 511 byte frames           555191 256 to 511 byte frames
       279079 512 to 1023 byte frames          153265 512 to 1023 byte frames
      3288786 1024 to 1518 byte frames         495071 1024 to 1518 byte frames
LAST UPDATE 3650 msecs AGO
Transmit                  GigabitEthernet2/0/14                 Receive
    993612523 Total bytes                   600176159 Total bytes
      1333081 Unicast frames                  1136293 Unicast frames
    844763242 Unicast bytes                 597950406 Unicast bytes
       784828 Multicast frames                   9842 Multicast frames
    103888890 Multicast bytes                 1688937 Multicast bytes
       422325 Broadcast frames                   4770 Broadcast frames
     44960391 Broadcast bytes                  536816 Broadcast bytes
       514867 Minimum size frames              445688 Minimum size frames
       823742 65 to 127 byte frames            119219 65 to 127 byte frames
       582575 128 to 255 byte frames           173036 128 to 255 byte frames
        88172 256 to 511 byte frames            96615 256 to 511 byte frames
        34137 512 to 1023 byte frames           42141 512 to 1023 byte frames
       496741 1024 to 1518 byte frames         314080 1024 to 1518 byte frames
            0 1519 to 2047 byte frames             61 1519 to 2047 byte frames
            0 Gold frames dropped               39935 FcsErr frames
Transmit                  GigabitEthernet2/0/15                 Receive
  18082691055 Total bytes                  3482926228 Total bytes
     22115034 Unicast frames                 16371799 Unicast frames
  16040893938 Unicast bytes                3401670496 Unicast bytes
     14487570 Multicast frames                 370291 Multicast frames
   1550888340 Multicast bytes                73849082 Multicast bytes
      4733297 Broadcast frames                  69552 Broadcast frames
    490908777 Broadcast bytes                 7406650 Broadcast bytes
      4719274 Minimum size frames             6194346 Minimum size frames
     15196705 65 to 127 byte frames           2117911 65 to 127 byte frames
     11138757 128 to 255 byte frames          7001845 128 to 255 byte frames
       718173 256 to 511 byte frames           525790 256 to 511 byte frames
       256972 512 to 1023 byte frames          243641 512 to 1023 byte frames
      9305963 1024 to 1518 byte frames         728109 1024 to 1518 byte frames
LAST UPDATE 3660 msecs AGO
Transmit                  GigabitEthernet2/0/16                 Receive
LAST UPDATE 8140735860 msecs AGO
Transmit                  GigabitEthernet2/0/17                 Receive
   3969608827 Total bytes                  1848010647 Total bytes
     10325597 Unicast frames                  9152872 Unicast frames
   1908696271 Unicast bytes                1828162560 Unicast bytes
     14565842 Multicast frames                 135673 Multicast frames
   1563514740 Multicast bytes                18994505 Multicast bytes
      4789463 Broadcast frames                  13327 Broadcast frames
    497397816 Broadcast bytes                  853582 Broadcast bytes
      2731771 Minimum size frames              838871 Minimum size frames
     14498746 65 to 127 byte frames            510034 65 to 127 byte frames
     12106438 128 to 255 byte frames          7959455 128 to 255 byte frames
       322514 256 to 511 byte frames               68 256 to 511 byte frames
        17125 512 to 1023 byte frames               5 512 to 1023 byte frames
         4308 1024 to 1518 byte frames              5 1024 to 1518 byte frames
            0 Gold frames dropped                6566 FcsErr frames
LAST UPDATE 3670 msecs AGO
Transmit                  GigabitEthernet2/0/18                 Receive
   3691401768 Total bytes                  2341906081 Total bytes
     10193050 Unicast frames                 11271815 Unicast frames
   3033560209 Unicast bytes                2332385436 Unicast bytes
      4623684 Multicast frames                  55182 Multicast frames
    498080030 Multicast bytes                 8663672 Multicast bytes
      1532920 Broadcast frames                   8137 Broadcast frames
    159761529 Broadcast bytes                  856973 Broadcast bytes
      2340758 Minimum size frames             1166263 Minimum size frames
      5010840 65 to 127 byte frames           1862021 65 to 127 byte frames
      7629372 128 to 255 byte frames          7833503 128 to 255 byte frames
       328366 256 to 511 byte frames           152675 256 to 511 byte frames
       139503 512 to 1023 byte frames           84841 512 to 1023 byte frames
       900815 1024 to 1518 byte frames         239261 1024 to 1518 byte frames
            0 Gold frames dropped                3430 FcsErr frames
Transmit                  GigabitEthernet2/0/19                 Receive
  13187365080 Total bytes                  3480593229 Total bytes
     19877703 Unicast frames                 17690780 Unicast frames
  11136250408 Unicast bytes                3409717212 Unicast bytes
     14520248 Multicast frames                 320858 Multicast frames
   1555882939 Multicast bytes                67792323 Multicast bytes
      4772740 Broadcast frames                  30109 Broadcast frames
    495231733 Broadcast bytes                 3083694 Broadcast bytes
      7273136 Minimum size frames             5167433 Minimum size frames
     15772926 65 to 127 byte frames           6484290 65 to 127 byte frames
      8587224 128 to 255 byte frames          4246023 128 to 255 byte frames
       946825 256 to 511 byte frames           961293 256 to 511 byte frames
       422878 512 to 1023 byte frames          281966 512 to 1023 byte frames
      6167645 1024 to 1518 byte frames         900742 1024 to 1518 byte frames
LAST UPDATE 3730 msecs AGO
Transmit                  GigabitEthernet2/0/20                 Receive
  14730720334 Total bytes                  3379325890 Total bytes
     17924260 Unicast frames                 13570917 Unicast frames
  12678825059 Unicast bytes                3309195977 Unicast bytes
     14525036 Multicast frames                 315745 Multicast frames
   1556838753 Multicast bytes                66869261 Multicast bytes
      4770988 Broadcast frames                  31876 Broadcast frames
    495056522 Broadcast bytes                 3260652 Broadcast bytes
      5126574 Minimum size frames             5595138 Minimum size frames
     15550547 65 to 127 byte frames           2476974 65 to 127 byte frames
      7743744 128 to 255 byte frames          3508500 128 to 255 byte frames
       911116 256 to 511 byte frames           850675 256 to 511 byte frames
       488923 512 to 1023 byte frames          398013 512 to 1023 byte frames
      7399231 1024 to 1518 byte frames        1089238 1024 to 1518 byte frames
          149 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet2/0/21                 Receive
    227695755 Total bytes                   285546158 Total bytes
       329395 Unicast frames                   263274 Unicast frames
    146683207 Unicast bytes                 284863036 Unicast bytes
       599378 Multicast frames                   3544 Multicast frames
     63116812 Multicast bytes                  508715 Multicast bytes
       179033 Broadcast frames                   1052 Broadcast frames
     17895736 Broadcast bytes                  174407 Broadcast bytes
       202621 Minimum size frames               64475 Minimum size frames
       623764 65 to 127 byte frames              3134 65 to 127 byte frames
       179163 128 to 255 byte frames            15094 128 to 255 byte frames
        15698 256 to 511 byte frames             5402 256 to 511 byte frames
         3716 512 to 1023 byte frames            2203 512 to 1023 byte frames
        82844 1024 to 1518 byte frames         181360 1024 to 1518 byte frames
            0 1519 to 2047 byte frames              7 1519 to 2047 byte frames
            0 Gold frames dropped                3805 FcsErr frames
LAST UPDATE 3740 msecs AGO
Transmit                  GigabitEthernet2/0/22                 Receive
LAST UPDATE 8140735940 msecs AGO
Transmit                  GigabitEthernet2/0/23                 Receive
Transmit                  GigabitEthernet2/0/24                 Receive
  12597182897 Total bytes                  4111105996 Total bytes
     20928265 Unicast frames                 19779162 Unicast frames
  10546237889 Unicast bytes                4040115212 Unicast bytes
     14517593 Multicast frames                 322273 Multicast frames
   1555277295 Multicast bytes                68342927 Multicast bytes
      4777315 Broadcast frames                  25536 Broadcast frames
    495667713 Broadcast bytes                 2647857 Broadcast bytes
      7910317 Minimum size frames             4448388 Minimum size frames
     16090763 65 to 127 byte frames           7838282 65 to 127 byte frames
      8947603 128 to 255 byte frames          5057583 128 to 255 byte frames
      1116237 256 to 511 byte frames          1401734 256 to 511 byte frames
       556699 512 to 1023 byte frames          291875 512 to 1023 byte frames
      5601497 1024 to 1518 byte frames        1089109 1024 to 1518 byte frames
LAST UPDATE 3750 msecs AGO
Transmit                  GigabitEthernet2/0/25                 Receive
LAST UPDATE 8140735950 msecs AGO
Transmit                  GigabitEthernet2/0/26                 Receive
  21124971536 Total bytes                  7377693312 Total bytes
     33346891 Unicast frames                 28267387 Unicast frames
  19073428700 Unicast bytes                7307278144 Unicast bytes
     14525968 Multicast frames                 314795 Multicast frames
   1556845790 Multicast bytes                66796125 Multicast bytes
      4768709 Broadcast frames                  34142 Broadcast frames
    494697046 Broadcast bytes                 3619043 Broadcast bytes
      7448200 Minimum size frames             8613401 Minimum size frames
     17721334 65 to 127 byte frames           4255190 65 to 127 byte frames
     15635977 128 to 255 byte frames         11282451 128 to 255 byte frames
      1039866 256 to 511 byte frames           915972 256 to 511 byte frames
       372999 512 to 1023 byte frames         1718357 512 to 1023 byte frames
     10423126 1024 to 1518 byte frames        1830953 1024 to 1518 byte frames
LAST UPDATE 2740 msecs AGO
Transmit                  GigabitEthernet2/0/27                 Receive
LAST UPDATE 8140735960 msecs AGO
Transmit                  GigabitEthernet2/0/28                 Receive
   6381750367 Total bytes                  2378410013 Total bytes
     10430860 Unicast frames                  8446440 Unicast frames
   4326185632 Unicast bytes                2312049068 Unicast bytes
     14541028 Multicast frames                 298910 Multicast frames
   1559571930 Multicast bytes                64037390 Multicast bytes
      4781686 Broadcast frames                  21169 Broadcast frames
    495992805 Broadcast bytes                 2323555 Broadcast bytes
      3645468 Minimum size frames             1645758 Minimum size frames
     14962767 65 to 127 byte frames           1534460 65 to 127 byte frames
      8442470 128 to 255 byte frames          4358803 128 to 255 byte frames
       562353 256 to 511 byte frames           444635 256 to 511 byte frames
       145477 512 to 1023 byte frames          122776 512 to 1023 byte frames
      1995006 1024 to 1518 byte frames         660087 1024 to 1518 byte frames
           33 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet2/0/29                 Receive
   4293979098 Total bytes                  1834728023 Total bytes
     10171477 Unicast frames                  9140134 Unicast frames
   3216336095 Unicast bytes                1821259963 Unicast bytes
      7665368 Multicast frames                  80964 Multicast frames
    818317230 Multicast bytes                12719204 Multicast bytes
      2501389 Broadcast frames                   7229 Broadcast frames
    259325773 Broadcast bytes                  748856 Broadcast bytes
      2738488 Minimum size frames             1175757 Minimum size frames
      7989561 65 to 127 byte frames           1903965 65 to 127 byte frames
      7965921 128 to 255 byte frames          5739612 128 to 255 byte frames
       405581 256 to 511 byte frames           141724 256 to 511 byte frames
       175842 512 to 1023 byte frames           57574 512 to 1023 byte frames
      1062841 1024 to 1518 byte frames         209803 1024 to 1518 byte frames
            0 1519 to 2047 byte frames              1 1519 to 2047 byte frames
            0 Gold frames dropped                 109 FcsErr frames
LAST UPDATE 2750 msecs AGO
Transmit                  GigabitEthernet2/0/30                 Receive
LAST UPDATE 8140735970 msecs AGO
Transmit                  GigabitEthernet2/0/31                 Receive
   2708765341 Total bytes                    45857210 Total bytes
      2338566 Unicast frames                   504922 Unicast frames
    657532044 Unicast bytes                  35355853 Unicast bytes
     14494479 Multicast frames                  69440 Multicast frames
   1553555610 Multicast bytes                 9992101 Multicast bytes
      4793649 Broadcast frames                   7924 Broadcast frames
    497677687 Broadcast bytes                  509256 Broadcast bytes
      3207818 Minimum size frames              500469 Minimum size frames
     13532187 65 to 127 byte frames              7898 65 to 127 byte frames
      4194612 128 to 255 byte frames            70757 128 to 255 byte frames
       322660 256 to 511 byte frames             1561 256 to 511 byte frames
        19065 512 to 1023 byte frames              39 512 to 1023 byte frames
       350352 1024 to 1518 byte frames           1568 1024 to 1518 byte frames
            0 Gold frames dropped                   6 FcsErr frames
Transmit                  GigabitEthernet2/0/32                 Receive
  11974026750 Total bytes                  4557306513 Total bytes
     21688988 Unicast frames                 18108106 Unicast frames
  10030056997 Unicast bytes                4519380687 Unicast bytes
     13773394 Multicast frames                 161140 Multicast frames
   1477837641 Multicast bytes                34168418 Multicast bytes
      4483355 Broadcast frames                  45524 Broadcast frames
    466132112 Broadcast bytes                 3757408 Broadcast bytes
     11023213 Minimum size frames             9927967 Minimum size frames
     14359302 65 to 127 byte frames           1520316 65 to 127 byte frames
      8395725 128 to 255 byte frames          4595490 128 to 255 byte frames
       565066 256 to 511 byte frames           403445 256 to 511 byte frames
       206222 512 to 1023 byte frames          147732 512 to 1023 byte frames
      5396049 1024 to 1518 byte frames        1719882 1024 to 1518 byte frames
          160 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 Gold frames dropped                  62 FcsErr frames
LAST UPDATE 2760 msecs AGO
Transmit                  GigabitEthernet2/0/33                 Receive
  25985313091 Total bytes                  6812779972 Total bytes
     31016303 Unicast frames                 25941817 Unicast frames
  23952409022 Unicast bytes                6723838632 Unicast bytes
     14413460 Multicast frames                 429383 Multicast frames
   1539711110 Multicast bytes                83930568 Multicast bytes
      4765438 Broadcast frames                  36384 Broadcast frames
    493192959 Broadcast bytes                 5010772 Broadcast bytes
      8576112 Minimum size frames            12337203 Minimum size frames
     16669231 65 to 127 byte frames           4192284 65 to 127 byte frames
      7252397 128 to 255 byte frames          4763323 128 to 255 byte frames
      2214875 256 to 511 byte frames          1884164 256 to 511 byte frames
      1474507 512 to 1023 byte frames          750760 512 to 1023 byte frames
     14007974 1024 to 1518 byte frames        2479851 1024 to 1518 byte frames
          105 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet2/0/34                 Receive
   9647976420 Total bytes                  5079067092 Total bytes
     21953070 Unicast frames                 22570551 Unicast frames
   7616229813 Unicast bytes                4988678281 Unicast bytes
     14411712 Multicast frames                 432624 Multicast frames
   1538120309 Multicast bytes                85700930 Multicast bytes
      4772806 Broadcast frames                  30040 Broadcast frames
    493626298 Broadcast bytes                 4687881 Broadcast bytes
      4523710 Minimum size frames             5789122 Minimum size frames
     14901303 65 to 127 byte frames           1831789 65 to 127 byte frames
     17873722 128 to 255 byte frames          9441584 128 to 255 byte frames
       722254 256 to 511 byte frames          5239679 256 to 511 byte frames
       184639 512 to 1023 byte frames          141992 512 to 1023 byte frames
      2931894 1024 to 1518 byte frames         589049 1024 to 1518 byte frames
LAST UPDATE 2770 msecs AGO
Transmit                  GigabitEthernet2/0/35                 Receive
  24245806489 Total bytes                  8874589913 Total bytes
     31357011 Unicast frames                 27137638 Unicast frames
  22279634057 Unicast bytes                8718611852 Unicast bytes
     14533210 Multicast frames                 311225 Multicast frames
   1561072258 Multicast bytes                62764020 Multicast bytes
      3859670 Broadcast frames                 943177 Broadcast frames
    405100174 Broadcast bytes                93214041 Broadcast bytes
      7952156 Minimum size frames             9359355 Minimum size frames
     15526619 65 to 127 byte frames           5430047 65 to 127 byte frames
     10336145 128 to 255 byte frames          7714400 128 to 255 byte frames
      1775774 256 to 511 byte frames          1796384 256 to 511 byte frames
      1879699 512 to 1023 byte frames          589645 512 to 1023 byte frames
     12279432 1024 to 1518 byte frames        3502209 1024 to 1518 byte frames
Transmit                  GigabitEthernet2/0/36                 Receive
   5751917209 Total bytes                  1959466655 Total bytes
      9731684 Unicast frames                  7868793 Unicast frames
   3699230691 Unicast bytes                1891884639 Unicast bytes
     14525855 Multicast frames                 305717 Multicast frames
   1557076959 Multicast bytes                65456257 Multicast bytes
      4776464 Broadcast frames                  20886 Broadcast frames
    495609559 Broadcast bytes                 2125759 Broadcast bytes
      3652209 Minimum size frames             1441522 Minimum size frames
     14836852 65 to 127 byte frames           1572395 65 to 127 byte frames
      8113602 128 to 255 byte frames          4130284 128 to 255 byte frames
       556643 256 to 511 byte frames           465019 256 to 511 byte frames
       188881 512 to 1023 byte frames          142013 512 to 1023 byte frames
      1685615 1024 to 1518 byte frames         444163 1024 to 1518 byte frames
          201 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 2850 msecs AGO
Transmit                  GigabitEthernet2/0/37                 Receive
   2592191047 Total bytes                    49267185 Total bytes
      2292242 Unicast frames                   536769 Unicast frames
    541786274 Unicast bytes                  37482019 Unicast bytes
     14491383 Multicast frames                  74955 Multicast frames
   1552633370 Multicast bytes                11243938 Multicast bytes
      4794387 Broadcast frames                   8407 Broadcast frames
    497771403 Broadcast bytes                  541228 Broadcast bytes
      3236735 Minimum size frames              530934 Minimum size frames
     13536290 65 to 127 byte frames              9277 65 to 127 byte frames
      4191015 128 to 255 byte frames            76230 128 to 255 byte frames
       322774 256 to 511 byte frames             1669 256 to 511 byte frames
        18501 512 to 1023 byte frames             128 512 to 1023 byte frames
       272697 1024 to 1518 byte frames           1901 1024 to 1518 byte frames
            0 Gold frames dropped                   8 FcsErr frames
LAST UPDATE 1830 msecs AGO
Transmit                  GigabitEthernet2/0/38                 Receive
   2535894936 Total bytes                    47441757 Total bytes
      2233215 Unicast frames                   530426 Unicast frames
    484699213 Unicast bytes                  36456848 Unicast bytes
     14492534 Multicast frames                  73810 Multicast frames
   1552997165 Multicast bytes                10867149 Multicast bytes
      4800987 Broadcast frames                   1840 Broadcast frames
    498198558 Broadcast bytes                  117760 Broadcast bytes
      3230898 Minimum size frames              527930 Minimum size frames
     13526181 65 to 127 byte frames              1426 65 to 127 byte frames
      4192092 128 to 255 byte frames            73313 128 to 255 byte frames
       322621 256 to 511 byte frames             1650 256 to 511 byte frames
        18415 512 to 1023 byte frames             108 512 to 1023 byte frames
       236529 1024 to 1518 byte frames           1696 1024 to 1518 byte frames
            0 Gold frames dropped                  47 FcsErr frames
Transmit                  GigabitEthernet2/0/39                 Receive
   2213356604 Total bytes                    82451319 Total bytes
      1906051 Unicast frames                   484870 Unicast frames
    153934885 Unicast bytes                  79683471 Unicast bytes
     14552906 Multicast frames                  13532 Multicast frames
   1561184455 Multicast bytes                 2679336 Multicast bytes
      4801742 Broadcast frames                   1181 Broadcast frames
    498237264 Broadcast bytes                   88512 Broadcast bytes
      3099779 Minimum size frames              438944 Minimum size frames
     13543745 65 to 127 byte frames             11239 65 to 127 byte frames
      4252005 128 to 255 byte frames            14203 128 to 255 byte frames
       322770 256 to 511 byte frames              830 256 to 511 byte frames
        19087 512 to 1023 byte frames            1445 512 to 1023 byte frames
        23313 1024 to 1518 byte frames          33672 1024 to 1518 byte frames
            0 Gold frames dropped                 751 FcsErr frames
LAST UPDATE 1840 msecs AGO
Transmit                  GigabitEthernet2/0/40                 Receive
   2891205000 Total bytes                    62728323 Total bytes
      2491698 Unicast frames                   590703 Unicast frames
    840517151 Unicast bytes                  51279493 Unicast bytes
     14491659 Multicast frames                  74519 Multicast frames
   1552890263 Multicast bytes                10955894 Multicast bytes
      4794916 Broadcast frames                   7669 Broadcast frames
    497797586 Broadcast bytes                  492936 Broadcast bytes
      3242754 Minimum size frames              580323 Minimum size frames
     13532792 65 to 127 byte frames              8381 65 to 127 byte frames
      4191360 128 to 255 byte frames            74069 128 to 255 byte frames
       322777 256 to 511 byte frames             1995 256 to 511 byte frames
        19613 512 to 1023 byte frames             442 512 to 1023 byte frames
       468977 1024 to 1518 byte frames           8790 1024 to 1518 byte frames
            0 Gold frames dropped                1109 FcsErr frames
Transmit                  GigabitEthernet2/0/41                 Receive
    665571182 Total bytes                  1374604325 Total bytes
      2605343 Unicast frames                  6607997 Unicast frames
    624050883 Unicast bytes                1373960607 Unicast bytes
       214487 Multicast frames                   3167 Multicast frames
     28399306 Multicast bytes                  488561 Multicast bytes
       124973 Broadcast frames                   1430 Broadcast frames
     13120993 Broadcast bytes                  155157 Broadcast bytes
       371113 Minimum size frames              147987 Minimum size frames
       269774 65 to 127 byte frames            505018 65 to 127 byte frames
      2162697 128 to 255 byte frames          5925542 128 to 255 byte frames
        37674 256 to 511 byte frames            15671 256 to 511 byte frames
        18624 512 to 1023 byte frames            5707 512 to 1023 byte frames
        84921 1024 to 1518 byte frames          20895 1024 to 1518 byte frames
            0 Gold frames dropped                8226 FcsErr frames
Transmit                  GigabitEthernet2/0/42                 Receive
   2953241461 Total bytes                   829500747 Total bytes
      5035863 Unicast frames                  3671501 Unicast frames
    891135273 Unicast bytes                 809496090 Unicast bytes
     14566299 Multicast frames                 134252 Multicast frames
   1563786684 Multicast bytes                20003539 Multicast bytes
      4802872 Broadcast frames                      3 Broadcast frames
    498319504 Broadcast bytes                    1118 Broadcast bytes
      2731793 Minimum size frames                   0 Minimum size frames
     13948096 65 to 127 byte frames            695852 65 to 127 byte frames
      7104371 128 to 255 byte frames          2971142 128 to 255 byte frames
       528432 256 to 511 byte frames               31 256 to 511 byte frames
        87674 512 to 1023 byte frames          138514 512 to 1023 byte frames
         4626 1024 to 1518 byte frames            178 1024 to 1518 byte frames
           42 1519 to 2047 byte frames             39 1519 to 2047 byte frames
LAST UPDATE 1850 msecs AGO
Transmit                  GigabitEthernet2/0/43                 Receive
   3976409244 Total bytes                  2240256148 Total bytes
     11779902 Unicast frames                 10733928 Unicast frames
   2302328975 Unicast bytes                2224753030 Unicast bytes
     11695275 Multicast frames                 105899 Multicast frames
   1263728848 Multicast bytes                14823714 Multicast bytes
      3945885 Broadcast frames                  10496 Broadcast frames
    410351421 Broadcast bytes                  679404 Broadcast bytes
            0 System FCS error frames               0 IpgViolation frames
            0 MacUnderrun frames                    0 MacOverrun frames
            0 Pause frames                          0 Pause frames
            0 Cos 0 Pause frames                    0 Cos 0 Pause frames
            0 Cos 1 Pause frames                    0 Cos 1 Pause frames
            0 Cos 2 Pause frames                    0 Cos 2 Pause frames
            0 Cos 3 Pause frames                    0 Cos 3 Pause frames
            0 Cos 4 Pause frames                    0 Cos 4 Pause frames
            0 Cos 5 Pause frames                    0 Cos 5 Pause frames
            0 Cos 6 Pause frames                    0 Cos 6 Pause frames
            0 Cos 7 Pause frames                    0 Cos 7 Pause frames
            0 Oam frames                            0 OamProcessed frames
            0 Oam frames                            0 OamDropped frames
      2311062 Minimum size frames              646045 Minimum size frames
     11589340 65 to 127 byte frames            409039 65 to 127 byte frames
     13239339 128 to 255 byte frames          9803212 128 to 255 byte frames
       259334 256 to 511 byte frames               86 256 to 511 byte frames
        14397 512 to 1023 byte frames              15 512 to 1023 byte frames
         7590 1024 to 1518 byte frames            109 1024 to 1518 byte frames
            0 2048 to 4095 byte frames              0 2048 to 4095 byte frames
            0 4096 to 8191 byte frames              0 4096 to 8191 byte frames
            0 8192 to 16383 byte frames             0 8192 to 16383 byte frames
            0 16384 to 32767 byte frame             0 16384 to 32767 byte frame
            0 > 32768 byte frames                   0 > 32768 byte frames
            0 Late collision frames                 0 SymbolErr frames
            0 Excess Defer frames                   0 Collision fragments
            0 Good (1 coll) frames                  0 ValidUnderSize frames
            0 Good (>1 coll) frames                 0 InvalidOverSize frames
            0 Deferred frames                       0 ValidOverSize frames
            0 Gold frames dropped                8183 FcsErr frames
            0 Gold frames truncated
            0 Gold frames successful
            0 1 collision frames
            0 2 collision frames
            0 3 collision frames
            0 4 collision frames
            0 5 collision frames
            0 6 collision frames
            0 7 collision frames
            0 8 collision frames
            0 9 collision frames
            0 10 collision frames
            0 11 collision frames
            0 12 collision frames
            0 13 collision frames
            0 14 collision frames
            0 15 collision frames
            0 Excess collision frames
Transmit                  GigabitEthernet2/0/44                 Receive
  39523996268 Total bytes                  9896168320 Total bytes
     41041696 Unicast frames                 34387447 Unicast frames
  37491769342 Unicast bytes                9829966625 Unicast bytes
     14429080 Multicast frames                 332139 Multicast frames
   1543946219 Multicast bytes                56213504 Multicast bytes
      4717155 Broadcast frames                  85245 Broadcast frames
    488280707 Broadcast bytes                 9988191 Broadcast bytes
      7682341 Minimum size frames             9148163 Minimum size frames
     15532448 65 to 127 byte frames          11447381 65 to 127 byte frames
     12231111 128 to 255 byte frames          8511783 128 to 255 byte frames
      1184286 256 to 511 byte frames          1338052 256 to 511 byte frames
       797471 512 to 1023 byte frames          525835 512 to 1023 byte frames
     22760030 1024 to 1518 byte frames        3833586 1024 to 1518 byte frames
          244 1519 to 2047 byte frames             32 1519 to 2047 byte frames
LAST UPDATE 1860 msecs AGO
Transmit                  GigabitEthernet2/0/45                 Receive
   1228245221 Total bytes                   146476699 Total bytes
      1451110 Unicast frames                   550631 Unicast frames
    318021084 Unicast bytes                 137503404 Unicast bytes
      6351650 Multicast frames                  57981 Multicast frames
    684964691 Multicast bytes                 8635703 Multicast bytes
      2161602 Broadcast frames                   3453 Broadcast frames
    225259446 Broadcast bytes                  337592 Broadcast bytes
      1497426 Minimum size frames               74780 Minimum size frames
      6091735 65 to 127 byte frames            313117 65 to 127 byte frames
      1989587 128 to 255 byte frames           130607 128 to 255 byte frames
       233867 256 to 511 byte frames            10812 256 to 511 byte frames
        41034 512 to 1023 byte frames           63237 512 to 1023 byte frames
       110659 1024 to 1518 byte frames          22341 1024 to 1518 byte frames
           54 1519 to 2047 byte frames             23 1519 to 2047 byte frames
            0 Gold frames dropped                2852 FcsErr frames
Transmit                  GigabitEthernet2/0/46                 Receive
   2232114958 Total bytes                   154352866 Total bytes
      2427568 Unicast frames                  1217279 Unicast frames
    170295712 Unicast bytes                  94447065 Unicast bytes
     14566182 Multicast frames                 271265 Multicast frames
   1563738388 Multicast bytes                59671661 Multicast bytes
      4799431 Broadcast frames                   3421 Broadcast frames
    498080858 Broadcast bytes                  234140 Broadcast bytes
      2731789 Minimum size frames                   0 Minimum size frames
     14436753 65 to 127 byte frames           1205794 65 to 127 byte frames
      4280394 128 to 255 byte frames           150516 128 to 255 byte frames
       322589 256 to 511 byte frames           135642 256 to 511 byte frames
        17169 512 to 1023 byte frames               5 512 to 1023 byte frames
         4430 1024 to 1518 byte frames              8 1024 to 1518 byte frames
           57 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 Gold frames dropped                   0 FcsErr frames
Transmit                  GigabitEthernet2/0/47                 Receive
  15184762358 Total bytes                  4557939247 Total bytes
     20116768 Unicast frames                 15616560 Unicast frames
  13160111852 Unicast bytes                4490835119 Unicast bytes
     14252312 Multicast frames                 307178 Multicast frames
   1532049662 Multicast bytes                65003751 Multicast bytes
      4746902 Broadcast frames                  20492 Broadcast frames
    492600844 Broadcast bytes                 2100377 Broadcast bytes
      5158392 Minimum size frames             5749832 Minimum size frames
     16410479 65 to 127 byte frames           3095798 65 to 127 byte frames
      8785136 128 to 255 byte frames          4201625 128 to 255 byte frames
       859349 256 to 511 byte frames           813592 256 to 511 byte frames
       410603 512 to 1023 byte frames          392474 512 to 1023 byte frames
      7491957 1024 to 1518 byte frames        1690909 1024 to 1518 byte frames
LAST UPDATE 1870 msecs AGO
Transmit                  GigabitEthernet2/0/48                 Receive
   7777092014 Total bytes                  3546662302 Total bytes
     17749690 Unicast frames                 15830814 Unicast frames
   5724083599 Unicast bytes                3477788805 Unicast bytes
     14530151 Multicast frames                 309569 Multicast frames
   1557508714 Multicast bytes                66057969 Multicast bytes
      4774984 Broadcast frames                  27869 Broadcast frames
    495499701 Broadcast bytes                 2815528 Broadcast bytes
      3532103 Minimum size frames             1619683 Minimum size frames
     14756768 65 to 127 byte frames           1532472 65 to 127 byte frames
     16385986 128 to 255 byte frames         12371688 128 to 255 byte frames
       476848 256 to 511 byte frames           249561 256 to 511 byte frames
       141192 512 to 1023 byte frames           52211 512 to 1023 byte frames
      1761866 1024 to 1518 byte frames         342637 1024 to 1518 byte frames
           62 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet3/0/1          Receive
 189349898045 Total bytes                 33276417960 Total bytes
    293414030 Unicast frames                104703608 Unicast frames
 187634262826 Unicast bytes               33209156668 Unicast bytes
     10374411 Multicast frames                 407281 Multicast frames
   1239063656 Multicast bytes                67241712 Multicast bytes
      4491399 Broadcast frames                    143 Broadcast frames
    476571563 Broadcast bytes                   19580 Broadcast bytes
      7181799 Minimum size frames              460696 Minimum size frames
     13987057 65 to 127 byte frames           9711698 65 to 127 byte frames
    170346373 128 to 255 byte frames         75374689 128 to 255 byte frames
     17180665 256 to 511 byte frames          5551983 256 to 511 byte frames
      3468330 512 to 1023 byte frames         2606595 512 to 1023 byte frames
     96115616 1024 to 1518 byte frames       11405371 1024 to 1518 byte frames
LAST UPDATE 3150 msecs AGO
Transmit                  GigabitEthernet3/0/2          Receive
  48854783142 Total bytes                  9117081778 Total bytes
    108121120 Unicast frames                 30853006 Unicast frames
  47139153960 Unicast bytes                9049809363 Unicast bytes
     10374344 Multicast frames                 407375 Multicast frames
   1239055237 Multicast bytes                67252835 Multicast bytes
      4491419 Broadcast frames                    143 Broadcast frames
    476573945 Broadcast bytes                   19580 Broadcast bytes
      7180779 Minimum size frames              460791 Minimum size frames
     13806290 65 to 127 byte frames           9088535 65 to 127 byte frames
     75590369 128 to 255 byte frames         16436768 128 to 255 byte frames
      6500371 256 to 511 byte frames          1570259 256 to 511 byte frames
       962379 512 to 1023 byte frames          698885 512 to 1023 byte frames
     18946695 1024 to 1518 byte frames        3005286 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/3          Receive
  68497923812 Total bytes                 12977965843 Total bytes
    147608224 Unicast frames                 37832334 Unicast frames
  66782296625 Unicast bytes               12910704511 Unicast bytes
     10374366 Multicast frames                 407283 Multicast frames
   1239055544 Multicast bytes                67241752 Multicast bytes
      4491397 Broadcast frames                    143 Broadcast frames
    476571643 Broadcast bytes                   19580 Broadcast bytes
      7181734 Minimum size frames              460507 Minimum size frames
     13918544 65 to 127 byte frames           9119023 65 to 127 byte frames
    104235413 128 to 255 byte frames         20283656 128 to 255 byte frames
      8828012 256 to 511 byte frames          2597768 256 to 511 byte frames
       841420 512 to 1023 byte frames          974817 512 to 1023 byte frames
     27468864 1024 to 1518 byte frames        4803989 1024 to 1518 byte frames
LAST UPDATE 3160 msecs AGO
Transmit                  GigabitEthernet3/0/4          Receive
 134625099731 Total bytes                 37842529572 Total bytes
    260396770 Unicast frames                 83096345 Unicast frames
 132909473517 Unicast bytes               37775267367 Unicast bytes
     10374367 Multicast frames                 407290 Multicast frames
   1239055295 Multicast bytes                67242625 Multicast bytes
      4491400 Broadcast frames                    143 Broadcast frames
    476570919 Broadcast bytes                   19580 Broadcast bytes
      7180727 Minimum size frames              460540 Minimum size frames
     13909062 65 to 127 byte frames           9569585 65 to 127 byte frames
    168587033 128 to 255 byte frames         44091892 128 to 255 byte frames
     23192149 256 to 511 byte frames         10549292 256 to 511 byte frames
      3374659 512 to 1023 byte frames         2399036 512 to 1023 byte frames
     59018907 1024 to 1518 byte frames       16433433 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/5          Receive
            0 Total bytes                           0 Total bytes
            0 Unicast frames                        0 Unicast frames
            0 Unicast bytes                         0 Unicast bytes
            0 Multicast frames                      0 Multicast frames
            0 Multicast bytes                       0 Multicast bytes
            0 Broadcast bytes                       0 Broadcast bytes
            0 256 to 511 byte frames                0 256 to 511 byte frames
            0 1024 to 1518 byte frames              0 1024 to 1518 byte frames
LAST UPDATE 8140736200 msecs AGO
Transmit                  GigabitEthernet3/0/6          Receive
Transmit                  GigabitEthernet3/0/7          Receive
 145467027631 Total bytes                 46808349203 Total bytes
    294535532 Unicast frames                106909061 Unicast frames
 143772428005 Unicast bytes               46741755884 Unicast bytes
     10255459 Multicast frames                 403259 Multicast frames
   1223929544 Multicast bytes                66571895 Multicast bytes
      4435686 Broadcast frames                    157 Broadcast frames
    470670082 Broadcast bytes                   21424 Broadcast bytes
      7119855 Minimum size frames              453291 Minimum size frames
     13947127 65 to 127 byte frames           9678402 65 to 127 byte frames
    197229426 128 to 255 byte frames         63338030 128 to 255 byte frames
     24788777 256 to 511 byte frames         10431865 256 to 511 byte frames
      3996536 512 to 1023 byte frames         3426862 512 to 1023 byte frames
     62144956 1024 to 1518 byte frames       19984027 1024 to 1518 byte frames
LAST UPDATE 3230 msecs AGO
Transmit                  GigabitEthernet3/0/8          Receive
  13712149385 Total bytes                  4393280909 Total bytes
     20794079 Unicast frames                 17599664 Unicast frames
  11697910703 Unicast bytes                4282063811 Unicast bytes
     14327384 Multicast frames                 569037 Multicast frames
   1532789515 Multicast bytes                94348253 Multicast bytes
      4632456 Broadcast frames                 170413 Broadcast frames
    481449167 Broadcast bytes                16868845 Broadcast bytes
      4906166 Minimum size frames             4561763 Minimum size frames
     15122698 65 to 127 byte frames           3049621 65 to 127 byte frames
     12422247 128 to 255 byte frames          8387568 128 to 255 byte frames
       862442 256 to 511 byte frames          1027432 256 to 511 byte frames
       360634 512 to 1023 byte frames          265729 512 to 1023 byte frames
      6079675 1024 to 1518 byte frames        1047001 1024 to 1518 byte frames
LAST UPDATE 3240 msecs AGO
Transmit                  GigabitEthernet3/0/9          Receive
  15662249466 Total bytes                  8198202256 Total bytes
     35379239 Unicast frames                 32272387 Unicast frames
  13624439537 Unicast bytes                8114165274 Unicast bytes
     14517983 Multicast frames                 323093 Multicast frames
   1555478524 Multicast bytes                68049449 Multicast bytes
      4638560 Broadcast frames                 164304 Broadcast frames
    482331405 Broadcast bytes                15987533 Broadcast bytes
      4949550 Minimum size frames             4368376 Minimum size frames
     15436889 65 to 127 byte frames           2896582 65 to 127 byte frames
     26641464 128 to 255 byte frames         21752842 128 to 255 byte frames
      1116846 256 to 511 byte frames          1755941 256 to 511 byte frames
       406247 512 to 1023 byte frames          362417 512 to 1023 byte frames
      5984729 1024 to 1518 byte frames        1623626 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/10                 Receive
   9640866216 Total bytes                  4158395998 Total bytes
     20073433 Unicast frames                 17845291 Unicast frames
   7604420411 Unicast bytes                4072891049 Unicast bytes
     14518564 Multicast frames                 321336 Multicast frames
   1555456250 Multicast bytes                68176340 Multicast bytes
      4623781 Broadcast frames                 179094 Broadcast frames
    480989555 Broadcast bytes                17328609 Broadcast bytes
      3893848 Minimum size frames             2605860 Minimum size frames
     14928469 65 to 127 byte frames           2265667 65 to 127 byte frames
     15920534 128 to 255 byte frames         11785395 128 to 255 byte frames
       841251 256 to 511 byte frames           823123 256 to 511 byte frames
       270567 512 to 1023 byte frames          249913 512 to 1023 byte frames
      3361043 1024 to 1518 byte frames         615763 1024 to 1518 byte frames
           66 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet3/0/11                 Receive
   8324726058 Total bytes                  1630067633 Total bytes
      7672335 Unicast frames                  5766913 Unicast frames
   4425686243 Unicast bytes                1589002254 Unicast bytes
     15607938 Multicast frames                 177457 Multicast frames
   1637394866 Multicast bytes                32580405 Multicast bytes
     24115224 Broadcast frames                  84120 Broadcast frames
   2261644949 Broadcast bytes                 8484974 Broadcast bytes
      9241602 Minimum size frames             2107552 Minimum size frames
     28858185 65 to 127 byte frames            906142 65 to 127 byte frames
      5983380 128 to 255 byte frames          1507988 128 to 255 byte frames
       589809 256 to 511 byte frames           576471 256 to 511 byte frames
       240559 512 to 1023 byte frames          513758 512 to 1023 byte frames
      2481900 1024 to 1518 byte frames         418594 1024 to 1518 byte frames
            0 Gold frames dropped                2015 FcsErr frames
LAST UPDATE 3250 msecs AGO
Transmit                  GigabitEthernet3/0/12                 Receive
  14351948344 Total bytes                  5142524811 Total bytes
     22187266 Unicast frames                 19064655 Unicast frames
  12316461869 Unicast bytes                5056010761 Unicast bytes
     14516460 Multicast frames                 324275 Multicast frames
   1555574453 Multicast bytes                68109390 Multicast bytes
      4613970 Broadcast frames                 188883 Broadcast frames
    479912022 Broadcast bytes                18404660 Broadcast bytes
      5832948 Minimum size frames             5061789 Minimum size frames
     15678926 65 to 127 byte frames           3776978 65 to 127 byte frames
     11688285 128 to 255 byte frames          7398165 128 to 255 byte frames
      1160915 256 to 511 byte frames          1388962 256 to 511 byte frames
       523577 512 to 1023 byte frames          466957 512 to 1023 byte frames
      6432988 1024 to 1518 byte frames        1484962 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/13                 Receive
   5373278250 Total bytes                  1632907387 Total bytes
      8244103 Unicast frames                  6351106 Unicast frames
   3315168570 Unicast bytes                1569157585 Unicast bytes
     14551007 Multicast frames                 287931 Multicast frames
   1561242442 Multicast bytes                62299060 Multicast bytes
      4787866 Broadcast frames                  14998 Broadcast frames
    496867238 Broadcast bytes                 1450742 Broadcast bytes
      3636241 Minimum size frames             1437790 Minimum size frames
     14793551 65 to 127 byte frames           1523886 65 to 127 byte frames
      6948596 128 to 255 byte frames          2739487 128 to 255 byte frames
       498068 256 to 511 byte frames           354182 256 to 511 byte frames
       130461 512 to 1023 byte frames          157300 512 to 1023 byte frames
      1576002 1024 to 1518 byte frames         441390 1024 to 1518 byte frames
LAST UPDATE 2240 msecs AGO
Transmit                  GigabitEthernet3/0/14                 Receive
   9072154080 Total bytes                  2672299556 Total bytes
     14098190 Unicast frames                 11666389 Unicast frames
   7028675661 Unicast bytes                2593742385 Unicast bytes
     14529904 Multicast frames                 311656 Multicast frames
   1557827990 Multicast bytes                65891845 Multicast bytes
      4673182 Broadcast frames                 129671 Broadcast frames
    485650429 Broadcast bytes                12665326 Broadcast bytes
      3712580 Minimum size frames             2581311 Minimum size frames
     14909969 65 to 127 byte frames           2012131 65 to 127 byte frames
     10362845 128 to 255 byte frames          6308929 128 to 255 byte frames
       669529 256 to 511 byte frames           547082 256 to 511 byte frames
       176221 512 to 1023 byte frames          197019 512 to 1023 byte frames
      3470066 1024 to 1518 byte frames         461244 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/15                 Receive
  10496174977 Total bytes                  5983057558 Total bytes
     15600489 Unicast frames                 12770454 Unicast frames
   8442825286 Unicast bytes                5914365917 Unicast bytes
     14532204 Multicast frames                 309160 Multicast frames
   1558112502 Multicast bytes                65609276 Multicast bytes
      4772809 Broadcast frames                  30055 Broadcast frames
    495237189 Broadcast bytes                 3082365 Broadcast bytes
      4295776 Minimum size frames             3132827 Minimum size frames
     16221458 65 to 127 byte frames           1697936 65 to 127 byte frames
      8955050 128 to 255 byte frames          3711987 128 to 255 byte frames
       644428 256 to 511 byte frames           828726 256 to 511 byte frames
       227863 512 to 1023 byte frames         1137998 512 to 1023 byte frames
      4560870 1024 to 1518 byte frames        2600195 1024 to 1518 byte frames
LAST UPDATE 2250 msecs AGO
Transmit                  GigabitEthernet3/0/16                 Receive
  20982426608 Total bytes                  2099669315 Total bytes
     18150905 Unicast frames                 12086449 Unicast frames
  18945905072 Unicast bytes                2073633997 Unicast bytes
     14440055 Multicast frames                 132324 Multicast frames
   1543732430 Multicast bytes                20515853 Multicast bytes
      4753641 Broadcast frames                  49112 Broadcast frames
    492789106 Broadcast bytes                 5519465 Broadcast bytes
      5060298 Minimum size frames             6358882 Minimum size frames
     14214156 65 to 127 byte frames           3953580 65 to 127 byte frames
      4746104 128 to 255 byte frames           669574 128 to 255 byte frames
       734200 256 to 511 byte frames           282144 256 to 511 byte frames
       423316 512 to 1023 byte frames          268836 512 to 1023 byte frames
     12166527 1024 to 1518 byte frames         741840 1024 to 1518 byte frames
            0 Gold frames dropped                6971 FcsErr frames
Transmit                  GigabitEthernet3/0/17                 Receive
   4841891363 Total bytes                  2282431942 Total bytes
     11081769 Unicast frames                  9742489 Unicast frames
   2801502374 Unicast bytes                2200625277 Unicast bytes
     14469120 Multicast frames                 375135 Multicast frames
   1547983529 Multicast bytes                75897746 Multicast bytes
      4744240 Broadcast frames                  58609 Broadcast frames
    492405460 Broadcast bytes                 5908919 Broadcast bytes
      3260210 Minimum size frames              796635 Minimum size frames
     14670609 65 to 127 byte frames           1516735 65 to 127 byte frames
     11204229 128 to 255 byte frames          7240143 128 to 255 byte frames
       443785 256 to 511 byte frames           286533 256 to 511 byte frames
        93600 512 to 1023 byte frames           71398 512 to 1023 byte frames
       622639 1024 to 1518 byte frames         264789 1024 to 1518 byte frames
LAST UPDATE 2260 msecs AGO
Transmit                  GigabitEthernet3/0/18                 Receive
  20168270948 Total bytes                  8649700883 Total bytes
     23282815 Unicast frames                 18424922 Unicast frames
  18122905482 Unicast bytes                8572899251 Unicast bytes
     14492122 Multicast frames                 351447 Multicast frames
   1551770401 Multicast bytes                72081724 Multicast bytes
      4757260 Broadcast frames                  45590 Broadcast frames
    493595065 Broadcast bytes                 4719908 Broadcast bytes
      6650264 Minimum size frames             7348366 Minimum size frames
     16139710 65 to 127 byte frames           2195156 65 to 127 byte frames
      7478071 128 to 255 byte frames          2560712 128 to 255 byte frames
       821917 256 to 511 byte frames           855943 256 to 511 byte frames
       450573 512 to 1023 byte frames         1792040 512 to 1023 byte frames
     10991605 1024 to 1518 byte frames        4069742 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/19                 Receive
   8621323758 Total bytes                  1556172389 Total bytes
      9918291 Unicast frames                  6791539 Unicast frames
   6563171204 Unicast bytes                1513658736 Unicast bytes
     14553358 Multicast frames                 210492 Multicast frames
   1560913477 Multicast bytes                41475935 Multicast bytes
      4792529 Broadcast frames                   9928 Broadcast frames
    497239077 Broadcast bytes                 1037718 Broadcast bytes
      3607873 Minimum size frames             2438162 Minimum size frames
     14912395 65 to 127 byte frames           1607570 65 to 127 byte frames
      6170151 128 to 255 byte frames          2113067 128 to 255 byte frames
       524627 256 to 511 byte frames           222383 256 to 511 byte frames
       145577 512 to 1023 byte frames          119264 512 to 1023 byte frames
      3903507 1024 to 1518 byte frames         511513 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/20                 Receive
  20139831561 Total bytes                  6593017834 Total bytes
     26087771 Unicast frames                 20806995 Unicast frames
  18090705757 Unicast bytes                6520237380 Unicast bytes
     14514574 Multicast frames                 325645 Multicast frames
   1553915575 Multicast bytes                69675650 Multicast bytes
      4772699 Broadcast frames                  30151 Broadcast frames
    495210229 Broadcast bytes                 3104804 Broadcast bytes
      5255420 Minimum size frames             6655109 Minimum size frames
     15883316 65 to 127 byte frames           1725063 65 to 127 byte frames
     11781781 128 to 255 byte frames          7041085 128 to 255 byte frames
      1973992 256 to 511 byte frames          2981911 256 to 511 byte frames
       321257 512 to 1023 byte frames          525107 512 to 1023 byte frames
     10159221 1024 to 1518 byte frames        2234516 1024 to 1518 byte frames
LAST UPDATE 2270 msecs AGO
Transmit                  GigabitEthernet3/0/21                 Receive
            0 Minimum size frames                   0 Minimum size frames
            0 128 to 255 byte frames                0 128 to 255 byte frames
LAST UPDATE 8140736260 msecs AGO
Transmit                  GigabitEthernet3/0/22                 Receive
LAST UPDATE 8140736330 msecs AGO
Transmit                  GigabitEthernet3/0/23                 Receive
    994377568 Total bytes                    75806590 Total bytes
       930357 Unicast frames                   583172 Unicast frames
     77711362 Unicast bytes                  46820516 Unicast bytes
      6478688 Multicast frames                 121101 Multicast frames
    697720987 Multicast bytes                27223013 Multicast bytes
      2100604 Broadcast frames                  25708 Broadcast frames
    218945219 Broadcast bytes                 1763061 Broadcast bytes
       980925 Minimum size frames                5219 Minimum size frames
      6459146 65 to 127 byte frames            598671 65 to 127 byte frames
      1896186 128 to 255 byte frames            63126 128 to 255 byte frames
       149798 256 to 511 byte frames            61723 256 to 511 byte frames
        15811 512 to 1023 byte frames             423 512 to 1023 byte frames
         7783 1024 to 1518 byte frames            863 1024 to 1518 byte frames
            0 Gold frames dropped                  44 FcsErr frames
LAST UPDATE 2340 msecs AGO
Transmit                  GigabitEthernet3/0/24                 Receive
LAST UPDATE 8140736340 msecs AGO
Transmit                  GigabitEthernet3/0/25                 Receive
Transmit                  GigabitEthernet3/0/26                 Receive
  37119715886 Total bytes                 14719292051 Total bytes
     49530695 Unicast frames                 41265406 Unicast frames
  32524529588 Unicast bytes               14626237982 Unicast bytes
     18771989 Multicast frames                 332480 Multicast frames
   1949584353 Multicast bytes                69355102 Multicast bytes
     28293119 Broadcast frames                 244950 Broadcast frames
   2645601945 Broadcast bytes                23698967 Broadcast bytes
     16098015 Minimum size frames            13167183 Minimum size frames
     39232662 65 to 127 byte frames           4836602 65 to 127 byte frames
     20322783 128 to 255 byte frames         15570497 128 to 255 byte frames
      1715527 256 to 511 byte frames          1473471 256 to 511 byte frames
       907449 512 to 1023 byte frames          633907 512 to 1023 byte frames
     18319310 1024 to 1518 byte frames        6161176 1024 to 1518 byte frames
LAST UPDATE 1340 msecs AGO
Transmit                  GigabitEthernet3/0/27                 Receive
LAST UPDATE 8140736350 msecs AGO
Transmit                  GigabitEthernet3/0/28                 Receive
Transmit                  GigabitEthernet3/0/29                 Receive
  43795442381 Total bytes                  9475135609 Total bytes
     41631016 Unicast frames                 29283992 Unicast frames
  41747201797 Unicast bytes                9401459143 Unicast bytes
     14507346 Multicast frames                 332950 Multicast frames
   1553656865 Multicast bytes                69946152 Multicast bytes
      4765754 Broadcast frames                  37094 Broadcast frames
    494583719 Broadcast bytes                 3730314 Broadcast bytes
      6170038 Minimum size frames            15373000 Minimum size frames
     16685789 65 to 127 byte frames           2260950 65 to 127 byte frames
     10029437 128 to 255 byte frames          5953792 128 to 255 byte frames
      1448608 256 to 511 byte frames          1267482 256 to 511 byte frames
       546232 512 to 1023 byte frames          581907 512 to 1023 byte frames
     26023909 1024 to 1518 byte frames        4216905 1024 to 1518 byte frames
          103 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 1350 msecs AGO
Transmit                  GigabitEthernet3/0/30                 Receive
LAST UPDATE 8140736360 msecs AGO
Transmit                  GigabitEthernet3/0/31                 Receive
  59932543688 Total bytes                  6542302398 Total bytes
     50100335 Unicast frames                 32035152 Unicast frames
  57883105692 Unicast bytes                6469892384 Unicast bytes
     14508667 Multicast frames                 330663 Multicast frames
   1553843456 Multicast bytes                69689983 Multicast bytes
      4777225 Broadcast frames                  25626 Broadcast frames
    495594540 Broadcast bytes                 2720031 Broadcast bytes
      6002313 Minimum size frames            21273818 Minimum size frames
     15922165 65 to 127 byte frames           2674010 65 to 127 byte frames
      8725308 128 to 255 byte frames          4082185 128 to 255 byte frames
      1125623 256 to 511 byte frames          1489917 256 to 511 byte frames
       691649 512 to 1023 byte frames          631972 512 to 1023 byte frames
     36919112 1024 to 1518 byte frames        2239539 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/32                 Receive
  56029047414 Total bytes                112152767911 Total bytes
    178615131 Unicast frames                192508558 Unicast frames
  53983754078 Unicast bytes              112076139973 Unicast bytes
     14508404 Multicast frames                 332018 Multicast frames
   1553940542 Multicast bytes                69666696 Multicast bytes
      4734699 Broadcast frames                  68148 Broadcast frames
    491352794 Broadcast bytes                 6961242 Broadcast bytes
     37129657 Minimum size frames            16980830 Minimum size frames
    118185515 65 to 127 byte frames           3319164 65 to 127 byte frames
     11734627 128 to 255 byte frames          4989301 128 to 255 byte frames
      2362362 256 to 511 byte frames          2190924 256 to 511 byte frames
       889531 512 to 1023 byte frames       153677150 512 to 1023 byte frames
     27556485 1024 to 1518 byte frames       11751355 1024 to 1518 byte frames
LAST UPDATE 1360 msecs AGO
Transmit                  GigabitEthernet3/0/33                 Receive
LAST UPDATE 8140736370 msecs AGO
Transmit                  GigabitEthernet3/0/34                 Receive
  15104084987 Total bytes                 10200623403 Total bytes
     19816217 Unicast frames                 16586372 Unicast frames
  13053616416 Unicast bytes               10129155580 Unicast bytes
     14517372 Multicast frames                 323306 Multicast frames
   1555508107 Multicast bytes                68113784 Multicast bytes
      4770162 Broadcast frames                  32688 Broadcast frames
    494960464 Broadcast bytes                 3354039 Broadcast bytes
      5943148 Minimum size frames             4843289 Minimum size frames
     16666073 65 to 127 byte frames           1728476 65 to 127 byte frames
      7828457 128 to 255 byte frames          3647183 128 to 255 byte frames
       841741 256 to 511 byte frames           737773 256 to 511 byte frames
       196446 512 to 1023 byte frames          319467 512 to 1023 byte frames
      7627829 1024 to 1518 byte frames        5666178 1024 to 1518 byte frames
LAST UPDATE 1370 msecs AGO
Transmit                  GigabitEthernet3/0/35                 Receive
  10001920892 Total bytes                 19074707514 Total bytes
     21116319 Unicast frames                 18966349 Unicast frames
   7944279227 Unicast bytes               19010570718 Unicast bytes
     14544964 Multicast frames                 293370 Multicast frames
   1560304868 Multicast bytes                63158947 Multicast bytes
      4792325 Broadcast frames                  10523 Broadcast frames
    497336797 Broadcast bytes                  977849 Broadcast bytes
      5243887 Minimum size frames             2854702 Minimum size frames
     24666532 65 to 127 byte frames           1504140 65 to 127 byte frames
      5435697 128 to 255 byte frames           912475 128 to 255 byte frames
       662347 256 to 511 byte frames           525391 256 to 511 byte frames
       133751 512 to 1023 byte frames         2147966 512 to 1023 byte frames
      4311281 1024 to 1518 byte frames       11325568 1024 to 1518 byte frames
          113 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet3/0/36                 Receive
  18561080061 Total bytes                  2026163434 Total bytes
     15474637 Unicast frames                  9497886 Unicast frames
  16502424228 Unicast bytes                1963064939 Unicast bytes
     14554603 Multicast frames                 283503 Multicast frames
   1561778980 Multicast bytes                61661120 Multicast bytes
      4789751 Broadcast frames                  13098 Broadcast frames
    496876853 Broadcast bytes                 1437375 Broadcast bytes
      3356363 Minimum size frames             5648289 Minimum size frames
     14797906 65 to 127 byte frames           1398127 65 to 127 byte frames
      5542576 128 to 255 byte frames          1223070 128 to 255 byte frames
       541993 256 to 511 byte frames           768948 256 to 511 byte frames
       112031 512 to 1023 byte frames           63441 512 to 1023 byte frames
     10468065 1024 to 1518 byte frames         692612 1024 to 1518 byte frames
LAST UPDATE 1380 msecs AGO
Transmit                  GigabitEthernet3/0/37                 Receive
   6331858590 Total bytes                    55094300 Total bytes
      4764288 Unicast frames                   627892 Unicast frames
   4281934318 Unicast bytes                  43564912 Unicast bytes
     14487480 Multicast frames                  74630 Multicast frames
   1552366436 Multicast bytes                10973716 Multicast bytes
      4792247 Broadcast frames                   8583 Broadcast frames
    497557836 Broadcast bytes                  555672 Broadcast bytes
      3237679 Minimum size frames              618504 Minimum size frames
     13533629 65 to 127 byte frames             12100 65 to 127 byte frames
      4188790 128 to 255 byte frames            76977 128 to 255 byte frames
       322895 256 to 511 byte frames             1634 256 to 511 byte frames
        32217 512 to 1023 byte frames             111 512 to 1023 byte frames
      2728805 1024 to 1518 byte frames           1796 1024 to 1518 byte frames
            0 Gold frames dropped                  17 FcsErr frames
LAST UPDATE 360 msecs AGO
Transmit                  GigabitEthernet3/0/38                 Receive
  24982541352 Total bytes                  6081858147 Total bytes
     23984121 Unicast frames                 16754541 Unicast frames
  22932830206 Unicast bytes                6009667257 Unicast bytes
     14512728 Multicast frames                 327478 Multicast frames
   1554587487 Multicast bytes                68999690 Multicast bytes
      4772792 Broadcast frames                  30062 Broadcast frames
    495123659 Broadcast bytes                 3191200 Broadcast bytes
      4500171 Minimum size frames             8263238 Minimum size frames
     16261496 65 to 127 byte frames           1759905 65 to 127 byte frames
      7074530 128 to 255 byte frames          3067787 128 to 255 byte frames
       900385 256 to 511 byte frames           837918 256 to 511 byte frames
       253181 512 to 1023 byte frames          313219 512 to 1023 byte frames
     14279821 1024 to 1518 byte frames        2870014 1024 to 1518 byte frames
LAST UPDATE 430 msecs AGO
Transmit                  GigabitEthernet3/0/39                 Receive
            0 Broadcast frames                      0 Broadcast frames
            0 65 to 127 byte frames                 0 65 to 127 byte frames
            0 512 to 1023 byte frames               0 512 to 1023 byte frames
LAST UPDATE 8140736470 msecs AGO
Transmit                  GigabitEthernet3/0/40                 Receive
   4698515656 Total bytes                  2059454125 Total bytes
      7581111 Unicast frames                  6093366 Unicast frames
   2657350164 Unicast bytes                1978543050 Unicast bytes
     14468338 Multicast frames                 374590 Multicast frames
   1547755953 Multicast bytes                76005851 Multicast bytes
      4753199 Broadcast frames                  49654 Broadcast frames
    493409539 Broadcast bytes                 4905224 Broadcast bytes
      3351656 Minimum size frames              877670 Minimum size frames
     14658556 65 to 127 byte frames           1394417 65 to 127 byte frames
      7182398 128 to 255 byte frames          3083693 128 to 255 byte frames
       418971 256 to 511 byte frames           409440 256 to 511 byte frames
        50839 512 to 1023 byte frames           32994 512 to 1023 byte frames
      1140159 1024 to 1518 byte frames         719396 1024 to 1518 byte frames
           69 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 440 msecs AGO
Transmit                  GigabitEthernet3/0/41                 Receive
   9608567165 Total bytes                  5763561204 Total bytes
     62964842 Unicast frames                 75081820 Unicast frames
   7882315446 Unicast bytes                5739296746 Unicast bytes
     12129182 Multicast frames                 135282 Multicast frames
   1301808186 Multicast bytes                20709866 Multicast bytes
      4099651 Broadcast frames                  20837 Broadcast frames
    424443533 Broadcast bytes                 3554592 Broadcast bytes
     40958611 Minimum size frames            44805591 Minimum size frames
     30336161 65 to 127 byte frames          29113499 65 to 127 byte frames
      4909271 128 to 255 byte frames           656442 128 to 255 byte frames
       565800 256 to 511 byte frames           337059 256 to 511 byte frames
        96736 512 to 1023 byte frames           90869 512 to 1023 byte frames
      2327096 1024 to 1518 byte frames         239054 1024 to 1518 byte frames
            0 Gold frames dropped                4575 FcsErr frames
Transmit                  GigabitEthernet3/0/42                 Receive
  18255386228 Total bytes                  3589136963 Total bytes
     22508677 Unicast frames                 16690547 Unicast frames
  16234930323 Unicast bytes                3516429835 Unicast bytes
     14243513 Multicast frames                 322509 Multicast frames
   1530206259 Multicast bytes                67754316 Multicast bytes
      4725733 Broadcast frames                  46254 Broadcast frames
    490249646 Broadcast bytes                 4952812 Broadcast bytes
      5330178 Minimum size frames             7229216 Minimum size frames
     15777039 65 to 127 byte frames           3043418 65 to 127 byte frames
      9585379 128 to 255 byte frames          4388702 128 to 255 byte frames
       983992 256 to 511 byte frames          1156221 256 to 511 byte frames
       389001 512 to 1023 byte frames          285544 512 to 1023 byte frames
      9412189 1024 to 1518 byte frames         956209 1024 to 1518 byte frames
          145 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 450 msecs AGO
Transmit                  GigabitEthernet3/0/43                 Receive
   4393842607 Total bytes                   845627356 Total bytes
      5065898 Unicast frames                  3320888 Unicast frames
   2334326117 Unicast bytes                 801223606 Unicast bytes
     14558577 Multicast frames                 215938 Multicast frames
   1562547652 Multicast bytes                43173982 Multicast bytes
      4792374 Broadcast frames                   9391 Broadcast frames
    496968838 Broadcast bytes                 1229768 Broadcast bytes
      3342838 Minimum size frames             1133960 Minimum size frames
     14648944 65 to 127 byte frames           1403793 65 to 127 byte frames
      4580542 128 to 255 byte frames           444485 128 to 255 byte frames
       394851 256 to 511 byte frames           158879 256 to 511 byte frames
       136357 512 to 1023 byte frames           55793 512 to 1023 byte frames
      1313233 1024 to 1518 byte frames         349307 1024 to 1518 byte frames
           84 1519 to 2047 byte frames              0 1519 to 2047 byte frames
Transmit                  GigabitEthernet3/0/44                 Receive
  52348163382 Total bytes                 17695246050 Total bytes
     51528443 Unicast frames                 40368066 Unicast frames
  50301485653 Unicast bytes               17619920532 Unicast bytes
     14491669 Multicast frames                 349843 Multicast frames
   1551925314 Multicast bytes                71763840 Multicast bytes
      4767755 Broadcast frames                  35094 Broadcast frames
    494752415 Broadcast bytes                 3561678 Broadcast bytes
      8908909 Minimum size frames            18958198 Minimum size frames
     19676902 65 to 127 byte frames           3673438 65 to 127 byte frames
      7165218 128 to 255 byte frames          2958626 128 to 255 byte frames
      1265063 256 to 511 byte frames          1549949 256 to 511 byte frames
       795766 512 to 1023 byte frames         5927482 512 to 1023 byte frames
     32975952 1024 to 1518 byte frames        7685310 1024 to 1518 byte frames
Transmit                  GigabitEthernet3/0/45                 Receive
   1215097769 Total bytes                   443591758 Total bytes
      1783885 Unicast frames                  1255232 Unicast frames
    697375528 Unicast bytes                 425683235 Unicast bytes
      3702032 Multicast frames                  80633 Multicast frames
    395775943 Multicast bytes                17244584 Multicast bytes
      1175099 Broadcast frames                   6440 Broadcast frames
    121946298 Broadcast bytes                  663939 Broadcast bytes
      1156075 Minimum size frames              395349 Minimum size frames
      3748971 65 to 127 byte frames            431504 65 to 127 byte frames
      1228815 128 to 255 byte frames           194282 128 to 255 byte frames
       127294 256 to 511 byte frames            93797 256 to 511 byte frames
        31588 512 to 1023 byte frames           27522 512 to 1023 byte frames
       368157 1024 to 1518 byte frames         199852 1024 to 1518 byte frames
          116 1519 to 2047 byte frames              0 1519 to 2047 byte frames
LAST UPDATE 460 msecs AGO
Transmit                  GigabitEthernet3/0/46                 Receive
  86477136901 Total bytes                  5629455330 Total bytes
     68327025 Unicast frames                 43269240 Unicast frames
  84426707207 Unicast bytes                5557961613 Unicast bytes
     14520339 Multicast frames                 319820 Multicast frames
   1555526912 Multicast bytes                68081940 Multicast bytes
      4772325 Broadcast frames                  30524 Broadcast frames
    494902782 Broadcast bytes                 3411777 Broadcast bytes
      6517022 Minimum size frames            31193856 Minimum size frames
     16621381 65 to 127 byte frames           7218478 65 to 127 byte frames
      5938929 128 to 255 byte frames          1653227 128 to 255 byte frames
      2485130 256 to 511 byte frames          1794372 256 to 511 byte frames
       747009 512 to 1023 byte frames          648568 512 to 1023 byte frames
     55310156 1024 to 1518 byte frames        1111083 1024 to 1518 byte frames
LAST UPDATE 470 msecs AGO
Transmit                  GigabitEthernet3/0/47                 Receive
   7201631437 Total bytes                  1759282425 Total bytes
     11017935 Unicast frames                  6094023 Unicast frames
   6761512482 Unicast bytes                1743841476 Unicast bytes
      3142434 Multicast frames                  70433 Multicast frames
    338344524 Multicast bytes                10964227 Multicast bytes
       966633 Broadcast frames                  42737 Broadcast frames
    101774431 Broadcast bytes                 4476722 Broadcast bytes
      1713630 Minimum size frames             2165647 Minimum size frames
      3428371 65 to 127 byte frames            795438 65 to 127 byte frames
      5216785 128 to 255 byte frames          1781883 128 to 255 byte frames
       972222 256 to 511 byte frames           552859 256 to 511 byte frames
       303067 512 to 1023 byte frames          380998 512 to 1023 byte frames
      3492879 1024 to 1518 byte frames         547166 1024 to 1518 byte frames
           48 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 Gold frames dropped               16798 FcsErr frames
Transmit                  GigabitEthernet3/0/48                 Receive
  55142893825 Total bytes                  9286445688 Total bytes
     51685397 Unicast frames                 36439552 Unicast frames
  53099244562 Unicast bytes                9208124480 Unicast bytes
     14473865 Multicast frames                 367185 Multicast frames
   1548723536 Multicast bytes                74933440 Multicast bytes
      4768873 Broadcast frames                  33972 Broadcast frames
    494925727 Broadcast bytes                 3387768 Broadcast bytes
      7033673 Minimum size frames            20691951 Minimum size frames
     17311338 65 to 127 byte frames           4153960 65 to 127 byte frames
      9259444 128 to 255 byte frames          5027566 128 to 255 byte frames
      2632665 256 to 511 byte frames          2614276 256 to 511 byte frames
       997620 512 to 1023 byte frames          737452 512 to 1023 byte frames
     33693338 1024 to 1518 byte frames        3615504 1024 to 1518 byte frames
------------------ show user ------------------
    Line       User       Host(s)              Idle       Location
*  2 vty 0     admjkude   idle                 00:00:07 10.10.5.52
  Interface    User               Mode         Idle     Peer Address
------------------ show logging ------------------
Syslog logging: enabled (0 messages dropped, 293 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level critical, 4 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 364301 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
    Trap logging: level informational, 366041 message lines logged
        Logging to 10.1.1.123  (udp port 514, audit disabled,
              link up),
              365775 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.1.5.239  (udp port 514, audit disabled,
              link up),
              filtering disabled
        Logging Source-Interface:       VRF Name:
Log Buffer (16000 bytes):
itEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363903: .Jan 13 06:24:10.728 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363904: .Jan 13 06:24:54.925 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363905: Jan 13 06:25:10.728 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363906: .Jan 13 06:25:54.925 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363907: .Jan 13 06:26:10.728 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363908: .Jan 13 06:26:54.925 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363909: .Jan 13 06:27:10.727 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363910: .Jan 13 06:27:54.924 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363911: .Jan 13 06:28:10.727 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363912: .Jan 13 06:28:54.924 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363913: .Jan 13 06:29:10.726 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363914: .Jan 13 06:29:54.924 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363915: .Jan 13 06:30:10.726 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363916: .Jan 13 06:30:54.924 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363917: .Jan 13 06:31:10.725 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363918: .Jan 13 06:31:54.923 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363919: .Jan 13 06:32:10.726 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363920: .Jan 13 06:32:54.923 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363921: .Jan 13 06:33:10.725 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363922: .Jan 13 06:33:54.923 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363923: .Jan 13 06:34:10.724 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363924: .Jan 13 06:34:53.389 PST: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.10.20.90 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-md5' Succeeded
363925: .Jan 13 06:34:53.414 PST: %SSH-5-SSH2_USERAUTH: User 'svc-prime' authentication for SSH2 Session from 10.10.20.90 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-md5' Succeeded
363926: .Jan 13 06:34:53.506 PST: %PARSER-5-CFGLOG_LOGGEDCMD: User:svc-prime  logged command:!exec: enable
363927: .Jan 13 06:34:54.922 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363928: .Jan 13 06:35:06.063 PST: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.10.20.90 (tty = 0) for user 'svc-prime' using crypto cipher 'aes128-cbc', hmac 'hmac-md5' closed
363929: .Jan 13 06:35:10.724 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363930: .Jan 13 06:35:54.922 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363931: .Jan 13 06:36:10.724 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363932: .Jan 13 06:36:54.922 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363933: .Jan 13 06:37:10.723 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363934: .Jan 13 06:37:54.922 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363935: Jan 13 06:38:10.723 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363936: .Jan 13 06:38:54.921 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363937: .Jan 13 06:39:10.723 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363938: .Jan 13 06:39:54.921 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363939: .Jan 13 06:40:10.722 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363940: .Jan 13 06:40:54.921 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363941: .Jan 13 06:41:10.722 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363942: .Jan 13 06:41:54.920 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363943: .Jan 13 06:42:10.721 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363944: .Jan 13 06:42:54.920 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363945: .Jan 13 06:43:10.729 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363946: .Jan 13 06:43:54.920 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363947: .Jan 13 06:44:10.720 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363948: .Jan 13 06:44:54.919 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363949: .Jan 13 06:45:10.720 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363950: Jan 13 06:45:54.919 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363951: Jan 13 06:46:10.719 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363952: .Jan 13 06:46:54.920 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363953: .Jan 13 06:47:10.719 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363954: .Jan 13 06:47:54.919 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363955: .Jan 13 06:48:10.719 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363956: .Jan 13 06:48:54.918 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363957: .Jan 13 06:49:10.718 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363958: Jan 13 06:49:54.919 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363959: .Jan 13 06:50:10.718 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363960: .Jan 13 06:50:16.697 PST: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.10.20.90 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-md5' Succeeded
363961: .Jan 13 06:50:16.714 PST: %SSH-5-SSH2_USERAUTH: User 'svc-prime' authentication for SSH2 Session from 10.10.20.90 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-md5' Succeeded
363962: .Jan 13 06:50:16.787 PST: %PARSER-5-CFGLOG_LOGGEDCMD: User:svc-prime  logged command:!exec: enable
363963: .Jan 13 06:50:31.378 PST: %SSH-5-SSH2_CLOSE: SSH2 Session from 10.10.20.90 (tty = 0) for user 'svc-prime' using crypto cipher 'aes128-cbc', hmac 'hmac-md5' closed
363964: .Jan 13 06:50:54.918 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363965: Jan 13 06:51:10.722 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363966: .Jan 13 06:51:54.918 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363967: .Jan 13 06:52:10.717 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363968: .Jan 13 06:52:54.917 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363969: Jan 13 06:53:10.717 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363970: Jan 13 06:53:54.917 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363971: .Jan 13 06:54:10.716 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363972: Jan 13 06:54:54.917 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363973: .Jan 13 06:55:10.716 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363974: Jan 13 06:55:54.916 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363975: .Jan 13 06:56:10.715 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363976: Jan 13 06:56:54.916 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363977: .Jan 13 06:57:10.715 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363978: .Jan 13 06:57:54.916 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363979: .Jan 13 06:58:10.715 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363980: Jan 13 06:58:54.915 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363981: Jan 13 06:59:10.714 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363982: .Jan 13 06:59:54.915 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363983: .Jan 13 07:00:10.714 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363984: Jan 13 07:00:54.915 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363985: Jan 13 07:01:10.714 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363986: .Jan 13 07:01:54.915 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363987: .Jan 13 07:02:10.713 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363988: Jan 13 07:02:54.914 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363989: Jan 13 07:03:10.713 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363990: Jan 13 07:03:30.518 PST: %SEC-6-IPACCESSLOGS: list 2 denied 10.2.2.31 1 packet
363991: .Jan 13 07:03:54.914 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363992: .Jan 13 07:04:10.712 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
363993: .Jan 13 07:04:36.624 PST: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.10.5.52 (tty = 0) using crypto cipher 'aes256-cbc', hmac 'hmac-sha1' Succeeded
363994: Jan 13 07:04:43.397 PST: %SSH-5-SSH2_USERAUTH: User 'admjkude' authentication for SSH2 Session from 10.10.5.52 (tty = 0) using crypto cipher 'aes256-cbc', hmac 'hmac-sha1' Succeeded
363995: Jan 13 07:04:54.914 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/4 (not half duplex), with SEP0004f2f5a9e1 port 1 (half duplex).
363996: .Jan 13 07:05:10.712 PST: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/17 (not half duplex), with SEP0004f2f5a87d port 1 (half duplex).
------------------ show env all ------------------
Switch 1 FAN 1 is OK
Switch 1 FAN 2 is OK
Switch 1 FAN 3 is OK
FAN PS-1 is OK
FAN PS-2 is OK
Switch 2 FAN 1 is OK
Switch 2 FAN 2 is OK
Switch 2 FAN 3 is OK
FAN PS-1 is OK
FAN PS-2 is OK
Switch 3 FAN 1 is OK
Switch 3 FAN 2 is OK
Switch 3 FAN 3 is OK
FAN PS-1 is OK
FAN PS-2 is OK
Switch 1: SYSTEM TEMPERATURE is OK
Switch 2: SYSTEM TEMPERATURE is OK
Switch 3: SYSTEM TEMPERATURE is OK
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  PWR-C1-1100WAC      LIT18310ZRG  OK              Good     Good     1100
1B  PWR-C1-1100WAC      LIT1831102U  OK              Good     Good     1100
2A  PWR-C1-1100WAC      LIT183110AZ  OK              Good     Good     1100
2B  PWR-C1-1100WAC      LIT18310MAR  OK              Good     Good     1100
3A  PWR-C1-1100WAC      LIT18311112  OK              Good     Good     1100
3B  PWR-C1-1100WAC      DTN1841V0XW  OK              Good     Good     1100
------------------ show interfaces status ------------------
Port      Name               Status       Vlan       Duplex  Speed       Type
Gi1/0/1                      notconnect   999          full    100 10/100/1000BaseTX
Gi1/0/2                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/3                      notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/4                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/5                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/6                      notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/7                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/8                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/9                      connected    380          full    100 10/100/1000BaseTX
Gi1/0/10                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/11                     notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/12                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/13                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/14                     notconnect   380          full    100 10/100/1000BaseTX
Gi1/0/15                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/16                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/17                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/18                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/19                     notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/20                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/21                     notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/22                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/23                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/24                     notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/25                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/26                     notconnect   380          auto    100 10/100/1000BaseTX
Gi1/0/27                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/28                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/29                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/30                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/31                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/32                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/33                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/34                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/35                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/36                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/37                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/38                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/39                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/40                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/41                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/42                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/43                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/44                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/45                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/46                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/47                     connected    380          full    100 10/100/1000BaseTX
Gi1/0/48                     connected    380          full    100 10/100/1000BaseTX
Gi1/1/1   Trunk to 19th Floo connected    trunk        full   1000 1000BaseSX SFP
Gi1/1/2   Trunk to 19th Floo connected    trunk        full   1000 1000BaseSX SFP
Gi1/1/3                      notconnect   1            auto   auto unknown
Gi1/1/4                      notconnect   1            auto   auto unknown
Gi2/0/1                      notconnect   380          auto   auto 10/100/1000BaseTX
Gi2/0/2                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/3                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/4                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/5                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/6                      connected    380          full    100 10/100/1000BaseTX
Gi2/0/7                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/8                      notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/9                      connected    380          full    100 10/100/1000BaseTX
Gi2/0/10                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/11                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/12                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/13                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/14                     notconnect   380          full    100 10/100/1000BaseTX
Gi2/0/15                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/16                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/17                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/18                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/19                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/20                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/21                     notconnect   380          full    100 10/100/1000BaseTX
Gi2/0/22                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/23                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/24                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/25                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/26                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/27                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/28                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/29                     notconnect   380          full    100 10/100/1000BaseTX
Gi2/0/30                     notconnect   380          auto    100 10/100/1000BaseTX
Gi2/0/31                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/32                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/33                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/34                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/35                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/36                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/37                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/38                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/39                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/40                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/41                     notconnect   380          full    100 10/100/1000BaseTX
Gi2/0/42                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/43                     connected    380        a-full a-1000 10/100/1000BaseTX
Gi2/0/44                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/45                     notconnect   380          full    100 10/100/1000BaseTX
Gi2/0/46                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/47                     connected    380          full    100 10/100/1000BaseTX
Gi2/0/48                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/1   WAP                connected    380        a-full a-1000 10/100/1000BaseTX
Gi3/0/2   WAP                connected    380          full   1000 10/100/1000BaseTX
Gi3/0/3   WAP                connected    380          full   1000 10/100/1000BaseTX
Gi3/0/4   WAP                connected    380          full   1000 10/100/1000BaseTX
Gi3/0/5   WAP                notconnect   380          auto   1000 10/100/1000BaseTX
Gi3/0/6   WAP                notconnect   380          auto   1000 10/100/1000BaseTX
Gi3/0/7   WAP                notconnect   380          full   1000 10/100/1000BaseTX
Gi3/0/8                      connected    380          full    100 10/100/1000BaseTX
Gi3/0/9                      connected    380          full    100 10/100/1000BaseTX
Gi3/0/10                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/11                     connected    1            full    100 10/100/1000BaseTX
Gi3/0/12                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/13                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/14                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/15                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/16                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/17                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/18                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/19                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/20                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/21                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/22                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/23                     notconnect   380          full    100 10/100/1000BaseTX
Gi3/0/24                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/25                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/26                     connected    1            full    100 10/100/1000BaseTX
Gi3/0/27                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/28                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/29                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/30                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/31                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/32                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/33                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/34                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/35                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/36                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/37                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/38                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/39                     notconnect   380          auto    100 10/100/1000BaseTX
Gi3/0/40                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/41                     notconnect   380          full    100 10/100/1000BaseTX
Gi3/0/42                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/43                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/44                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/45                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/46                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/47                     connected    380          full    100 10/100/1000BaseTX
Gi3/0/48                     connected    380          full    100 10/100/1000BaseTX
Po1       Trunk              connected    trunk      a-full a-1000
------------------ show interfaces status err-disabled ------------------
------------------ show interfaces switchport ------------------
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 999 (Marketing_DSL)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 385 (VLAN0385)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: trusted
Switchport: Enabled
Operational Mode: static access
Operational Trunking Encapsulation: native
Access Mode VLAN: 380 (VLAN0380)
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk (member of bundle Po1)
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Voice VLAN: none
Pruning VLANs Enabled: NONE
Protected: false
Appliance trust: none
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Administrative Mode: static access
Voice VLAN: none
Protected: false
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Protected: false
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Switchport: Enabled
Voice VLAN: none
Protected: false
------------------ show interfaces trunk ------------------
Port        Mode             Encapsulation  Status        Native vlan
Po1         on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po1         1-4094
Port        Vlans allowed and active in management domain
Po1         1,4-10,15,20,30,41-44,60,80,85,101,110,115,140,145,170,175,180,185,190,194-195,197-200,205,210-212,215,220,225,252,380,385,990,998-999
Port        Vlans in spanning tree forwarding state and not pruned
------------------ show vlan ------------------
VLAN Name                             Status    Ports
1    default                          active    Gi1/1/3, Gi1/1/4, Gi3/0/11, Gi3/0/26
4    Telco                            active
5    Servers                          active
6    Servers_6                        active
7    Fidelity                         active
8    Servers_8                        active
9    WAAS                             active
10   1st_Floor                        active
15   1st_Floor_Telco                  active
20   Core_Switch_Mgmt                 active
30   Server_DRAC                      active
41   Telco_10.1.4.128/29              active
42   Telco_10.1.4.136/29              active
43   Telco_10.1.4.144/29              active
44   Telco_10.1.4.152/29              active
60   WAP                              active
80   8th_Floor                        active
85   8th_Floor_Telco                  active
101  1st_Floor_MFP                    active
110  11th_Floor                       active
115  11th_Floor_Telco                 active
140  14th_Floor                       active
145  14th_Floor_Telco                 active
170  17th_Floor                       active
175  17th_Floor_Telco                 active
180  18th_Floor                       active
185  18th_Floor_Telco                 active
190  19th_Floor                       active
194  19th_Floor_Wifi                  active
195  19th_Floor_Telco                 active
197  IT_Test_VoIP                     active
198  IT_Test                          active
199  Win7_Imaging                     active
200  20th_Floor                       active
205  20th_Floor_Telco                 active
210  21st_Floor                       active
211  21st_Floor_MFP                   active
212  SWIFT_Users                      active
215  21st_Floor_Telco                 active
220  22nd_Floor                       active
225  22nd_Floor_Telco                 active
252  PAN-OS_Test                      active
380  VLAN0380                         active    Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17
                                                Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21, Gi1/0/22, Gi1/0/23, Gi1/0/24, Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi1/0/28, Gi1/0/29, Gi1/0/30, Gi1/0/31, Gi1/0/32
                                                Gi1/0/33, Gi1/0/34, Gi1/0/35, Gi1/0/36, Gi1/0/37, Gi1/0/38, Gi1/0/39, Gi1/0/40, Gi1/0/41, Gi1/0/42, Gi1/0/43, Gi1/0/44, Gi1/0/45, Gi1/0/46, Gi1/0/47
                                                Gi1/0/48, Gi2/0/1, Gi2/0/2, Gi2/0/3, Gi2/0/4, Gi2/0/5, Gi2/0/6, Gi2/0/7, Gi2/0/8, Gi2/0/9, Gi2/0/10, Gi2/0/11, Gi2/0/12, Gi2/0/13, Gi2/0/14, Gi2/0/15
                                                Gi2/0/16, Gi2/0/17, Gi2/0/18, Gi2/0/19, Gi2/0/20, Gi2/0/21, Gi2/0/22, Gi2/0/23, Gi2/0/24, Gi2/0/25, Gi2/0/26, Gi2/0/27, Gi2/0/28, Gi2/0/29, Gi2/0/30
                                                Gi2/0/31, Gi2/0/32, Gi2/0/33, Gi2/0/34, Gi2/0/35, Gi2/0/36, Gi2/0/37, Gi2/0/38, Gi2/0/39, Gi2/0/40, Gi2/0/41, Gi2/0/42, Gi2/0/43, Gi2/0/44, Gi2/0/45
                                                Gi2/0/46, Gi2/0/47, Gi2/0/48, Gi3/0/1, Gi3/0/2, Gi3/0/3, Gi3/0/4, Gi3/0/5, Gi3/0/6, Gi3/0/7, Gi3/0/8, Gi3/0/9, Gi3/0/10, Gi3/0/12, Gi3/0/13, Gi3/0/14
                                                Gi3/0/15, Gi3/0/16, Gi3/0/17, Gi3/0/18, Gi3/0/19, Gi3/0/20, Gi3/0/21, Gi3/0/22, Gi3/0/23, Gi3/0/24, Gi3/0/25, Gi3/0/27, Gi3/0/28, Gi3/0/29, Gi3/0/30
                                                Gi3/0/31, Gi3/0/32, Gi3/0/33, Gi3/0/34, Gi3/0/35, Gi3/0/36, Gi3/0/37, Gi3/0/38, Gi3/0/39, Gi3/0/40, Gi3/0/41, Gi3/0/42, Gi3/0/43, Gi3/0/44, Gi3/0/45
                                                Gi3/0/46, Gi3/0/47, Gi3/0/48
385  VLAN0385                         active    Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16
                                                Gi1/0/17, Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21, Gi1/0/22, Gi1/0/23, Gi1/0/24, Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi1/0/28, Gi1/0/29, Gi1/0/30, Gi1/0/31
                                                Gi1/0/32, Gi1/0/33, Gi1/0/34, Gi1/0/35, Gi1/0/36, Gi1/0/37, Gi1/0/38, Gi1/0/39, Gi1/0/40, Gi1/0/41, Gi1/0/42, Gi1/0/43, Gi1/0/44, Gi1/0/45, Gi1/0/46
                                                Gi1/0/47, Gi1/0/48, Gi2/0/1, Gi2/0/2, Gi2/0/3, Gi2/0/4, Gi2/0/5, Gi2/0/6, Gi2/0/7, Gi2/0/8, Gi2/0/9, Gi2/0/10, Gi2/0/11, Gi2/0/12, Gi2/0/13, Gi2/0/14
                                                Gi2/0/15, Gi2/0/16, Gi2/0/17, Gi2/0/18, Gi2/0/19, Gi2/0/20, Gi2/0/21, Gi2/0/22, Gi2/0/23, Gi2/0/24, Gi2/0/25, Gi2/0/26, Gi2/0/27, Gi2/0/28, Gi2/0/29
                                                Gi2/0/30, Gi2/0/31, Gi2/0/32, Gi2/0/33, Gi2/0/34, Gi2/0/35, Gi2/0/36, Gi2/0/37, Gi2/0/38, Gi2/0/39, Gi2/0/40, Gi2/0/41, Gi2/0/42, Gi2/0/43, Gi2/0/44
                                                Gi2/0/45, Gi2/0/46, Gi2/0/47, Gi2/0/48, Gi3/0/8, Gi3/0/9, Gi3/0/10, Gi3/0/11, Gi3/0/12, Gi3/0/13, Gi3/0/14, Gi3/0/15, Gi3/0/16, Gi3/0/17, Gi3/0/18, Gi3/0/19
                                                Gi3/0/20, Gi3/0/21, Gi3/0/22, Gi3/0/23, Gi3/0/24, Gi3/0/25, Gi3/0/26, Gi3/0/27, Gi3/0/28, Gi3/0/29, Gi3/0/30, Gi3/0/31, Gi3/0/32, Gi3/0/33, Gi3/0/34
                                                Gi3/0/35, Gi3/0/36, Gi3/0/37, Gi3/0/38, Gi3/0/39, Gi3/0/40, Gi3/0/41, Gi3/0/42, Gi3/0/43, Gi3/0/44, Gi3/0/45, Gi3/0/46, Gi3/0/47, Gi3/0/48
990  VLAN0990                         active
998  DMZ_Visitors                     active
999  Marketing_DSL                    active    Gi1/0/1
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
4    enet  100004     1500  -      -      -        -    -        0      0
5    enet  100005     1500  -      -      -        -    -        0      0
6    enet  100006     1500  -      -      -        -    -        0      0
7    enet  100007     1500  -      -      -        -    -        0      0
8    enet  100008     1500  -      -      -        -    -        0      0
9    enet  100009     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
15   enet  100015     1500  -      -      -        -    -        0      0
20   enet  100020     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
41   enet  100041     1500  -      -      -        -    -        0      0
42   enet  100042     1500  -      -      -        -    -        0      0
43   enet  100043     1500  -      -      -        -    -        0      0
44   enet  100044     1500  -      -      -        -    -        0      0
60   enet  100060     1500  -      -      -        -    -        0      0
80   enet  100080     1500  -      -      -        -    -        0      0
85   enet  100085     1500  -      -      -        -    -        0      0
101  enet  100101     1500  -      -      -        -    -        0      0
110  enet  100110     1500  -      -      -        -    -        0      0
115  enet  100115     1500  -      -      -        -    -        0      0
140  enet  100140     1500  -      -      -        -    -        0      0
145  enet  100145     1500  -      -      -        -    -        0      0
170  enet  100170     1500  -      -      -        -    -        0      0
175  enet  100175     1500  -      -      -        -    -        0      0
180  enet  100180     1500  -      -      -        -    -        0      0
185  enet  100185     1500  -      -      -        -    -        0      0
190  enet  100190     1500  -      -      -        -    -        0      0
194  enet  100194     1500  -      -      -        -    -        0      0
195  enet  100195     1500  -      -      -        -    -        0      0
197  enet  100197     1500  -      -      -        -    -        0      0
198  enet  100198     1500  -      -      -        -    -        0      0
199  enet  100199     1500  -      -      -        -    -        0      0
200  enet  100200     1500  -      -      -        -    -        0      0
205  enet  100205     1500  -      -      -        -    -        0      0
210  enet  100210     1500  -      -      -        -    -        0      0
211  enet  100211     1500  -      -      -        -    -        0      0
212  enet  100212     1500  -      -      -        -    -        0      0
215  enet  100215     1500  -      -      -        -    -        0      0
220  enet  100220     1500  -      -      -        -    -        0      0
225  enet  100225     1500  -      -      -        -    -        0      0
252  enet  100252     1500  -      -      -        -    -        0      0
380  enet  100380     1500  -      -      -        -    -        0      0
385  enet  100385     1500  -      -      -        -    -        0      0
990  enet  100990     1500  -      -      -        -    -        0      0
998  enet  100998     1500  -      -      -        -    -        0      0
999  enet  100999     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 trcrf 101003     4472  1005   3276   -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trbrf 101005     4472  -      -      15       ibm  -        0      0
VLAN AREHops STEHops Backup CRF
1003 7       7       off
Remote SPAN VLANs
Primary Secondary Type              Ports
------------------ show spanning-tree ------------------
VLAN0001
  Spanning tree enabled protocol rstp
  Root ID    Priority    1
             Address     0008.e3ff.fc28
             Cost        3
             Port        2027 (Port-channel1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    61441  (priority 61440 sys-id-ext 1)
             Address     f09e.63dc.2a00
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi3/0/11            Desg FWD 19        128.139  P2p Edge
Gi3/0/26            Desg FWD 19        128.154  P2p Edge
Po1                 Root FWD 3         128.2027 P2p
VLAN0004
  Root ID    Priority    4
             Cost        3
  Bridge ID  Priority    61444  (priority 61440 sys-id-ext 4)
             Aging Time  300 sec
VLAN0005
  Root ID    Priority    5
             Cost        3
  Bridge ID  Priority    61445  (priority 61440 sys-id-ext 5)
             Aging Time  300 sec
VLAN0006
  Root ID    Priority    6
             Cost        3
  Bridge ID  Priority    61446  (priority 61440 sys-id-ext 6)
             Aging Time  300 sec
VLAN0007
  Root ID    Priority    7
             Cost        3
  Bridge ID  Priority    61447  (priority 61440 sys-id-ext 7)
             Aging Time  300 sec
VLAN0008
  Root ID    Priority    8
             Cost        3
  Bridge ID  Priority    61448  (priority 61440 sys-id-ext 8)
             Aging Time  300 sec
VLAN0009
  Root ID    Priority    9
             Cost        3
  Bridge ID  Priority    61449  (priority 61440 sys-id-ext 9)
             Aging Time  300 sec
VLAN0010
  Root ID    Priority    10
             Cost        3
  Bridge ID  Priority    61450  (priority 61440 sys-id-ext 10)
             Aging Time  300 sec
VLAN0015
  Root ID    Priority    15
             Cost        3
  Bridge ID  Priority    61455  (priority 61440 sys-id-ext 15)
             Aging Time  300 sec
VLAN0020
  Root ID    Priority    20
             Cost        3
  Bridge ID  Priority    61460  (priority 61440 sys-id-ext 20)
             Aging Time  300 sec
VLAN0030
  Root ID    Priority    30
             Cost        3
  Bridge ID  Priority    61470  (priority 61440 sys-id-ext 30)
             Aging Time  300 sec
VLAN0041
  Root ID    Priority    41
             Cost        3
  Bridge ID  Priority    61481  (priority 61440 sys-id-ext 41)
             Aging Time  300 sec
VLAN0042
  Root ID    Priority    42
             Cost        3
  Bridge ID  Priority    61482  (priority 61440 sys-id-ext 42)
             Aging Time  300 sec
VLAN0043
  Root ID    Priority    43
             Cost        3
  Bridge ID  Priority    61483  (priority 61440 sys-id-ext 43)
             Aging Time  300 sec
VLAN0044
  Root ID    Priority    44
             Cost        3
  Bridge ID  Priority    61484  (priority 61440 sys-id-ext 44)
             Aging Time  300 sec
VLAN0060
  Root ID    Priority    60
             Cost        3
  Bridge ID  Priority    61500  (priority 61440 sys-id-ext 60)
             Aging Time  300 sec
VLAN0080
  Root ID    Priority    80
             Cost        3
  Bridge ID  Priority    61520  (priority 61440 sys-id-ext 80)
             Aging Time  300 sec
VLAN0085
  Root ID    Priority    85
             Cost        3
  Bridge ID  Priority    61525  (priority 61440 sys-id-ext 85)
             Aging Time  300 sec
VLAN0101
  Root ID    Priority    101
             Cost        3
  Bridge ID  Priority    61541  (priority 61440 sys-id-ext 101)
             Aging Time  300 sec
VLAN0110
  Root ID    Priority    110
             Cost        3
  Bridge ID  Priority    61550  (priority 61440 sys-id-ext 110)
             Aging Time  300 sec
VLAN0115
  Root ID    Priority    115
             Cost        3
  Bridge ID  Priority    61555  (priority 61440 sys-id-ext 115)
             Aging Time  300 sec
VLAN0140
  Root ID    Priority    140
             Cost        3
  Bridge ID  Priority    61580  (priority 61440 sys-id-ext 140)
             Aging Time  300 sec
VLAN0145
  Root ID    Priority    145
             Cost        3
  Bridge ID  Priority    61585  (priority 61440 sys-id-ext 145)
             Aging Time  300 sec
VLAN0170
  Root ID    Priority    170
             Cost        3
  Bridge ID  Priority    61610  (priority 61440 sys-id-ext 170)
             Aging Time  300 sec
VLAN0175
  Root ID    Priority    175
             Cost        3
  Bridge ID  Priority    61615  (priority 61440 sys-id-ext 175)
             Aging Time  300 sec
VLAN0180
  Root ID    Priority    180
             Cost        3
  Bridge ID  Priority    61620  (priority 61440 sys-id-ext 180)
             Aging Time  300 sec
VLAN0185
  Root ID    Priority    185
             Cost        3
  Bridge ID  Priority    61625  (priority 61440 sys-id-ext 185)
             Aging Time  300 sec
VLAN0190
  Root ID    Priority    190
             Cost        3
  Bridge ID  Priority    61630  (priority 61440 sys-id-ext 190)
             Aging Time  300 sec
VLAN0194
  Root ID    Priority    194
             Cost        3
  Bridge ID  Priority    61634  (priority 61440 sys-id-ext 194)
             Aging Time  300 sec
VLAN0195
  Root ID    Priority    195
             Cost        3
  Bridge ID  Priority    61635  (priority 61440 sys-id-ext 195)
             Aging Time  300 sec
VLAN0197
  Root ID    Priority    197
             Cost        3
  Bridge ID  Priority    61637  (priority 61440 sys-id-ext 197)
             Aging Time  300 sec
VLAN0198
  Root ID    Priority    198
             Cost        3
  Bridge ID  Priority    61638  (priority 61440 sys-id-ext 198)
             Aging Time  300 sec
VLAN0199
  Root ID    Priority    199
             Cost        3
  Bridge ID  Priority    61639  (priority 61440 sys-id-ext 199)
             Aging Time  300 sec
VLAN0200
  Root ID    Priority    200
             Cost        3
  Bridge ID  Priority    61640  (priority 61440 sys-id-ext 200)
             Aging Time  300 sec
VLAN0205
  Root ID    Priority    205
             Cost        3
  Bridge ID  Priority    61645  (priority 61440 sys-id-ext 205)
             Aging Time  300 sec
VLAN0210
  Root ID    Priority    210
             Cost        3
  Bridge ID  Priority    61650  (priority 61440 sys-id-ext 210)
             Aging Time  300 sec
VLAN0211
  Root ID    Priority    211
             Cost        3
  Bridge ID  Priority    61651  (priority 61440 sys-id-ext 211)
             Aging Time  300 sec
VLAN0212
  Root ID    Priority    212
             Cost        3
  Bridge ID  Priority    61652  (priority 61440 sys-id-ext 212)
             Aging Time  300 sec
VLAN0215
  Root ID    Priority    215
             Cost        3
  Bridge ID  Priority    61655  (priority 61440 sys-id-ext 215)
             Aging Time  300 sec
VLAN0220
  Root ID    Priority    220
             Cost        3
  Bridge ID  Priority    61660  (priority 61440 sys-id-ext 220)
             Aging Time  300 sec
VLAN0225
  Root ID    Priority    225
             Cost        3
  Bridge ID  Priority    61665  (priority 61440 sys-id-ext 225)
             Aging Time  300 sec
VLAN0252
  Root ID    Priority    252
             Cost        3
  Bridge ID  Priority    61692  (priority 61440 sys-id-ext 252)
             Aging Time  300 sec
VLAN0380
  Root ID    Priority    380
             Cost        3
  Bridge ID  Priority    61820  (priority 61440 sys-id-ext 380)
             Aging Time  300 sec
Gi1/0/2             Desg FWD 19        128.2    P2p Edge
Gi1/0/4             Desg FWD 19        128.4    P2p Edge
Gi1/0/5             Desg FWD 19        128.5    P2p Edge
Gi1/0/7             Desg FWD 19        128.7    P2p Edge
Gi1/0/8             Desg FWD 19        128.8    P2p Edge
Gi1/0/9             Desg FWD 19        128.9    P2p Edge
Gi1/0/10            Desg FWD 19        128.10   P2p Edge
Gi1/0/12            Desg FWD 19        128.12   P2p Edge
Gi1/0/13            Desg FWD 19        128.13   P2p Edge
Gi1/0/15            Desg FWD 19        128.15   P2p Edge
Gi1/0/16            Desg FWD 19        128.16   P2p Edge
Gi1/0/17            Desg FWD 19        128.17   P2p Edge
Gi1/0/18            Desg FWD 19        128.18   P2p Edge
Gi1/0/20            Desg FWD 19        128.20   P2p Edge
Gi1/0/22            Desg FWD 19        128.22   P2p Edge
Gi1/0/23            Desg FWD 19        128.23   P2p Edge
Gi1/0/25            Desg FWD 19        128.25   P2p Edge
Gi1/0/27            Desg FWD 19        128.27   P2p Edge
Gi1/0/28            Desg FWD 19        128.28   P2p Edge
Gi1/0/29            Desg FWD 19        128.29   P2p Edge
Gi1/0/30            Desg FWD 19        128.30   P2p Edge
Gi1/0/31            Desg FWD 19        128.31   P2p Edge
Gi1/0/32            Desg FWD 19        128.32   P2p Edge
Gi1/0/33            Desg FWD 19        128.33   P2p Edge
Gi1/0/34            Desg FWD 19        128.34   P2p Edge
Gi1/0/35            Desg FWD 19        128.35   P2p Edge
Gi1/0/36            Desg FWD 19        128.36   P2p Edge
Gi1/0/37            Desg FWD 19        128.37   P2p Edge
Gi1/0/38            Desg FWD 19        128.38   P2p Edge
Gi1/0/39            Desg FWD 19        128.39   P2p Edge
Gi1/0/40            Desg FWD 19        128.40   P2p Edge
Gi1/0/41            Desg FWD 19        128.41   P2p Edge
Gi1/0/42            Desg FWD 19        128.42   P2p Edge
Gi1/0/43            Desg FWD 19        128.43   P2p Edge
Gi1/0/44            Desg FWD 19        128.44   P2p Edge
Gi1/0/45            Desg FWD 19        128.45   P2p Edge
Gi1/0/46            Desg FWD 19        128.46   P2p Edge
Gi1/0/47            Desg FWD 19        128.47   P2p Edge
Gi1/0/48            Desg FWD 19        128.48   P2p Edge
Gi2/0/6             Desg FWD 19        128.70   P2p Edge
Gi2/0/9             Desg FWD 19        128.73   P2p Edge
Gi2/0/11            Desg FWD 19        128.75   P2p Edge
Gi2/0/12            Desg FWD 19        128.76   P2p Edge
Gi2/0/13            Desg FWD 19        128.77   P2p Edge
Gi2/0/15            Desg FWD 19        128.79   P2p Edge
Gi2/0/17            Desg FWD 19        128.81   P2p Edge
Gi2/0/19            Desg FWD 19        128.83   P2p Edge
Gi2/0/20            Desg FWD 19        128.84   P2p Edge
Gi2/0/24            Desg FWD 19        128.88   P2p Edge
Gi2/0/26            Desg FWD 19        128.90   P2p Edge
Gi2/0/28            Desg FWD 19        128.92   P2p Edge
Gi2/0/31            Desg FWD 19        128.95   P2p Edge
Gi2/0/32            Desg FWD 19        128.96   P2p Edge
Gi2/0/33            Desg FWD 19        128.97   P2p Edge
Gi2/0/34            Desg FWD 19        128.98   P2p Edge
Gi2/0/35            Desg FWD 19        128.99   P2p Edge
Gi2/0/36            Desg FWD 19        128.100  P2p Edge
Gi2/0/37            Desg FWD 19        128.101  P2p Edge
Gi2/0/38            Desg FWD 19        128.102  P2p Edge
Gi2/0/39            Desg FWD 19        128.103  P2p Edge
Gi2/0/40            Desg FWD 19        128.104  P2p Edge
Gi2/0/42            Desg FWD 19        128.106  P2p Edge
Gi2/0/43            Desg FWD 4         128.107  P2p Edge
Gi2/0/44            Desg FWD 19        128.108  P2p Edge
Gi2/0/46            Desg FWD 19        128.110  P2p Edge
Gi2/0/47            Desg FWD 19        128.111  P2p Edge
Gi2/0/48            Desg FWD 19        128.112  P2p Edge
Gi3/0/1             Desg FWD 4         128.129  P2p Edge
Gi3/0/2             Desg FWD 4         128.130  P2p Edge
Gi3/0/3             Desg FWD 4         128.131  P2p Edge
Gi3/0/4             Desg FWD 4         128.132  P2p Edge
Gi3/0/8             Desg FWD 19        128.136  P2p Edge
Gi3/0/9             Desg FWD 19        128.137  P2p Edge
Gi3/0/10            Desg FWD 19        128.138  P2p Edge
Gi3/0/12            Desg FWD 19        128.140  P2p Edge
Gi3/0/13            Desg FWD 19        128.141  P2p Edge
Gi3/0/14            Desg FWD 19        128.142  P2p Edge
Gi3/0/15            Desg FWD 19        128.143  P2p Edge
Gi3/0/16            Desg FWD 19        128.144  P2p Edge
Gi3/0/17            Desg FWD 19        128.145  P2p Edge
Gi3/0/18            Desg FWD 19        128.146  P2p Edge
Gi3/0/19            Desg FWD 19        128.147  P2p Edge
Gi3/0/20            Desg FWD 19        128.148  P2p Edge
Gi3/0/29            Desg FWD 19        128.157  P2p Edge
Gi3/0/31            Desg FWD 19        128.159  P2p Edge
Gi3/0/32            Desg FWD 19        128.160  P2p Edge
Gi3/0/34            Desg FWD 19        128.162  P2p Edge
Gi3/0/35            Desg FWD 19        128.163  P2p Edge
Gi3/0/36            Desg FWD 19        128.164  P2p Edge
Gi3/0/37            Desg FWD 19        128.165  P2p Edge
Gi3/0/38            Desg FWD 19        128.166  P2p Edge
Gi3/0/40            Desg FWD 19        128.168  P2p Edge
Gi3/0/42            Desg FWD 19        128.170  P2p Edge
Gi3/0/43            Desg FWD 19        128.171  P2p Edge
Gi3/0/44            Desg FWD 19        128.172  P2p Edge
Gi3/0/45            Desg FWD 19        128.173  P2p Edge
Gi3/0/46            Desg FWD 19        128.174  P2p Edge
Gi3/0/47            Desg FWD 19        128.175  P2p Edge
Gi3/0/48            Desg FWD 19        128.176  P2p Edge
VLAN0385
  Root ID    Priority    385
             Cost        3
  Bridge ID  Priority    61825  (priority 61440 sys-id-ext 385)
             Aging Time  300 sec
VLAN0990
  Root ID    Priority    990
             Cost        3
  Bridge ID  Priority    62430  (priority 61440 sys-id-ext 990)
             Aging Time  300 sec
VLAN0998
  Root ID    Priority    998
             Cost        3
  Bridge ID  Priority    62438  (priority 61440 sys-id-ext 998)
             Aging Time  300 sec
VLAN0999
  Root ID    Priority    999
             Cost        3
  Bridge ID  Priority    62439  (priority 61440 sys-id-ext 999)
             Aging Time  300 sec
------------------ show etherchannel summary ------------------
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi1/1/1(P)  Gi1/1/2(P)
------------------ show cef linecard ------------------
 Slot   Flags
*2      up
VRF IPv4:Mgmt-vrf, 8 routes
Slot    I/Fs State    Flags
2          0 Active   sync, table-up
VRF IPv4:Default, 14 routes
2         58 Active   sync, table-up
VRF IPv6:Default, 2 routes
------------------ show data-corruption ------------------
No data inconsistency errors have been recorded.
------------------ show memory statistics ------------------
------------------ show process memory ------------------
System memory  : 4004464K total, 1880716K used, 2123748K free, 150332K kernel reserved
Lowest(b)      : 1005124224
PID     Text         Data      Stack     Heap      RSS       Total     Process
1       320          372       88        268       1736      4596      init
2       0            0         0         0         0         0         kthreadd
3       0            0         0         0         0         0         migration/0
4       0            0         0         0         0         0         sirq-high/0
5       0            0         0         0         0         0         sirq-timer/0
6       0            0         0         0         0         0         sirq-net-tx/0
7       0            0         0         0         0         0         sirq-net-rx/0
8       0            0         0         0         0         0         sirq-block/0
9       0            0         0         0         0         0         sirq-block-iopo
10      0            0         0         0         0         0         sirq-tasklet/0
11      0            0         0         0         0         0         sirq-sched/0
12      0            0         0         0         0         0         sirq-hrtimer/0
13      0            0         0         0         0         0         sirq-rcu/0
14      0            0         0         0         0         0         desched/0
15      0            0         0         0         0         0         migration/1
16      0            0         0         0         0         0         sirq-high/1
17      0            0         0         0         0         0         sirq-timer/1
18      0            0         0         0         0         0         sirq-net-tx/1
19      0            0         0         0         0         0         sirq-net-rx/1
20      0            0         0         0         0         0         sirq-block/1
21      0            0         0         0         0         0         sirq-block-iopo
22      0            0         0         0         0         0         sirq-tasklet/1
23      0            0         0         0         0         0         sirq-sched/1
24      0            0         0         0         0         0         sirq-hrtimer/1
25      0            0         0         0         0         0         sirq-rcu/1
26      0            0         0         0         0         0         desched/1
27      0            0         0         0         0         0         migration/2
28      0            0         0         0         0         0         sirq-high/2
29      0            0         0         0         0         0         sirq-timer/2
30      0            0         0         0         0         0         sirq-net-tx/2
31      0            0         0         0         0         0         sirq-net-rx/2
32      0            0         0         0         0         0         sirq-block/2
33      0            0         0         0         0         0         sirq-block-iopo
34      0            0         0         0         0         0         sirq-tasklet/2
35      0            0         0         0         0         0         sirq-sched/2
36      0            0         0         0         0         0         sirq-hrtimer/2
37      0            0         0         0         0         0         sirq-rcu/2
38      0            0         0         0         0         0         desched/2
39      0            0         0         0         0         0         migration/3
40      0            0         0         0         0         0         sirq-high/3
41      0            0         0         0         0         0         sirq-timer/3
42      0            0         0         0         0         0         sirq-net-tx/3
43      0            0         0         0         0         0         sirq-net-rx/3
44      0            0         0         0         0         0         sirq-block/3
45      0            0         0         0         0         0         sirq-block-iopo
46      0            0         0         0         0         0         sirq-tasklet/3
47      0            0         0         0         0         0         sirq-sched/3
48      0            0         0         0         0         0         sirq-hrtimer/3
49      0            0         0         0         0         0         sirq-rcu/3
50      0            0         0         0         0         0         desched/3
51      0            0         0         0         0         0         events/0
52      0            0         0         0         0         0         events/1
53      0            0         0         0         0         0         events/2
54      0            0         0         0         0         0         events/3
55      0            0         0         0         0         0         khelper
58      0            0         0         0         0         0         netns
60      0            0         0         0         0         0         async/mgr
158     0            0         0         0         0         0         sync_supers
160     0            0         0         0         0         0         bdi-default
162     0            0         0         0         0         0         kblockd/0
163     0            0         0         0         0         0         kblockd/1
164     0            0         0         0         0         0         kblockd/2
165     0            0         0         0         0         0         kblockd/3
171     0            0         0         0         0         0         ata/0
172     0            0         0         0         0         0         ata/1
173     0            0         0         0         0         0         ata/2
174     0            0         0         0         0         0         ata/3
175     0            0         0         0         0         0         ata_aux
183     0            0         0         0         0         0         khubd
210     0            0         0         0         0         0         rpciod/0
211     0            0         0         0         0         0         rpciod/1
212     0            0         0         0         0         0         rpciod/2
213     0            0         0         0         0         0         rpciod/3
229     0            0         0         0         0         0         kswapd0
230     0            0         0         0         0         0         aio/0
231     0            0         0         0         0         0         aio/1
232     0            0         0         0         0         0         aio/2
233     0            0         0         0         0         0         aio/3
234     0            0         0         0         0         0         nfsiod
236     0            0         0         0         0         0         crypto/0
237     0            0         0         0         0         0         crypto/1
238     0            0         0         0         0         0         crypto/2
239     0            0         0         0         0         0         crypto/3
513     48           900       88        132       2684      15472     in.telnetd
524     16           792       88        132       2392      14980     brelay
789     0            0         0         0         0         0         pata_octeon_cf
790     0            0         0         0         0         0         scsi_eh_0
796     0            0         0         0         0         0         mtdblockd
823     0            0         0         0         0         0         octeon-ethernet
857     0            0         0         0         0         0         kstriped
859     0            0         0         0         0         0         ksnapd
937     120          356       88        256       712       2444      udevd
1268    0            0         0         0         0         0         flush-8:0
1534    0            0         0         0         0         0         loop1
1559    0            0         0         0         0         0         loop2
1584    0            0         0         0         0         0         loop3
1609    0            0         0         0         0         0         loop4
1634    0            0         0         0         0         0         loop5
1679    0            0         0         0         0         0         loop6
2359    120          292       88        256       732       2380      udevd
2360    120          292       88        256       716       2380      udevd
3258    368          168       88        132       1236      2860      dbus-daemon
3636    24           836       88        740       1120      2576      klogd
3648    16           160       88        132       464       1892      portmap
3717    216          360       88        132       988       5420      sshd
3729    144          320       88        132       812       3316      xinetd
3733    144          320       88        132       812       3316      xinetd
3767    24           836       88        740       1120      2576      lockd
3768    16           160       88        132       456       1892      nfsd
3769    216          360       88        132       988       5420      nfsd
3770    144          320       88        132       812       3316      nfsd
3771    144          320       88        132       796       3316      nfsd
3772    0            0         0         0         0         0         nfsd
3773    0            0         0         0         0         0         nfsd
3774    0            0         0         0         0         0         nfsd
3775    0            0         0         0         0         0         nfsd
3781    76           252       88        132       740       2780      rpc.mountd
5331    1420         103752    88        2356      10520     171272    system_mgr
5560    104          40720     88        544       7180      58800     slproc
5636    15040        350624    92        93644     255364    681904    fed
5637    1120         161888    92        1648      20728     254612    platform_mgr
5638    836          164500    88        4288      75008     373452    stack-mgr
6129    4            94196     116       88484     95520     113168    idope.py
6273    20           63852     88        876       6060      119880    ns_oir_proxy
6274    84           101616    88        728       7480      163944    profiled
6275    752          1008      88        960       2272      4036      oom_poll.sh
6276    1132         171036    88        3044      14484     249672    obfld
6277    40           101468    88        580       7444      163732    consoled
6278    16           60336     88        984       7552      117912    console_relay
6279    44           101616    88        712       7748      165292    csprovider
6280    48           119408    88        1196      8168      184364    system_mgr_cli
6281    44           114732    88        1184      10852     186544    plogd
6282    88           101620    88        592       7968      227672    psdprov
6283    52           113340    88        1188      24840     206348    pdsd
6284    164          90632     88        1924      13724     167636    gold_slave
6285    1016         109568    88        2300      14764     175204    osinfo-provider
6286    180          101580    88        560       7620      164092    oscore_p
6287    28           89644     88        1060      8512      149012    netd
6288    60           99800     88        1484      9980      173904    mem_mgmt
6289    48           68104     88        896       23152     156168    mgmte_tap
6290    312          185920    88        872       14016     268012    installer
6291    3532         160976    88        18780     132500    371140    ffm
6292    1232         345892    88        24416     63012     528996    eicored
6293    252          111620    88        6096      14124     201696    dtmgr
6294    208          105220    88        1052      8196      172780    cpumemd
6300    28           64440     88        304       23008     151188    liin_tap
6310    112          163040    88        11976     50412     235176    cli_agent
6311    856          345972    88        6156      145728    422800    snmp_subagent
6312    116          101080    88        1216      7708      163444    erm_p
6313    80           101696    88        612       7700      164028    ngdumper_provid
6314    36           101600    88        712       7632      163880    sysinfo_p
6327    8            9020      88        164       2664      23108     fs_cmd
8433    752          1936      88        1888      3184      4964      rollback_timer.
8742    752          1928      88        1880      2408      4956      rollback_timer.
8748    20           876       88        132       2956      19420     xlogger
8757    20           240       88        132       584       2072      inotifywait
8904    752          480       88        432       1732      3508      nova_sntp.sh
9178    752          480       88        432       948       3508      nova_sntp.sh
9183    20           876       88        132       2964      19420     xlogger
9186    56           160       88        132       716       3264      sntp
12121   21980        557212    88        14936     106584    726152    wcm
12122   192          145808    88        1476      13660     231092    table_mgr
12123   752          364       88        316       1604      3392      wnweb.sh
12124   48           106932    88        1796      11032     178332    iifd
12126   56944        37708     92        6656      202040    347356    iosd
12128   244          115528    88        1088      12432     195828    ha_mgr
13365   4            144824    236       17808     46240     241484    wnweb_paster.py
13366   20           1060      88        132       3684      23828     xlogger
16243   20           160       88        132       476       1896      sleep
16329   48           704       88        0         1460      14328     in.telnetd
------------------ show process cpu ------------------
Core 0: CPU utilization for five seconds: 37%; one minute: 22%; five minutes: 20%
Core 1: CPU utilization for five seconds: 43%; one minute: 22%; five minutes: 17%
Core 2: CPU utilization for five seconds: 36%; one minute: 18%; five minutes: 14%
Core 3: CPU utilization for five seconds: 41%; one minute: 17%; five minutes: 14%
PID     Runtime(ms) Invoked   uSecs  5Sec 1Min 5Min TTY   Process
1       30740       4983049   6      2.54 4.14 4.22 0     init
2       0           164       0      0.00 0.00 0.00 0     kthreadd
3       102010      12134433  8      0.00 0.00 0.00 0     migration/0
4       0           3         0      0.00 0.00 0.00 0     sirq-high/0
5       2315403     839039455 28     0.00 0.00 0.00 0     sirq-timer/0
6       0           33        0      0.00 0.00 0.00 0     sirq-net-tx/0
7       267032      66208346  68     0.00 0.03 0.03 0     sirq-net-rx/0
8       1450        330467    4      0.00 0.00 0.00 0     sirq-block/0
9       0           8         0      0.00 0.00 0.00 0     sirq-block-iopo
10      0           149       0      0.00 0.00 0.00 0     sirq-tasklet/0
11      88422       374976759 11     0.00 0.00 0.00 0     sirq-sched/0
12      6000        183556    32     0.00 0.00 0.00 0     sirq-hrtimer/0
13      395893      732211785 94     0.00 0.00 0.00 0     sirq-rcu/0
14      86470       20423395  4      0.00 0.01 0.01 0     desched/0
15      120090      15628031  7      0.00 0.00 0.00 0     migration/1
16      0           15        0      0.00 0.00 0.00 0     sirq-high/1
17      2564970     769713685 3      0.00 0.03 0.02 0     sirq-timer/1
18      0           80        0      0.00 0.00 0.00 0     sirq-net-tx/1
19      2946180     67324477  43     0.00 0.02 0.04 0     sirq-net-rx/1
20      1020        119469    8      0.00 0.00 0.00 0     sirq-block/1
21      0           20        0      0.00 0.00 0.00 0     sirq-block-iopo
22      0           21        0      0.00 0.00 0.00 0     sirq-tasklet/1
23      864290      396899468 2      0.00 0.00 0.00 0     sirq-sched/1
24      0           144834    0      0.00 0.00 0.00 0     sirq-hrtimer/1
25      808152      682280291 7      0.00 0.00 0.00 0     sirq-rcu/1
26      113040      24602880  4      0.00 0.00 0.02 0     desched/1
27      125940      13941060  9      0.00 0.00 0.00 0     migration/2
28      0           27        0      0.00 0.00 0.00 0     sirq-high/2
29      289550      648447953 0      0.00 0.00 0.02 0     sirq-timer/2
30      0           88        0      0.00 0.00 0.00 0     sirq-net-tx/2
31      2393340     65015175  36     0.00 0.00 0.00 0     sirq-net-rx/2
32      310         34096     9      0.00 0.00 0.00 0     sirq-block/2
33      0           32        0      0.00 0.00 0.00 0     sirq-block-iopo
34      0           33        0      0.00 0.00 0.00 0     sirq-tasklet/2
35      129090      372958968 0      0.00 0.00 0.00 0     sirq-sched/2
36      0           119731    0      0.00 0.00 0.00 0     sirq-hrtimer/2
37      461760      611323674 0      0.00 0.00 0.00 0     sirq-rcu/2
38      117170      24017155  4      0.00 0.00 0.00 0     desched/2
39      150010      15659466  9      0.00 0.00 0.00 0     migration/3
40      0           39        0      0.00 0.00 0.00 0     sirq-high/3
41      40          595118983 0      0.00 0.00 0.00 0     sirq-timer/3
42      10          104       96     0.00 0.00 0.00 0     sirq-net-tx/3
43      2174500     62616478  34     0.00 0.01 0.01 0     sirq-net-rx/3
44      120         16217     7      0.00 0.00 0.00 0     sirq-block/3
45      0           44        0      0.00 0.00 0.00 0     sirq-block-iopo
46      0           45        0      0.00 0.00 0.00 0     sirq-tasklet/3
47      30          368715920 0      0.00 0.00 0.00 0     sirq-sched/3
48      0           87667     0      0.00 0.00 0.00 0     sirq-hrtimer/3
49      50          582483573 0      0.00 0.00 0.00 0     sirq-rcu/3
50      147090      23875652  6      0.00 0.00 0.00 0     desched/3
51      941060      21234064  44     0.00 0.00 0.00 0     events/0
52      46250       12270764  3      0.00 0.00 0.00 0     events/1
53      13140       11521990  1      0.00 0.00 0.03 0     events/2
54      4230        11739882  0      0.00 0.00 0.00 0     events/3
55      60          3197      18     0.00 0.00 0.00 0     khelper
58      0           55        0      0.00 0.00 0.00 0     netns
60      0           66        0      0.00 0.00 0.00 0     async/mgr
158     72350       1356845   53     0.00 0.00 0.00 0     sync_supers
160     56510       1628594   34     0.00 0.00 0.00 0     bdi-default
162     13250       267737    49     0.00 0.00 0.00 0     kblockd/0
163     710         94570     7      0.00 0.00 0.00 0     kblockd/1
164     70          25250     2      0.00 0.00 0.00 0     kblockd/2
165     10          11047     0      0.00 0.00 0.00 0     kblockd/3
171     0           67        0      0.00 0.00 0.00 0     ata/0
172     0           66        0      0.00 0.00 0.00 0     ata/1
173     0           65        0      0.00 0.00 0.00 0     ata/2
174     0           66        0      0.00 0.00 0.00 0     ata/3
175     0           67        0      0.00 0.00 0.00 0     ata_aux
183     250         223       1121   0.00 0.00 0.00 0     khubd
210     120         3541      33     0.00 0.00 0.00 0     rpciod/0
211     180         3774      47     0.00 0.00 0.00 0     rpciod/1
212     50          3947      12     0.00 0.00 0.00 0     rpciod/2
213     90          4497      20     0.00 0.00 0.00 0     rpciod/3
229     0           77        0      0.00 0.00 0.00 0     kswapd0
230     0           78        0      0.00 0.00 0.00 0     aio/0
231     0           79        0      0.00 0.00 0.00 0     aio/1
232     0           80        0      0.00 0.00 0.00 0     aio/2
233     0           81        0      0.00 0.00 0.00 0     aio/3
234     990         14166     69     0.00 0.00 0.00 0     nfsiod
236     0           83        0      0.00 0.00 0.00 0     crypto/0
237     0           84        0      0.00 0.00 0.00 0     crypto/1
238     0           85        0      0.00 0.00 0.00 0     crypto/2
239     0           86        0      0.00 0.00 0.00 0     crypto/3
513     140         9193908   0      0.00 0.00 0.00 34816 in.telnetd
524     130         9193905   0      0.00 0.00 0.00 34816 brelay
789     3760        528639    7      0.00 0.00 0.00 0     pata_octeon_cf
790     0           97        0      0.00 0.00 0.00 0     scsi_eh_0
796     50820       6169      8237   0.63 0.63 0.63 0     mtdblockd
823     564900      13862921  40     0.00 0.00 0.01 0     octeon-ethernet
857     0           96        0      0.00 0.00 0.00 0     kstriped
859     0           97        0      0.00 0.00 0.00 0     ksnapd
937     310         1426      217    0.00 0.00 0.00 0     udevd
1268    69800       1631903   42     0.00 0.00 0.00 0     flush-8:0
1534    90          4422      20     0.00 0.00 0.00 0     loop1
1559    110         4323      25     0.00 0.00 0.00 0     loop2
1584    40          2160      18     0.00 0.00 0.00 0     loop3
1609    140         2893      48     0.00 0.00 0.00 0     loop4
1634    60          2501      23     0.00 0.00 0.00 0     loop5
1679    20          561       35     0.00 0.00 0.00 0     loop6
2359    10          1104      9      0.00 0.00 0.00 0     udevd
2360    0           1001      0      0.00 0.00 0.00 0     udevd
3258    100         1109      90     0.00 0.00 0.00 0     dbus-daemon
3636    150         1441      104    0.00 0.00 0.00 0     klogd
3648    10          1122      8      0.00 0.00 0.00 0     portmap
3717    0           956       0      0.00 0.00 0.00 0     sshd
3729    0           1038      0      0.00 0.00 0.00 0     xinetd
3733    1175630     9965406   117    1.95 3.58 3.69 0     xinetd
3767    0           112       0      0.00 0.00 0.00 0     lockd
3768    50          2376      21     0.00 0.00 0.00 0     nfsd
3769    110         2376      46     0.00 0.00 0.00 0     nfsd
3770    100         2378      42     0.00 0.00 0.00 0     nfsd
3771    30          2379      12     0.00 0.00 0.00 0     nfsd
3772    50          2570      19     0.00 0.00 0.00 0     nfsd
3773    160         2424      66     0.00 0.00 0.00 0     nfsd
3774    60          2540      23     0.00 0.00 0.00 0     nfsd
3775    90          2381      37     0.00 0.00 0.00 0     nfsd
3781    60          1156      51     0.00 0.00 0.00 0     rpc.mountd
5331    3767800     40318660  93     0.00 0.01 0.02 0     system_mgr
5560    238660      8974568   26     0.00 0.00 0.00 1088  slproc
5636    2752904     330046867 103    3.17 2.83 2.78 1088  fed
5637    287629      207079089 22     0.05 0.12 0.12 0     platform_mgr
5638    2511377     163172807 67     0.29 0.29 0.29 0     stack-mgr
6129    1660460     16263011  102    0.00 0.02 0.00 0     idope.py
6273    714500      33002221  21     0.00 0.00 0.02 0     ns_oir_proxy
6274    705150      33011249  21     0.00 0.02 0.04 0     profiled
6275    710310      803335    884    0.00 0.02 0.04 0     oom_poll.sh
6276    1619260     51272695  31     0.00 0.02 0.04 0     obfld
6277    711280      33011187  21     0.00 0.02 0.04 0     consoled
6278    2207880     41469861  53     0.00 0.01 0.03 0     console_relay
6279    710690      33011346  21     0.00 0.03 0.04 0     csprovider
6280    714920      33092636  21     0.00 0.00 0.00 0     system_mgr_cli
6281    2605190     67415563  38     0.00 0.02 0.04 0     plogd
6282    709930      33011714  21     0.00 0.00 0.00 0     psdprov
6283    1518055     105794788 54     0.24 0.15 0.15 0     pdsd
6284    991550      35128197  28     0.00 0.00 0.00 0     gold_slave
6285    806690      33120219  24     0.00 0.00 0.00 0     osinfo-provider
6286    718730      33011271  21     0.00 0.00 0.00 0     oscore_p
6287    912030      33971781  26     0.00 0.00 0.00 0     netd
6288    3968970     40326404  98     0.00 0.01 0.00 0     mem_mgmt
6289    990750      41141165  24     0.00 0.03 0.02 0     mgmte_tap
6290    725470      33053409  21     0.29 0.29 0.02 0     installer
6291    3285235     697143769 109    0.59 0.57 0.51 0     ffm
6292    3276255     171400259 69     9.23 1.16 0.60 0     eicored
6293    722160      33287546  21     0.00 0.00 0.00 0     dtmgr
6294    1988689     41100428  1197   0.15 0.14 0.14 0     cpumemd
6300    2702960     51711186  52     0.00 0.00 0.01 0     liin_tap
6310    826300      33652201  24     1.86 0.15 1.86 0     cli_agent
6311    1343648     418763365 187    0.00 0.68 0.26 0     snmp_subagent
6312    941440      41150145  22     0.00 0.00 0.02 0     erm_p
6313    923150      41150279  22     0.00 0.00 0.00 0     ngdumper_provid
6314    915520      41150315  22     0.00 0.00 0.00 0     sysinfo_p
6327    236050      8956235   26     0.00 0.00 0.00 0     fs_cmd
8433    410         1416      289    0.00 0.00 0.00 0     rollback_timer.
8742    10          1406      7      0.00 0.00 0.00 0     rollback_timer.
8748    160         1406      113    0.00 0.00 0.00 0     xlogger
8757    0           1410      0      0.00 0.00 0.00 0     inotifywait
8904    140         1181      118    0.00 0.00 0.00 0     nova_sntp.sh
9178    0           1179      0      0.00 0.00 0.00 0     nova_sntp.sh
9183    160         1179      135    0.00 0.00 0.00 0     xlogger
9186    3570        24327     146    0.00 0.00 0.00 0     sntp
12121   2303280     200138420 33     0.05 0.14 0.12 0     wcm
12122   1340885     283797579 34     0.00 0.03 0.03 0     table_mgr
12123   120         1474      81     0.00 0.00 0.00 0     wnweb.sh
12124   712770      33017346  21     0.00 0.00 0.00 0     iifd
12126   2784719     414795728 188    8.84 4.33 3.18 0     iosd
12128   2450550     43800847  55     0.05 0.04 0.03 0     ha_mgr
13365   2176800     40372385  53     0.00 0.03 0.04 0     wnweb_paster.py
13366   380         1474      257    0.00 0.00 0.00 34816 xlogger
16243   10          803335    0      0.00 0.00 0.00 34817 sleep
16329   30          9965406   0      0.00 0.00 0.00 34817 in.telnetd
------------------ show process cpu history ------------------
History information for system:
    333333333332222211111111111111111111111111111111111111111111
    900000555558888822222444443333377777444444444488888444444444
100
 90
 80
 70
 60
 50
 40 *     *****
 30 ****************
 20 ****************               *****          *****
 10 ************************************************************
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    111131141321413113122141131313314113141131412314113131131442
    867747757257168679695817787864072768616716278872771796626127
100
 90
 80
 70
 60
 50        *
 40        *    * *  *    *  * *    *  * *    *  * *    *    **
 30     *  * ** * *  * ** *  * * ** *  * *  * * ** *  * *  * ***
 20 ****#**#*#**#*#**#*##*#**#*#*##*#**#*#**#*#*##*#**#*#**#*###
 10 ############################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    444454544544445544545444455445444454444544454444554545444454444544444445
    869518554283354358332955411420964584485364507448105166569389327654454399
100
 90
 80
 70
 60       *                           *                  *    *    *       *
 50 ******** **  ****** **** **  *** **  **** ***  ********** **  ***  *  **
 40 ************************************************************************
 30 ************************************************************************
 20 ########################################################################
 10 ########################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                       CPU% per hour (last 72 hours)
History information for core 0:
    322222333332222211111111112222222222111111111122222222221111
    788888555558888800000444440000011111888887777744444888885555
100
 90
 80
 70
 60
 50
 40 *     *****
 30 ****************                                   *****
 20 ****************          **********************************
             0    5    0    5    0    5    0    5    0    5
    222233242422524223233243252424223224242232633424232243343444
    886951788083246266475830473473952247346383433245707414024330
100
 90
 80
 70
 60                          *                *
 50        *    * *          *         *      *    *
 40     *  * *  * *  * ** *  * * *     * *  * *  * *    *  * ***
 30 *********** * * ** ***** * ******  * ** * **** **** ********
             0    5    0    5    0    5    0    5    0    5
    666675655656666565556655666565565665565656655666656565655555
    202846915034125934474037452439829418706819832107280918243898
100
 90
 80
 70    ** *       *          *             * **    *            *          *
 60 ******* ** ******  *** **** ************ **  **********  **** **********
 50 ************************************************************************
History information for core 1:
    444444444441111111111111111111111111111112222211111111111111
    388888111117777766666999994444488888444443333377777111118888
100
 90
 80
 70
 60
 50  *****
 40 ***********
 30 ***********
 20 **************************     *****     **********     ****
             0    5    0    5    0    5    0    5    0    5
    222142262321524215223242142414325223261232313425124242231352
    314760115377246294880129901491730634467817775820954451019766
100
 90
 80
 70                                      *
 60        *                             *                    *
 50     *  *    * *  *              *    *       * *    *     *
 40     *  *    * *  *    *  * * ** *    *    * ** *  * *    **
 30     *  **** * *  **** ** * * ** ** * * **** ** * ** *  * ***
 20 #*#*#**#*##*#*#**#*##*##*#*#*##*##***#**###*####**#*#**#*##*
             0    5    0    5    0    5    0    5    0    5
    676666656665566665557556656666655567667676657555566667567676
    826507783549700688970772091842072611100512360088646504600330
100
 90
 80
 70 **** **  *     **   *      *       *  ***   *     ** *  * *     * *  * *
 60 ******************************** ************ ************************ *
History information for core 2:
    322222333333333311111          11111111111111111111     1111
    644444666667777700000888887777755555666660000088888888885555
100
 90
 80
 70
 60
 50
 40 *     **********
 30 *     **********
 20 ****************               **********     *****     ****
             0    5    0    5    0    5    0    5    0    5
    222121162232314125232232232323224223231132322313213242223552
    124688926305992930017080704234834669138730747586485393263516
100
 90
 80
 70
 60        *                                                 *
 50        *         *                                  *    **
 40        *    * *  *    *         *  *      *  * *  * *    **
 30     *  ** *** *  * ** * ** * ** **** *  * * ** *  * *  *****
 20 *******##***#*#**#****#****#*#**#**#*#**#*#**#*#****#****##*
             0    5    0    5    0    5    0    5    0    5
    555557655655555655666655566555566655566555555555566667665455
    533871779485413919830573963721121663603763349277750256828594
100
 90
 80                                                      *
 70      **        *  *  *   *       *               *  ***       **
 60 *  *********   * ****** ****   **** *****   * *********** *  *** ** ****
 20 *************####*####***************#*#######**************************
History information for core 3:
    411111222222222211111111111111111111          1111111111
    199999777779999900000666662222222222999998888844444000008888
100
 90
 80
 70
 60
 50
 40 *
 30 *     **********
             0    5    0    5    0    5    0    5    0    5
    121232232322312213221141121512224223132222223224212242231332
    636012660297194875398966955180655011966384986828180825128461
100
 90
 80
 70
 60
 50                       *    *    *              *
 30     * ** ****  * * *  *  * *  ***  * ** * **** *   *** * **
 20 ****#**#***##**#*#****#****#****#***********#**#****#****##*
             0    5    0    5    0    5    0    5    0    5
    556556554675555576565575656566654575655655556555665565666566
    216609767036726903018225147031187724864231194609865139241231
100
 90
 80
 70   *  *    *     *     *   *       * *           **                  **
 60   ** *** **** **** ** *** * **** ** ** *   *** **** ***** *******   ****
 20 ********************#***************************************************
------------------ show switch detail ------------------
Switch/Stack Mac Address : f09e.63dc.2a00 - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   f09e.63dc.2a00     15     V03     Ready
 2       Standby  f09e.6343.9500     1      V03     Ready
 3       Member   f09e.63dc.a380     1      V03     Ready
 4       Member   0000.0000.0000     0      0       Provisioned
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1         OK         OK               2        3
  2         OK         OK               3        1
  3         OK         OK               1        2
------------------ show platform oir states ------------------
Card #  Type    Provisioned     State
1       16385   Yes             COMPATIBLE
2       16385   Yes             COMPATIBLE_REMOTE
3       16385   Yes             COMPATIBLE_REMOTE
4       1       Yes             CREATED
5       0       No              CREATED_REMOTE
6       0       No              CREATED_REMOTE
7       0       No              CREATED_REMOTE
8       0       No              CREATED_REMOTE
9       0       No              CREATED_REMOTE
------------------ show platform ses states ------------------
Card #  Card State
1       NG3K_SES_CARD_ADD_COMPLETED(51)
2       NG3K_SES_CARD_ADD_COMPLETED(51)
3       NG3K_SES_CARD_ADD_COMPLETED(51)
4       NG3K_SES_CARD_EMPTY(0)
5       NG3K_SES_CARD_EMPTY(0)
6       NG3K_SES_CARD_EMPTY(0)
7       NG3K_SES_CARD_EMPTY(0)
8       NG3K_SES_CARD_EMPTY(0)
9       NG3K_SES_CARD_EMPTY(0)
------------------  * rtu_license.sts - RTU show cmds added to show tech-support  ------------------
------------------  * July 2012, Sunil Kumar G ------------------
------------------  * Copyright (c) 2012 by cisco Systems, Inc. ------------------
------------------  * All rights reserved. ------------------
------------------ show license right-to-use summary ------------------
  License Name    Type     Count   Period left
  ipbase       permanent   N/A      Lifetime
  apcount      base        0        Lifetime
  apcount      adder       0        Lifetime
License Level In Use: ipbase
License Level on Reboot: ipbase
Evaluation AP-Count: Disabled
Total AP Count Licenses: 0
AP Count Licenses In-use: 0
AP Count Licenses Remaining: 0
------------------ show license right-to-use ------------------
 Slot#  License name   Type     Count   Period left
 1      ipbase       permanent     N/A   Lifetime
 2      ipbase       permanent     N/A   Lifetime
 3      ipbase       permanent     N/A   Lifetime
------------------ show license right-to-use usage ------------------
 Slot#  License Name     Type     usage-duration(y:m:d)  In-Use  EULA
 1      ipservices     permanent    0 :0 :0                no    no
 1      ipservices     evaluation   0 :0 :0                no    no
 1      ipbase         permanent    0 :9 :16               yes   yes
 1      ipbase         evaluation   0 :0 :0                no    no
 1      lanbase        permanent    0 :0 :0                no    no
 1      apcount        evaluation   0 :0 :0                no    no
 1      apcount        base         0 :0 :0                no    no
 1      apcount        adder        0 :0 :0                no    no
 2      ipservices     permanent    0 :0 :0                no    no
 2      ipservices     evaluation   0 :0 :0                no    no
 2      ipbase         permanent    0 :9 :16               yes   yes
 2      ipbase         evaluation   0 :0 :0                no    no
 2      lanbase        permanent    0 :0 :0                no    no
 2      apcount        evaluation   0 :0 :0                no    no
 2      apcount        base         0 :0 :0                no    no
 2      apcount        adder        0 :0 :0                no    no
 3      ipservices     permanent    0 :0 :0                no    no
 3      ipservices     evaluation   0 :0 :0                no    no
 3      ipbase         permanent    0 :9 :16               yes   yes
 3      ipbase         evaluation   0 :0 :0                no    no
 3      lanbase        permanent    0 :0 :0                no    no
 3      apcount        evaluation   0 :0 :0                no    no
 3      apcount        base         0 :0 :0                no    no
 3      apcount        adder        0 :0 :0                no    no
------------------ show license right-to-use mismatch ------------------
 Slot#    License Name    Adder AP Count   Base AP Count
------------------ show license right-to-use default ------------------
 Slot#    License Name    Type      Count
 1        apcount        base          0
 2        apcount        base          0
 3        apcount        base          0
------------------ show license right-to-use detail ------------------
Index 1:  License Name: ipservices
           Period left: Lifetime
           License Type: permanent
           License State: Not Activated
           License Count: Non-Counted
           License Location: Slot 1
Index 2:  License Name: ipservices
           Period left: 90
           License Type: evaluation
Index 3:  License Name: ipbase
           License State: Active, In use
Index 4:  License Name: ipbase
           Period left: 90
Index 5:  License Name: lanbase
Index 6:  License Name: apcount
           Period left: 90
           License Count: 50
Index 7:  License Name: apcount
           License Type: base
           License Count: 0
Index 8:  License Name: apcount
           License Type: adder
           License Count: 0
           License Location: Slot 2
           Period left: 90
           Period left: 90
           Period left: 90
           License Count: 50
           License Type: base
           License Count: 0
           License Type: adder
           License Count: 0
           License Location: Slot 3
           Period left: 90
           Period left: 90
           Period left: 90
           License Count: 50
           License Type: base
           License Count: 0
           License Type: adder
           License Count: 0
------------------ show version running ------------------
Package: Base, version: 03.02.03.SE, status: active
  File: cat3k_caa-base.SPA.03.02.03.SE.pkg, on: Switch1
  Built: Mon Sep 23 18:32:45 PDT 2013, by: udonthi
Package: Drivers, version: 1.1, status: active
  File: cat3k_caa-drivers.SSA.1.1.pkg, on: Switch1
  Built: Tue Jul 23 19:11:34 PDT 2013, by: udonthi
Package: Infra, version: 03.02.03.SE, status: active
  File: cat3k_caa-infra.SPA.03.02.03.SE.pkg, on: Switch1
  Built: Mon Sep 23 18:33:46 PDT 2013, by: udonthi
Package: IOS, version: 150-1.EX3, status: active
  File: cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg, on: Switch1
  Built: Mon Sep 23 18:35:18 PDT 2013, by: udonthi
Package: Platform, version: 03.02.03.SE, status: active
  File: cat3k_caa-platform.SPA.03.02.03.SE.pkg, on: Switch1
  Built: Mon Sep 23 18:34:36 PDT 2013, by: udonthi
Package: WCM, version: 10.0.120.0, status: active
  File: cat3k_caa-wcm.SPA.10.0.120.0.pkg, on: Switch1
  Built: Mon Sep 23 18:36:05 PDT 2013, by: udonthi
  File: cat3k_caa-base.SPA.03.02.03.SE.pkg, on: Switch2
  File: cat3k_caa-drivers.SSA.1.1.pkg, on: Switch2
  File: cat3k_caa-infra.SPA.03.02.03.SE.pkg, on: Switch2
  File: cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg, on: Switch2
  File: cat3k_caa-platform.SPA.03.02.03.SE.pkg, on: Switch2
  File: cat3k_caa-wcm.SPA.10.0.120.0.pkg, on: Switch2
  File: cat3k_caa-base.SPA.03.02.03.SE.pkg, on: Switch3
  File: cat3k_caa-drivers.SSA.1.1.pkg, on: Switch3
  File: cat3k_caa-infra.SPA.03.02.03.SE.pkg, on: Switch3
  File: cat3k_caa-iosd-universalk9.SPA.150-1.EX3.pkg, on: Switch3
  File: cat3k_caa-platform.SPA.03.02.03.SE.pkg, on: Switch3
  File: cat3k_caa-wcm.SPA.10.0.120.0.pkg, on: Switch3
------------------ show processes cpu detailed ------------------
Core 0: CPU utilization for five seconds: 37%; one minute: 24%; five minutes: 20%
Core 1: CPU utilization for five seconds: 51%; one minute: 24%; five minutes: 18%
Core 2: CPU utilization for five seconds: 39%; one minute: 20%; five minutes: 15%
Core 3: CPU utilization for five seconds: 31%; one minute: 18%; five minutes: 14%
PID     T C  TID     Runtime(ms) Invoked   uSecs  5Sec   1Min 5Min TTY   Process
1       L            30740       4983049   6      2.54   4.14 4.22 0     init
2       L            0           164       0      0.00   0.00 0.00 0     kthreadd
3       L            102010      12134433  8      0.00   0.00 0.00 0     migration/0
4       L            0           3         0      0.00   0.00 0.00 0     sirq-high/0
5       L            2315403     839039455 28     0.00   0.00 0.00 0     sirq-timer/0
6       L            0           33        0      0.00   0.00 0.00 0     sirq-net-tx/0
7       L            267032      66208346  68     0.00   0.03 0.03 0     sirq-net-rx/0
8       L            1450        330467    4      0.00   0.00 0.00 0     sirq-block/0
9       L            0           8         0      0.00   0.00 0.00 0     sirq-block-iopo
10      L            0           149       0      0.00   0.00 0.00 0     sirq-tasklet/0
11      L            88422       374976759 11     0.00   0.00 0.00 0     sirq-sched/0
12      L            6000        183556    32     0.00   0.00 0.00 0     sirq-hrtimer/0
13      L            395893      732211785 94     0.00   0.00 0.00 0     sirq-rcu/0
14      L            86470       20423395  4      0.00   0.01 0.01 0     desched/0
15      L            120090      15628031  7      0.00   0.00 0.00 0     migration/1
16      L            0           15        0      0.00   0.00 0.00 0     sirq-high/1
17      L            2564970     769713685 3      0.00   0.03 0.02 0     sirq-timer/1
18      L            0           80        0      0.00   0.00 0.00 0     sirq-net-tx/1
19      L            2946180     67324477  43     0.00   0.02 0.04 0     sirq-net-rx/1
20      L            1020        119469    8      0.00   0.00 0.00 0     sirq-block/1
21      L            0           20        0      0.00   0.00 0.00 0     sirq-block-iopo
22      L            0           21        0      0.00   0.00 0.00 0     sirq-tasklet/1
23      L            864290      396899468 2      0.00   0.00 0.00 0     sirq-sched/1
24      L            0           144834    0      0.00   0.00 0.00 0     sirq-hrtimer/1
25      L            808152      682280291 7      0.00   0.00 0.00 0     sirq-rcu/1
26      L            113040      24602880  4      0.00   0.00 0.02 0     desched/1
27      L            125940      13941060  9      0.00   0.00 0.00 0     migration/2
28      L            0           27        0      0.00   0.00 0.00 0     sirq-high/2
29      L            289550      648447953 0      0.00   0.00 0.02 0     sirq-timer/2
30      L            0           88        0      0.00   0.00 0.00 0     sirq-net-tx/2
31      L            2393340     65015175  36     0.00   0.00 0.00 0     sirq-net-rx/2
32      L            310         34096     9      0.00   0.00 0.00 0     sirq-block/2
33      L            0           32        0      0.00   0.00 0.00 0     sirq-block-iopo
34      L            0           33        0      0.00   0.00 0.00 0     sirq-tasklet/2
35      L            129090      372958968 0      0.00   0.00 0.00 0     sirq-sched/2
36      L            0           119731    0      0.00   0.00 0.00 0     sirq-hrtimer/2
37      L            461760      611323674 0      0.00   0.00 0.00 0     sirq-rcu/2
38      L            117170      24017155  4      0.00   0.00 0.00 0     desched/2
39      L            150010      15659466  9      0.00   0.00 0.00 0     migration/3
40      L            0           39        0      0.00   0.00 0.00 0     sirq-high/3
41      L            40          595118983 0      0.00   0.00 0.00 0     sirq-timer/3
42      L            10          104       96     0.00   0.00 0.00 0     sirq-net-tx/3
43      L            2174500     62616478  34     0.00   0.01 0.01 0     sirq-net-rx/3
44      L            120         16217     7      0.00   0.00 0.00 0     sirq-block/3
45      L            0           44        0      0.00   0.00 0.00 0     sirq-block-iopo
46      L            0           45        0      0.00   0.00 0.00 0     sirq-tasklet/3
47      L            30          368715920 0      0.00   0.00 0.00 0     sirq-sched/3
48      L            0           87667     0      0.00   0.00 0.00 0     sirq-hrtimer/3
49      L            50          582483573 0      0.00   0.00 0.00 0     sirq-rcu/3
50      L            147090      23875652  6      0.00   0.00 0.00 0     desched/3
51      L            941060      21234064  44     0.00   0.00 0.00 0     events/0
52      L            46250       12270764  3      0.00   0.00 0.00 0     events/1
53      L            13140       11521990  1      0.00   0.00 0.03 0     events/2
54      L            4230        11739882  0      0.00   0.00 0.00 0     events/3
55      L            60          3197      18     0.00   0.00 0.00 0     khelper
58      L            0           55        0      0.00   0.00 0.00 0     netns
60      L            0           66        0      0.00   0.00 0.00 0     async/mgr
158     L            72350       1356845   53     0.00   0.00 0.00 0     sync_supers
160     L            56510       1628594   34     0.00   0.00 0.00 0     bdi-default
162     L            13250       267737    49     0.00   0.00 0.00 0     kblockd/0
163     L            710         94570     7      0.00   0.00 0.00 0     kblockd/1
164     L            70          25250     2      0.00   0.00 0.00 0     kblockd/2
165     L            10          11047     0      0.00   0.00 0.00 0     kblockd/3
171     L            0           67        0      0.00   0.00 0.00 0     ata/0
172     L            0           66        0      0.00   0.00 0.00 0     ata/1
173     L            0           65        0      0.00   0.00 0.00 0     ata/2
174     L            0           66        0      0.00   0.00 0.00 0     ata/3
175     L            0           67        0      0.00   0.00 0.00 0     ata_aux
183     L            250         223       1121   0.00   0.00 0.00 0     khubd
210     L            120         3541      33     0.00   0.00 0.00 0     rpciod/0
211     L            180         3774      47     0.00   0.00 0.00 0     rpciod/1
212     L            50          3947      12     0.00   0.00 0.00 0     rpciod/2
213     L            90          4497      20     0.00   0.00 0.00 0     rpciod/3
229     L            0           77        0      0.00   0.00 0.00 0     kswapd0
230     L            0           78        0      0.00   0.00 0.00 0     aio/0
231     L            0           79        0      0.00   0.00 0.00 0     aio/1
232     L            0           80        0      0.00   0.00 0.00 0     aio/2
233     L            0           81        0      0.00   0.00 0.00 0     aio/3
234     L            990         14166     69     0.00   0.00 0.00 0     nfsiod
236     L            0           83        0      0.00   0.00 0.00 0     crypto/0
237     L            0           84        0      0.00   0.00 0.00 0     crypto/1
238     L            0           85        0      0.00   0.00 0.00 0     crypto/2
239     L            0           86        0      0.00   0.00 0.00 0     crypto/3
513     L            140         9193908   0      0.00   0.00 0.00 34816 in.telnetd
524     L            130         9193905   0      0.00   0.00 0.00 34816 brelay
789     L            3760        528639    7      0.00   0.00 0.00 0     pata_octeon_cf
790     L            0           97        0      0.00   0.00 0.00 0     scsi_eh_0
796     L            50820       6169      8237   0.63   0.63 0.63 0     mtdblockd
823     L            564900      13862921  40     0.00   0.00 0.01 0     octeon-ethernet
857     L            0           96        0      0.00   0.00 0.00 0     kstriped
859     L            0           97        0      0.00   0.00 0.00 0     ksnapd
937     L            310         1426      217    0.00   0.00 0.00 0     udevd
1268    L            69800       1631903   42     0.00   0.00 0.00 0     flush-8:0
1534    L            90          4422      20     0.00   0.00 0.00 0     loop1
1559    L            110         4323      25     0.00   0.00 0.00 0     loop2
1584    L            40          2160      18     0.00   0.00 0.00 0     loop3
1609    L            140         2893      48     0.00   0.00 0.00 0     loop4
1634    L            60          2501      23     0.00   0.00 0.00 0     loop5
1679    L            20          561       35     0.00   0.00 0.00 0     loop6
2359    L            10          1104      9      0.00   0.00 0.00 0     udevd
2360    L            0           1001      0      0.00   0.00 0.00 0     udevd
3258    L            100         1109      90     0.00   0.00 0.00 0     dbus-daemon
3636    L            150         1441      104    0.00   0.00 0.00 0     klogd
3648    L            10          1122      8      0.00   0.00 0.00 0     portmap
3717    L            0           956       0      0.00   0.00 0.00 0     sshd
3729    L            0           1038      0      0.00   0.00 0.00 0     xinetd
3733    L            1175630     9965406   117    1.95   3.58 3.69 0     xinetd
3767    L            0           112       0      0.00   0.00 0.00 0     lockd
3768    L            50          2376      21     0.00   0.00 0.00 0     nfsd
3769    L            110         2376      46     0.00   0.00 0.00 0     nfsd
3770    L            100         2378      42     0.00   0.00 0.00 0     nfsd
3771    L            30          2379      12     0.00   0.00 0.00 0     nfsd
3772    L            50          2570      19     0.00   0.00 0.00 0     nfsd
3773    L            160         2424      66     0.00   0.00 0.00 0     nfsd
3774    L            60          2540      23     0.00   0.00 0.00 0     nfsd
3775    L            90          2381      37     0.00   0.00 0.00 0     nfsd
3781    L            60          1156      51     0.00   0.00 0.00 0     rpc.mountd
5331    L            3767800     40318660  93     0.00   0.01 0.02 0     system_mgr
5331    L 0  5331    3313370     16275929  0      0.10   0.02 0.02 0     system_mgr
5331    L 0  5632    10          1166      0      0.00   0.00 0.00 0     system_mgr
5331    L 0  5633    20          1132      0      0.00   0.00 0.00 0     system_mgr
5331    L 1  5634    146250      8133989   0      0.00   0.00 0.00 0     system_mgr
5331    L 0  5635    10          1136      0      0.00   0.00 0.00 0     SPI default ST
5331    L 3  7921    0           1122      0      0.00   0.00 0.00 0     system_mgr
5331    L 3  7922    0           1122      0      0.00   0.00 0.00 0     system_mgr
5331    L 3  7923    0           1122      0      0.00   0.00 0.00 0     system_mgr
5331    L 0  8004    149980      7949329   0      0.00   0.00 0.00 0     system_mgr
5331    L 0  8007    158160      7949283   0      0.00   0.00 0.00 0     system_mgr
5331    L 3  8008    0           1127      0      0.00   0.00 0.00 1088  system_mgr
5331    L 3  8010    0           1127      0      0.00   0.00 0.00 1088  system_mgr
5331    L 3  8011    0           1127      0      0.00   0.00 0.00 1088  system_mgr
5560    L            238660      8974568   26     0.00   0.00 0.00 1088  slproc
5560    L 0  5560    400         1123      0      0.00   0.00 0.00 1088  slproc
5560    L 0  5620    212020      8140216   0      0.00   0.00 0.00 1088  slproc
5560    L 2  5621    25230       814541    0      0.00   0.00 0.00 1088  slproc
5560    L 1  5622    530         5543      0      0.00   0.00 0.00 1088  slproc
5560    L 1  5623    20          1627      0      0.00   0.00 0.00 1088  slproc
5560    L 1  5624    360         4311      0      0.00   0.00 0.00 1088  slproc
5560    L 1  5625    60          2928      0      0.00   0.00 0.00 1088  slproc
5560    L 3  5626    0           1107      0      0.00   0.00 0.00 1088  slproc
5560    L 3  5627    0           1117      0      0.00   0.00 0.00 1088  slproc
5560    L 1  5628    40          2066      0      0.00   0.00 0.00 1088  slproc
5636    L            2752904     330046867 103    3.17   2.83 2.78 1088  fed
5636    L 2  5636    32440       8966      0      0.00   0.00 0.00 1088  fed
5636    L 0  6077    4041935     9317721   0      0.00   0.03 0.04 1088  fed
5636    L 0  6078    80          1675      0      0.00   0.00 0.00 1088  fed
5636    L 1  6079    1183910     13994649  0      0.00   0.02 0.04 1088  fed
5636    L 1  6080    153110      8134128   0      0.00   0.02 0.04 1088  fed
5636    L 2  6081    30          1309      0      0.00   0.00 0.00 0     SPI default TP
5636    L 2  6082    0           1224      0      0.00   0.00 0.00 0     SPI default TP
5636    L 2  6083    0           1330      0      0.00   0.00 0.00 0     SPI default TP
5636    L 2  6084    40          1332      0      0.00   0.00 0.00 0     SPI default TP
5636    L 0  6085    0           1149      0      0.00   0.00 0.00 0     SPI default TP
5636    L 1  6086    24360       814593    0      0.00   0.00 0.00 0     fed
5636    L 0  6087    10590       544020    0      0.00   0.00 0.00 0     fed
5636    L 3  6090    3701422     187054655 0      0.86   0.81 0.79 0     fed-ots-main
5636    L 1  6091    30          1276      0      0.00   0.00 0.00 0     fed-ots-mo
5636    L 1  6093    736955      7971237   0      0.48   0.44 0.43 0     fed-ots-nfl
5636    L 3  6094    2516632     50628584  0      0.00   0.00 0.00 0     fed
5636    L 1  6095    381830      8141532   0      0.00   0.00 0.00 0     pdslib thread
5636    L 3  6096    1090910     9609899   0      0.05   0.01 0.01 0     SPI default ST
5636    L 1  6097    3380702     356464074 0      0.00   0.03 0.05 0     Timer
5636    L 3  6098    40          2823      0      0.00   0.00 0.00 0     fed
5636    L 3  6121    2356094     861432881 0      0.48   0.63 0.51 0     IntrDrv
5636    L 2  6124    2085300     81293127  0      0.00   0.01 0.03 0     LED
5636    L 1  7948    0           1162      0      0.00   0.00 0.00 0     fed
5636    L 1  7949    0           1162      0      0.00   0.00 0.00 0     fed
5636    L 0  7950    0           1213      0      0.00   0.00 0.00 0     fed
5636    L 3  7962    167400      7949459   0      0.00   0.00 0.01 0     fed
5636    L 2  7965    310620      7950043   0      0.00   0.00 0.02 0     fed
5636    L 1  7968    468910      8721964   0      0.00   0.03 0.04 0     fed
5636    L 0  7971    20          1305      0      0.00   0.00 0.00 0     fed
5636    L 2  7975    0           1163      0      0.00   0.00 0.00 0     fed
5636    L 0  11599   50          10283     0      0.00   0.00 0.00 0     Xcvr
5636    L 1  11602   2943386     89104196  0      0.29   0.23 0.22 0     Xcvr
5636    L 3  12745   1178706     501306762 0      0.19   0.16 0.14 0     Replenish
5636    L 2  12746   80          9390      0      0.00   0.00 0.00 0     PdsEvent
5636    L 1  12747   523010      501799994 0      0.19   0.24 0.23 0     PunjectRx
5636    L 3  12748   674344      287998485 0      0.53   0.50 0.42 0     PunjectTx
5636    L 2  12749   0           8431      0      0.00   0.00 0.00 0     Consistency
5636    L 0  12751   0           8437      0      0.00   0.00 0.00 0     ShFwd
5636    L 2  12754   0           8473      0      0.00   0.00 0.00 0     eicore_bdn
5636    L 2  12755   0           8473      0      0.00   0.00 0.00 0     eicore_bdn
5636    L 2  12756   0           8472      0      0.00   0.00 0.00 0     eicore_bdn
5636    L 2  12759   10          8511      0      0.00   0.00 0.00 0     eicore_ipc
5636    L 2  13204   0           8962      0      0.00   0.00 0.00 0     fed
5636    L 1  13317   561348      300142778 0      0.05   0.01 0.02 0     XcvrPoll
5637    L            287629      207079089 22     0.05   0.12 0.12 0     platform_mgr
5637    L 1  5637    1800        174639    0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  6057    260520      8140199   0      0.00   0.00 0.02 0     platform_mgr
5637    L 3  6058    30          1246      0      0.00   0.00 0.00 0     platform_mgr
5637    L 0  6059    1006940     23663603  0      0.05   0.01 0.04 0     platform_mgr
5637    L 1  6060    146970      8134113   0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  6061    0           1162      0      0.00   0.00 0.00 0     SPI default TP
5637    L 1  6062    0           1204      0      0.00   0.00 0.00 0     SPI default TP
5637    L 2  6063    10          1202      0      0.00   0.00 0.00 0     SPI default TP
5637    L 1  6064    0           1211      0      0.00   0.00 0.00 0     SPI default TP
5637    L 2  6065    0           1136      0      0.00   0.00 0.00 0     SPI default TP
5637    L 0  6066    24530       814573    0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  6069    2494950     18750508  0      0.00   0.03 0.04 0     SPI default ST
5637    L 0  6070    2154440     81265893  0      0.00   0.01 0.02 0     LED
5637    L 0  6072    11010       543918    0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  6073    1768350     34913324  0      0.00   0.00 0.01 0     platform_mgr
5637    L 1  6074    3230905     257395911 0      0.00   0.01 0.03 0     Timer
5637    L 1  6075    0           1192      0      0.00   0.00 0.00 0     platform_mgr
5637    L 3  6099    2386813     151753665 0      0.14   0.05 0.05 0     RedEarthMgr
5637    L 0  6128    200         196265    0      0.00   0.00 0.00 0     platform_mgr
5637    L 0  7951    0           1154      0      0.00   0.00 0.00 0     platform_mgr
5637    L 0  7952    0           1154      0      0.00   0.00 0.00 0     platform_mgr
5637    L 0  7953    0           1154      0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  8012    160450      7949486   0      0.00   0.00 0.00 0     platform_mgr
5637    L 0  8013    168720      7949443   0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  8014    10          1200      0      0.00   0.00 0.00 0     platform_mgr
5637    L 2  8015    0           1175      0      0.00   0.00 0.00 0     platform_mgr
5637    L 2  8016    0           1161      0      0.00   0.00 0.00 0     platform_mgr
5637    L 1  13032   2080190     81441533  0      0.00   0.01 0.03 0     USB
5637    L 2  13033   0           174597    0      0.00   0.00 0.00 0     eicore_bdn
5637    L 2  13034   0           174597    0      0.00   0.00 0.00 0     eicore_bdn
5637    L 2  13035   0           174596    0      0.00   0.00 0.00 0     eicore_bdn
5637    L 0  13039   10          174629    0      0.00   0.00 0.00 0     eicore_ipc
5637    L 1  13045   1570570     21029134  0      0.00   0.04 0.00 0     Therm
5637    L 2  13158   120         174689    0      0.00   0.00 0.00 0     CfgMgr
5637    L 1  13162   0           1726      0      0.00   0.00 0.00 0     OBFL feature XD
5637    L 2  13163   0           1726      0      0.00   0.00 0.00 0     OBFL feature XD
5637    L 2  13164   0           1726      0      0.00   0.00 0.00 0     OBFL feature XD
5638    L            2511377     163172807 67     0.29   0.29 0.29 0     stack-mgr
5638    L 3  5638    3440        3814      0      0.00   0.00 0.00 0     stack-mgr
5638    L 1  6044    211610      8140255   0      0.00   0.00 0.00 0     stack-mgr
5638    L 0  6045    10          1272      0      0.00   0.00 0.00 0     stack-mgr
5638    L 3  6046    73600       547958    0      0.00   0.00 0.02 0     stack-mgr
5638    L 0  6047    149270      8134125   0      0.00   0.00 0.00 0     stack-mgr
5638    L 2  6048    30          1295      0      0.00   0.00 0.00 0     SPI default TP
5638    L 3  6049    0           1256      0      0.00   0.00 0.00 0     SPI default TP
5638    L 2  6050    10          1298      0      0.00   0.00 0.00 0     SPI default TP
5638    L 1  6051    10          1264      0      0.00   0.00 0.00 0     SPI default TP
5638    L 3  6052    0           1148      0      0.00   0.00 0.00 0     SPI default TP
5638    L 3  6053    25270       814586    0      0.00   0.00 0.00 0     stack-mgr
5638    L 2  6056    66330       313005    0      0.00   0.00 0.00 0     SPI default ST
5638    L 1  6106    2371350     86210563  0      0.00   0.04 0.03 0     stack-mgr-ots-m
5638    L 0  6107    3477393     110426923 0      0.00   0.01 0.04 0     Timer
5638    L 3  6108    64330       279420    0      0.00   0.00 0.00 0     stack-mgr-ots-n
5638    L 3  6109    818087      533450516 0      0.14   0.15 0.15 0     IntrDrv
5638    L 0  6112    2322        32525815  0      0.00   0.01 0.03 0     stack-mgr
5638    L 2  6113    10          3703      0      0.00   0.00 0.00 0     SIF
5638    L 3  6114    282500      8142612   0      0.00   0.00 0.00 0     pdslib thread
5638    L 3  6115    1187342     237199546 0      0.05   0.02 0.02 0     Replenish
5638    L 3  6116    3231580     237575224 0      0.05   0.07 0.05 0     OOBnd RX
5638    L 3  6117    2009892     346789327 0      0.05   0.04 0.04 0     OOBnd TX
5638    L 1  6118    1097880     5240214   0      0.00   0.00 0.00 0     SDP RX
5638    L 2  6119    0           3701      0      0.00   0.00 0.00 0     OobEv
5638    L 3  7942    0           1179      0      0.00   0.00 0.00 0     stack-mgr
5638    L 3  7943    0           1179      0      0.00   0.00 0.00 0     stack-mgr
5638    L 3  7944    0           1179      0      0.00   0.00 0.00 0     stack-mgr
5638    L 0  7988    157030      7949510   0      0.00   0.00 0.00 0     stack-mgr
5638    L 0  7990    167120      7949463   0      0.00   0.00 0.00 0     stack-mgr
5638    L 0  7993    0           1181      0      0.00   0.00 0.00 0     stack-mgr
5638    L 0  7995    0           1181      0      0.00   0.00 0.00 0     stack-mgr
5638    L 3  7999    0           1181      0      0.00   0.00 0.00 0     stack-mgr
5638    L 2  8089    0           3791      0      0.00   0.00 0.00 0     eicore_bdn
5638    L 2  8090    0           3791      0      0.00   0.00 0.00 0     eicore_bdn
5638    L 2  8091    0           3791      0      0.00   0.00 0.00 0     eicore_bdn
5638    L 3  9797    0           3807      0      0.00   0.00 0.00 0     eicore_ipc
6129    L            1660460     16263011  102    0.00   0.02 0.00 0     idope.py
6129    L 3  6129    18730       1515      0      0.00   0.00 0.00 0     idope.py
6129    L 1  7903    1641730     16261516  0      0.05   0.02 0.00 0     idope.py
6273    L            714500      33002221  21     0.00   0.00 0.02 0     ns_oir_proxy
6273    L 1  6273    200         1253      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 1  7106    211360      8140303   0      0.00   0.00 0.02 0     ns_oir_proxy
6273    L 3  7123    25040       814683    0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 2  7124    30          1280      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 2  7130    20          1293      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 1  7157    0           1267      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 1  7158    153570      8134200   0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 2  7160    0           1267      0      0.00   0.00 0.00 0     SPI default ST
6273    L 1  7933    0           1263      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 1  7934    0           1263      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 1  7935    0           1263      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 0  7957    159980      7949595   0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 0  7970    164300      7949537   0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 0  7972    0           1265      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 0  7978    0           1265      0      0.00   0.00 0.00 0     ns_oir_proxy
6273    L 0  7979    0           1265      0      0.00   0.00 0.00 0     ns_oir_proxy
6274    L            705150      33011249  21     0.00   0.02 0.04 0     profiled
6274    L 1  6274    200         1286      0      0.00   0.00 0.00 0     profiled
6274    L 0  7159    209180      8140302   0      0.00   0.01 0.04 0     profiled
6274    L 0  7173    24650       814682    0      0.00   0.00 0.00 0     profiled
6274    L 3  8331    40          1304      0      0.00   0.00 0.00 0     profiled
6274    L 3  8333    0           1276      0      0.00   0.00 0.00 0     profiled
6274    L 0  8334    149230      8134206   0      0.00   0.04 0.04 0     profiled
6274    L 0  8335    0           1268      0      0.00   0.00 0.00 0     SPI default TP
6274    L 3  8336    0           1269      0      0.00   0.00 0.00 0     SPI default TP
6274    L 3  8337    0           1276      0      0.00   0.00 0.00 0     SPI default TP
6274    L 3  8338    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6274    L 3  8339    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6274    L 2  8351    0           1276      0      0.00   0.00 0.00 0     eicore_bdn
6274    L 2  8352    0           1275      0      0.00   0.00 0.00 0     eicore_bdn
6274    L 2  8353    0           1275      0      0.00   0.00 0.00 0     eicore_bdn
6274    L 3  8381    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 3  8383    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 3  8385    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 0  8386    157770      7949595   0      0.00   0.00 0.00 0     profiled
6274    L 0  8387    164080      7949548   0      0.00   0.00 0.00 0     profiled
6274    L 1  8388    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 1  8391    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 1  8393    0           1269      0      0.00   0.00 0.00 0     profiled
6274    L 3  9753    0           1288      0      0.00   0.00 0.00 0     eicore_ipc
6275    L            710310      803335    884    0.00   0.02 0.04 0     oom_poll.sh
6276    L            1619260     51272695  31     0.00   0.02 0.04 0     obfld
6276    L 2  6276    610         1388      0      0.05   0.02 0.04 0     obfld
6276    L 0  7443    248100      8143371   0      0.00   0.00 0.03 0     obfld
6276    L 1  7471    30600       814718    0      0.00   0.00 0.00 0     obfld
6276    L 0  7480    643300      976006    0      0.00   0.00 0.03 0     obfl async
6276    L 1  8097    30          1357      0      0.00   0.00 0.00 0     obfld
6276    L 0  8100    169550      1001908   0      0.00   0.01 0.03 0     obfld
6276    L 1  8101    202010      8134172   0      0.00   0.00 0.00 0     obfld
6276    L 3  8108    0           1307      0      0.00   0.00 0.00 0     obfld
6276    L 3  8110    0           1308      0      0.00   0.00 0.00 0     obfld
6276    L 3  8111    0           1307      0      0.00   0.00 0.00 0     obfld
6276    L 0  8112    159550      7949633   0      0.00   0.00 0.00 0     obfld
6276    L 1  8115    165520      7949582   0      0.00   0.00 0.00 0     obfld
6276    L 3  8116    0           1307      0      0.00   0.00 0.00 0     obfld
6276    L 3  8119    0           1307      0      0.00   0.00 0.00 0     obfld
6276    L 0  8120    0           1307      0      0.00   0.00 0.00 0     obfld
6276    L 2  8123    0           1309      0      0.00   0.00 0.00 0     SPI default TP
6276    L 2  8124    0           1310      0      0.00   0.00 0.00 0     SPI default TP
6276    L 2  8125    0           1323      0      0.00   0.00 0.00 0     SPI default TP
6276    L 2  8126    0           1323      0      0.00   0.00 0.00 0     SPI default TP
6276    L 2  8127    0           1323      0      0.00   0.00 0.00 0     SPI default TP
6276    L 0  8152    0           1324      0      0.00   0.00 0.00 0     eicore_bdn
6276    L 0  8153    0           1326      0      0.00   0.00 0.00 0     eicore_bdn
6276    L 0  8154    0           1327      0      0.00   0.00 0.00 0     eicore_bdn
6276    L 0  9789    0           1339      0      0.00   0.00 0.00 0     eicore_ipc
6276    L 1  13167   0           1322      0      0.00   0.00 0.00 0     PUBLIC XDM
6276    L 0  13168   0           1321      0      0.00   0.00 0.00 0     PUBLIC XDM
6276    L 0  13169   0           1321      0      0.00   0.00 0.00 0     PUBLIC XDM
6276    L 1  16216   0           4069236   0      0.00   0.00 0.00 0     OBFL feature XD
6276    L 2  16453   0           4069229   0      0.00   0.00 0.00 0     OBFL feature XD
6276    L 2  16455   0           4069226   0      0.00   0.00 0.00 0     OBFL feature XD
6276    L 2  16457   0           4069228   0      0.00   0.00 0.00 0     OBFL feature XD
6277    L            711280      33011187  21     0.00   0.02 0.04 0     consoled
6277    L 3  6277    200         1284      0      0.00   0.00 0.00 0     consoled
6277    L 2  7863    209170      8140301   0      0.00   0.00 0.00 0     consoled
6277    L 3  7864    25550       814682    0      0.00   0.00 0.00 0     consoled
6277    L 2  8030    20          1302      0      0.00   0.00 0.00 0     consoled
6277    L 3  8034    10          1274      0      0.00   0.00 0.00 0     consoled
6277    L 0  8035    152050      8134208   0      0.00   0.00 0.00 0     consoled
6277    L 1  8036    0           1266      0      0.00   0.00 0.00 0     SPI default TP
6277    L 3  8037    0           1274      0      0.00   0.00 0.00 0     SPI default TP
6277    L 3  8038    0           1274      0      0.00   0.00 0.00 0     SPI default TP
6277    L 3  8039    0           1274      0      0.00   0.00 0.00 0     SPI default TP
6277    L 3  8040    0           1265      0      0.00   0.00 0.00 0     SPI default TP
6277    L 2  8049    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 2  8050    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 2  8051    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 1  8052    157090      7949593   0      0.00   0.00 0.00 0     consoled
6277    L 3  8053    167190      7949543   0      0.00   0.02 0.04 0     consoled
6277    L 3  8054    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 3  8055    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 3  8056    0           1264      0      0.00   0.00 0.00 0     consoled
6277    L 3  8058    0           1273      0      0.00   0.00 0.00 0     eicore_bdn
6277    L 3  8059    0           1273      0      0.00   0.00 0.00 0     eicore_bdn
6277    L 3  8060    0           1272      0      0.00   0.00 0.00 0     eicore_bdn
6277    L 3  9743    0           1286      0      0.00   0.00 0.00 0     eicore_ipc
6278    L            2207880     41469861  53     0.00   0.01 0.03 0     console_relay
6278    L 2  6278    1426630     8470263   0      0.00   0.04 0.08 0     console_relay
6278    L 1  7891    274520      8140173   0      0.00   0.00 0.00 0     console_relay
6278    L 0  7895    25320       814681    0      0.00   0.00 0.02 0     console_relay
6278    L 0  7898    20          1296      0      0.00   0.00 0.00 0     console_relay
6278    L 3  7899    0           1269      0      0.00   0.00 0.00 0     console_relay
6278    L 0  7900    156080      8134213   0      0.00   0.00 0.00 0     console_relay
6278    L 3  7901    10          1269      0      0.00   0.00 0.00 0     SPI default ST
6278    L 3  7954    0           1267      0      0.00   0.00 0.00 0     console_relay
6278    L 3  7955    0           1267      0      0.00   0.00 0.00 0     console_relay
6278    L 3  7956    0           1267      0      0.00   0.00 0.00 0     console_relay
6278    L 3  7989    159290      7949595   0      0.00   0.00 0.00 0     console_relay
6278    L 0  7992    166010      7949547   0      0.00   0.00 0.00 0     console_relay
6278    L 0  7994    0           1268      0      0.00   0.00 0.00 0     console_relay
6278    L 0  7997    0           1268      0      0.00   0.00 0.00 0     console_relay
6278    L 0  8000    0           1268      0      0.00   0.00 0.00 0     console_relay
6279    L            710690      33011346  21     0.00   0.03 0.04 0     csprovider
6279    L 2  6279    270         1298      0      0.00   0.00 0.00 0     csprovider
6279    L 0  7228    206830      8140296   0      0.00   0.00 0.00 0     csprovider
6279    L 2  7254    25760       814682    0      0.00   0.00 0.00 0     csprovider
6279    L 1  8173    10          1315      0      0.00   0.00 0.00 0     csprovider
6279    L 2  8199    0           1276      0      0.00   0.00 0.00 0     csprovider
6279    L 2  8202    153000      8134206   0      0.00   0.00 0.00 0     csprovider
6279    L 2  8210    0           1267      0      0.00   0.00 0.00 0     SPI default TP
6279    L 2  8211    0           1267      0      0.00   0.00 0.00 0     SPI default TP
6279    L 2  8212    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6279    L 2  8213    0           1276      0      0.00   0.00 0.00 0     SPI default TP
6279    L 2  8214    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6279    L 3  8276    0           1270      0      0.00   0.00 0.00 0     csprovider
6279    L 3  8277    0           1270      0      0.00   0.00 0.00 0     csprovider
6279    L 3  8278    0           1270      0      0.00   0.00 0.00 0     csprovider
6279    L 0  8279    157360      7949598   0      0.00   0.00 0.00 0     csprovider
6279    L 0  8280    0           1286      0      0.00   0.00 0.00 0     eicore_bdn
6279    L 3  8281    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6279    L 3  8282    0           1288      0      0.00   0.00 0.00 0     eicore_bdn
6279    L 2  8283    167460      7949550   0      0.00   0.03 0.04 0     csprovider
6279    L 3  8284    0           1276      0      0.00   0.00 0.00 0     csprovider
6279    L 1  8285    0           1280      0      0.00   0.00 0.00 0     csprovider
6279    L 0  8286    0           1280      0      0.00   0.00 0.00 0     csprovider
6279    L 2  9792    0           1300      0      0.00   0.00 0.00 0     eicore_ipc
6280    L            714920      33092636  21     0.00   0.00 0.00 0     system_mgr_cli
6280    L 0  6280    2010        82687     0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 2  7255    213990      8140301   0      0.00   0.01 0.00 0     system_mgr_cli
6280    L 1  7275    24850       814682    0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 1  8168    30          1308      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 0  8201    0           1274      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 1  8204    148350      8134202   0      0.00   0.00 0.02 0     system_mgr_cli
6280    L 0  8215    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6280    L 0  8216    0           1265      0      0.00   0.00 0.00 0     SPI default TP
6280    L 0  8217    0           1272      0      0.00   0.00 0.00 0     SPI default TP
6280    L 0  8218    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6280    L 2  8219    0           1272      0      0.00   0.00 0.00 0     SPI default TP
6280    L 3  8267    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 3  8268    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 3  8269    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 0  8270    159080      7949596   0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 0  8271    166620      7949548   0      0.00   0.04 0.05 0     system_mgr_cli
6280    L 3  8272    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 3  8273    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 3  8274    0           1270      0      0.00   0.00 0.00 0     system_mgr_cli
6280    L 1  8288    0           1272      0      0.00   0.00 0.00 0     eicore_bdn
6280    L 1  8289    0           1272      0      0.00   0.00 0.00 0     eicore_bdn
6280    L 1  8290    0           1272      0      0.00   0.00 0.00 0     eicore_bdn
6280    L 0  9759    0           1284      0      0.00   0.00 0.00 0     eicore_ipc
6281    L            2605190     67415563  38     0.00   0.02 0.04 0     plogd
6281    L 0  6281    1893300     34402646  0      0.00   0.02 0.04 0     plogd
6281    L 0  7422    208600      8140303   0      0.00   0.00 0.00 0     plogd
6281    L 3  7433    25560       814682    0      0.00   0.00 0.00 0     plogd
6281    L 1  8165    10          1378      0      0.00   0.00 0.00 0     plogd
6281    L 2  8170    10          1288      0      0.00   0.00 0.00 0     plogd
6281    L 0  8172    152080      8134204   0      0.00   0.00 0.00 0     plogd
6281    L 3  8183    10          1294      0      0.00   0.00 0.00 0     SPI default TP
6281    L 3  8187    0           1280      0      0.00   0.00 0.00 0     SPI default TP
6281    L 1  8188    10          1300      0      0.00   0.00 0.00 0     SPI default TP
6281    L 1  8189    0           1277      0      0.00   0.00 0.00 0     plogd
6281    L 0  8190    0           1277      0      0.00   0.00 0.00 0     plogd
6281    L 2  8191    0           1277      0      0.00   0.00 0.00 0     plogd
6281    L 0  8192    158730      7949608   0      0.00   0.00 0.00 0     plogd
6281    L 1  8193    166850      7949558   0      0.00   0.00 0.00 0     plogd
6281    L 2  8194    0           1282      0      0.00   0.00 0.00 0     plogd
6281    L 3  8195    20          1321      0      0.00   0.00 0.00 0     SPI default TP
6281    L 2  8196    10          1287      0      0.00   0.00 0.00 0     plogd
6281    L 2  8197    0           1285      0      0.00   0.00 0.00 0     SPI default TP
6281    L 2  8198    0           1285      0      0.00   0.00 0.00 0     plogd
6281    L 0  8298    0           1296      0      0.00   0.00 0.00 0     eicore_bdn
6281    L 0  8299    0           1296      0      0.00   0.00 0.00 0     eicore_bdn
6281    L 0  8300    0           1295      0      0.00   0.00 0.00 0     eicore_bdn
6281    L 0  9750    0           1308      0      0.00   0.00 0.00 0     eicore_ipc
6281    L 3  9939    0           1304      0      0.00   0.00 0.00 0     SPI default ST
6281    L 3  10398   0           1316      0      0.00   0.00 0.00 0     eicore_ipc
6282    L            709930      33011714  21     0.00   0.00 0.00 0     psdprov
6282    L 0  6282    250         1301      0      0.00   0.00 0.00 0     psdprov
6282    L 0  7139    211400      8140307   0      0.00   0.00 0.00 0     psdprov
6282    L 1  7150    25130       814681    0      0.00   0.00 0.00 0     psdprov
6282    L 1  8304    20          1320      0      0.00   0.00 0.00 0     psdprov
6282    L 2  8309    0           1324      0      0.00   0.00 0.00 0     psdprov
6282    L 1  8310    151230      8134206   0      0.00   0.00 0.00 0     psdprov
6282    L 2  8311    0           1272      0      0.00   0.00 0.00 0     SPI default TP
6282    L 0  8312    0           1339      0      0.00   0.00 0.00 0     SPI default TP
6282    L 2  8313    0           1318      0      0.00   0.00 0.00 0     SPI default TP
6282    L 3  8314    0           1337      0      0.00   0.00 0.00 0     SPI default TP
6282    L 2  8315    10          1326      0      0.00   0.00 0.00 0     SPI default TP
6282    L 2  8316    0           1275      0      0.00   0.00 0.00 0     psdprov
6282    L 2  8317    0           1275      0      0.00   0.00 0.00 0     psdprov
6282    L 2  8318    0           1275      0      0.00   0.00 0.00 0     psdprov
6282    L 2  8319    157660      7949600   0      0.00   0.00 0.00 0     psdprov
6282    L 0  8320    164160      7949556   0      0.00   0.00 0.00 0     psdprov
6282    L 3  8321    0           1278      0      0.00   0.00 0.00 0     psdprov
6282    L 3  8322    0           1278      0      0.00   0.00 0.00 0     psdprov
6282    L 2  8323    0           1278      0      0.00   0.00 0.00 0     psdprov
6282    L 3  8325    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6282    L 3  8326    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6282    L 3  8327    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6282    L 2  9802    70          1348      0      0.00   0.00 0.00 0     eicore_ipc
6283    L            1518055     105794788 54     0.24   0.15 0.15 0     pdsd
6283    L 2  6283    260         1295      0      0.00   0.00 0.00 0     pdsd
6283    L 0  7127    215200      8140310   0      0.00   0.00 0.00 0     pdsd
6283    L 2  7163    23600       814683    0      0.00   0.00 0.03 0     pdsd
6283    L 0  7204    253470      8140200   0      0.00   0.00 0.00 0     pdslib thread
6283    L 1  8330    20          1312      0      0.00   0.00 0.00 0     pdsd
6283    L 3  8341    0           1277      0      0.00   0.00 0.00 0     pdsd
6283    L 2  8342    151370      8134216   0      0.00   0.00 0.00 0     pdsd
6283    L 2  8343    0           1269      0      0.00   0.00 0.00 0     SPI default TP
6283    L 2  8344    0           1269      0      0.00   0.00 0.00 0     SPI default TP
6283    L 0  8345    0           1277      0      0.00   0.00 0.00 0     SPI default TP
6283    L 0  8346    0           1277      0      0.00   0.00 0.00 0     SPI default TP
6283    L 0  8347    0           1277      0      0.00   0.00 0.00 0     SPI default TP
6283    L 0  8363    0           1269      0      0.00   0.00 0.00 0     pdsd
6283    L 0  8364    0           1270      0      0.00   0.00 0.00 0     pdsd
6283    L 0  8368    0           1270      0      0.00   0.00 0.00 0     pdsd
6283    L 0  8369    157090      7949604   0      0.00   0.00 0.00 0     pdsd
6283    L 1  8378    166430      7949557   0      0.00   0.01 0.00 0     pdsd
6283    L 0  8379    0           1274      0      0.00   0.00 0.00 0     pdsd
6283    L 1  8380    0           1275      0      0.00   0.00 0.00 0     pdsd
6283    L 0  8382    0           1278      0      0.00   0.00 0.00 0     pdsd
6283    L 1  8389    0           1282      0      0.00   0.00 0.00 0     eicore_bdn
6283    L 1  8390    0           1282      0      0.00   0.00 0.00 0     eicore_bdn
6283    L 1  8392    0           1282      0      0.00   0.00 0.00 0     eicore_bdn
6283    L 0  9785    0           1295      0      0.00   0.00 0.00 0     eicore_ipc
6283    L 1  9887    1914290     4070182   0      0.00   0.01 0.02 0     pdsd
6283    L 1  9888    577532      850350168 0      0.34   0.17 0.15 0     pdsd
6283    L 0  9889    2353870     162378110 0      0.00   0.00 0.00 0     pdsd
6284    L            991550      35128197  28     0.00   0.00 0.00 0     gold_slave
6284    L 3  6284    670         1301      0      0.00   0.00 0.00 0     gold_slave
6284    L 0  7636    220210      8140385   0      0.00   0.00 0.00 0     gold_slave
6284    L 2  7642    10          1323      0      0.00   0.00 0.00 0     gold_slave
6284    L 0  7643    81850       453349    0      0.00   0.00 0.00 0     gold_slave
6284    L 2  7647    151310      8134201   0      0.00   0.02 0.04 0     gold_slave
6284    L 2  7650    5180        134871    0      0.00   0.00 0.00 0     SPI default TP
6284    L 0  7651    9220        239759    0      0.00   0.00 0.00 0     SPI default TP
6284    L 1  7652    9490        258195    0      0.00   0.00 0.00 0     SPI default TP
6284    L 3  7653    12500       319702    0      0.00   0.00 0.00 0     SPI default TP
6284    L 3  7654    12200       316544    0      0.00   0.00 0.00 0     SPI default TP
6284    L 3  7678    26030       814704    0      0.00   0.00 0.00 0     gold_slave
6284    L 2  7688    10          1309      0      0.00   0.00 0.00 0     SPI default ST
6284    L 3  7918    137930      405793    0      0.00   0.00 0.00 0     DiagCard1/-1
6284    L 2  7924    0           1270      0      0.00   0.00 0.00 0     gold_slave
6284    L 2  7925    0           1270      0      0.00   0.00 0.00 0     gold_slave
6284    L 2  7926    0           1270      0      0.00   0.00 0.00 0     gold_slave
6284    L 3  7961    158260      7949602   0      0.00   0.01 0.04 0     gold_slave
6284    L 3  7964    166670      7949560   0      0.00   0.00 0.00 0     gold_slave
6284    L 0  7966    10          1279      0      0.00   0.00 0.00 0     gold_slave
6284    L 1  7984    0           1277      0      0.00   0.00 0.00 0     gold_slave
6284    L 0  7985    0           1273      0      0.00   0.00 0.00 0     gold_slave
6285    L            806690      33120219  24     0.00   0.00 0.00 0     osinfo-provider
6285    L 3  6285    370         1337      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 2  7281    238720      8167601   0      0.86   0.20 0.15 0     os_info_p
6285    L 0  7295    23550       814688    0      0.00   0.00 0.00 0     os_info_p
6285    L 2  8332    10          1332      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 1  8354    2550        17418     0      0.10   0.10 0.10 0     osinfo-provider
6285    L 0  8355    149250      8134217   0      0.00   0.00 0.00 0     osinfo-provider
6285    L 1  8356    860         11257     0      0.00   0.00 0.00 0     SPI default TP
6285    L 3  8357    1150        12626     0      0.05   0.05 0.05 0     SPI default TP
6285    L 1  8358    770         9389      0      0.14   0.14 0.14 0     SPI default TP
6285    L 1  8359    1040        11144     0      0.10   0.10 0.10 0     SPI default TP
6285    L 0  8360    610         6026      0      0.00   0.00 0.00 0     SPI default TP
6285    L 3  8365    0           1291      0      0.00   0.00 0.00 0     eicore_bdn
6285    L 3  8366    0           1291      0      0.00   0.00 0.00 0     eicore_bdn
6285    L 3  8367    0           1291      0      0.00   0.00 0.00 0     eicore_bdn
6285    L 0  8370    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8371    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8372    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8373    160110      7949623   0      0.00   0.00 0.00 0     osinfo-provider
6285    L 1  8374    167640      7949575   0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8375    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8376    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 0  8377    0           1296      0      0.00   0.00 0.00 0     osinfo-provider
6285    L 1  9800    60280       19209     0      1.87   0.67 0.59 0     eicore_ipc
6285    L 0  21452   660         5501      0      0.00   0.00 0.00 0     SPI default ST
6286    L            718730      33011271  21     0.00   0.00 0.00 0     oscore_p
6286    L 0  6286    220         1286      0      0.00   0.00 0.00 0     oscore_p
6286    L 1  7075    212270      8140301   0      0.00   0.00 0.00 0     oscore_p
6286    L 0  7089    24690       814683    0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8163    20          1306      0      0.00   0.00 0.00 0     oscore_p
6286    L 3  8200    0           1281      0      0.00   0.00 0.00 0     oscore_p
6286    L 1  8203    153010      8134209   0      0.00   0.00 0.00 0     oscore_p
6286    L 3  8205    0           1281      0      0.00   0.00 0.00 0     SPI default TP
6286    L 2  8206    0           1273      0      0.00   0.00 0.00 0     SPI default TP
6286    L 2  8207    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6286    L 3  8208    0           1281      0      0.00   0.00 0.00 0     SPI default TP
6286    L 3  8209    0           1281      0      0.00   0.00 0.00 0     SPI default TP
6286    L 0  8220    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8221    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8223    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 3  8224    161670      7949591   0      0.00   0.00 0.00 0     oscore_p
6286    L 1  8225    166850      7949545   0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8226    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8227    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 0  8228    0           1266      0      0.00   0.00 0.00 0     oscore_p
6286    L 3  8264    0           1278      0      0.00   0.00 0.00 0     eicore_bdn
6286    L 3  8265    0           1278      0      0.00   0.00 0.00 0     eicore_bdn
6286    L 3  8266    0           1278      0      0.00   0.00 0.00 0     eicore_bdn
6286    L 1  9769    0           1288      0      0.00   0.00 0.00 0     eicore_ipc
6287    L            912030      33971781  26     0.00   0.00 0.00 0     netd
6287    L 0  6287    200         1295      0      0.00   0.00 0.00 0     netd
6287    L 1  7186    217710      8140296   0      0.00   0.00 0.00 0     netd
6287    L 1  7222    40          1289      0      0.00   0.00 0.00 0     netd
6287    L 3  7237    47240       405203    0      0.00   0.00 0.00 0     netd
6287    L 1  7238    153980      8134201   0      0.00   0.00 0.00 0     netd
6287    L 2  7239    0           1257      0      0.00   0.00 0.00 0     SPI default TP
6287    L 3  7240    0           1262      0      0.00   0.00 0.00 0     SPI default TP
6287    L 2  7241    0           1261      0      0.00   0.00 0.00 0     SPI default TP
6287    L 3  7242    0           1264      0      0.00   0.00 0.00 0     SPI default TP
6287    L 3  7243    0           1270      0      0.00   0.00 0.00 0     SPI default TP
6287    L 0  7270    25890       814691    0      0.00   0.00 0.00 0     netd
6287    L 2  7273    10          1287      0      0.00   0.00 0.00 0     OIR xdm
6287    L 1  7274    44570       287886    0      0.00   0.00 0.00 0     SPI default ST
6287    L 0  7276    98940       272625    0      0.00   0.00 0.00 0     netd
6287    L 1  7936    0           1264      0      0.00   0.00 0.00 0     netd
6287    L 1  7937    0           1264      0      0.00   0.00 0.00 0     netd
6287    L 1  7938    0           1264      0      0.00   0.00 0.00 0     netd
6287    L 3  7958    155920      7949594   0      0.00   0.00 0.00 0     netd
6287    L 0  7982    167530      7949548   0      0.00   0.00 0.00 0     netd
6287    L 2  7983    0           1267      0      0.00   0.00 0.00 0     netd
6287    L 3  7986    0           1267      0      0.00   0.00 0.00 0     netd
6287    L 3  7987    0           1267      0      0.00   0.00 0.00 0     netd
6288    L            3968970     40326404  98     0.00   0.01 0.00 0     mem_mgmt
6288    L 0  6288    3212730     8130101   0      0.00   0.02 0.03 0     mem_mgmt
6288    L 1  7387    240200      8140263   0      0.00   0.00 0.01 0     mem_mgmt
6288    L 0  8164    30          1361      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 1  8169    0           1329      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 0  8171    191820      8134207   0      0.00   0.00 0.00 0     mem_mgmt
6288    L 0  8174    0           1324      0      0.00   0.00 0.00 0     SPI default TP
6288    L 0  8175    0           1324      0      0.00   0.00 0.00 0     SPI default TP
6288    L 1  8176    0           1328      0      0.00   0.00 0.00 0     SPI default TP
6288    L 1  8177    0           1328      0      0.00   0.00 0.00 0     SPI default TP
6288    L 0  8178    0           1328      0      0.00   0.00 0.00 0     SPI default TP
6288    L 0  8229    0           1331      0      0.00   0.00 0.00 0     eicore_bdn
6288    L 0  8230    0           1331      0      0.00   0.00 0.00 0     eicore_bdn
6288    L 0  8231    0           1330      0      0.00   0.00 0.00 0     eicore_bdn
6288    L 2  8255    0           1328      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 3  8256    0           1328      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 3  8257    0           1328      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 1  8258    161690      7949654   0      0.00   0.02 0.04 0     mem_mgmt
6288    L 0  8259    162500      7949605   0      0.00   0.00 0.00 0     mem_mgmt
6288    L 1  8261    0           1329      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 1  8262    0           1329      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 2  8263    0           1329      0      0.00   0.00 0.00 0     mem_mgmt
6288    L 3  9805    0           1339      0      0.00   0.00 0.00 0     eicore_ipc
6289    L            990750      41141165  24     0.00   0.03 0.02 0     mgmte_tap
6289    L 3  6289    170         1267      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 1  7867    210450      8140306   0      0.00   0.00 0.00 0     mgmte_tap
6289    L 2  7868    24440       814683    0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7870    275330      8140179   0      0.00   0.00 0.01 0     pdslib thread
6289    L 3  7871    20          1295      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 2  7872    0           1271      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 1  7873    155990      8134203   0      0.00   0.03 0.04 0     mgmte_tap
6289    L 2  7875    0           1270      0      0.00   0.00 0.00 0     SPI default ST
6289    L 3  7930    0           1264      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 3  7931    0           1264      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 3  7932    0           1264      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7960    160240      7949598   0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7973    164110      7949547   0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7976    0           1268      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7980    0           1268      0      0.00   0.00 0.00 0     mgmte_tap
6289    L 0  7981    0           1268      0      0.00   0.00 0.00 0     mgmte_tap
6290    L            725470      33053409  21     0.29   0.29 0.02 0     installer
6290    L 1  6290    550         1357      0      1.63   0.42 0.36 0     installer
6290    L 1  8864    214690      8140430   0      0.00   0.00 0.00 0     installer
6290    L 0  8865    40          1394      0      0.00   0.00 0.00 0     installer
6290    L 0  8866    400         3169      0      0.10   0.10 0.10 0     installer
6290    L 0  8867    155600      8134202   0      0.00   0.00 0.00 0     installer
6290    L 3  8868    120         3161      0      0.00   0.00 0.00 0     SPI default TP
6290    L 1  8869    180         3393      0      0.00   0.00 0.00 0     SPI default TP
6290    L 3  8870    260         3730      0      0.00   0.00 0.00 0     SPI default TP
6290    L 3  8871    40          2231      0      0.00   0.04 0.05 0     SPI default TP
6290    L 2  8872    100         3009      0      0.00   0.00 0.00 0     SPI default TP
6290    L 2  8873    0           1272      0      0.00   0.00 0.00 0     installer
6290    L 2  8874    0           1272      0      0.00   0.00 0.00 0     installer
6290    L 2  8875    0           1272      0      0.00   0.00 0.00 0     installer
6290    L 0  8876    161220      7949598   0      0.00   0.00 0.01 0     installer
6290    L 0  8877    166530      7949545   0      0.00   0.01 0.03 0     installer
6290    L 3  8878    80          1715      0      0.00   0.00 0.00 0     installer
6290    L 2  8879    25300       814707    0      0.00   0.00 0.00 0     installer
6290    L 2  8880    0           1284      0      0.00   0.00 0.00 0     installer
6290    L 2  8881    0           1283      0      0.00   0.00 0.00 0     installer
6290    L 0  8883    0           1298      0      0.00   0.00 0.00 0     installer
6290    L 2  8884    0           1299      0      0.00   0.00 0.00 0     installer
6290    L 3  8886    10          1314      0      0.00   0.00 0.00 0     SPI default ST
6290    L 1  8887    40          1370      0      0.00   0.00 0.00 0     OIR Client XDM
6290    L 2  8889    0           1309      0      0.00   0.00 0.00 0     eicore_bdn
6290    L 3  8890    0           1309      0      0.00   0.00 0.00 0     eicore_bdn
6290    L 2  8891    0           1308      0      0.00   0.00 0.00 0     eicore_bdn
6290    L 0  9795    280         2248      0      0.00   0.00 0.00 0     eicore_ipc
6290    L 2  9919    0           1326      0      0.00   0.00 0.00 0     Installer Provi
6290    L 2  9920    0           1326      0      0.00   0.00 0.00 0     Installer Provi
6290    L 2  9921    0           1326      0      0.00   0.00 0.00 0     Installer Provi
6290    L 2  9922    0           1326      0      0.00   0.00 0.00 0     Result Synthesi
6290    L 3  9924    0           1326      0      0.00   0.00 0.00 0     Result Synthesi
6290    L 3  9925    0           1326      0      0.00   0.00 0.00 0     Result Synthesi
6290    L 1  11448   0           1335      0      0.00   0.00 0.00 0     HALib Dispatch
6290    L 3  11449   20          1371      0      0.00   0.00 0.00 0     HALib Dispatch
6290    L 1  11450   0           1332      0      0.00   0.00 0.00 0     HALib Dispatch
6290    L 1  11453   20          1421      0      0.00   0.00 0.00 0     RF Slave Main T
6290    L 3  13053   0           1335      0      0.00   0.00 0.00 0     HALib Dispatch
6290    L 0  14441   0           2323      0      0.00   0.00 0.00 0     INSTALLER SERVI
6290    L 0  15775   0           2320      0      0.00   0.00 0.00 0     INSTALLER SERVI
6290    L 2  15776   10          2339      0      0.00   0.08 0.09 0     INSTALLER SERVI
6290    L 3  16309   0           2305      0      0.00   0.00 0.00 0     INSTALLER SERVI
6291    L            3285235     697143769 109    0.59   0.57 0.51 0     ffm
6291    L 3  6291    754270      8505510   0      0.00   0.01 0.03 0     ffm
6291    L 0  7906    342430      8140265   0      0.00   0.00 0.02 0     ffm
6291    L 2  7907    29340       814754    0      0.00   0.00 0.00 0     ffm
6291    L 1  7908    40          1484      0      0.00   0.00 0.00 0     ffm
6291    L 1  7909    451053      252276152 0      0.19   0.15 0.15 0     ffm
6291    L 1  7910    192310      8134258   0      0.00   0.00 0.02 0     ffm
6291    L 1  7911    1307282     23437704  0      0.10   0.12 0.05 0     SPI default TP
6291    L 0  7912    1296522     23479668  0      0.00   0.01 0.05 0     SPI default TP
6291    L 0  7913    1343432     23955663  0      0.00   0.02 0.01 0     SPI default TP
6291    L 3  7914    1404732     23979200  0      0.00   0.00 0.00 0     SPI default TP
6291    L 0  7915    1482432     23902107  0      0.00   0.01 0.04 0     SPI default TP
6291    L 1  7945    0           1351      0      0.00   0.00 0.00 0     ffm
6291    L 1  7946    0           1351      0      0.00   0.00 0.00 0     ffm
6291    L 1  7947    0           1351      0      0.00   0.00 0.00 0     ffm
6291    L 1  7963    158990      7949685   0      0.00   0.00 0.00 0     ffm
6291    L 0  7967    457240      7951747   0      0.00   0.00 0.00 0     ffm
6291    L 1  7969    1714550     19736233  0      0.00   0.02 0.02 0     ffm
6291    L 3  7974    0           1355      0      0.00   0.00 0.00 0     ffm
6291    L 3  7977    0           1353      0      0.00   0.00 0.00 0     ffm
6291    L 3  8027    0           1363      0      0.00   0.00 0.00 0     eicore_bdn
6291    L 3  8028    0           1363      0      0.00   0.00 0.00 0     eicore_bdn
6291    L 3  8029    0           1363      0      0.00   0.00 0.00 0     eicore_bdn
6291    L 3  9763    20          1380      0      0.00   0.00 0.00 0     eicore_ipc
6291    L 2  9811    2881975     170207672 0      0.14   0.21 0.20 0     SPI default ST
6291    L 3  9923    0           1449      0      0.00   0.00 0.00 0     ffm
6291    L 2  11160   2352155     94653074  0      0.05   0.03 0.02 0     ffm_reply aggre
6291    L 0  11162   0           1573      0      0.00   0.00 0.00 0     ffm
6291    L 3  11165   0           1577      0      0.00   0.00 0.00 0     ffm
6291    L 1  12787   1460        2572      0      0.00   0.00 0.00 0     ffm
6292    L            3276255     171400259 69     9.23   1.16 0.60 0     eicored
6292    L 1  6292    11470       1567      0      0.00   0.00 0.22 0     eicored
6292    L 1  7811    1490422     16048455  0      0.10   0.13 0.14 0     eicored
6292    L 0  7822    25200       814695    0      0.00   0.00 0.00 0     eicored
6292    L 1  8032    50          1647      0      0.00   0.00 0.00 0     eicored
6292    L 3  8045    1452080     11403536  0      0.24   0.09 0.06 0     eicored
6292    L 3  8047    170990      8134225   0      0.00   0.00 0.03 0     eicored
6292    L 2  8061    0           1301      0      0.00   0.00 0.00 0     eicored
6292    L 2  8062    0           1301      0      0.00   0.00 0.00 0     eicored
6292    L 2  8063    0           1301      0      0.00   0.00 0.00 0     eicored
6292    L 0  8064    159030      7949630   0      0.00   0.00 0.00 0     eicored
6292    L 1  8065    167080      7949586   0      0.05   0.05 0.05 0     eicored
6292    L 2  8067    540         5507      0      0.00   0.00 0.00 0     eicored
6292    L 1  8068    793980      8273807   0      0.19   0.13 0.14 0     SPI default TP
6292    L 2  8069    817040      8373086   0      0.00   0.03 0.04 0     SPI default TP
6292    L 3  8070    781450      8246960   0      0.53   0.17 0.15 0     SPI default TP
6292    L 3  8071    799070      8286662   0      0.10   0.07 0.09 0     SPI default TP
6292    L 3  8072    793500      8283292   0      0.05   0.18 0.22 0     SPI default TP
6292    L 3  8073    70          1475      0      0.00   0.00 0.00 0     eicored
6292    L 2  8074    0           1315      0      0.00   0.00 0.00 0     eicored
6292    L 1  8078    0           1324      0      0.00   0.00 0.00 0     eicore xdm
6292    L 3  8079    4080        4152      0      0.00   0.00 0.00 0     eicore push xdm
6292    L 2  8080    0           1373      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 2  8081    10          1373      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 3  8082    0           1334      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 2  8595    1720        7725586   0      0.00   0.03 0.05 0     eicore_ipc
6292    L 1  9623    0           1469      0      0.00   0.00 0.00 0     eicored
6292    L 0  9779    2580        25812     0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  9781    13070       57968     0      0.00   0.00 0.00 0     eicore_ipc
6292    L 2  9782    7320        82030     0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  9783    10          1496      0      0.00   0.00 0.00 0     eicore em shim
6292    L 2  9791    10          1506      0      0.00   0.00 0.00 0     SPI default ST
6292    L 3  9823    10          1351      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 0  9825    0           1353      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 0  9827    0           1351      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 3  9844    30          1522      0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  9846    0           1328      0      0.00   0.00 0.00 0     eicore push xdm
6292    L 0  9890    0           1543      0      0.00   0.00 0.00 0     EICORE_HA_PROG
6292    L 1  9956    0           1560      0      0.00   0.00 0.00 0     HALib Dispatch
6292    L 1  9957    0           1560      0      0.00   0.00 0.00 0     HALib Dispatch
6292    L 0  9958    0           1564      0      0.00   0.00 0.00 0     HALib Dispatch
6292    L 3  9964    0           1657      0      0.00   0.00 0.00 0     RF Slave Main T
6292    L 1  9966    0           1563      0      0.00   0.00 0.00 0     eicore iosd  xd
6292    L 2  10458   5340        7726853   0      0.00   0.17 0.03 0     eicore_ipc
6292    L 2  10788   0           1360      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 2  10828   6020        3401      0      0.00   0.00 0.00 0     EICORE_BULK_SYN
6292    L 3  10900   0           1518      0      0.00   0.00 0.00 0     eicore push xdm
6292    L 3  10959   19810       81071     0      0.00   0.00 0.00 0     eicore_ipc
6292    L 0  10964   20080       81750     0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  11095   0           1385      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 3  11097   0           1351      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 3  11098   0           1351      0      0.00   0.00 0.00 0     eicore_bdn
6292    L 2  11101   2020        2695      0      0.00   0.00 0.00 0     EICORE_BULK_SYN
6292    L 1  11114   0           1564      0      0.00   0.00 0.00 0     eicore push xdm
6292    L 2  12449   3590        7726057   0      0.00   0.41 0.04 0     eicore_ipc
6292    L 2  12455   400         7724984   0      0.00   0.35 0.22 0     eicore_ipc
6292    L 1  13017   0           1560      0      0.00   0.00 0.00 0     HALib Dispatch
6292    L 0  14402   3210        7723591   0      0.00   0.00 0.27 0     eicore_ipc
6292    L 3  14405   5490        7724012   0      8.21   4.04 3.42 0     eicore_ipc
6292    L 1  14409   10          7723155   0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  15092   30          7723215   0      0.00   0.00 0.00 0     eicore_ipc
6292    L 2  15096   0           7723594   0      0.00   0.00 0.00 0     eicore_ipc
6292    L 1  32506   17780       7728096   0      0.00   0.00 0.00 0     eicore_ipc
6293    L            722160      33287546  21     0.00   0.00 0.00 0     dtmgr
6293    L 2  6293    250         1309      0      0.00   0.00 0.00 0     dtmgr
6293    L 0  7076    211940      8140309   0      0.00   0.00 0.00 0     dtmgr
6293    L 1  7092    25300       814688    0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8166    50          1347      0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8240    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8241    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8242    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 0  8243    157220      7949613   0      0.00   0.00 0.00 0     dtmgr
6293    L 1  8244    168740      7949559   0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8245    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8246    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 2  8247    0           1283      0      0.00   0.00 0.00 0     dtmgr
6293    L 1  8248    160         2054      0      0.00   0.00 0.00 0     dtmgr
6293    L 0  8249    153030      8134223   0      0.00   0.00 0.00 0     dtmgr
6293    L 0  8250    80          1537      0      0.00   0.00 0.00 0     SPI default TP
6293    L 3  8251    0           1523      0      0.00   0.00 0.00 0     SPI default TP
6293    L 0  8252    20          1343      0      0.00   0.00 0.00 0     SPI default TP
6293    L 2  8253    80          1603      0      0.00   0.00 0.00 0     SPI default TP
6293    L 1  8254    60          1622      0      0.00   0.00 0.00 0     SPI default TP
6293    L 2  8293    0           1295      0      0.00   0.00 0.00 0     eicore_bdn
6293    L 2  8294    0           1295      0      0.00   0.00 0.00 0     eicore_bdn
6293    L 2  8295    0           1295      0      0.00   0.00 0.00 0     eicore_bdn
6293    L 3  9777    20          1310      0      0.00   0.00 0.00 0     eicore_ipc
6293    L 0  9885    5210        272657    0      0.00   0.00 0.00 0     dtmgr
6293    L 2  9886    0           1307      0      0.00   0.00 0.00 0     dtmgr
6294    L            1988689     41100428  1197   0.15   0.14 0.14 0     cpumemd
6294    L 0  6294    1275619     8090398   0      0.10   0.14 0.14 0     cpumemd
6294    L 1  7155    213590      8140284   0      0.00   0.00 0.00 0     cpumemd
6294    L 0  7168    25170       814682    0      0.00   0.00 0.00 0     cpumemd
6294    L 2  7192    30          1315      0      0.00   0.00 0.00 0     cpumemd
6294    L 0  7195    0           1275      0      0.00   0.00 0.00 0     cpumemd
6294    L 1  7196    150220      8134221   0      0.00   0.00 0.00 0     cpumemd
6294    L 0  7197    0           1274      0      0.00   0.00 0.00 0     SPI default TP
6294    L 0  7198    0           1274      0      0.00   0.00 0.00 0     SPI default TP
6294    L 0  7199    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6294    L 2  7200    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6294    L 2  7201    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6294    L 3  7939    0           1276      0      0.00   0.00 0.00 0     cpumemd
6294    L 3  7940    0           1276      0      0.00   0.00 0.00 0     cpumemd
6294    L 3  7941    0           1276      0      0.00   0.00 0.00 0     cpumemd
6294    L 0  7959    157410      7949603   0      0.00   0.00 0.00 0     cpumemd
6294    L 1  8003    166700      7949559   0      0.00   0.00 0.03 0     cpumemd
6294    L 0  8005    0           1279      0      0.00   0.00 0.00 0     cpumemd
6294    L 0  8006    0           1279      0      0.00   0.00 0.00 0     cpumemd
6294    L 3  8009    0           1279      0      0.00   0.00 0.00 0     cpumemd
6294    L 0  8394    0           1276      0      0.00   0.00 0.00 0     eicore_bdn
6294    L 0  8395    0           1276      0      0.00   0.00 0.00 0     eicore_bdn
6294    L 0  8396    0           1276      0      0.00   0.00 0.00 0     eicore_bdn
6294    L 2  8399    0           1277      0      0.00   0.00 0.00 0     SPI default ST
6300    L            2702960     51711186  52     0.00   0.00 0.01 0     liin_tap
6300    L 3  6300    1686820     10571531  0      0.00   0.02 0.01 0     liin_tap
6300    L 2  7057    244020      8140221   0      0.00   0.00 0.03 0     liin_tap
6300    L 1  7065    25020       814682    0      0.00   0.00 0.00 0     liin_tap
6300    L 0  7095    263280      8140187   0      0.00   0.00 0.00 0     pdslib thread
6300    L 2  12939   30          1294      0      0.00   0.00 0.00 0     liin_tap
6300    L 2  12940   0           1268      0      0.00   0.00 0.00 0     liin_tap
6300    L 2  12942   157970      8134165   0      0.00   0.00 0.00 0     liin_tap
6300    L 0  12945   0           1268      0      0.00   0.00 0.00 0     SPI default ST
6300    L 3  12946   0           1262      0      0.00   0.00 0.00 0     liin_tap
6300    L 3  12947   0           1262      0      0.00   0.00 0.00 0     liin_tap
6300    L 3  12948   0           1262      0      0.00   0.00 0.00 0     liin_tap
6300    L 0  12949   158230      7949552   0      0.00   0.00 0.00 0     liin_tap
6300    L 1  12950   167590      7949505   0      0.00   0.00 0.00 0     liin_tap
6300    L 3  12951   0           1262      0      0.00   0.00 0.00 0     liin_tap
6300    L 3  12952   0           1262      0      0.00   0.00 0.00 0     liin_tap
6300    L 3  12953   0           1262      0      0.00   0.00 0.00 0     liin_tap
6310    L            826300      33652201  24     1.86   0.15 1.86 0     cli_agent
6310    L 2  6310    810         1298      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  7657    243610      8149217   0      0.34   0.34 0.34 0     cli_agent
6310    L 0  7673    25380       814686    0      0.00   0.00 0.00 0     cli_agent
6310    L 1  7695    10          1325      0      0.00   0.00 0.00 0     cli_agent
6310    L 2  7704    21180       122949    0      0.00   0.04 0.05 0     cli_agent
6310    L 0  7705    155730      8134220   0      0.00   0.00 0.00 0     cli_agent
6310    L 2  7706    9560        83333     0      0.00   0.00 0.00 0     SPI default TP
6310    L 3  7707    9080        90375     0      0.10   0.26 0.28 0     SPI default TP
6310    L 2  7708    10050       100880    0      0.00   0.04 0.05 0     SPI default TP
6310    L 1  7709    8000        85447     0      0.00   0.04 0.05 0     SPI default TP
6310    L 2  7710    7220        73278     0      0.00   0.00 0.00 0     SPI default TP
6310    L 2  7725    0           1283      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  7927    0           1279      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  7928    0           1279      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  7929    0           1279      0      0.00   0.00 0.00 0     cli_agent
6310    L 1  7991    160780      7949614   0      0.00   0.00 0.00 0     cli_agent
6310    L 2  7996    165790      7949555   0      0.00   0.00 0.03 0     cli_agent
6310    L 0  7998    0           1286      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  8001    0           1286      0      0.00   0.00 0.00 0     cli_agent
6310    L 0  8002    0           1286      0      0.00   0.00 0.00 0     cli_agent
6310    L 2  8092    4140        20912     0      0.00   0.00 0.00 0     cli_agent
6310    L 0  8094    4800        20900     0      0.00   0.00 0.00 0     SPI default ST
6310    L 1  13231   0           1300      0      0.00   0.00 0.00 0     eicore_bdn
6310    L 2  13232   0           1300      0      0.00   0.00 0.00 0     eicore_bdn
6310    L 0  13233   0           1299      0      0.00   0.00 0.00 0     eicore_bdn
6310    L 1  16316   0           20901     0      0.00   0.00 0.00 0     cli_agent
6310    L 2  16317   410         21095     0      0.00   0.52 0.56 0     cli_agent
6310    L 1  16349   0           20913     0      0.00   0.00 0.00 0     cli_agent
6310    L 2  16350   1850        20979     0      5.57   5.57 5.57 0     cli_agent
6311    L            1343648     418763365 187    0.00   0.68 0.26 0     snmp_subagent
6311    L 2  6311    7160        1766      0      0.00   1.30 0.03 0     snmp_subagent
6311    L 1  7522    2929000     11413348  0      0.00   0.12 0.01 0     snmp_subagent
6311    L 2  7527    24950       814682    0      0.00   0.00 0.00 0     snmp_subagent
6311    L 1  8087    20          1363      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 1  8096    502848      92550453  0      0.00   0.28 0.05 0     snmp_subagent
6311    L 1  8098    152230      8134224   0      0.00   0.00 0.00 0     snmp_subagent
6311    L 1  8102    734160      7033237   0      0.00   0.00 0.01 0     SPI default TP
6311    L 3  8103    739420      7026583   0      0.00   0.03 0.04 0     SPI default TP
6311    L 0  8104    728250      7010609   0      0.00   0.07 0.02 0     SPI default TP
6311    L 0  8105    722480      6971683   0      0.00   0.03 0.04 0     SPI default TP
6311    L 3  8106    723380      6963549   0      0.00   0.03 0.04 0     SPI default TP
6311    L 3  8107    0           1294      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 3  8109    0           1294      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 3  8113    0           1295      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 0  8114    154880      7949624   0      0.00   0.00 0.00 0     snmp_subagent
6311    L 0  8117    167080      7949566   0      0.00   0.00 0.00 0     snmp_subagent
6311    L 3  8118    0           1295      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 0  8121    0           1295      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 0  8122    0           1295      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 1  8151    1148778     91011030  0      0.00   0.75 0.07 0     snmp_subagent
6311    L 3  8155    0           1310      0      0.00   0.00 0.00 0     HALib Dispatch
6311    L 0  8156    0           1313      0      0.00   0.00 0.00 0     HALib Dispatch
6311    L 0  8157    0           1314      0      0.00   0.00 0.00 0     HALib Dispatch
6311    L 0  8160    1165176     84402785  0      0.00   0.64 0.07 0     SPI default ST
6311    L 0  8162    30          1424      0      0.00   0.00 0.00 0     RF Slave Main T
6311    L 2  8301    0           1320      0      0.00   0.00 0.00 0     eicore_bdn
6311    L 2  8302    0           1320      0      0.00   0.00 0.00 0     eicore_bdn
6311    L 2  8303    0           1320      0      0.00   0.00 0.00 0     eicore_bdn
6311    L 1  10958   13420       76011     0      0.00   0.01 0.03 0     eicore_ipc
6311    L 0  11146   20          1821      0      0.00   0.00 0.00 0     eicore_ipc
6311    L 3  11149   10          1768      0      0.00   0.00 0.00 0     snmp_subagent
6311    L 2  11154   20250       760381    0      0.00   0.00 0.00 0     xos_thread
6311    L 0  13052   0           1313      0      0.00   0.00 0.00 0     HALib Dispatch
6311    L 2  13124   0           819428    0      0.00   0.00 0.00 0     SNMP SA CACHE
6311    L 1  15094   10          819471    0      0.00   0.00 0.00 0     SNMP SA CACHE
6311    L 2  16211   10          18848282  0      0.00   0.00 0.00 0     COMET_SUB_AGENT
6311    L 2  16231   0           18848188  0      0.00   0.00 0.00 0     COMET_SUB_AGENT
6311    L 2  16269   20          819501    0      0.00   0.00 0.00 0     SNMP SA CACHE
6311    L 0  16280   0           819472    0      0.00   0.00 0.00 0     SNMP SA CACHE
6311    L 2  16308   0           18848161  0      0.00   0.00 0.00 0     COMET_SUB_AGENT
6311    L 2  16328   0           18848086  0      0.00   0.00 0.00 0     COMET_SUB_AGENT
6312    L            941440      41150145  22     0.00   0.00 0.02 0     erm_p
6312    L 2  6312    230210      8140248   0      0.00   0.00 0.00 0     erm_p
6312    L 1  7060    206500      8140300   0      0.00   0.00 0.02 0     erm_p
6312    L 3  7074    24980       814682    0      0.00   0.00 0.00 0     erm_p
6312    L 3  8095    20          1299      0      0.00   0.00 0.00 0     erm_p
6312    L 3  8099    0           1274      0      0.00   0.00 0.00 0     erm_p
6312    L 3  8128    150610      8134211   0      0.00   0.00 0.00 0     erm_p
6312    L 2  8129    0           1267      0      0.00   0.00 0.00 0     SPI default TP
6312    L 2  8130    0           1267      0      0.00   0.00 0.00 0     SPI default TP
6312    L 3  8131    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6312    L 3  8132    0           1275      0      0.00   0.00 0.00 0     SPI default TP
6312    L 3  8133    10          1275      0      0.00   0.00 0.00 0     SPI default TP
6312    L 3  8134    0           1266      0      0.00   0.00 0.00 0     erm_p
6312    L 3  8135    0           1266      0      0.00   0.00 0.00 0     erm_p
6312    L 0  8136    0           1266      0      0.00   0.00 0.00 0     erm_p
6312    L 0  8137    161380      7949591   0      0.00   0.00 0.00 0     erm_p
6312    L 2  8138    167730      7949541   0      0.00   0.00 0.02 0     erm_p
6312    L 0  8139    0           1266      0      0.00   0.00 0.00 0     erm_p
6312    L 0  8140    0           1266      0      0.00   0.00 0.00 0     erm_p
6312    L 0  8141    0           1266      0      0.00   0.00 0.00 34816 erm_p
6312    L 0  8144    0           1270      0      0.00   0.00 0.00 0     eicore_bdn
6312    L 0  8145    0           1270      0      0.00   0.00 0.00 0     eicore_bdn
6312    L 0  8146    0           1270      0      0.00   0.00 0.00 0     eicore_bdn
6312    L 3  9764    0           1284      0      0.00   0.00 0.00 0     eicore_ipc
6313    L            923150      41150279  22     0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  6313    208390      8140333   0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8455    208740      8140278   0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8456    25590       814680    0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 2  8488    20          1294      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8490    0           1278      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8491    151280      8134211   0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 1  8494    0           1270      0      0.00   0.00 0.00 0     SPI default TP
6313    L 1  8495    0           1270      0      0.00   0.00 0.00 0     SPI default TP
6313    L 0  8496    0           1278      0      0.00   0.00 0.00 0     SPI default TP
6313    L 0  8497    0           1278      0      0.00   0.00 0.00 0     SPI default TP
6313    L 0  8498    0           1278      0      0.00   0.00 0.00 0     SPI default TP
6313    L 0  8500    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8501    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8502    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8503    160100      7949595   0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8504    169040      7949539   0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8505    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8506    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 0  8507    0           1269      0      0.00   0.00 0.00 0     ngdumper_provid
6313    L 1  8511    0           1280      0      0.00   0.00 0.00 0     eicore_bdn
6313    L 1  8512    0           1280      0      0.00   0.00 0.00 0     eicore_bdn
6313    L 1  8513    0           1280      0      0.00   0.00 0.00 0     eicore_bdn
6313    L 0  9773    0           1293      0      0.00   0.00 0.00 0     eicore_ipc
6314    L            915520      41150315  22     0.00   0.00 0.00 0     sysinfo_p
6314    L 1  6314    207890      8140346   0      0.00   0.00 0.00 0     sysinfo_p
6314    L 1  7372    211810      8140302   0      0.00   0.00 0.01 0     sysinfo_p
6314    L 2  7376    25320       814682    0      0.00   0.00 0.00 0     sysinfo_p
6314    L 3  8167    10          1299      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8179    20          1277      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 0  8180    148750      8134208   0      0.00   0.00 0.00 0     sysinfo_p
6314    L 3  8181    0           1265      0      0.00   0.00 0.00 0     SPI default TP
6314    L 3  8182    0           1277      0      0.00   0.00 0.00 0     SPI default TP
6314    L 2  8184    0           1277      0      0.00   0.00 0.00 0     SPI default TP
6314    L 2  8185    0           1268      0      0.00   0.00 0.00 0     SPI default TP
6314    L 1  8186    10          1276      0      0.00   0.00 0.00 0     SPI default TP
6314    L 2  8232    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8233    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8234    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 0  8235    157870      7949593   0      0.00   0.00 0.00 0     sysinfo_p
6314    L 0  8236    163840      7949545   0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8237    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8238    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 2  8239    0           1265      0      0.00   0.00 0.00 0     sysinfo_p
6314    L 3  8306    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6314    L 3  8307    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6314    L 3  8308    0           1287      0      0.00   0.00 0.00 0     eicore_bdn
6314    L 3  9809    0           1301      0      0.00   0.00 0.00 0     eicore_ipc
6327    L            236050      8956235   26     0.00   0.00 0.00 0     fs_cmd
6327    L 0  6327    140         1259      0      0.00   0.00 0.00 0     fs_cmd
6327    L 0  7022    211360      8140304   0      0.05   0.05 0.05 0     fs_cmd
6327    L 0  7035    24560       814683    0      0.00   0.00 0.00 0     fs_cmd
8433    L            410         1416      289    0.00   0.00 0.00 0     rollback_timer.
8742    L            10          1406      7      0.00   0.00 0.00 0     rollback_timer.
8748    L            160         1406      113    0.00   0.00 0.00 0     xlogger
8757    L            0           1410      0      0.00   0.00 0.00 0     inotifywait
8904    L            140         1181      118    0.00   0.00 0.00 0     nova_sntp.sh
9178    L            0           1179      0      0.00   0.00 0.00 0     nova_sntp.sh
9183    L            160         1179      135    0.00   0.00 0.00 0     xlogger
9186    L            3570        24327     146    0.00   0.00 0.00 0     sntp
12121   L            2303280     200138420 33     0.05   0.14 0.12 0     wcm
12121   L 2  12121   2560        1467      0      0.00   0.00 0.00 0     wcm
12121   L 2  12722   250860      8144214   0      0.00   0.00 0.00 0     wcm
12121   L 0  12723   29030       814874    0      0.00   0.00 0.00 0     wcm
12121   L 0  12793   985212      162311198 0      0.00   0.02 0.00 0     osapiTimer
12121   L 3  12794   2867710     42183466  0      0.00   0.02 0.04 0     osapiBsnTimer
12121   L 3  12797   0           1601      0      0.00   0.00 0.00 0     debugMainTask
12121   L 3  12798   0           1601      0      0.00   0.00 0.00 0     loggerMainTask
12121   L 0  12799   50          1834      0      0.00   0.00 0.00 0     fp_main_task
12121   L 3  12800   231310      1640676   0      0.00   0.00 0.00 0     fp_main_task
12121   L 0  12801   198990      8134467   0      0.00   0.01 0.03 0     fp_main_task
12121   L 2  12802   119120      1349010   0      0.00   0.00 0.01 0     SPI default TP
12121   L 2  12803   118970      1348233   0      0.00   0.00 0.00 0     SPI default TP
12121   L 3  12804   117150      1307081   0      0.00   0.00 0.00 0     SPI default TP
12121   L 3  12805   122270      1365401   0      0.00   0.00 0.00 0     SPI default TP
12121   L 1  12806   117890      1296839   0      0.00   0.00 0.00 0     SPI default TP
12121   L 1  12807   0           1614      0      0.00   0.00 0.00 0     fp_main_task
12121   L 1  12808   0           1614      0      0.00   0.00 0.00 0     fp_main_task
12121   L 2  12809   0           1705      0      0.00   0.00 0.00 0     fp_main_task
12121   L 0  12810   156830      7949909   0      0.00   0.00 0.00 0     fp_main_task
12121   L 1  12811   167670      7949867   0      0.00   0.00 0.00 0     fp_main_task
12121   L 0  12812   0           1617      0      0.00   0.00 0.00 0     fp_main_task
12121   L 3  12813   0           1617      0      0.00   0.00 0.00 0     fp_main_task
12121   L 2  12814   0           1620      0      0.00   0.00 0.00 0     fp_main_task
12121   L 3  12818   20          1693      0      0.00   0.00 0.00 0     qosSvcTask
12121   L 1  12820   0           1678      0      0.00   0.00 0.00 0     HALib Dispatch
12121   L 0  12821   210         1847      0      0.00   0.00 0.00 0     HALib Dispatch
12121   L 0  12822   10          1696      0      0.00   0.00 0.00 0     HALib Dispatch
12121   L 0  12825   360         3889      0      0.00   0.00 0.00 0     SPI default ST
12121   L 0  12826   50          1763      0      0.00   0.00 0.00 0     RF Slave Main T
12121   L 0  12827   20          1757      0      0.00   0.00 0.00 0     novaSocketTask
12121   L 1  12828   349030      8140432   0      0.00   0.00 0.00 0     pdslib thread
12121   L 0  12829   10          1713      0      0.00   0.00 0.00 0     simSvcRcvTask
12121   L 2  12831   0           1682      0      0.00   0.00 0.00 0     PTG Packet Hand
12121   L 1  12832   0           1698      0      0.00   0.00 0.00 0     clientTroubleSh
12121   L 3  12833   10          1703      0      0.00   0.00 0.00 0     mfpEventTask
12121   L 1  12834   54450       815748    0      0.00   0.03 0.04 0     mfpTrapForwardT
12121   L 1  12835   0           1706      0      0.00   0.00 0.00 0     mmMfpTask
12121   L 0  12836   10          1735      0      0.00   0.00 0.00 0     spamSocketTask
12121   L 2  12837   10          1732      0      0.00   0.00 0.00 0     spamReceiveTask
12121   L 1  12838   0           1733      0      0.00   0.00 0.00 0     spamApTask0
12121   L 2  12839   0           1716      0      0.00   0.00 0.00 0     spamApTask1
12121   L 1  12845   0           1764      0      0.00   0.00 0.00 0     capwapSocketTas
12121   L 2  12847   0           1763      0      0.00   0.00 0.00 0     capwapKASocketT
12121   L 0  12848   0           1762      0      0.00   0.00 0.00 0     capwapDataSocke
12121   L 1  12849   0           1767      0      0.00   0.00 0.00 0     capwapHATask
12121   L 1  12850   6110        277909    0      0.00   0.00 0.00 0     sshpmSvcRcvTask
12121   L 1  12854   1922830     27378740  0      0.00   0.00 0.01 0     nmspRxServerTas
12121   L 1  12855   2031490     81269982  0      0.00   0.00 0.00 0     nmspTxServerTas
12121   L 3  12857   0           1782      0      0.00   0.00 0.00 0     dot1xWcmTask_0
12121   L 0  12858   0           1797      0      0.00   0.00 0.00 0     t296367696
12121   L 2  12861   6290        275568    0      0.00   0.00 0.00 0     ccxL2RoamTask
12121   L 2  12862   0           1786      0      0.00   0.00 0.00 0     ccxRmTask
12121   L 2  12863   0           1787      0      0.00   0.00 0.00 0     ccxS69Task
12121   L 2  12864   0           1786      0      0.00   0.00 0.00 0     ccxDiagTask
12121   L 0  12865   0           1801      0      0.00   0.00 0.00 0     iappSocketTask
12121   L 2  12866   0           1786      0      0.00   0.00 0.00 0     iappMsgTask
12121   L 2  12867   0           1786      0      0.00   0.00 0.00 0     pemReceiveTask
12121   L 2  12868   0           1786      0      0.00   0.00 0.00 0     webAuthMessageT
12121   L 3  12870   0           1792      0      0.00   0.00 0.00 0     AAA Lib Thread
12121   L 0  12871   400         15362     0      0.00   0.00 0.00 0     AAA shim housek
12121   L 3  12872   0           1791      0      0.00   0.00 0.00 0     aaashimMsgTask
12121   L 0  12873   0           1798      0      0.00   0.00 0.00 0     mmListen
12121   L 3  12874   142700      839232    0      0.00   0.00 0.02 0     mmMobility
12121   L 1  12875   0           1795      0      0.00   0.00 0.00 0     mmMaListen
12121   L 0  12877   0           1805      0      0.00   0.00 0.00 0     capwapPingSocke
12121   L 3  12878   0           1799      0      0.00   0.00 0.00 0     capwapPingOsapi
12121   L 2  12879   0           1802      0      0.00   0.00 0.00 0     NetflowTask
12121   L 1  12880   1620        29205     0      0.00   0.00 0.00 0     apfReceiveTask
12121   L 0  12881   0           1819      0      0.00   0.00 0.00 0     apfRLDPRecv
12121   L 3  12882   0           1807      0      0.00   0.00 0.00 0     apfRLDP
12121   L 2  12883   0           1806      0      0.00   0.00 0.00 0     apfRldpDhcp
12121   L 1  12884   0           1821      0      0.00   0.00 0.00 0     apfOpenDtlSocke
12121   L 0  12885   0           1821      0      0.00   0.00 0.00 0     apfProbeThread
12121   L 0  12886   1000        69644     0      0.00   0.00 0.00 0     apfRogueDetecto
12121   L 0  12887   458860      4257478   0      0.00   0.00 0.02 0     apfLbsTask
12121   L 2  12888   0           1809      0      0.00   0.00 0.00 0     apfMsConnTask_0
12121   L 0  12889   35860       1630050   0      0.00   0.00 0.00 0     apfPmkCacheTime
12121   L 2  12892   0           1817      0      0.00   0.00 0.00 0     RLDP Schedule T
12121   L 0  12893   0           1833      0      0.00   0.00 0.00 0     rrmSocketTask
12121   L 0  12894   0           1841      0      0.00   0.00 0.00 0     rrm Socket Task
12121   L 3  12895   15860       825552    0      0.00   0.00 0.00 0     dot11b
12121   L 0  12896   0           1839      0      0.00   0.00 0.00 0     rrm Socket Task
12121   L 3  12897   0           1819      0      0.00   0.00 0.00 0     grouping Task
12121   L 3  12898   105670      1059455   0      0.00   0.02 0.00 0     dot11b
12121   L 0  12899   0           1841      0      0.00   0.00 0.00 0     rrm Socket Task
12121   L 0  12900   15400       825878    0      0.00   0.00 0.00 0     dot11a
12121   L 0  12901   0           1842      0      0.00   0.00 0.00 0     rrm Socket Task
12121   L 3  12902   0           1821      0      0.00   0.00 0.00 0     grouping Task
12121   L 3  12903   104590      1190803   0      0.00   0.00 0.00 0     dot11a
12121   L 3  12904   860         6833      0      0.00   0.00 0.00 0     rrmPeriodicTask
12121   L 1  12905   0           1822      0      0.00   0.00 0.00 0     CDP Main
12121   L 0  12907   0           1832      0      0.00   0.00 0.00 0     bcastWcmRcvTask
12121   L 1  12908   0           1825      0      0.00   0.00 0.00 0     ProcessLoggingT
12121   L 0  12909   0           1839      0      0.00   0.00 0.00 0     rfidSocketTask
12121   L 3  12910   126100      4199568   0      0.00   0.00 0.00 0     rfidTask
12121   L 1  12911   0           1826      0      0.00   0.00 0.00 0     Spam Mesh
12121   L 1  12912   3246650     805779121 0      0.00   0.03 0.01 0     tsmTask
12121   L 2  12913   970         11456     0      0.00   0.00 0.00 0     spectrumDataTas
12121   L 2  12914   0           1826      0      0.00   0.00 0.00 0     wipsTask
12121   L 0  12915   113670      3874134   0      0.00   0.03 0.04 0     rrcEngineTask
12121   L 1  12916   0           1828      0      0.00   0.00 0.00 0     apstatEngineTas
12121   L 1  12917   2747930     805768640 0      0.00   0.02 0.04 0     fmcHsTask
12121   L 1  12918   0           1827      0      0.00   0.00 0.00 0     IPv6_Msg_Task
12121   L 2  12919   40          1927      0      0.00   0.00 0.00 0     lbListen
12121   L 0  12922   1404735     814943    0      0.00   0.02 0.05 0     osapiReaper
12121   L 2  12923   4280        273197    0      0.00   0.00 0.00 0     reaperWatcher
12121   L 0  13018   10          1706      0      0.00   0.00 0.00 0     HALib Dispatch
12121   L 3  13064   0           1687      0      0.00   0.00 0.00 0     eicore_bdn
12121   L 3  13065   0           1687      0      0.00   0.00 0.00 0     eicore_bdn
12121   L 3  13066   0           1687      0      0.00   0.00 0.00 0     eicore_bdn
12121   L 2  13076   955890      1537069   0      0.00   0.07 0.04 0     eicore_ipc
12121   L 0  13136   0           1838      0      0.00   0.00 0.00 0     Transport Libra
12121   L 0  13137   0           1838      0      0.00   0.00 0.00 0     Transport Libra
12121   L 0  13138   0           1838      0      0.00   0.00 0.00 0     Transport Libra
12121   L 0  13139   0           1838      0      0.00   0.00 0.00 0     Transport Libra
12121   L 1  13313   0           1803      0      0.00   0.00 0.00 0     cids-cl Task
12121   L 2  13314   143580      4285646   0      0.00   0.00 0.02 0     apfRogueTask
12122   L            1340885     283797579 34     0.00   0.03 0.03 0     table_mgr
12122   L 0  12122   830         1455      0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12503   209720      8140367   0      0.00   0.00 0.00 0     table_mgr
12122   L 1  12504   24220       814772    0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12509   30          1563      0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12510   70          1756      0      0.00   0.00 0.00 0     table_mgr
12122   L 3  12512   149180      8134279   0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12514   20          1402      0      0.00   0.00 0.00 0     SPI default TP
12122   L 3  12515   0           1386      0      0.00   0.00 0.00 0     SPI default TP
12122   L 3  12516   0           1412      0      0.00   0.00 0.00 0     SPI default TP
12122   L 0  12517   20          1393      0      0.00   0.00 0.00 0     SPI default TP
12122   L 3  12518   0           1387      0      0.00   0.00 0.00 0     SPI default TP
12122   L 0  12522   0           1361      0      0.00   0.00 0.00 0     table_mgr
12122   L 3  12523   0           1362      0      0.00   0.00 0.00 0     table_mgr
12122   L 1  12524   0           1379      0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12525   160870      7949667   0      0.00   0.00 0.00 0     table_mgr
12122   L 3  12526   168970      7949619   0      0.00   0.00 0.00 0     table_mgr
12122   L 2  12527   0           1465      0      0.00   0.00 0.00 0     table_mgr
12122   L 0  12530   120         1637      0      0.00   0.00 0.00 0     tms-ots-event
12122   L 3  12531   10          1398      0      0.00   0.00 0.00 0     table_mgr
12122   L 3  12532   0           1391      0      0.00   0.00 0.00 0     table_mgr
12122   L 1  12534   30          1573      0      0.00   0.00 0.00 0     SPI default ST
12122   L 1  12571   0           1411      0      0.00   0.00 0.00 0     HALib Dispatch
12122   L 1  12572   0           1411      0      0.00   0.00 0.00 0     HALib Dispatch
12122   L 3  12573   30          1423      0      0.00   0.00 0.00 0     HALib Dispatch
12122   L 0  12576   20          1482      0      0.00   0.00 0.00 0     RF Slave Main T
12122   L 0  12584   10930       544136    0      0.00   0.00 0.00 0     table_mgr
12122   L 1  12585   615805      250225975 0      0.05   0.03 0.02 0     Timer
12122   L 2  12586   0           1439      0      0.00   0.00 0.00 34816 table_mgr
12122   L 2  12587   0           1439      0      0.00   0.00 0.00 34817 Timer
12122   L 3  12646   0           1441      0      0.00   0.00 0.00 0     eicore_bdn
12122   L 3  12647   0           1441      0      0.00   0.00 0.00 0     eicore_bdn
12122   L 3  12648   0           1441      0      0.00   0.00 0.00 0     eicore_bdn
12122   L 3  12689   0           1458      0      0.00   0.00 0.00 0     eicore_ipc
12122   L 0  14963   10          1411      0      0.00   0.00 0.00 0     HALib Dispatch
12123   L            120         1474      81     0.00   0.00 0.00 0     wnweb.sh
12124   L            712770      33017346  21     0.00   0.00 0.00 0     iifd
12124   L 2  12124   600         2210      0      0.00   0.00 0.00 0     iifd
12124   L 1  12335   211120      8140369   0      0.00   0.00 0.00 0     iifd
12124   L 2  12336   24630       814772    0      0.00   0.00 0.00 0     iifd
12124   L 3  12344   10          1413      0      0.00   0.00 0.00 0     iifd
12124   L 2  12345   180         2355      0      0.00   0.00 0.00 0     iifd
12124   L 1  12348   154210      8134268   0      0.00   0.00 0.00 0     iifd
12124   L 3  12353   0           1352      0      0.00   0.00 0.00 0     SPI default TP
12124   L 0  12354   0           1353      0      0.00   0.00 0.00 0     SPI default TP
12124   L 0  12355   0           1360      0      0.00   0.00 0.00 0     SPI default TP
12124   L 0  12356   0           1360      0      0.00   0.00 0.00 0     SPI default TP
12124   L 0  12357   0           1360      0      0.00   0.00 0.00 0     SPI default TP
12124   L 2  12358   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 2  12359   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 2  12360   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 0  12361   157570      7949656   0      0.00   0.00 0.00 0     iifd
12124   L 0  12362   164230      7949606   0      0.00   0.00 0.00 0     iifd
12124   L 2  12363   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 2  12364   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 2  12365   0           1358      0      0.00   0.00 0.00 0     iifd
12124   L 2  12366   210         2308      0      0.00   0.00 0.00 0     SPI default ST
12124   L 1  12451   0           1371      0      0.00   0.00 0.00 0     eicore_bdn
12124   L 1  12452   0           1371      0      0.00   0.00 0.00 0     eicore_bdn
12124   L 0  12453   0           1372      0      0.00   0.00 0.00 0     eicore_bdn
12124   L 0  12563   10          1384      0      0.00   0.00 0.00 0     eicore_ipc
12126   L            2784719     414795728 188    8.84   4.33 3.18 0     iosd
12126   L 3  12126   3087639     326852938 0      3.12   3.33 2.09 0     iosd
12126   L 3  12979   3965597     879114740 0      1.20   1.50 1.24 0     iosd.fastpath
12126   L 3  12980   29170       318727    0      0.00   0.00 0.00 0     iosd.aux
1       I            0           39        0      0.00   0.00 0.00 0       Chunk Manager
2       I            180370      1628101   0      0.00   0.00 0.00 0       Load Meter
3       I            0           1         0      0.00   0.00 0.00 0       HA-IDB-SYNC
4       I            0           114       0      0.00   0.00 0.00 0       Retransmission of
5       I            0           2         0      0.00   0.00 0.00 0       IPC ISSU Dispatch
6       I            2509923     2155409   0      3.33   0.44 0.22 0       Check heaps
7       I            62090       135679    0      0.00   0.00 0.00 0       Pool Manager
8       I            10          2         0      0.00   0.00 0.00 0       DiscardQ Backgrou
9       I            0           2         0      0.00   0.00 0.00 0       Timers
10      I            660         55633     0      0.00   0.00 0.00 0       WATCH_AFS
11      I            0           2         0      0.00   0.00 0.00 0       DDR Timers
12      I            0           2         0      0.00   0.00 0.00 0       Dialer event
13      I            0           2         0      0.00   0.00 0.00 0       Serial Background
14      I            511620      1628094   0      0.00   0.00 0.00 0       IOSD ipc task
15      I            10          18        0      0.00   0.00 0.00 0       IOSD chasfs task
16      I            1112830     9092092   0      0.00   0.00 0.00 0       IPC Bootstrap
17      I            86510       4070151   0      0.00   0.00 0.00 0       IOSD heartbeat pr
18      I            5350        542700    0      0.00   0.00 0.00 0       IOSD taskmonitor
19      I            10          23        0      0.00   0.00 0.00 0       IPC Apps Task
20      I            410         211       0      0.00   0.00 0.00 0       RF Slave Main Thr
21      I            0           12        0      0.00   0.00 0.00 0       ifIndex Receive P
22      I            1387680     5127898   0      0.00   0.00 0.00 0       ARP Input
23      I            211570      8443040   0      0.00   0.00 0.00 0       ARP Background
24      I            0           1         0      0.00   0.00 0.00 0       CEF MIB API
25      I            0           1         0      0.00   0.00 0.00 0       AAA_SERVER_DEADTI
26      I            0           1         0      0.00   0.00 0.00 0       Policy Manager
27      I            40          11        0      0.00   0.00 0.00 0       Entity MIB API
28      I            0           1         0      0.00   0.00 0.00 0       IFS Agent Manager
29      I            17300       1628104   0      0.00   0.00 0.00 0       IPC Event Notifie
30      I            138130      7902987   0      0.00   0.00 0.00 0       IPC Mcast Pending
31      I            1510        135676    0      0.00   0.00 0.00 0       IPC Dynamic Cache
32      I            0           30        0      0.00   0.00 0.00 0       IPC Session Servi
33      I            1417731     156125130 0      0.00   0.66 0.44 0       SPI PL client app
34      I            2514960     7902987   0      0.22   0.00 0.00 0       IPC Periodic Time
35      I            122790      7902986   0      0.00   0.00 0.00 0       IPC Deferred Port
36      I            0           1         0      0.00   0.00 0.00 0       IPC Process level
37      I            1401932     48024708  0      0.00   0.00 0.00 0       IPC Seat Manager
38      I            10320       542702    0      0.00   0.00 0.00 0       IPC Check Queue T
39      I            20          246       0      0.00   0.00 0.00 0       IPC Seat RX Contr
40      I            10          31        0      0.00   0.00 0.00 0       IPC Seat TX Contr
41      I            176730      814057    0      0.00   0.00 0.00 0       IPC Keep Alive Me
42      I            270810      1628094   0      0.00   0.00 0.00 0       IPC Loadometer
43      I            20          21        0      0.00   0.00 0.00 0       PrstVbl
44      I            0           1         0      0.00   0.00 0.00 0       SERIAL A'detect
45      I            90          496       0      0.00   0.00 0.00 0       SL async process
46      I            0           1         0      0.00   0.00 0.00 0       SPI PL process
47      I            0           1         0      0.00   0.00 0.00 0       SPI PL FC process
48      I            0           1         0      0.00   0.00 0.00 0       SPI IPC Cleanup p
49      I            10          16        0      0.00   0.00 0.00 0       SPI Delayed Init
50      I            0           1         0      0.00   0.00 0.00 0       WCDB ARP Process
51      I            3957176     196905233 0      0.77   0.44 0.44 0       ARP Snoop
52      I            148870      8139953   0      0.00   0.00 0.00 0       Dynamic ARP Inspe
53      I            0           1         0      0.00   0.00 0.00 0       IOSD signals IOS
54      I            20          31        0      0.00   0.00 0.00 0       SPI TMS MQIPC Ctr
55      I            717900      135986903 0      0.00   0.33 0.22 0       SPI TMS MQIPC Dat
56      I            372080      8139953   0      0.00   0.00 0.00 0       pdslib stats task
57      I            0           1         0      0.00   0.00 0.00 0       AggMgr Process
58      I            0           1         0      0.00   0.00 0.00 0       SPI-FC IFM proc
59      I            10          6         0      0.00   0.00 0.00 0       client_entity_sen
60      I            103480      8140476   0      0.00   0.00 0.00 0       GraphIt
61      I            0           1         0      0.00   0.00 0.00 0       Critical Bkgnd
62      I            558595      49871057  0      0.00   0.00 0.00 0       Net Background
63      I            0           4         0      0.00   0.00 0.00 0       IDB Work
64      I            20360       683641    0      0.00   0.00 0.00 0       Logger
65      I            167910      8139917   0      0.00   0.00 0.00 0       TTY Background
66      I            0           1         0      0.00   0.00 0.00 0       NG3K StackEventSe
67      I            2603860     66113963  0      0.00   0.00 0.00 0       Net Input
68      I            511800      814067    0      0.00   0.00 0.00 0       Compute load avgs
69      I            2619510     271351    0      0.00   0.00 0.00 0       Per-minute Jobs
70      I            888580      10582678  0      0.00   0.00 0.00 0       Per-Second Jobs
71      I            1669243     19299283  0      0.33   0.33 0.33 0       SPI PL client app
72      I            10          6         0      0.00   0.00 0.00 0       SPI PL client app
73      I            0           4         0      0.00   0.00 0.00 0       SPI PL client app
74      I            0           4         0      0.00   0.00 0.00 0       SPI PL client app
75      I            0           4         0      0.00   0.00 0.00 0       SPI PL client app
76      I            0           1         0      0.00   0.00 0.00 0       SPI-FC SEC_UTIL p
77      I            10          36        0      0.00   0.00 0.00 0       NGWC SECURITY pro
78      I            0           1         0      0.00   0.00 0.00 0       NGWC SPI Async Re
79      I            50          234       0      0.00   0.00 0.00 0       IF-MGR control pr
80      I            10          1240      0      0.00   0.00 0.00 0       IF-MGR event proc
81      I            0           1         0      0.00   0.00 0.00 0       SPI-FC STATS proc
82      I            0           1         0      0.00   0.00 0.00 0       NGWC SPI Async Re
83      I            81062       23505156  0      0.00   0.00 0.00 0       STATS SPI client
84      I            0           1         0      0.00   0.00 0.00 0       STATS stacking in
85      I            0           1         0      0.00   0.00 0.00 0       SPI-FC L2 Ctrl pr
86      I            0           4         0      0.00   0.00 0.00 0       L2 control proces
87      I            0           1         0      0.00   0.00 0.00 0       SPI-FC L2M proc
88      I            0           4         0      0.00   0.00 0.00 0       L2M Client SPI Pr
89      I            0           1         0      0.00   0.00 0.00 0       NGWC L2M STACKING
90      I            0           1         0      0.00   0.00 0.00 0       SPI-FC MATM proc
91      I            10          4         0      0.00   0.00 0.00 0       MATM SPI client p
92      I            0           1         0      0.00   0.00 0.00 0       SPI-FC PM proc
93      I            176070      1963173   0      0.00   0.00 0.00 0       NGPM spi message
94      I            0           4         0      0.00   0.00 0.00 0       NG Backup Interfa
95      I            0           1         0      0.00   0.00 0.00 0       SPI-FC BACKUPIF p
96      I            0           1         0      0.00   0.00 0.00 0       SPI-FC PLAT-SPI p
97      I            0           4         0      0.00   0.00 0.00 0       PLAT-SPI message
98      I            0           17        0      0.00   0.00 0.00 0       SPI-FC PLATFORM p
99      I            2742420     35330992  0      0.00   0.11 0.22 0       PLATFORM_MGR SPI
100     I            0           1         0      0.00   0.00 0.00 0       PLATFORM_MGR stac
101     I            0           1         0      0.00   0.00 0.00 0       SPI-FC NG3K WIR p
102     I            0           1         0      0.00   0.00 0.00 0       NG3K WIRELESS STA
103     I            0           1         0      0.00   0.00 0.00 0       SPI-FC SC proc
104     I            0           4         0      0.00   0.00 0.00 0       NGWC SC process
105     I            0           1         0      0.00   0.00 0.00 0       sw_idbman_nova II
106     I            0           32        0      0.00   0.00 0.00 0       NG3K OIR CC Proce
107     I            520         160       0      0.00   0.00 0.00 0       NG3K SM Process
108     I            0           1         0      0.00   0.00 0.00 0       SPI-FC SEC_CTRL p
109     I            0           3         0      0.00   0.00 0.00 0       NGWC Security Ctr
110     I            0           2         0      0.00   0.00 0.00 0       Parser SPI sever
111     I            0           4         0      0.00   0.00 0.00 0       PTH spi message p
112     I            0           1         0      0.00   0.00 0.00 0       SPI-FC L3M proc
113     I            0           4         0      0.00   0.00 0.00 0       L3M Client SPI Pr
114     I            18480       1162937   0      0.00   0.00 0.00 0       REDUNDANCY FSM
115     I            0           34        0      0.00   0.00 0.00 0       PrstVbl IPC Msg P
116     I            0           1         0      0.00   0.00 0.00 0       SPI-FC EM-HA proc
117     I            0           4         0      0.00   0.00 0.00 0       EM-HA spi message
118     I            0           1         0      0.00   0.00 0.00 0       Smart Install HA
119     I            0           2         0      0.00   0.00 0.00 0       IP Admission HA P
120     I            70          68        0      0.00   0.00 0.00 0       cpf_msg_holdq_pro
121     I            250         1706      0      0.00   0.00 0.00 0       cpf_msg_rcvq_proc
122     I            1281722     43259213  0      0.00   0.11 0.00 0       cpf_process_tpQ
123     I            0           4         0      0.00   0.00 0.00 0       IFM spi message p
124     I            0           1         0      0.00   0.00 0.00 0       SPI-FC DTLS proc
125     I            0           32        0      0.00   0.00 0.00 0       NGWC ILP CF Proce
126     I            0           2         0      0.00   0.00 0.00 0       NGWC DTLS STACKIN
127     I            10          32        0      0.00   0.00 0.00 0       MATM CF Flow Cont
128     I            2384090     3631345   0      0.00   0.00 0.00 0       NGWC Learning Pro
129     I            10          6         0      0.00   0.00 0.00 0       NGWC Configuratio
130     I            40          2546      0      0.00   0.00 0.00 0       BACK CHECK
131     I            80          5         0      0.00   0.00 0.00 0       IIF Bulk Sync pro
132     I            0           6         0      0.00   0.00 0.00 0       IP Host Track HA
133     I            0           1         0      0.00   0.00 0.00 0       Ng3k envvar sync
134     I            0           1         0      0.00   0.00 0.00 0       NG3K STACK MAC pr
135     I            0           4         0      0.00   0.00 0.00 0       QoS spi message p
136     I            0           1         0      0.00   0.00 0.00 0       CONSOLE helper pr
137     I            30          2264      0      0.00   0.00 0.00 0       SSH Event handler
138     I            10          46        0      0.00   0.00 0.00 0       dbflags resync wi
139     I            0           3         0      0.00   0.00 0.00 0       SISF HA Process
140     I            188290      8140076   0      0.00   0.00 0.00 0       REDUNDANCY peer m
141     I            1125860     81404429  0      0.00   0.00 0.00 0       100ms check
142     I            0           1         0      0.00   0.00 0.00 0       RTTYS Process
143     I            0           8         0      0.00   0.00 0.00 0       RFS server proces
144     I            23540       271345    0      0.00   0.00 0.00 0       Standby Time
145     I            0           2         0      0.00   0.00 0.00 0       DHCPD HA
146     I            980         1679      0      0.00   0.00 0.00 0       SpanTree Helper
147     I            477740      949862    0      0.00   0.00 0.00 0       ARP HA
148     I            3850        68256     0      0.00   0.00 0.00 0       EM_SHIM_TASK
149     I            90          23        0      0.00   0.00 0.00 0       EM_SHIM_NOTIFY_TA
150     I            0           2         0      0.00   0.00 0.00 0       Network-rf Notify
151     I            0           3         0      0.00   0.00 0.00 0       OBFL Cfg Dispatch
152     I            20          2         0      0.00   0.00 0.00 0       IP SNMPV6
153     I            112640      5009664   0      0.00   0.00 0.00 0       Transport Port Ag
154     I            279830      2438792   0      0.00   0.00 0.00 0       HC Counter Timers
155     I            1901950     1449339   0      0.00   0.00 0.00 0       NGWC L2M
156     I            0           1         0      0.00   0.00 0.00 0       NGWC MATM Stack P
157     I            594960      21364154  0      0.00   0.00 0.00 0       ngpm main process
158     I            0           7         0      0.00   0.00 0.00 0       NG Backup Interfa
159     I            1310        135676    0      0.00   0.00 0.00 0       MMN bkgrd process
160     I            2765830     2035135   0      0.00   0.00 0.00 0       FEP background pr
161     I            828700      2035152   0      0.00   0.00 0.00 0       Thermal backgroun
162     I            20          43        0      0.00   0.00 0.00 0       NG3K Intif WCM SP
163     I            0           1         0      0.00   0.00 0.00 0       ACL Logging Proce
164     I            2270        135676    0      0.00   0.00 0.00 0       Call Home Timer P
165     I            0           1         0      0.00   0.00 0.00 0       NGWC DOT1X Proces
166     I            0           1         0      0.00   0.00 0.00 0       iosv_debug_trace
167     I            1510        135675    0      0.00   0.00 0.00 0       Crashinfo File Tr
168     I            650         45226     0      0.00   0.00 0.00 0       PL3U bkgrd proces
169     I            422180      10910598  0      0.00   0.00 0.00 0       EEM ED ND
170     I            0           2         0      0.00   0.00 0.00 0       EEM ED Identity
171     I            0           3         0      0.00   0.00 0.00 0       EEM ED MAT
172     I            1119302     10168082  0      0.00   0.00 0.00 0       MATM RP Shim Proc
173     I            40          48        0      0.00   0.00 0.00 0       CEF RP Background
174     I            51500       1628046   0      0.00   0.00 0.00 0       MGMTE stats Proce
175     I            0           1         0      0.00   0.00 0.00 0       SPI-FC WCM_CONF p
176     I            160760      1759236   0      0.00   0.00 0.00 0       LACP Protocol
177     I            1450        135677    0      0.00   0.00 0.00 0       Port-Security
178     I            30          1427      0      0.00   0.00 0.00 0       Auth Manager
179     I            314240      16151637  0      0.00   0.00 0.00 0       SVM UT Process
180     I            0           1         0      0.00   0.00 0.00 0       CMD HANDLER
181     I            0           2         0      0.00   0.00 0.00 0       Dot1x Mgr Process
182     I            0           2         0      0.00   0.00 0.00 0       CDP Forward Proce
183     I            120         1426      0      0.00   0.00 0.00 0       802.1x switch
184     I            0           1         0      0.00   0.00 0.00 0       EAP Framework
185     I            0           1         0      0.00   0.00 0.00 0       EAP Test
186     I            4227970     17173180  0      0.00   0.00 0.00 0       DTP Protocol
187     I            0           2         0      0.00   0.00 0.00 0       PI MATM Aging Pro
188     I            2293422     12763247  0      0.00   0.00 0.00 0       Inline Power
189     I            0           49        0      0.00   0.00 0.00 0       NGWC led process
190     I            0           1         0      0.00   0.00 0.00 0       Switch Backup Int
191     I            2098783     65726315  0      0.33   0.33 0.33 0       IP Host Track Pro
192     I            770         686       0      0.00   0.00 0.00 0       VMATM Callback
193     I            0           11        0      0.00   0.00 0.00 0       DiagCard1/-1
194     I            0           1         0      0.00   0.00 0.00 0       SPI-FC WCM_WCDB p
195     I            10          4         0      0.00   0.00 0.00 0       WCDB Process
196     I            3585035     810470326 0      0.11   0.00 0.11 0       Tunnel IOSd shim
197     I            11800       814049    0      0.00   0.00 0.00 0       Ethchnl
198     I            10          22        0      0.00   0.00 0.00 0       PKI/SSL SPI proce
199     I            1010        20126     0      0.00   0.00 0.00 0       AAA Server
200     I            0           1         0      0.00   0.00 0.00 0       AAA ACCT Proc
201     I            0           1         0      0.00   0.00 0.00 0       ACCT Periodic Pro
202     I            0           1         0      0.00   0.00 0.00 0       AAA System Acct P
203     I            0           1         0      0.00   0.00 0.00 0       Auth-proxy AAA Bk
204     I            0           1         0      0.00   0.00 0.00 0       Auth-proxy HTTP d
205     I            0           1         0      0.00   0.00 0.00 0       IP Admin SM Proce
206     I            0           1         0      0.00   0.00 0.00 0       EPM MAIN PROCESS
207     I            0           1         0      0.00   0.00 0.00 0       Timer Handler Pro
208     I            0           1         0      0.00   0.00 0.00 0       EPM Downlad Manag
209     I            0           1         0      0.00   0.00 0.00 0       EPM ACL PLUG-IN P
210     I            0           1         0      0.00   0.00 0.00 0       DCT Bkgd Process
211     I            2787605     22474539  0      0.00   0.11 0.11 0       CDP Protocol
212     I            10          10        0      0.00   0.00 0.00 0       RSMP Server
213     I            10          20        0      0.00   0.00 0.00 0       DiagCard2/-1
214     I            0           2         0      0.00   0.00 0.00 0       AAA Dictionary Re
215     I            1420        67838     0      0.00   0.00 0.00 0       DHCP Snooping
216     I            0           1         0      0.00   0.00 0.00 0       DHCP Snooping db
217     I            0           11        0      0.00   0.00 0.00 0       IP ARP Adjacency
218     I            466722      203311845 0      0.11   0.00 0.00 0       IP ARP Retry Ager
219     I            4049175     29974051  0      0.77   0.33 0.11 0       IP Input
220     I            0           1         0      0.00   0.00 0.00 0       ICMP event handle
221     I            364610      15653433  0      0.00   0.00 0.00 0       IP ARP Track
222     I            0           1         0      0.00   0.00 0.00 0       IPv6 ping process
223     I            0           3         0      0.00   0.00 0.00 0       PIM register asyn
224     I            0           2         0      0.00   0.00 0.00 0       CEF switching bac
225     I            0           1         0      0.00   0.00 0.00 0       ADJ NSF process
226     I            10          23        0      0.00   0.00 0.00 0       SpanTree Flush
227     I            0           1         0      0.00   0.00 0.00 0       SMI Director DB P
228     I            0           1         0      0.00   0.00 0.00 0       SMI CDP Update Ha
229     I            0           1         0      0.00   0.00 0.00 0       SMI Backup Proces
230     I            0           2         0      0.00   0.00 0.00 0       SMI IBC server pr
231     I            0           1         0      0.00   0.00 0.00 0       SMI IBC client pr
232     I            0           2         0      0.00   0.00 0.00 0       SMI IBC Download
233     I            697144      197772069 0      1.11   1.00 1.00 0       Spanning Tree
234     I            1656122     81404299  0      0.00   0.00 0.00 0       UDLD
235     I            1240        135676    0      0.00   0.00 0.00 0       FRR Background Pr
236     I            10580       266248    0      0.00   0.00 0.00 0       CEF background pr
237     I            0           1         0      0.00   0.00 0.00 0       fib_fib_bfd_sb ev
238     I            0           1         0      0.00   0.00 0.00 0       IP IRDP
239     I            0           1         0      0.00   0.00 0.00 0       Critical Auth
240     I            0           4         0      0.00   0.00 0.00 0       AAA HA
241     I            0           1         0      0.00   0.00 0.00 0       AAA HA cleanup
242     I            0           2         0      0.00   0.00 0.00 0       Dot1x Supplicant
243     I            0           2         0      0.00   0.00 0.00 0       Dot1x Supplicant
244     I            0           2         0      0.00   0.00 0.00 0       Dot1x Supplicant
245     I            0           1         0      0.00   0.00 0.00 0       MAB Framework
246     I            0           1         0      0.00   0.00 0.00 0       XDR background pr
247     I            16870       137059    0      0.00   0.00 0.00 0       XDR mcast
248     I            0           3         0      0.00   0.00 0.00 0       XDR RP Ping Backg
249     I            20          109       0      0.00   0.00 0.00 0       XDR mcast rcv
250     I            2650        135676    0      0.00   0.00 0.00 0       XDR RP background
251     I            0           4         0      0.00   0.00 0.00 0       IPC LC Message Ha
252     I            0           1         0      0.00   0.00 0.00 0       XDR RP Test Backg
253     I            0           1         0      0.00   0.00 0.00 0       CAPWAP Events
254     I            20          2         0      0.00   0.00 0.00 0       CAPWAP DATA
255     I            0           1         0      0.00   0.00 0.00 0       SPI-FC CAPWAP pro
256     I            10          21        0      0.00   0.00 0.00 0       DiagCard3/-1
257     I            0           76        0      0.00   0.00 0.00 0       WCM CONFIG SHARE
258     I            0           2         0      0.00   0.00 0.00 0       worker thread
259     I            0           1         0      0.00   0.00 0.00 0       SPI-FC WCM_DTLS p
260     I            10          26        0      0.00   0.00 0.00 0       DTLS PROCESS
261     I            210         3075      0      0.00   0.00 0.00 0       IGMPSN L2MCM
262     I            0           1         0      0.00   0.00 0.00 0       IGMPSN MRD
263     I            48670       332373    0      0.00   0.00 0.00 0       IGMPSN
264     I            0           1         0      0.00   0.00 0.00 0       IGMPQR
265     I            0           1         0      0.00   0.00 0.00 0       Socket Timers
266     I            0           2         0      0.00   0.00 0.00 0       L2TRACE SERVER
267     I            233240      1060806   0      0.00   0.00 0.00 0       NGWC stack power
268     I            0           3         0      0.00   0.00 0.00 0       Flow Exporter Tim
269     I            30          2674      0      0.00   0.00 0.00 0       NG3K punt Tx proc
270     I            160         3072      0      0.00   0.00 0.00 0       MLDSN L2MCM
271     I            0           1         0      0.00   0.00 0.00 0       MRD
272     I            0           1         0      0.00   0.00 0.00 0       MLD_SNOOP
273     I            0           2         0      0.00   0.00 0.00 0       ipc thread
274     I            30          15        0      0.00   0.00 0.00 0       L2MCAST Wireless
275     I            0           1         0      0.00   0.00 0.00 0       NGWC DHCP Snoopin
276     I            3263415     196917518 0      0.00   0.11 0.11 0       DAI Packet Proces
277     I            40          39        0      0.00   0.00 0.00 0       os_info_p provide
278     I            23010       64072     0      0.00   0.00 0.00 0       SNMP Timers
279     I            3237010     82759842  0      0.00   0.11 0.00 0       snmp_spi Process
280     I            2600        637       0      2.33   3.55 0.88 2       SSH Process
281     I            40          23        0      0.00   0.00 0.00 0       RSMP Server
282     I            48990       522217    0      0.00   0.00 0.00 0       PDU DISPATCHER
283     I            295628      83713973  0      0.00   1.11 0.44 0       SNMP ENGINE
284     I            0           1         0      0.00   0.00 0.00 0       Nova RAW
285     I            0           1         0      0.00   0.00 0.00 0       Nova TCP
286     I            158010      1032206   0      0.00   0.00 0.00 0       IP SNMP
287     I            0           2         0      0.00   0.00 0.00 0       Routing Topology
288     I            0           6         0      0.00   0.00 0.00 0       IP RIB Update
289     I            3000        135677    0      0.00   0.00 0.00 0       IP Background
290     I            80          2312      0      0.00   0.00 0.00 0       IP Connected Rout
291     I            241170      4595847   0      0.00   0.00 0.00 0       CEF: IPv4 process
292     I            0           3         0      0.00   0.00 0.00 0       ADJ background
293     I            0           4         0      0.00   0.00 0.00 0       Collection proces
294     I            0           3         0      0.00   0.00 0.00 0       IPv6 RIB Event Ha
295     I            0           1         0      0.00   0.00 0.00 0       SNMP ConfCopyProc
296     I            122470      8139928   0      0.00   0.00 0.00 0       NMSP SPI
297     I            600         429       0      0.00   0.00 0.00 0       SNMP Traps
298     I            0           4         0      0.00   0.00 0.00 0       IGMPSN-HA
299     I            0           4         0      0.00   0.00 0.00 0       MLDSN-HA
300     I            10          5         0      0.00   0.00 0.00 0       XDR FOF process
301     I            0           3         0      0.00   0.00 0.00 0       DHCP Snooping HA
302     I            2018680     12970606  0      0.00   0.00 0.00 0       NGWC Ethernet Man
303     I            850         25009     0      0.00   0.00 0.00 0       TCP Timer
304     I            828830      5002685   0      0.00   0.00 0.00 0       TCP Protocols
305     I            116560      92214     0      0.00   0.00 0.00 0       HTTP CORE
306     I            0           3         0      0.00   0.00 0.00 0       MFIB Master backg
307     I            332690      8494580   0      0.00   0.00 0.00 0       NTP
308     I            0           2         0      0.00   0.00 0.00 0       Multicast Offload
309     I            0           1         0      0.00   0.00 0.00 0       Nova UDP
310     I            0           3         0      0.00   0.00 0.00 0       ADJ resolve proce
311     I            0           63        0      0.00   0.00 0.00 0       static
312     I            3868998     814049    0      0.33   0.22 0.22 0       QoS stats process
313     I            0           10        0      0.00   0.00 0.00 0       DHCP IOSd Agent
314     I            0           2         0      0.00   0.00 0.00 0       AAA Cached Server
315     I            0           1         0      0.00   0.00 0.00 0       EM Background Pro
316     I            0           1         0      0.00   0.00 0.00 0       Key chain livekey
317     I            25090       442793    0      0.00   0.00 0.00 0       LOCAL AAA
318     I            0           2         0      0.00   0.00 0.00 0       ENABLE AAA
319     I            0           2         0      0.00   0.00 0.00 0       LINE AAA
320     I            0           1         0      0.00   0.00 0.00 0       IPv6 Access Contr
321     I            0           2         0      0.00   0.00 0.00 0       TPLUS
322     I            0           3         0      0.00   0.00 0.00 0       LDAP process
323     I            10          42        0      0.00   0.00 0.00 0       AAA Proxy
324     I            0           2         0      0.00   0.00 0.00 0       crypto engine pro
325     I            0           4         0      0.00   0.00 0.00 0       Crypto CA
326     I            0           1         0      0.00   0.00 0.00 0       Crypto PKI-CRL
327     I            0           1         0      0.00   0.00 0.00 0       encrypt proc
328     I            1130        11026     0      0.00   0.00 0.00 0       crypto sw pk proc
329     I            0           55        0      0.00   0.00 0.00 0       VTP Trap Process
330     I            1179590     8139696   0      0.00   0.00 0.00 0       Inline power incr
331     I            0           1         0      0.00   0.00 0.00 0       Licensing MIB pro
333     I            3340320     124740110 0      0.00   0.00 0.00 0       PM Callback
334     I            0           1         0      0.00   0.00 0.00 0       NCD Process
335     I            11350       651239    0      0.00   0.00 0.00 0       dhcp snooping sw
336     I            0           2         0      0.00   0.00 0.00 0       DHCP Security Hel
337     I            501760      16220430  0      0.00   0.00 0.00 0       SPI IOSd Show
338     I            0           1         0      0.00   0.00 0.00 0       FFCP msg process
339     I            0           1         0      0.00   0.00 0.00 0       DiagCard4/-1
340     I            930         13406     0      0.00   0.00 0.00 0       AAA SEND STOP EVE
341     I            0           1         0      0.00   0.00 0.00 0       Test AAA Client
342     I            19900       359932    0      0.00   0.00 0.00 0       EEM ED Syslog
343     I            0           2         0      0.00   0.00 0.00 0       EEM ED Routing
344     I            0           1         0      0.00   0.00 0.00 0       Syslog Traps
345     I            0           1         0      0.00   0.00 0.00 0       QoS TAM Request H
346     I            0           1         0      0.00   0.00 0.00 0       IOSD-ISSU commitv
347     I            1900        135676    0      0.00   0.00 0.00 0       FNF background pr
348     I            108680      342603    0      0.00   0.00 0.00 0       Syslog
349     I            40          430       0      0.00   0.00 0.00 0       EEM Server
350     I            0           2         0      0.00   0.00 0.00 0       EEM Policy Direct
351     I            0           1         0      0.00   0.00 0.00 0       WSMA_NOTIFY
352     I            0           2         0      0.00   0.00 0.00 0       EEM ED CLI
353     I            0           3         0      0.00   0.00 0.00 0       EEM ED Counter
354     I            0           3         0      0.00   0.00 0.00 0       EEM ED Interface
355     I            0           3         0      0.00   0.00 0.00 0       EEM ED IOSWD
356     I            0           3         0      0.00   0.00 0.00 0       EEM ED None
357     I            0           3         0      0.00   0.00 0.00 0       EEM ED OIR
358     I            0           14        0      0.00   0.00 0.00 0       EEM ED RF
359     I            0           2         0      0.00   0.00 0.00 0       EEM ED SNMP
360     I            6420        221091    0      0.00   0.00 0.00 0       EEM ED Timer
361     I            0           3         0      0.00   0.00 0.00 0       EEM ED SNMP Objec
362     I            0           2         0      0.00   0.00 0.00 0       EEM ED SNMP Noti
363     I            0           3         0      0.00   0.00 0.00 0       EEM ED Ipsla
364     I            0           2         0      0.00   0.00 0.00 0       EEM ED Nf
365     I            0           2         0      0.00   0.00 0.00 0       Call Home process
366     I            0           3         0      0.00   0.00 0.00 0       EEM ED Test
367     I            0           3         0      0.00   0.00 0.00 0       EEM ED Config
368     I            0           3         0      0.00   0.00 0.00 0       EEM ED Env
369     I            0           3         0      0.00   0.00 0.00 0       EEM ED RPC
370     I            3260        26804     0      0.00   0.00 0.00 0       VLAN Manager
371     I            0           1         0      0.00   0.00 0.00 0       SPI-FC L2MCAST_ p
372     I            0           2         0      0.00   0.00 0.00 0       MRIB Process
373     I            0           1         0      0.00   0.00 0.00 0       SPI-FC WCM_PLAT p
374     I            0           1         0      0.00   0.00 0.00 0       SEP NODE PROC
375     I            0           1         0      0.00   0.00 0.00 0       SEP NODE PROC
376     I            10          1         0      0.00   0.00 0.00 0       XTF Agent
12128   L            2450550     43800847  55     0.05   0.04 0.03 0     ha_mgr
12128   L 0  12128   2030        82848     0      0.00   0.00 0.00 0     ha_mgr
12128   L 0  12375   251470      8140304   0      0.00   0.00 0.03 0     ha_mgr
12128   L 0  12385   30          1486      0      0.00   0.00 0.00 0     ha_mgr
12128   L 2  12388   659080      2718741   0      0.00   0.00 0.00 0     ha_mgr
12128   L 2  12391   155810      8134259   0      0.00   0.00 0.00 0     ha_mgr
12128   L 3  12394   46670       704075    0      0.00   0.00 0.00 0     SPI default TP
12128   L 3  12395   68020       1086737   0      0.00   0.00 0.00 0     SPI default TP
12128   L 1  12396   54290       827497    0      0.00   0.00 0.00 0     SPI default TP
12128   L 0  12397   69070       1064447   0      0.00   0.00 0.01 0     SPI default TP
12128   L 2  12398   69310       1076521   0      0.00   0.00 0.00 0     SPI default TP
12128   L 1  12402   24310       814787    0      0.00   0.00 0.00 0     ha_mgr
12128   L 0  12407   0           1357      0      0.00   0.00 0.00 0     ha_mgr
12128   L 3  12408   0           1357      0      0.00   0.00 0.00 0     ha_mgr
12128   L 1  12409   0           1361      0      0.00   0.00 0.00 0     ha_mgr
12128   L 0  12411   161020      7949661   0      0.00   0.03 0.04 0     ha_mgr
12128   L 1  12412   431380      7949715   0      0.00   0.00 0.00 0     ha_mgr
12128   L 2  12413   88140       906790    0      0.00   0.04 0.05 0     ha_mgr
12128   L 0  12414   0           1393      0      0.00   0.00 0.00 0     ha_mgr
12128   L 0  12415   0           1395      0      0.00   0.00 0.00 0     ha_mgr
12128   L 3  12419   41050       909969    0      0.00   0.00 0.00 0     RF Master Main
12128   L 2  12420   328870      1419063   0      0.00   0.00 0.00 0     RF Master Statu
12128   L 0  12427   0           1422      0      0.00   0.00 0.00 0     SPI default ST
12128   L 3  12554   0           1425      0      0.00   0.00 0.00 0     eicore_bdn
12128   L 3  12555   0           1425      0      0.00   0.00 0.00 0     eicore_bdn
12128   L 3  12556   0           1425      0      0.00   0.00 0.00 0     eicore_bdn
12128   L 3  12596   0           1444      0      0.00   0.00 0.00 0     eicore_ipc
13365   L            2176800     40372385  53     0.00   0.03 0.04 0     wnweb_paster.py
13365   L 2  13365   1378820     8139727   0      0.05   0.03 0.04 0     wnweb_paster.py
13365   L 2  13489   10          2169      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 2  13490   0           2148      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 0  13491   196090      8134915   0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 3  13492   0           2145      0      0.00   0.00 0.00 0     SPI default TP
13365   L 3  13493   0           2148      0      0.00   0.00 0.00 0     SPI default TP
13365   L 3  13494   0           2148      0      0.00   0.00 0.00 0     SPI default TP
13365   L 2  13495   20          2149      0      0.00   0.00 0.00 0     SPI default TP
13365   L 3  13496   0           2138      0      0.00   0.00 0.00 34817 SPI default TP
13365   L 0  13497   0           2136      0      0.00   0.00 0.00 34817 wnweb_paster.py
13365   L 0  13498   0           2136      0      0.00   0.00 0.00 34817 wnweb_paster.py
13365   L 0  13499   0           2136      0      0.00   0.00 0.00 34816 wnweb_paster.py
13365   L 0  13500   159270      7950358   0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 3  13501   165270      7950305   0      0.00   0.00 0.00 34817 wnweb_paster.py
13365   L 0  13502   0           2136      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 0  13503   0           2136      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 0  13504   0           2136      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 2  13505   0           2148      0      0.00   0.00 0.00 0     Transport Libra
13365   L 2  13506   0           2148      0      0.00   0.00 0.00 0     Transport Libra
13365   L 2  13507   0           2148      0      0.00   0.00 0.00 0     Transport Libra
13365   L 0  13508   277310      8140946   0      0.00   0.00 0.00 0     pdslib thread
13365   L 1  13509   0           2184      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 1  13510   0           2169      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 1  13511   10          2170      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 2  13512   0           2195      0      0.00   0.00 0.00 0     wnweb_paster.py
13365   L 1  13513   0           2175      0      0.00   0.00 0.00 34816 wnweb_paster.py
13365   L 1  13514   0           2184      0      0.00   0.00 0.00 34816 wnweb_paster.py
13365   L 2  13515   0           2189      0      0.00   0.00 0.00 34817 wnweb_paster.py
13365   L 2  13516   0           2197      0      0.00   0.00 0.00 34816 wnweb_paster.py
13365   L 2  13517   0           2205      0      0.00   0.00 0.00 34816 wnweb_paster.py
13365   L 3  13519   0           2211      0      0.00   0.00 0.00 34816 wnweb_paster.py
13366   L            380         1474      257    0.00   0.00 0.00 34816 xlogger
16243   L            10          803335    0      0.00   0.00 0.00 34817 sleep
16329   L            30          9965406   0      0.00   0.00 0.00 34817 in.telnetd
------------------ show processes ------------------
CPU utilization for five seconds: 38%; one minute: 28%;  five minutes: 19%
PID     TID     Runtime(ms) Invoked   uSecs  Stacks        Process
1               30740       4983064   6      88/8192       init
2               0           164       0      0/8192        kthreadd
3               102010      12134499  8      0/8192        migration/0
4               0           3         0      0/8192        sirq-high/0
5               2315583     839044093 28     0/8192        sirq-timer/0
6               0           33        0      0/8192        sirq-net-tx/0
7               267052      66208705  68     0/8192        sirq-net-rx/0
8               1450        330469    4      0/8192        sirq-block/0
9               0           8         0      0/8192        sirq-block-iopo
10              0           149       0      0/8192        sirq-tasklet/0
11              88452       374978602 11     0/8192        sirq-sched/0
12              6000        183556    32     0/8192        sirq-hrtimer/0
13              396263      732215355 94     0/8192        sirq-rcu/0
14              86470       20423501  4      0/8192        desched/0
15              120090      15628085  7      0/8192        migration/1
16              0           15        0      0/8192        sirq-high/1
17              2565000     769717733 3      0/8192        sirq-timer/1
18              0           80        0      0/8192        sirq-net-tx/1
19              2946190     67324831  43     0/8192        sirq-net-rx/1
20              1020        119469    8      0/8192        sirq-block/1
21              0           20        0      0/8192        sirq-block-iopo
22              0           21        0      0/8192        sirq-tasklet/1
23              864320      396901407 2      0/8192        sirq-sched/1
24              0           144835    0      0/8192        sirq-hrtimer/1
25              808212      682283660 7      0/8192        sirq-rcu/1
26              113040      24602963  4      0/8192        desched/1
27              125940      13941075  9      0/8192        migration/2
28              0           27        0      0/8192        sirq-high/2
29              289550      648451910 0      0/8192        sirq-timer/2
30              0           88        0      0/8192        sirq-net-tx/2
31              2393340     65015250  36     0/8192        sirq-net-rx/2
32              310         34096     9      0/8192        sirq-block/2
33              0           32        0      0/8192        sirq-block-iopo
34              0           33        0      0/8192        sirq-tasklet/2
35              129090      372959708 0      0/8192        sirq-sched/2
36              0           119732    0      0/8192        sirq-hrtimer/2
37              461760      611327503 0      0/8192        sirq-rcu/2
38              117170      24017181  4      0/8192        desched/2
39              150030      15659527  9      0/8192        migration/3
40              0           39        0      0/8192        sirq-high/3
41              40          595122283 0      0/8192        sirq-timer/3
42              10          104       96     0/8192        sirq-net-tx/3
43              2174500     62616888  34     0/8192        sirq-net-rx/3
44              120         16217     7      0/8192        sirq-block/3
45              0           44        0      0/8192        sirq-block-iopo
46              0           45        0      0/8192        sirq-tasklet/3
47              30          368718058 0      0/8192        sirq-sched/3
48              0           87668     0      0/8192        sirq-hrtimer/3
49              50          582486719 0      0/8192        sirq-rcu/3
50              147090      23875772  6      0/8192        desched/3
51              941060      21234163  44     0/8192        events/0
52              46250       12270815  3      0/8192        events/1
53              13140       11522035  1      0/8192        events/2
54              4230        11739936  0      0/8192        events/3
55              60          3197      18     0/8192        khelper
58              0           55        0      0/8192        netns
60              0           66        0      0/8192        async/mgr
158             72350       1356852   53     0/8192        sync_supers
160             56510       1628602   34     0/8192        bdi-default
162             13250       267739    49     0/8192        kblockd/0
163             710         94570     7      0/8192        kblockd/1
164             70          25250     2      0/8192        kblockd/2
165             10          11047     0      0/8192        kblockd/3
171             0           67        0      0/8192        ata/0
172             0           66        0      0/8192        ata/1
173             0           65        0      0/8192        ata/2
174             0           66        0      0/8192        ata/3
175             0           67        0      0/8192        ata_aux
183             250         223       1121   0/8192        khubd
210             120         3541      33     0/8192        rpciod/0
211             180         3774      47     0/8192        rpciod/1
212             50          3947      12     0/8192        rpciod/2
213             90          4497      20     0/8192        rpciod/3
229             0           77        0      0/8192        kswapd0
230             0           78        0      0/8192        aio/0
231             0           79        0      0/8192        aio/1
232             0           80        0      0/8192        aio/2
233             0           81        0      0/8192        aio/3
234             990         14166     69     0/8192        nfsiod
236             0           83        0      0/8192        crypto/0
237             0           84        0      0/8192        crypto/1
238             0           85        0      0/8192        crypto/2
239             0           86        0      0/8192        crypto/3
513             140         9193908   0      88/8192       in.telnetd
524             130         9193905   0      88/8192       brelay
789             3760        528641    7      0/8192        pata_octeon_cf
790             0           97        0      0/8192        scsi_eh_0
796             50820       6169      8237   0/8192        mtdblockd
823             564900      13863001  40     0/8192        octeon-ethernet
857             0           96        0      0/8192        kstriped
859             0           97        0      0/8192        ksnapd
937             310         1426      217    88/8192       udevd
1268            69800       1631911   42     0/8192        flush-8:0
1534            90          4422      20     0/8192        loop1
1559            110         4335      25     0/8192        loop2
1584            40          2164      18     0/8192        loop3
1609            140         2893      48     0/8192        loop4
1634            60          2501      23     0/8192        loop5
1679            20          561       35     0/8192        loop6
2359            10          1104      9      88/8192       udevd
2360            0           1001      0      88/8192       udevd
3258            100         1109      90     88/8192       dbus-daemon
3636            150         1441      104    88/8192       klogd
3648            10          1122      8      88/8192       portmap
3717            0           956       0      88/8192       sshd
3729            0           1038      0      88/8192       xinetd
3733            1175630     9965433   117    88/8192       xinetd
3767            0           112       0      88/8192       lockd
3768            50          2376      21     88/8192       nfsd
3769            110         2376      46     88/8192       nfsd
3770            100         2378      42     88/8192       nfsd
3771            30          2379      12     88/8192       nfsd
3772            50          2570      19     0/8192        nfsd
3773            160         2424      66     0/8192        nfsd
3774            60          2540      23     0/8192        nfsd
3775            90          2381      37     0/8192        nfsd
3781            60          1156      51     88/8192       rpc.mountd
5331            3767810     40318860  93     88/8192       system_mgr
5331    5331    3313380     16275989  0      88/8192       system_mgr
5331    5632    10          1166      0      88/8192       system_mgr
5331    5633    20          1132      0      88/8192       system_mgr
5331    5634    146250      8134020   0      88/8192       system_mgr
5331    5635    10          1136      0      88/8192       system_mgr
5331    7921    0           1122      0      88/8192       system_mgr
5331    7922    0           1122      0      88/8192       system_mgr
5331    7923    0           1122      0      88/8192       system_mgr
5331    8004    149980      7949358   0      88/8192       system_mgr
5331    8007    158160      7949312   0      88/8192       system_mgr
5331    8008    0           1127      0      88/8192       system_mgr
5331    8010    0           1127      0      88/8192       system_mgr
5331    8011    0           1127      0      88/8192       system_mgr
5560            238660      8974612   26     88/4096       slproc
5560    5560    400         1123      0      88/4096       slproc
5560    5620    212020      8140246   0      88/4096       slproc
5560    5621    25230       814544    0      88/4096       slproc
5560    5622    530         5543      0      88/4096       slproc
5560    5623    20          1627      0      88/4096       slproc
5560    5624    360         4311      0      88/4096       slproc
5560    5625    60          2928      0      88/4096       slproc
5560    5626    0           1107      0      88/4096       slproc
5560    5627    0           1117      0      88/4096       slproc
5560    5628    40          2066      0      88/4096       slproc
5636            2758334     330050990 103    92/4096       fed
5636    5636    32440       8966      0      92/4096       fed
5636    6077    4041985     9317752   0      92/4096       fed
5636    6078    80          1675      0      92/4096       fed
5636    6079    1183910     13994682  0      92/4096       fed
5636    6080    153110      8134158   0      92/4096       fed
5636    6081    30          1309      0      92/4096       fed
5636    6082    0           1224      0      92/4096       fed
5636    6083    0           1330      0      92/4096       fed
5636    6084    40          1332      0      92/4096       fed
5636    6085    0           1149      0      92/4096       fed
5636    6086    24360       814596    0      92/4096       fed
5636    6087    10590       544022    0      92/4096       fed
5636    6090    3702092     187055451 0      92/4096       fed
5636    6091    30          1276      0      92/4096       fed
5636    6093    737415      7971266   0      92/4096       fed
5636    6094    2516642     50628766  0      92/4096       fed
5636    6095    381830      8141562   0      92/4096       fed
5636    6096    1090910     9609922   0      92/4096       fed
5636    6097    3380962     356465443 0      92/4096       fed
5636    6098    40          2823      0      92/4096       fed
5636    6121    2356954     861436244 0      92/4096       fed
5636    6124    2085310     81293428  0      92/4096       fed
5636    7948    0           1162      0      92/4096       fed
5636    7949    0           1162      0      92/4096       fed
5636    7950    0           1213      0      92/4096       fed
5636    7962    167400      7949488   0      92/4096       fed
5636    7965    310620      7950073   0      92/4096       fed
5636    7968    468920      8721982   0      92/4096       fed
5636    7971    20          1305      0      92/4096       fed
5636    7975    0           1163      0      92/4096       fed
5636    11599   50          10283     0      92/4096       fed
5636    11602   2943916     89120254  0      92/4096       fed
5636    12745   1178786     501308803 0      92/4096       fed
5636    12746   80          9390      0      92/4096       fed
5636    12747   523600      501802034 0      92/4096       fed
5636    12748   674594      287999571 0      92/4096       fed
5636    12749   0           8431      0      92/4096       fed
5636    12751   0           8437      0      92/4096       fed
5636    12754   0           8473      0      92/4096       fed
5636    12755   0           8473      0      92/4096       fed
5636    12756   0           8472      0      92/4096       fed
5636    12759   10          8511      0      92/4096       fed
5636    13204   0           8962      0      92/4096       fed
5636    13317   561408      300143885 0      92/4096       fed
5637            287909      207080070 22     92/4096       platform_mgr
5637    5637    1800        174639    0      92/4096       platform_mgr
5637    6057    260520      8140230   0      92/4096       platform_mgr
5637    6058    30          1246      0      92/4096       platform_mgr
5637    6059    1006960     23663684  0      92/4096       platform_mgr
5637    6060    146970      8134143   0      92/4096       platform_mgr
5637    6061    0           1162      0      92/4096       platform_mgr
5637    6062    0           1204      0      92/4096       platform_mgr
5637    6063    10          1202      0      92/4096       platform_mgr
5637    6064    0           1211      0      92/4096       platform_mgr
5637    6065    0           1136      0      92/4096       platform_mgr
5637    6066    24530       814576    0      92/4096       platform_mgr
5637    6069    2494970     18750574  0      92/4096       platform_mgr
5637    6070    2154480     81266195  0      92/4096       platform_mgr
5637    6072    11010       543920    0      92/4096       platform_mgr
5637    6073    1768360     34913447  0      92/4096       platform_mgr
5637    6074    3230945     257396914 0      92/4096       platform_mgr
5637    6075    0           1192      0      92/4096       platform_mgr
5637    6099    2386913     151754243 0      92/4096       platform_mgr
5637    6128    200         196265    0      92/4096       platform_mgr
5637    7951    0           1154      0      92/4096       platform_mgr
5637    7952    0           1154      0      92/4096       platform_mgr
5637    7953    0           1154      0      92/4096       platform_mgr
5637    8012    160450      7949515   0      92/4096       platform_mgr
5637    8013    168720      7949473   0      92/4096       platform_mgr
5637    8014    10          1200      0      92/4096       platform_mgr
5637    8015    0           1175      0      92/4096       platform_mgr
5637    8016    0           1161      0      92/4096       platform_mgr
5637    13032   2080190     81441834  0      92/4096       platform_mgr
5637    13033   0           174597    0      92/4096       platform_mgr
5637    13034   0           174597    0      92/4096       platform_mgr
5637    13035   0           174596    0      92/4096       platform_mgr
5637    13039   10          174629    0      92/4096       platform_mgr
5637    13045   1570580     21029227  0      92/4096       platform_mgr
5637    13158   120         174689    0      92/4096       platform_mgr
5637    13162   0           1726      0      92/4096       platform_mgr
5637    13163   0           1726      0      92/4096       platform_mgr
5637    13164   0           1726      0      92/4096       platform_mgr
5638            2511957     163173530 67     88/4096       stack-mgr
5638    5638    3440        3814      0      88/4096       stack-mgr
5638    6044    211610      8140285   0      88/4096       stack-mgr
5638    6045    10          1272      0      88/4096       stack-mgr
5638    6046    73600       547959    0      88/4096       stack-mgr
5638    6047    149270      8134155   0      88/4096       stack-mgr
5638    6048    30          1295      0      88/4096       stack-mgr
5638    6049    0           1256      0      88/4096       stack-mgr
5638    6050    10          1298      0      88/4096       stack-mgr
5638    6051    10          1264      0      88/4096       stack-mgr
5638    6052    0           1148      0      88/4096       stack-mgr
5638    6053    25270       814589    0      88/4096       stack-mgr
5638    6056    66330       313006    0      88/4096       stack-mgr
5638    6106    2371350     86210882  0      88/4096       stack-mgr
5638    6107    3477573     110427332 0      88/4096       stack-mgr
5638    6108    64330       279421    0      88/4096       stack-mgr
5638    6109    818227      533452161 0      88/4096       stack-mgr
5638    6112    2332        32525936  0      88/4096       stack-mgr
5638    6113    10          3703      0      88/4096       stack-mgr
5638    6114    282500      8142642   0      88/4096       stack-mgr
5638    6115    1187342     237200296 0      88/4096       stack-mgr
5638    6116    3231650     237575994 0      88/4096       stack-mgr
5638    6117    2009932     346790370 0      88/4096       stack-mgr
5638    6118    1097880     5240234   0      88/4096       stack-mgr
5638    6119    0           3701      0      88/4096       stack-mgr
5638    7942    0           1179      0      88/4096       stack-mgr
5638    7943    0           1179      0      88/4096       stack-mgr
5638    7944    0           1179      0      88/4096       stack-mgr
5638    7988    157030      7949539   0      88/4096       stack-mgr
5638    7990    167120      7949493   0      88/4096       stack-mgr
5638    7993    0           1181      0      88/4096       stack-mgr
5638    7995    0           1181      0      88/4096       stack-mgr
5638    7999    0           1181      0      88/4096       stack-mgr
5638    8089    0           3791      0      88/4096       stack-mgr
5638    8090    0           3791      0      88/4096       stack-mgr
5638    8091    0           3791      0      88/4096       stack-mgr
5638    9797    0           3807      0      88/4096       stack-mgr
6129            1660490     16263091  102    116/4096      idope.py
6129    6129    18730       1515      0      116/4096      idope.py
6129    7903    1641760     16261576  0      116/4096      idope.py
6273            714500      33002384  21     88/4096       ns_oir_proxy
6273    6273    200         1253      0      88/4096       ns_oir_proxy
6273    7106    211360      8140333   0      88/4096       ns_oir_proxy
6273    7123    25040       814686    0      88/4096       ns_oir_proxy
6273    7124    30          1280      0      88/4096       ns_oir_proxy
6273    7130    20          1293      0      88/4096       ns_oir_proxy
6273    7157    0           1267      0      88/4096       ns_oir_proxy
6273    7158    153570      8134230   0      88/4096       ns_oir_proxy
6273    7160    0           1267      0      88/4096       ns_oir_proxy
6273    7933    0           1263      0      88/4096       ns_oir_proxy
6273    7934    0           1263      0      88/4096       ns_oir_proxy
6273    7935    0           1263      0      88/4096       ns_oir_proxy
6273    7957    159980      7949625   0      88/4096       ns_oir_proxy
6273    7970    164300      7949566   0      88/4096       ns_oir_proxy
6273    7972    0           1265      0      88/4096       ns_oir_proxy
6273    7978    0           1265      0      88/4096       ns_oir_proxy
6273    7979    0           1265      0      88/4096       ns_oir_proxy
6274            705150      33011413  21     88/4096       profiled
6274    6274    200         1286      0      88/4096       profiled
6274    7159    209180      8140337   0      88/4096       profiled
6274    7173    24650       814686    0      88/4096       profiled
6274    8331    40          1304      0      88/4096       profiled
6274    8333    0           1276      0      88/4096       profiled
6274    8334    149230      8134241   0      88/4096       profiled
6274    8335    0           1268      0      88/4096       profiled
6274    8336    0           1269      0      88/4096       profiled
6274    8337    0           1276      0      88/4096       profiled
6274    8338    0           1275      0      88/4096       profiled
6274    8339    0           1275      0      88/4096       profiled
6274    8351    0           1276      0      88/4096       profiled
6274    8352    0           1275      0      88/4096       profiled
6274    8353    0           1275      0      88/4096       profiled
6274    8381    0           1269      0      88/4096       profiled
6274    8383    0           1269      0      88/4096       profiled
6274    8385    0           1269      0      88/4096       profiled
6274    8386    157770      7949629   0      88/4096       profiled
6274    8387    164080      7949583   0      88/4096       profiled
6274    8388    0           1269      0      88/4096       profiled
6274    8391    0           1269      0      88/4096       profiled
6274    8393    0           1269      0      88/4096       profiled
6274    9753    0           1288      0      88/4096       profiled
6275            710310      803338    884    88/4096       oom_poll.sh
6276            1619270     51272953  31     88/4096       obfld
6276    6276    610         1388      0      88/4096       obfld
6276    7443    248100      8143406   0      88/4096       obfld
6276    7471    30600       814722    0      88/4096       obfld
6276    7480    643310      976011    0      88/4096       obfld
6276    8097    30          1357      0      88/4096       obfld
6276    8100    169550      1001914   0      88/4096       obfld
6276    8101    202010      8134207   0      88/4096       obfld
6276    8108    0           1307      0      88/4096       obfld
6276    8110    0           1308      0      88/4096       obfld
6276    8111    0           1307      0      88/4096       obfld
6276    8112    159550      7949667   0      88/4096       obfld
6276    8115    165520      7949617   0      88/4096       obfld
6276    8116    0           1307      0      88/4096       obfld
6276    8119    0           1307      0      88/4096       obfld
6276    8120    0           1307      0      88/4096       obfld
6276    8123    0           1309      0      88/4096       obfld
6276    8124    0           1310      0      88/4096       obfld
6276    8125    0           1323      0      88/4096       obfld
6276    8126    0           1323      0      88/4096       obfld
6276    8127    0           1323      0      88/4096       obfld
6276    8152    0           1324      0      88/4096       obfld
6276    8153    0           1326      0      88/4096       obfld
6276    8154    0           1327      0      88/4096       obfld
6276    9789    0           1339      0      88/4096       obfld
6276    13167   0           1322      0      88/4096       obfld
6276    13168   0           1321      0      88/4096       obfld
6276    13169   0           1321      0      88/4096       obfld
6276    16453   0           4069241   0      88/4096       obfld
6276    16511   0           4069263   0      88/4096       obfld
6276    16512   0           4069237   0      88/4096       obfld
6276    16514   0           4069253   0      88/4096       obfld
6277            711280      33011350  21     88/4096       consoled
6277    6277    200         1284      0      88/4096       consoled
6277    7863    209170      8140337   0      88/4096       consoled
6277    7864    25550       814685    0      88/4096       consoled
6277    8030    20          1302      0      88/4096       consoled
6277    8034    10          1274      0      88/4096       consoled
6277    8035    152050      8134243   0      88/4096       consoled
6277    8036    0           1266      0      88/4096       consoled
6277    8037    0           1274      0      88/4096       consoled
6277    8038    0           1274      0      88/4096       consoled
6277    8039    0           1274      0      88/4096       consoled
6277    8040    0           1265      0      88/4096       consoled
6277    8049    0           1264      0      88/4096       consoled
6277    8050    0           1264      0      88/4096       consoled
6277    8051    0           1264      0      88/4096       consoled
6277    8052    157090      7949627   0      88/4096       consoled
6277    8053    167190      7949577   0      88/4096       consoled
6277    8054    0           1264      0      88/4096       consoled
6277    8055    0           1264      0      88/4096       consoled
6277    8056    0           1264      0      88/4096       consoled
6277    8058    0           1273      0      88/4096       consoled
6277    8059    0           1273      0      88/4096       consoled
6277    8060    0           1272      0      88/4096       consoled
6277    9743    0           1286      0      88/4096       consoled
6278            2207880     41470063  53     88/4096       console_relay
6278    6278    1426630     8470298   0      88/4096       console_relay
6278    7891    274520      8140208   0      88/4096       console_relay
6278    7895    25320       814685    0      88/4096       console_relay
6278    7898    20          1296      0      88/4096       console_relay
6278    7899    0           1269      0      88/4096       console_relay
6278    7900    156080      8134248   0      88/4096       console_relay
6278    7901    10          1269      0      88/4096       console_relay
6278    7954    0           1267      0      88/4096       console_relay
6278    7955    0           1267      0      88/4096       console_relay
6278    7956    0           1267      0      88/4096       console_relay
6278    7989    159290      7949630   0      88/4096       console_relay
6278    7992    166010      7949581   0      88/4096       console_relay
6278    7994    0           1268      0      88/4096       console_relay
6278    7997    0           1268      0      88/4096       console_relay
6278    8000    0           1268      0      88/4096       console_relay
6279            710700      33011509  21     88/4096       csprovider
6279    6279    270         1298      0      88/4096       csprovider
6279    7228    206840      8140331   0      88/4096       csprovider
6279    7254    25760       814685    0      88/4096       csprovider
6279    8173    10          1315      0      88/4096       csprovider
6279    8199    0           1276      0      88/4096       csprovider
6279    8202    153000      8134241   0      88/4096       csprovider
6279    8210    0           1267      0      88/4096       csprovider
6279    8211    0           1267      0      88/4096       csprovider
6279    8212    0           1275      0      88/4096       csprovider
6279    8213    0           1276      0      88/4096       csprovider
6279    8214    0           1275      0      88/4096       csprovider
6279    8276    0           1270      0      88/4096       csprovider
6279    8277    0           1270      0      88/4096       csprovider
6279    8278    0           1270      0      88/4096       csprovider
6279    8279    157360      7949632   0      88/4096       csprovider
6279    8280    0           1286      0      88/4096       csprovider
6279    8281    0           1287      0      88/4096       csprovider
6279    8282    0           1288      0      88/4096       csprovider
6279    8283    167460      7949584   0      88/4096       csprovider
6279    8284    0           1276      0      88/4096       csprovider
6279    8285    0           1280      0      88/4096       csprovider
6279    8286    0           1280      0      88/4096       csprovider
6279    9792    0           1300      0      88/4096       csprovider
6280            714940      33092799  21     88/4096       system_mgr_cli
6280    6280    2010        82687     0      88/4096       system_mgr_cli
6280    7255    214000      8140336   0      88/4096       system_mgr_cli
6280    7275    24850       814685    0      88/4096       system_mgr_cli
6280    8168    30          1308      0      88/4096       system_mgr_cli
6280    8201    0           1274      0      88/4096       system_mgr_cli
6280    8204    148350      8134238   0      88/4096       system_mgr_cli
6280    8215    0           1275      0      88/4096       system_mgr_cli
6280    8216    0           1265      0      88/4096       system_mgr_cli
6280    8217    0           1272      0      88/4096       system_mgr_cli
6280    8218    0           1275      0      88/4096       system_mgr_cli
6280    8219    0           1272      0      88/4096       system_mgr_cli
6280    8267    0           1270      0      88/4096       system_mgr_cli
6280    8268    0           1270      0      88/4096       system_mgr_cli
6280    8269    0           1270      0      88/4096       system_mgr_cli
6280    8270    159080      7949630   0      88/4096       system_mgr_cli
6280    8271    166620      7949582   0      88/4096       system_mgr_cli
6280    8272    0           1270      0      88/4096       system_mgr_cli
6280    8273    0           1270      0      88/4096       system_mgr_cli
6280    8274    0           1270      0      88/4096       system_mgr_cli
6280    8288    0           1272      0      88/4096       system_mgr_cli
6280    8289    0           1272      0      88/4096       system_mgr_cli
6280    8290    0           1272      0      88/4096       system_mgr_cli
6280    9759    0           1284      0      88/4096       system_mgr_cli
6281            2605190     67415897  38     88/4096       plogd
6281    6281    1893310     34402797  0      88/4096       plogd
6281    7422    208600      8140339   0      88/4096       plogd
6281    7433    25560       814685    0      88/4096       plogd
6281    8165    10          1378      0      88/4096       plogd
6281    8170    10          1288      0      88/4096       plogd
6281    8172    152080      8134239   0      88/4096       plogd
6281    8183    10          1294      0      88/4096       plogd
6281    8187    0           1280      0      88/4096       plogd
6281    8188    10          1300      0      88/4096       plogd
6281    8189    0           1277      0      88/4096       plogd
6281    8190    0           1277      0      88/4096       plogd
6281    8191    0           1277      0      88/4096       plogd
6281    8192    158730      7949643   0      88/4096       plogd
6281    8193    166850      7949592   0      88/4096       plogd
6281    8194    0           1282      0      88/4096       plogd
6281    8195    20          1321      0      88/4096       plogd
6281    8196    10          1287      0      88/4096       plogd
6281    8197    0           1285      0      88/4096       plogd
6281    8198    0           1285      0      88/4096       plogd
6281    8298    0           1296      0      88/4096       plogd
6281    8299    0           1296      0      88/4096       plogd
6281    8300    0           1295      0      88/4096       plogd
6281    9750    0           1308      0      88/4096       plogd
6281    9939    0           1304      0      88/4096       plogd
6281    10398   0           1316      0      88/4096       plogd
6282            709930      33011879  21     88/4096       psdprov
6282    6282    250         1301      0      88/4096       psdprov
6282    7139    211400      8140342   0      88/4096       psdprov
6282    7150    25130       814685    0      88/4096       psdprov
6282    8304    20          1320      0      88/4096       psdprov
6282    8309    0           1324      0      88/4096       psdprov
6282    8310    151230      8134242   0      88/4096       psdprov
6282    8311    0           1272      0      88/4096       psdprov
6282    8312    0           1339      0      88/4096       psdprov
6282    8313    0           1318      0      88/4096       psdprov
6282    8314    0           1337      0      88/4096       psdprov
6282    8315    10          1326      0      88/4096       psdprov
6282    8316    0           1275      0      88/4096       psdprov
6282    8317    0           1275      0      88/4096       psdprov
6282    8318    0           1275      0      88/4096       psdprov
6282    8319    157660      7949635   0      88/4096       psdprov
6282    8320    164160      7949590   0      88/4096       psdprov
6282    8321    0           1278      0      88/4096       psdprov
6282    8322    0           1278      0      88/4096       psdprov
6282    8323    0           1278      0      88/4096       psdprov
6282    8325    0           1287      0      88/4096       psdprov
6282    8326    0           1287      0      88/4096       psdprov
6282    8327    0           1287      0      88/4096       psdprov
6282    9802    70          1348      0      88/4096       psdprov
6283            1518475     105795392 54     88/4096       pdsd
6283    6283    260         1295      0      88/4096       pdsd
6283    7127    215200      8140346   0      88/4096       pdsd
6283    7163    23600       814687    0      88/4096       pdsd
6283    7204    253470      8140236   0      88/4096       pdsd
6283    8330    20          1312      0      88/4096       pdsd
6283    8341    0           1277      0      88/4096       pdsd
6283    8342    151370      8134251   0      88/4096       pdsd
6283    8343    0           1269      0      88/4096       pdsd
6283    8344    0           1269      0      88/4096       pdsd
6283    8345    0           1277      0      88/4096       pdsd
6283    8346    0           1277      0      88/4096       pdsd
6283    8347    0           1277      0      88/4096       pdsd
6283    8363    0           1269      0      88/4096       pdsd
6283    8364    0           1270      0      88/4096       pdsd
6283    8368    0           1270      0      88/4096       pdsd
6283    8369    157090      7949638   0      88/4096       pdsd
6283    8378    166430      7949591   0      88/4096       pdsd
6283    8379    0           1274      0      88/4096       pdsd
6283    8380    0           1275      0      88/4096       pdsd
6283    8382    0           1278      0      88/4096       pdsd
6283    8389    0           1282      0      88/4096       pdsd
6283    8390    0           1282      0      88/4096       pdsd
6283    8392    0           1282      0      88/4096       pdsd
6283    9785    0           1295      0      88/4096       pdsd
6283    9887    1914300     4070200   0      88/4096       pdsd
6283    9888    577892      850353864 0      88/4096       pdsd
6283    9889    2353880     162378811 0      88/4096       pdsd
6284            991550      35128380  28     88/4096       gold_slave
6284    6284    670         1301      0      88/4096       gold_slave
6284    7636    220210      8140421   0      88/4096       gold_slave
6284    7642    10          1323      0      88/4096       gold_slave
6284    7643    81850       453354    0      88/4096       gold_slave
6284    7647    151310      8134236   0      88/4096       gold_slave
6284    7650    5180        134874    0      88/4096       gold_slave
6284    7651    9220        239759    0      88/4096       gold_slave
6284    7652    9490        258198    0      88/4096       gold_slave
6284    7653    12500       319705    0      88/4096       gold_slave
6284    7654    12200       316545    0      88/4096       gold_slave
6284    7678    26030       814708    0      88/4096       gold_slave
6284    7688    10          1309      0      88/4096       gold_slave
6284    7918    137930      405798    0      88/4096       gold_slave
6284    7924    0           1270      0      88/4096       gold_slave
6284    7925    0           1270      0      88/4096       gold_slave
6284    7926    0           1270      0      88/4096       gold_slave
6284    7961    158270      7949637   0      88/4096       gold_slave
6284    7964    166670      7949594   0      88/4096       gold_slave
6284    7966    10          1279      0      88/4096       gold_slave
6284    7984    0           1277      0      88/4096       gold_slave
6284    7985    0           1273      0      88/4096       gold_slave
6285            808710      33125569  24     88/4096       osinfo-provider
6285    6285    370         1337      0      88/4096       osinfo-provider
6285    7281    239060      8169004   0      88/4096       osinfo-provider
6285    7295    23550       814692    0      88/4096       osinfo-provider
6285    8332    10          1332      0      88/4096       osinfo-provider
6285    8354    2670        17758     0      88/4096       osinfo-provider
6285    8355    149250      8134252   0      88/4096       osinfo-provider
6285    8356    890         11602     0      88/4096       osinfo-provider
6285    8357    1190        12999     0      88/4096       osinfo-provider
6285    8358    840         9781      0      88/4096       osinfo-provider
6285    8359    1050        11535     0      88/4096       osinfo-provider
6285    8360    610         6026      0      88/4096       osinfo-provider
6285    8365    0           1291      0      88/4096       osinfo-provider
6285    8366    0           1291      0      88/4096       osinfo-provider
6285    8367    0           1291      0      88/4096       osinfo-provider
6285    8370    0           1296      0      88/4096       osinfo-provider
6285    8371    0           1296      0      88/4096       osinfo-provider
6285    8372    0           1296      0      88/4096       osinfo-provider
6285    8373    160110      7949657   0      88/4096       osinfo-provider
6285    8374    167640      7949609   0      88/4096       osinfo-provider
6285    8375    0           1296      0      88/4096       osinfo-provider
6285    8376    0           1296      0      88/4096       osinfo-provider
6285    8377    0           1296      0      88/4096       osinfo-provider
6285    9800    61180       19734     0      88/4096       osinfo-provider
6285    21452   660         5501      0      88/4096       osinfo-provider
6286            718740      33011433  21     88/4096       oscore_p
6286    6286    220         1286      0      88/4096       oscore_p
6286    7075    212270      8140336   0      88/4096       oscore_p
6286    7089    24690       814687    0      88/4096       oscore_p
6286    8163    20          1306      0      88/4096       oscore_p
6286    8200    0           1281      0      88/4096       oscore_p
6286    8203    153020      8134244   0      88/4096       oscore_p
6286    8205    0           1281      0      88/4096       oscore_p
6286    8206    0           1273      0      88/4096       oscore_p
6286    8207    0           1275      0      88/4096       oscore_p
6286    8208    0           1281      0      88/4096       oscore_p
6286    8209    0           1281      0      88/4096       oscore_p
6286    8220    0           1266      0      88/4096       oscore_p
6286    8221    0           1266      0      88/4096       oscore_p
6286    8223    0           1266      0      88/4096       oscore_p
6286    8224    161670      7949626   0      88/4096       oscore_p
6286    8225    166850      7949579   0      88/4096       oscore_p
6286    8226    0           1266      0      88/4096       oscore_p
6286    8227    0           1266      0      88/4096       oscore_p
6286    8228    0           1266      0      88/4096       oscore_p
6286    8264    0           1278      0      88/4096       oscore_p
6286    8265    0           1278      0      88/4096       oscore_p
6286    8266    0           1278      0      88/4096       oscore_p
6286    9769    0           1288      0      88/4096       oscore_p
6287            912030      33971947  26     88/4096       netd
6287    6287    200         1295      0      88/4096       netd
6287    7186    217710      8140331   0      88/4096       netd
6287    7222    40          1289      0      88/4096       netd
6287    7237    47240       405204    0      88/4096       netd
6287    7238    153980      8134236   0      88/4096       netd
6287    7239    0           1257      0      88/4096       netd
6287    7240    0           1262      0      88/4096       netd
6287    7241    0           1261      0      88/4096       netd
6287    7242    0           1264      0      88/4096       netd
6287    7243    0           1270      0      88/4096       netd
6287    7270    25890       814695    0      88/4096       netd
6287    7273    10          1287      0      88/4096       netd
6287    7274    44570       287887    0      88/4096       netd
6287    7276    98940       272626    0      88/4096       netd
6287    7936    0           1264      0      88/4096       netd
6287    7937    0           1264      0      88/4096       netd
6287    7938    0           1264      0      88/4096       netd
6287    7958    155920      7949628   0      88/4096       netd
6287    7982    167530      7949583   0      88/4096       netd
6287    7983    0           1267      0      88/4096       netd
6287    7986    0           1267      0      88/4096       netd
6287    7987    0           1267      0      88/4096       netd
6288            3969000     40326603  98     88/4096       mem_mgmt
6288    6288    3212750     8130136   0      88/4096       mem_mgmt
6288    7387    240200      8140298   0      88/4096       mem_mgmt
6288    8164    30          1361      0      88/4096       mem_mgmt
6288    8169    0           1329      0      88/4096       mem_mgmt
6288    8171    191840      8134242   0      88/4096       mem_mgmt
6288    8174    0           1324      0      88/4096       mem_mgmt
6288    8175    0           1324      0      88/4096       mem_mgmt
6288    8176    0           1328      0      88/4096       mem_mgmt
6288    8177    0           1328      0      88/4096       mem_mgmt
6288    8178    0           1328      0      88/4096       mem_mgmt
6288    8229    0           1331      0      88/4096       mem_mgmt
6288    8230    0           1331      0      88/4096       mem_mgmt
6288    8231    0           1330      0      88/4096       mem_mgmt
6288    8255    0           1328      0      88/4096       mem_mgmt
6288    8256    0           1328      0      88/4096       mem_mgmt
6288    8257    0           1328      0      88/4096       mem_mgmt
6288    8258    161690      7949689   0      88/4096       mem_mgmt
6288    8259    162500      7949639   0      88/4096       mem_mgmt
6288    8261    0           1329      0      88/4096       mem_mgmt
6288    8262    0           1329      0      88/4096       mem_mgmt
6288    8263    0           1329      0      88/4096       mem_mgmt
6288    9805    0           1339      0      88/4096       mem_mgmt
6289            990760      41141368  24     88/4096       mgmte_tap
6289    6289    170         1267      0      88/4096       mgmte_tap
6289    7867    210450      8140341   0      88/4096       mgmte_tap
6289    7868    24440       814686    0      88/4096       mgmte_tap
6289    7870    275330      8140214   0      88/4096       mgmte_tap
6289    7871    20          1295      0      88/4096       mgmte_tap
6289    7872    0           1271      0      88/4096       mgmte_tap
6289    7873    155990      8134238   0      88/4096       mgmte_tap
6289    7875    0           1270      0      88/4096       mgmte_tap
6289    7930    0           1264      0      88/4096       mgmte_tap
6289    7931    0           1264      0      88/4096       mgmte_tap
6289    7932    0           1264      0      88/4096       mgmte_tap
6289    7960    160240      7949633   0      88/4096       mgmte_tap
6289    7973    164120      7949582   0      88/4096       mgmte_tap
6289    7976    0           1268      0      88/4096       mgmte_tap
6289    7980    0           1268      0      88/4096       mgmte_tap
6289    7981    0           1268      0      88/4096       mgmte_tap
6290            725490      33053638  21     88/4096       installer
6290    6290    550         1357      0      88/4096       installer
6290    8864    214690      8140466   0      88/4096       installer
6290    8865    40          1394      0      88/4096       installer
6290    8866    400         3169      0      88/4096       installer
6290    8867    155600      8134237   0      88/4096       installer
6290    8868    120         3161      0      88/4096       installer
6290    8869    180         3393      0      88/4096       installer
6290    8870    260         3730      0      88/4096       installer
6290    8871    40          2231      0      88/4096       installer
6290    8872    100         3009      0      88/4096       installer
6290    8873    0           1272      0      88/4096       installer
6290    8874    0           1272      0      88/4096       installer
6290    8875    0           1272      0      88/4096       installer
6290    8876    161220      7949633   0      88/4096       installer
6290    8877    166530      7949579   0      88/4096       installer
6290    8878    80          1715      0      88/4096       installer
6290    8879    25300       814711    0      88/4096       installer
6290    8880    0           1284      0      88/4096       installer
6290    8881    0           1283      0      88/4096       installer
6290    8883    0           1298      0      88/4096       installer
6290    8884    0           1299      0      88/4096       installer
6290    8886    10          1314      0      88/4096       installer
6290    8887    40          1370      0      88/4096       installer
6290    8889    0           1309      0      88/4096       installer
6290    8890    0           1309      0      88/4096       installer
6290    8891    0           1308      0      88/4096       installer
6290    9795    280         2248      0      88/4096       installer
6290    9919    0           1326      0      88/4096       installer
6290    9920    0           1326      0      88/4096       installer
6290    9921    0           1326      0      88/4096       installer
6290    9922    0           1326      0      88/4096       installer
6290    9924    0           1326      0      88/4096       installer
6290    9925    0           1326      0      88/4096       installer
6290    11448   0           1335      0      88/4096       installer
6290    11449   20          1371      0      88/4096       installer
6290    11450   0           1332      0      88/4096       installer
6290    11453   20          1421      0      88/4096       installer
6290    13053   0           1335      0      88/4096       installer
6290    14441   0           2323      0      88/4096       installer
6290    15775   0           2320      0      88/4096       installer
6290    15776   10          2339      0      88/4096       installer
6290    16309   0           2305      0      88/4096       installer
6291            3285815     697146860 109    88/4096       ffm
6291    6291    754280      8505548   0      88/4096       ffm
6291    7906    342440      8140301   0      88/4096       ffm
6291    7907    29340       814758    0      88/4096       ffm
6291    7908    40          1484      0      88/4096       ffm
6291    7909    451183      252277204 0      88/4096       ffm
6291    7910    192310      8134293   0      88/4096       ffm
6291    7911    1307402     23437811  0      88/4096       ffm
6291    7912    1296522     23479762  0      88/4096       ffm
6291    7913    1343432     23955776  0      88/4096       ffm
6291    7914    1404732     23979200  0      88/4096       ffm
6291    7915    1482472     23902254  0      88/4096       ffm
6291    7945    0           1351      0      88/4096       ffm
6291    7946    0           1351      0      88/4096       ffm
6291    7947    0           1351      0      88/4096       ffm
6291    7963    158990      7949720   0      88/4096       ffm
6291    7967    457240      7951781   0      88/4096       ffm
6291    7969    1714560     19736321  0      88/4096       ffm
6291    7974    0           1355      0      88/4096       ffm
6291    7977    0           1353      0      88/4096       ffm
6291    8027    0           1363      0      88/4096       ffm
6291    8028    0           1363      0      88/4096       ffm
6291    8029    0           1363      0      88/4096       ffm
6291    9763    20          1380      0      88/4096       ffm
6291    9811    2882085     170208373 0      88/4096       ffm
6291    9923    0           1449      0      88/4096       ffm
6291    11160   2352245     94653360  0      88/4096       ffm
6291    11162   0           1573      0      88/4096       ffm
6291    11165   0           1577      0      88/4096       ffm
6291    12787   1460        2572      0      88/4096       ffm
6292            3282655     171405589 69     88/4096       eicored
6292    6292    11470       1567      0      88/4096       eicored
6292    7811    1490452     16048529  0      88/4096       eicored
6292    7822    25200       814699    0      88/4096       eicored
6292    8032    50          1647      0      88/4096       eicored
6292    8045    1452160     11403881  0      88/4096       eicored
6292    8047    171000      8134260   0      88/4096       eicored
6292    8061    0           1301      0      88/4096       eicored
6292    8062    0           1301      0      88/4096       eicored
6292    8063    0           1301      0      88/4096       eicored
6292    8064    159030      7949664   0      88/4096       eicored
6292    8065    167080      7949620   0      88/4096       eicored
6292    8067    540         5507      0      88/4096       eicored
6292    8068    794020      8274351   0      88/4096       eicored
6292    8069    817040      8373086   0      88/4096       eicored
6292    8070    781470      8247336   0      88/4096       eicored
6292    8071    799160      8287221   0      88/4096       eicored
6292    8072    793510      8283741   0      88/4096       eicored
6292    8073    70          1475      0      88/4096       eicored
6292    8074    0           1315      0      88/4096       eicored
6292    8078    0           1324      0      88/4096       eicored
6292    8079    4080        4152      0      88/4096       eicored
6292    8080    0           1373      0      88/4096       eicored
6292    8081    10          1373      0      88/4096       eicored
6292    8082    0           1334      0      88/4096       eicored
6292    8595    1720        7725591   0      88/4096       eicored
6292    9623    0           1469      0      88/4096       eicored
6292    9779    2580        25812     0      88/4096       eicored
6292    9781    13070       57968     0      88/4096       eicored
6292    9782    7320        82030     0      88/4096       eicored
6292    9783    10          1496      0      88/4096       eicored
6292    9791    10          1506      0      88/4096       eicored
6292    9823    10          1351      0      88/4096       eicored
6292    9825    0           1353      0      88/4096       eicored
6292    9827    0           1351      0      88/4096       eicored
6292    9844    30          1522      0      88/4096       eicored
6292    9846    0           1328      0      88/4096       eicored
6292    9890    0           1543      0      88/4096       eicored
6292    9956    0           1560      0      88/4096       eicored
6292    9957    0           1560      0      88/4096       eicored
6292    9958    0           1564      0      88/4096       eicored
6292    9964    0           1657      0      88/4096       eicored
6292    9966    0           1563      0      88/4096       eicored
6292    10458   5340        7726853   0      88/4096       eicored
6292    10788   0           1360      0      88/4096       eicored
6292    10828   6020        3401      0      88/4096       eicored
6292    10900   0           1518      0      88/4096       eicored
6292    10959   19810       81071     0      88/4096       eicored
6292    10964   20080       81750     0      88/4096       eicored
6292    11095   0           1385      0      88/4096       eicored
6292    11097   0           1351      0      88/4096       eicored
6292    11098   0           1351      0      88/4096       eicored
6292    11101   2020        2695      0      88/4096       eicored
6292    11114   0           1564      0      88/4096       eicored
6292    12449   3590        7726062   0      88/4096       eicored
6292    12455   400         7724989   0      88/4096       eicored
6292    13017   0           1560      0      88/4096       eicored
6292    14402   3210        7723591   0      88/4096       eicored
6292    14405   10030       7724482   0      88/4096       eicored
6292    14409   10          7723155   0      88/4096       eicored
6292    15092   30          7723215   0      88/4096       eicored
6292    15096   0           7723594   0      88/4096       eicored
6292    32506   17780       7728096   0      88/4096       eicored
6293            722160      33287710  21     88/4096       dtmgr
6293    6293    250         1309      0      88/4096       dtmgr
6293    7076    211940      8140344   0      88/4096       dtmgr
6293    7092    25300       814691    0      88/4096       dtmgr
6293    8166    50          1347      0      88/4096       dtmgr
6293    8240    0           1283      0      88/4096       dtmgr
6293    8241    0           1283      0      88/4096       dtmgr
6293    8242    0           1283      0      88/4096       dtmgr
6293    8243    157220      7949648   0      88/4096       dtmgr
6293    8244    168740      7949593   0      88/4096       dtmgr
6293    8245    0           1283      0      88/4096       dtmgr
6293    8246    0           1283      0      88/4096       dtmgr
6293    8247    0           1283      0      88/4096       dtmgr
6293    8248    160         2054      0      88/4096       dtmgr
6293    8249    153030      8134258   0      88/4096       dtmgr
6293    8250    80          1537      0      88/4096       dtmgr
6293    8251    0           1523      0      88/4096       dtmgr
6293    8252    20          1343      0      88/4096       dtmgr
6293    8253    80          1603      0      88/4096       dtmgr
6293    8254    60          1622      0      88/4096       dtmgr
6293    8293    0           1295      0      88/4096       dtmgr
6293    8294    0           1295      0      88/4096       dtmgr
6293    8295    0           1295      0      88/4096       dtmgr
6293    9777    20          1310      0      88/4096       dtmgr
6293    9885    5210        272659    0      88/4096       dtmgr
6293    9886    0           1307      0      88/4096       dtmgr
6294            1988929     41100633  1197   88/4096       cpumemd
6294    6294    1275819     8090433   0      88/4096       cpumemd
6294    7155    213590      8140319   0      88/4096       cpumemd
6294    7168    25170       814685    0      88/4096       cpumemd
6294    7192    30          1315      0      88/4096       cpumemd
6294    7195    0           1275      0      88/4096       cpumemd
6294    7196    150220      8134256   0      88/4096       cpumemd
6294    7197    0           1274      0      88/4096       cpumemd
6294    7198    0           1274      0      88/4096       cpumemd
6294    7199    0           1275      0      88/4096       cpumemd
6294    7200    0           1275      0      88/4096       cpumemd
6294    7201    0           1275      0      88/4096       cpumemd
6294    7939    0           1276      0      88/4096       cpumemd
6294    7940    0           1276      0      88/4096       cpumemd
6294    7941    0           1276      0      88/4096       cpumemd
6294    7959    157410      7949638   0      88/4096       cpumemd
6294    8003    166700      7949593   0      88/4096       cpumemd
6294    8005    0           1279      0      88/4096       cpumemd
6294    8006    0           1279      0      88/4096       cpumemd
6294    8009    0           1279      0      88/4096       cpumemd
6294    8394    0           1276      0      88/4096       cpumemd
6294    8395    0           1276      0      88/4096       cpumemd
6294    8396    0           1276      0      88/4096       cpumemd
6294    8399    0           1277      0      88/4096       cpumemd
6300            2702960     51711419  52     88/4096       liin_tap
6300    6300    1686820     10571558  0      88/4096       liin_tap
6300    7057    244020      8140256   0      88/4096       liin_tap
6300    7065    25020       814686    0      88/4096       liin_tap
6300    7095    263280      8140222   0      88/4096       liin_tap
6300    12939   30          1294      0      88/4096       liin_tap
6300    12940   0           1268      0      88/4096       liin_tap
6300    12942   157970      8134200   0      88/4096       liin_tap
6300    12945   0           1268      0      88/4096       liin_tap
6300    12946   0           1262      0      88/4096       liin_tap
6300    12947   0           1262      0      88/4096       liin_tap
6300    12948   0           1262      0      88/4096       liin_tap
6300    12949   158230      7949586   0      88/4096       liin_tap
6300    12950   167590      7949539   0      88/4096       liin_tap
6300    12951   0           1262      0      88/4096       liin_tap
6300    12952   0           1262      0      88/4096       liin_tap
6300    12953   0           1262      0      88/4096       liin_tap
6310            854560      33653057  25     88/4096       cli_agent
6310    6310    810         1298      0      88/4096       cli_agent
6310    7657    243850      8149396   0      88/4096       cli_agent
6310    7673    25380       814690    0      88/4096       cli_agent
6310    7695    10          1325      0      88/4096       cli_agent
6310    7704    21190       122956    0      88/4096       cli_agent
6310    7705    155730      8134255   0      88/4096       cli_agent
6310    7706    9560        83339     0      88/4096       cli_agent
6310    7707    9160        90380     0      88/4096       cli_agent
6310    7708    10050       100883    0      88/4096       cli_agent
6310    7709    8000        85453     0      88/4096       cli_agent
6310    7710    7220        73278     0      88/4096       cli_agent
6310    7725    0           1283      0      88/4096       cli_agent
6310    7927    0           1279      0      88/4096       cli_agent
6310    7928    0           1279      0      88/4096       cli_agent
6310    7929    0           1279      0      88/4096       cli_agent
6310    7991    160780      7949648   0      88/4096       cli_agent
6310    7996    165790      7949590   0      88/4096       cli_agent
6310    7998    0           1286      0      88/4096       cli_agent
6310    8001    0           1286      0      88/4096       cli_agent
6310    8002    0           1286      0      88/4096       cli_agent
6310    8092    4140        20914     0      88/4096       cli_agent
6310    8094    4800        20902     0      88/4096       cli_agent
6310    13231   0           1300      0      88/4096       cli_agent
6310    13232   0           1300      0      88/4096       cli_agent
6310    13233   0           1299      0      88/4096       cli_agent
6310    16349   0           20916     0      88/4096       cli_agent
6310    16350   30980       21012     0      88/4096       cli_agent
6311            1343648     418763780 187    88/4096       snmp_subagent
6311    6311    7160        1766      0      88/4096       snmp_subagent
6311    7522    2929000     11413383  0      88/4096       snmp_subagent
6311    7527    24950       814685    0      88/4096       snmp_subagent
6311    8087    20          1363      0      88/4096       snmp_subagent
6311    8096    502848      92550453  0      88/4096       snmp_subagent
6311    8098    152230      8134259   0      88/4096       snmp_subagent
6311    8102    734160      7033237   0      88/4096       snmp_subagent
6311    8103    739420      7026583   0      88/4096       snmp_subagent
6311    8104    728250      7010609   0      88/4096       snmp_subagent
6311    8105    722480      6971683   0      88/4096       snmp_subagent
6311    8106    723380      6963549   0      88/4096       snmp_subagent
6311    8107    0           1294      0      88/4096       snmp_subagent
6311    8109    0           1294      0      88/4096       snmp_subagent
6311    8113    0           1295      0      88/4096       snmp_subagent
6311    8114    154880      7949658   0      88/4096       snmp_subagent
6311    8117    167080      7949601   0      88/4096       snmp_subagent
6311    8118    0           1295      0      88/4096       snmp_subagent
6311    8121    0           1295      0      88/4096       snmp_subagent
6311    8122    0           1295      0      88/4096       snmp_subagent
6311    8151    1148778     91011030  0      88/4096       snmp_subagent
6311    8155    0           1310      0      88/4096       snmp_subagent
6311    8156    0           1313      0      88/4096       snmp_subagent
6311    8157    0           1314      0      88/4096       snmp_subagent
6311    8160    1165176     84402785  0      88/4096       snmp_subagent
6311    8162    30          1424      0      88/4096       snmp_subagent
6311    8301    0           1320      0      88/4096       snmp_subagent
6311    8302    0           1320      0      88/4096       snmp_subagent
6311    8303    0           1320      0      88/4096       snmp_subagent
6311    10958   13420       76011     0      88/4096       snmp_subagent
6311    11146   20          1821      0      88/4096       snmp_subagent
6311    11149   10          1768      0      88/4096       snmp_subagent
6311    11154   20250       760381    0      88/4096       snmp_subagent
6311    13052   0           1313      0      88/4096       snmp_subagent
6311    13124   0           819428    0      88/4096       snmp_subagent
6311    15094   10          819471    0      88/4096       snmp_subagent
6311    16211   10          18848372  0      88/4096       snmp_subagent
6311    16231   0           18848218  0      88/4096       snmp_subagent
6311    16269   20          819501    0      88/4096       snmp_subagent
6311    16280   0           819472    0      88/4096       snmp_subagent
6311    16328   0           18848160  0      88/4096       snmp_subagent
6311    16556   0           18848178  0      88/4096       snmp_subagent
6312            941440      41150348  22     88/4096       erm_p
6312    6312    230210      8140283   0      88/4096       erm_p
6312    7060    206500      8140336   0      88/4096       erm_p
6312    7074    24980       814685    0      88/4096       erm_p
6312    8095    20          1299      0      88/4096       erm_p
6312    8099    0           1274      0      88/4096       erm_p
6312    8128    150610      8134246   0      88/4096       erm_p
6312    8129    0           1267      0      88/4096       erm_p
6312    8130    0           1267      0      88/4096       erm_p
6312    8131    0           1275      0      88/4096       erm_p
6312    8132    0           1275      0      88/4096       erm_p
6312    8133    10          1275      0      88/4096       erm_p
6312    8134    0           1266      0      88/4096       erm_p
6312    8135    0           1266      0      88/4096       erm_p
6312    8136    0           1266      0      88/4096       erm_p
6312    8137    161380      7949626   0      88/4096       erm_p
6312    8138    167730      7949576   0      88/4096       erm_p
6312    8139    0           1266      0      88/4096       erm_p
6312    8140    0           1266      0      88/4096       erm_p
6312    8141    0           1266      0      88/4096       erm_p
6312    8144    0           1270      0      88/4096       erm_p
6312    8145    0           1270      0      88/4096       erm_p
6312    8146    0           1270      0      88/4096       erm_p
6312    9764    0           1284      0      88/4096       erm_p
6313            923160      41150483  22     88/4096       ngdumper_provid
6313    6313    208390      8140369   0      88/4096       ngdumper_provid
6313    8455    208740      8140313   0      88/4096       ngdumper_provid
6313    8456    25590       814683    0      88/4096       ngdumper_provid
6313    8488    20          1294      0      88/4096       ngdumper_provid
6313    8490    0           1278      0      88/4096       ngdumper_provid
6313    8491    151280      8134246   0      88/4096       ngdumper_provid
6313    8494    0           1270      0      88/4096       ngdumper_provid
6313    8495    0           1270      0      88/4096       ngdumper_provid
6313    8496    0           1278      0      88/4096       ngdumper_provid
6313    8497    0           1278      0      88/4096       ngdumper_provid
6313    8498    0           1278      0      88/4096       ngdumper_provid
6313    8500    0           1269      0      88/4096       ngdumper_provid
6313    8501    0           1269      0      88/4096       ngdumper_provid
6313    8502    0           1269      0      88/4096       ngdumper_provid
6313    8503    160100      7949629   0      88/4096       ngdumper_provid
6313    8504    169040      7949574   0      88/4096       ngdumper_provid
6313    8505    0           1269      0      88/4096       ngdumper_provid
6313    8506    0           1269      0      88/4096       ngdumper_provid
6313    8507    0           1269      0      88/4096       ngdumper_provid
6313    8511    0           1280      0      88/4096       ngdumper_provid
6313    8512    0           1280      0      88/4096       ngdumper_provid
6313    8513    0           1280      0      88/4096       ngdumper_provid
6313    9773    0           1293      0      88/4096       ngdumper_provid
6314            915520      41150519  22     88/4096       sysinfo_p
6314    6314    207890      8140381   0      88/4096       sysinfo_p
6314    7372    211810      8140337   0      88/4096       sysinfo_p
6314    7376    25320       814685    0      88/4096       sysinfo_p
6314    8167    10          1299      0      88/4096       sysinfo_p
6314    8179    20          1277      0      88/4096       sysinfo_p
6314    8180    148750      8134244   0      88/4096       sysinfo_p
6314    8181    0           1265      0      88/4096       sysinfo_p
6314    8182    0           1277      0      88/4096       sysinfo_p
6314    8184    0           1277      0      88/4096       sysinfo_p
6314    8185    0           1268      0      88/4096       sysinfo_p
6314    8186    10          1276      0      88/4096       sysinfo_p
6314    8232    0           1265      0      88/4096       sysinfo_p
6314    8233    0           1265      0      88/4096       sysinfo_p
6314    8234    0           1265      0      88/4096       sysinfo_p
6314    8235    157870      7949627   0      88/4096       sysinfo_p
6314    8236    163840      7949579   0      88/4096       sysinfo_p
6314    8237    0           1265      0      88/4096       sysinfo_p
6314    8238    0           1265      0      88/4096       sysinfo_p
6314    8239    0           1265      0      88/4096       sysinfo_p
6314    8306    0           1287      0      88/4096       sysinfo_p
6314    8307    0           1287      0      88/4096       sysinfo_p
6314    8308    0           1287      0      88/4096       sysinfo_p
6314    9809    0           1301      0      88/4096       sysinfo_p
6327            236060      8956279   26     88/4096       fs_cmd
6327    6327    140         1259      0      88/4096       fs_cmd
6327    7022    211360      8140339   0      88/4096       fs_cmd
6327    7035    24560       814686    0      88/4096       fs_cmd
8433            410         1416      289    88/4096       rollback_timer.
8742            10          1406      7      88/4096       rollback_timer.
8748            160         1406      113    88/4096       xlogger
8757            0           1410      0      88/4096       inotifywait
8904            140         1181      118    88/8192       nova_sntp.sh
9178            0           1179      0      88/8192       nova_sntp.sh
9183            160         1179      135    88/8192       xlogger
9186            3570        24327     146    88/8192       sntp
12121           2303730     200139402 33     88/4096       wcm
12121   12121   2560        1467      0      88/4096       wcm
12121   12722   250860      8144250   0      88/4096       wcm
12121   12723   29030       814878    0      88/4096       wcm
12121   12793   985232      162311899 0      88/4096       wcm
12121   12794   2867730     42183650  0      88/4096       wcm
12121   12797   0           1601      0      88/4096       wcm
12121   12798   0           1601      0      88/4096       wcm
12121   12799   50          1834      0      88/4096       wcm
12121   12800   231310      1640676   0      88/4096       wcm
12121   12801   199010      8134502   0      88/4096       wcm
12121   12802   119120      1349010   0      88/4096       wcm
12121   12803   118970      1348233   0      88/4096       wcm
12121   12804   117150      1307081   0      88/4096       wcm
12121   12805   122270      1365401   0      88/4096       wcm
12121   12806   117890      1296839   0      88/4096       wcm
12121   12807   0           1614      0      88/4096       wcm
12121   12808   0           1614      0      88/4096       wcm
12121   12809   0           1705      0      88/4096       wcm
12121   12810   156830      7949944   0      88/4096       wcm
12121   12811   167670      7949901   0      88/4096       wcm
12121   12812   0           1617      0      88/4096       wcm
12121   12813   0           1617      0      88/4096       wcm
12121   12814   0           1620      0      88/4096       wcm
12121   12818   20          1693      0      88/4096       wcm
12121   12820   0           1678      0      88/4096       wcm
12121   12821   210         1847      0      88/4096       wcm
12121   12822   10          1696      0      88/4096       wcm
12121   12825   360         3889      0      88/4096       wcm
12121   12826   50          1763      0      88/4096       wcm
12121   12827   20          1757      0      88/4096       wcm
12121   12828   349030      8140467   0      88/4096       wcm
12121   12829   10          1713      0      88/4096       wcm
12121   12831   0           1682      0      88/4096       wcm
12121   12832   0           1698      0      88/4096       wcm
12121   12833   10          1703      0      88/4096       wcm
12121   12834   54450       815751    0      88/4096       wcm
12121   12835   0           1706      0      88/4096       wcm
12121   12836   10          1735      0      88/4096       wcm
12121   12837   10          1732      0      88/4096       wcm
12121   12838   0           1733      0      88/4096       wcm
12121   12839   0           1716      0      88/4096       wcm
12121   12845   0           1764      0      88/4096       wcm
12121   12847   0           1763      0      88/4096       wcm
12121   12848   0           1762      0      88/4096       wcm
12121   12849   0           1767      0      88/4096       wcm
12121   12850   6110        277910    0      88/4096       wcm
12121   12854   1922840     27378858  0      88/4096       wcm
12121   12855   2031500     81270333  0      88/4096       wcm
12121   12857   0           1782      0      88/4096       wcm
12121   12858   0           1797      0      88/4096       wcm
12121   12861   6290        275570    0      88/4096       wcm
12121   12862   0           1786      0      88/4096       wcm
12121   12863   0           1787      0      88/4096       wcm
12121   12864   0           1786      0      88/4096       wcm
12121   12865   0           1801      0      88/4096       wcm
12121   12866   0           1786      0      88/4096       wcm
12121   12867   0           1786      0      88/4096       wcm
12121   12868   0           1786      0      88/4096       wcm
12121   12870   0           1792      0      88/4096       wcm
12121   12871   400         15362     0      88/4096       wcm
12121   12872   0           1791      0      88/4096       wcm
12121   12873   0           1798      0      88/4096       wcm
12121   12874   142700      839236    0      88/4096       wcm
12121   12875   0           1795      0      88/4096       wcm
12121   12877   0           1805      0      88/4096       wcm
12121   12878   0           1799      0      88/4096       wcm
12121   12879   0           1802      0      88/4096       wcm
12121   12880   1620        29205     0      88/4096       wcm
12121   12881   0           1819      0      88/4096       wcm
12121   12882   0           1807      0      88/4096       wcm
12121   12883   0           1806      0      88/4096       wcm
12121   12884   0           1821      0      88/4096       wcm
12121   12885   0           1821      0      88/4096       wcm
12121   12886   1000        69645     0      88/4096       wcm
12121   12887   458860      4257497   0      88/4096       wcm
12121   12888   0           1809      0      88/4096       wcm
12121   12889   35860       1630057   0      88/4096       wcm
12121   12892   0           1817      0      88/4096       wcm
12121   12893   0           1833      0      88/4096       wcm
12121   12894   0           1841      0      88/4096       wcm
12121   12895   15860       825556    0      88/4096       wcm
12121   12896   0           1839      0      88/4096       wcm
12121   12897   0           1819      0      88/4096       wcm
12121   12898   105670      1059459   0      88/4096       wcm
12121   12899   0           1841      0      88/4096       wcm
12121   12900   15400       825882    0      88/4096       wcm
12121   12901   0           1842      0      88/4096       wcm
12121   12902   0           1821      0      88/4096       wcm
12121   12903   104590      1190810   0      88/4096       wcm
12121   12904   860         6833      0      88/4096       wcm
12121   12905   0           1822      0      88/4096       wcm
12121   12907   0           1832      0      88/4096       wcm
12121   12908   0           1825      0      88/4096       wcm
12121   12909   0           1839      0      88/4096       wcm
12121   12910   126100      4199586   0      88/4096       wcm
12121   12911   0           1826      0      88/4096       wcm
12121   12912   3246830     805782597 0      88/4096       wcm
12121   12913   970         11456     0      88/4096       wcm
12121   12914   0           1826      0      88/4096       wcm
12121   12915   113670      3874151   0      88/4096       wcm
12121   12916   0           1828      0      88/4096       wcm
12121   12917   2748070     805772117 0      88/4096       wcm
12121   12918   0           1827      0      88/4096       wcm
12121   12919   40          1927      0      88/4096       wcm
12121   12922   1404775     814947    0      88/4096       wcm
12121   12923   4280        273198    0      88/4096       wcm
12121   13018   10          1706      0      88/4096       wcm
12121   13064   0           1687      0      88/4096       wcm
12121   13065   0           1687      0      88/4096       wcm
12121   13066   0           1687      0      88/4096       wcm
12121   13076   955890      1537069   0      88/4096       wcm
12121   13136   0           1838      0      88/4096       wcm
12121   13137   0           1838      0      88/4096       wcm
12121   13138   0           1838      0      88/4096       wcm
12121   13139   0           1838      0      88/4096       wcm
12121   13313   0           1803      0      88/4096       wcm
12121   13314   143580      4285667   0      88/4096       wcm
12122           1340895     283799022 34     88/4096       table_mgr
12122   12122   830         1455      0      88/4096       table_mgr
12122   12503   209720      8140403   0      88/4096       table_mgr
12122   12504   24220       814775    0      88/4096       table_mgr
12122   12509   30          1563      0      88/4096       table_mgr
12122   12510   70          1756      0      88/4096       table_mgr
12122   12512   149190      8134314   0      88/4096       table_mgr
12122   12514   20          1402      0      88/4096       table_mgr
12122   12515   0           1386      0      88/4096       table_mgr
12122   12516   0           1412      0      88/4096       table_mgr
12122   12517   20          1393      0      88/4096       table_mgr
12122   12518   0           1387      0      88/4096       table_mgr
12122   12522   0           1361      0      88/4096       table_mgr
12122   12523   0           1362      0      88/4096       table_mgr
12122   12524   0           1379      0      88/4096       table_mgr
12122   12525   160870      7949702   0      88/4096       table_mgr
12122   12526   168970      7949653   0      88/4096       table_mgr
12122   12527   0           1465      0      88/4096       table_mgr
12122   12530   120         1637      0      88/4096       table_mgr
12122   12531   10          1398      0      88/4096       table_mgr
12122   12532   0           1391      0      88/4096       table_mgr
12122   12534   30          1573      0      88/4096       table_mgr
12122   12571   0           1411      0      88/4096       table_mgr
12122   12572   0           1411      0      88/4096       table_mgr
12122   12573   30          1423      0      88/4096       table_mgr
12122   12576   20          1482      0      88/4096       table_mgr
12122   12584   10930       544138    0      88/4096       table_mgr
12122   12585   615815      250227098 0      88/4096       table_mgr
12122   12586   0           1439      0      88/4096       table_mgr
12122   12587   0           1439      0      88/4096       table_mgr
12122   12646   0           1441      0      88/4096       table_mgr
12122   12647   0           1441      0      88/4096       table_mgr
12122   12648   0           1441      0      88/4096       table_mgr
12122   12689   0           1458      0      88/4096       table_mgr
12122   14963   10          1411      0      88/4096       table_mgr
12123           120         1474      81     88/4096       wnweb.sh
12124           712770      33017511  21     88/4096       iifd
12124   12124   600         2210      0      88/4096       iifd
12124   12335   211120      8140404   0      88/4096       iifd
12124   12336   24630       814776    0      88/4096       iifd
12124   12344   10          1413      0      88/4096       iifd
12124   12345   180         2355      0      88/4096       iifd
12124   12348   154210      8134303   0      88/4096       iifd
12124   12353   0           1352      0      88/4096       iifd
12124   12354   0           1353      0      88/4096       iifd
12124   12355   0           1360      0      88/4096       iifd
12124   12356   0           1360      0      88/4096       iifd
12124   12357   0           1360      0      88/4096       iifd
12124   12358   0           1358      0      88/4096       iifd
12124   12359   0           1358      0      88/4096       iifd
12124   12360   0           1358      0      88/4096       iifd
12124   12361   157580      7949691   0      88/4096       iifd
12124   12362   164230      7949641   0      88/4096       iifd
12124   12363   0           1358      0      88/4096       iifd
12124   12364   0           1358      0      88/4096       iifd
12124   12365   0           1358      0      88/4096       iifd
12124   12366   210         2308      0      88/4096       iifd
12124   12451   0           1371      0      88/4096       iifd
12124   12452   0           1371      0      88/4096       iifd
12124   12453   0           1372      0      88/4096       iifd
12124   12563   10          1384      0      88/4096       iifd
12126           2789909     414797756 188    92/8192       iosd
12126   12126   3089549     326854301 0      92/8192       iosd
12126   12979   3966747     879118407 0      92/8192       iosd
12126   12980   29170       318727    0      92/8192       iosd
12128           2450560     43801059  55     88/4096       ha_mgr
12128   12128   2030        82848     0      88/4096       ha_mgr
12128   12375   251470      8140339   0      88/4096       ha_mgr
12128   12385   30          1486      0      88/4096       ha_mgr
12128   12388   659080      2718753   0      88/4096       ha_mgr
12128   12391   155810      8134294   0      88/4096       ha_mgr
12128   12394   46670       704078    0      88/4096       ha_mgr
12128   12395   68020       1086737   0      88/4096       ha_mgr
12128   12396   54290       827500    0      88/4096       ha_mgr
12128   12397   69070       1064451   0      88/4096       ha_mgr
12128   12398   69310       1076526   0      88/4096       ha_mgr
12128   12402   24310       814791    0      88/4096       ha_mgr
12128   12407   0           1357      0      88/4096       ha_mgr
12128   12408   0           1357      0      88/4096       ha_mgr
12128   12409   0           1361      0      88/4096       ha_mgr
12128   12411   161020      7949696   0      88/4096       ha_mgr
12128   12412   431380      7949749   0      88/4096       ha_mgr
12128   12413   88140       906794    0      88/4096       ha_mgr
12128   12414   0           1393      0      88/4096       ha_mgr
12128   12415   0           1395      0      88/4096       ha_mgr
12128   12419   41050       909973    0      88/4096       ha_mgr
12128   12420   328880      1419069   0      88/4096       ha_mgr
12128   12427   0           1422      0      88/4096       ha_mgr
12128   12554   0           1425      0      88/4096       ha_mgr
12128   12555   0           1425      0      88/4096       ha_mgr
12128   12556   0           1425      0      88/4096       ha_mgr
12128   12596   0           1444      0      88/4096       ha_mgr
13365           2176810     40372583  53     236/4096      wnweb_paster.py
13365   13365   1378820     8139762   0      236/4096      wnweb_paster.py
13365   13489   10          2169      0      236/4096      wnweb_paster.py
13365   13490   0           2148      0      236/4096      wnweb_paster.py
13365   13491   196090      8134950   0      236/4096      wnweb_paster.py
13365   13492   0           2145      0      236/4096      wnweb_paster.py
13365   13493   0           2148      0      236/4096      wnweb_paster.py
13365   13494   0           2148      0      236/4096      wnweb_paster.py
13365   13495   20          2149      0      236/4096      wnweb_paster.py
13365   13496   0           2138      0      236/4096      wnweb_paster.py
13365   13497   0           2136      0      236/4096      wnweb_paster.py
13365   13498   0           2136      0      236/4096      wnweb_paster.py
13365   13499   0           2136      0      236/4096      wnweb_paster.py
13365   13500   159290      7950392   0      236/4096      wnweb_paster.py
13365   13501   165270      7950339   0      236/4096      wnweb_paster.py
13365   13502   0           2136      0      236/4096      wnweb_paster.py
13365   13503   0           2136      0      236/4096      wnweb_paster.py
13365   13504   0           2136      0      236/4096      wnweb_paster.py
13365   13505   0           2148      0      236/4096      wnweb_paster.py
13365   13506   0           2148      0      236/4096      wnweb_paster.py
13365   13507   0           2148      0      236/4096      wnweb_paster.py
13365   13508   277310      8140981   0      236/4096      wnweb_paster.py
13365   13509   0           2184      0      236/4096      wnweb_paster.py
13365   13510   0           2169      0      236/4096      wnweb_paster.py
13365   13511   10          2170      0      236/4096      wnweb_paster.py
13365   13512   0           2195      0      236/4096      wnweb_paster.py
13365   13513   0           2175      0      236/4096      wnweb_paster.py
13365   13514   0           2184      0      236/4096      wnweb_paster.py
13365   13515   0           2189      0      236/4096      wnweb_paster.py
13365   13516   0           2197      0      236/4096      wnweb_paster.py
13365   13517   0           2205      0      236/4096      wnweb_paster.py
13365   13519   0           2211      0      236/4096      wnweb_paster.py
13366           380         1474      257    88/4096       xlogger
16479           10          803339    0      88/4096       sleep
------------------ show redundancy history ------------------
00:03:05 *my state = INITIALIZATION(2) peer state = DISABLED(1)
00:03:05 RF_EVENT_INITIALIZATION(524) op=0 rc=0
00:03:05 *my state = NEGOTIATION(3) peer state = DISABLED(1)
00:03:06 client added: SNMP SA HA Client(20010) seq=24
00:03:06 client added: EICORE HA Client(20002) seq=4
00:03:06 client added: Installer HA Client(20007) seq=27
00:03:07 client added: Table Manager Client(24001) seq=21
00:03:11 client added: WCM_CAPWAP(24100) seq=5
00:03:11 client added: WCM QOS HA(24103) seq=8
00:03:11 client added: WCM_DOT1X(24106) seq=11
00:03:13 client added: WCM_MOBILITY(24105) seq=10
00:03:13 client added: WCM_NETFLOW(24111) seq=16
00:03:13 client added: WCM_APFROGUE(24107) seq=12
00:03:13 client added: WCM RRM HA(24101) seq=6
00:03:13 client added: WCM_MCAST(24112) seq=17
00:03:13 client added: WCM_CIDS(24110) seq=15
00:03:13 client added: wcm_comet(24120) seq=18
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) First Slave(0) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6290) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6292) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6311) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12121) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12122) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12126) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Installer HA Client(20007) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6290) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Table Manager Client(24001) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12122) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_CAPWAP(24100) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM RRM HA(24101) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM QOS HA(24103) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_MOBILITY(24105) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_DOT1X(24106) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_APFROGUE(24107) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_CIDS(24110) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EICORE HA Client(20002) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_NETFLOW(24111) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_MCAST(24112) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) wcm_comet(24120) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6292) op=405 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12121) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(29) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP SA HA Client(20010) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(139) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6311) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IIF-shim(20005) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) QEMU Platform RF(10001) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(22) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(71) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(24) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FFM RF(2900) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K OIR Rf client(10002) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K SES Rf client(10003) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NGWC FEC Rf client(10007) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Mac address Table Manager(519) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CAPWAP Data Plane Mgr(522) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DTLS Data Plane Mgr(523) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Wireless Client Database(524) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Wireless L2 Multicast(525) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(101) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(34) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(35) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(57) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Smart Install RF(1112) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(94) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Inline Power(10005) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Manager SPI(10008) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Inline Power rf client(505) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security(508) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch IP Device Tracking(509) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SISF table(515) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(130) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Admission RF Client(400) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(4005) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=0 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Online Diag HA(4056) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12126) op=405 rc=0
00:03:24 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Last Slave(65000) op=0 rc=0
00:03:24 RF_EVENT_SLAVE_STATUS_DONE(523) Last Slave(65000) op=0 rc=0
00:03:25 client added: Redundancy Mode RF(29) seq=60
00:03:25 client added: IfIndex(139) seq=61
00:03:25 client added: Persistent Variable(3300) seq=62
00:03:25 client added: CHKPT RF(25) seq=68
00:03:25 client added: IIF-shim(20005) seq=74
00:03:25 client added: QEMU Platform RF(10001) seq=82
00:03:25 client added: Event Manager(77) seq=84
00:03:25 client added: Network RF Client(22) seq=109
00:03:25 client added: LAN-Switch VTP VLAN(501) seq=132
00:03:25 client added: XDR RRP RF Client(71) seq=134
00:03:25 client added: CEF RRP RF Client(24) seq=135
00:03:25 client added: FFM RF(2900) seq=136
00:03:25 client added: RFS RF(520) seq=157
00:03:25 client added: Config Sync RF client(5) seq=159
00:03:25 client added: NG3K OIR Rf client(10002) seq=161
00:03:25 client added: NG3K SES Rf client(10003) seq=162
00:03:25 client added: NGWC FEC Rf client(10007) seq=164
00:03:25 client added: LAN-Switch Port Manager(502) seq=176
00:03:25 client added: Mac address Table Manager(519) seq=178
00:03:25 client added: CAPWAP Data Plane Mgr(522) seq=179
00:03:25 client added: DTLS Data Plane Mgr(523) seq=180
00:03:25 client added: Wireless Client Database(524) seq=181
00:03:25 client added: Wireless L2 Multicast(525) seq=182
00:03:25 client added: DHCPD(101) seq=221
00:03:25 client added: SNMP RF Client(34) seq=233
00:03:25 client added: History RF Client(35) seq=243
00:03:25 client added: ARP(57) seq=273
00:03:25 client added: Smart Install RF(1112) seq=294
00:03:25 client added: Config Verify RF client(94) seq=341
00:03:25 client added: Platform Inline Power(10005) seq=343
00:03:25 client added: Platform Manager SPI(10008) seq=344
00:03:25 client added: Inline Power rf client(505) seq=345
00:03:25 client added: Port Security(508) seq=348
00:03:25 client added: Switch IP Device Tracking(509) seq=349
00:03:25 client added: SISF table(515) seq=350
00:03:25 client added: CRYPTO RSA(130) seq=356
00:03:25 client added: IP Admission RF Client(400) seq=358
00:03:25 client added: ISSU Test Client(4005) seq=371
00:03:25 client added: Network RF 2 Client(93) seq=375
00:03:25 client added: LAN-Switch PAgP/LACP(510) seq=378
00:03:25 client added: DATA DESCRIPTOR RF CLIENT(141) seq=385
00:03:25 client added: IOS Config ARCHIVE(4020) seq=415
00:03:25 client added: IOS Config ROLLBACK(4021) seq=416
00:03:25 client added: Online Diag HA(4056) seq=461
00:03:25 client added: NG3K CFG MGR(10004) seq=462
00:03:28 RF_EVENT_GO_ACTIVE(512) op=0 rc=0
00:03:28 *my state = ACTIVE-FAST(9) peer state = DISABLED(1)
00:03:28 RF_PROG_ACTIVE_FAST(200) First Slave(0) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(6290) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(6292) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(6311) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(12121) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(12122) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Slave(12126) op=0 rc=23
00:03:28 RF_PROG_ACTIVE_FAST(200) Redundancy Mode RF(29) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) IfIndex(139) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Persistent Variable(3300) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Installer HA Client(20007) op=0 rc=0
00:03:28 RF_PROG_ACTIVE_FAST(200) EICORE HA Client(20002) op=0 rc=0
00:03:28 RF_PROG_ACTIVE_FAST(200) CHKPT RF(25) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) IIF-shim(20005) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) QEMU Platform RF(10001) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Event Manager(77) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Network RF Client(22) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) LAN-Switch VTP VLAN(501) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) XDR RRP RF Client(71) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) CEF RRP RF Client(24) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) FFM RF(2900) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) RFS RF(520) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Config Sync RF client(5) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) NG3K OIR Rf client(10002) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) NG3K SES Rf client(10003) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) NGWC FEC Rf client(10007) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) LAN-Switch Port Manager(502) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Mac address Table Manager(519) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) DTLS Data Plane Mgr(523) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Wireless Client Database(524) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Wireless L2 Multicast(525) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) DHCPD(101) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) SNMP RF Client(34) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) History RF Client(35) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) ARP(57) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Smart Install RF(1112) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Config Verify RF client(94) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Platform Inline Power(10005) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Platform Manager SPI(10008) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Inline Power rf client(505) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Port Security(508) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Switch IP Device Tracking(509) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) SISF table(515) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) CRYPTO RSA(130) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) IP Admission RF Client(400) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Table Manager Client(24001) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) Table Manager Client(24001) op=200 rc=11
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) Installer HA Client(20007) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_CAPWAP(24100) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_CAPWAP(24100) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM RRM HA(24101) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM RRM HA(24101) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM QOS HA(24103) op=0 rc=0
00:03:28 RF_PROG_ACTIVE_FAST(200) ISSU Test Client(4005) op=0 rc=11
00:03:28 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:03:28 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) SNMP SA HA Client(20010) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) SNMP SA HA Client(20010) op=200 rc=11
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM QOS HA(24103) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_MOBILITY(24105) op=0 rc=0
00:03:28 RF_PROG_ACTIVE_FAST(200) Network RF 2 Client(93) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) IOS Config ARCHIVE(4020) op=0 rc=11
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_MOBILITY(24105) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_DOT1X(24106) op=0 rc=0
00:03:28 RF_PROG_ACTIVE_FAST(200) IOS Config ROLLBACK(4021) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) Online Diag HA(4056) op=0 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) NG3K CFG MGR(10004) op=0 rc=11
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_DOT1X(24106) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_APFROGUE(24107) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_APFROGUE(24107) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_CIDS(24110) op=0 rc=0
00:03:28 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:03:28 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_CIDS(24110) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_NETFLOW(24111) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_NETFLOW(24111) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) WCM_MCAST(24112) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) WCM_MCAST(24112) op=200 rc=11
00:03:28 RF_PROG_ACTIVE_FAST(200) wcm_comet(24120) op=0 rc=0
00:03:28 RF_EVENT_LOCAL_PROG_DONE(505) wcm_comet(24120) op=200 rc=11
00:03:28 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:03:29 RF_EVENT_LOCAL_PROG_DONE(505) EICORE HA Client(20002) op=200 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_FAST(200) Last Slave(65000) op=0 rc=11
00:03:29 *my state = ACTIVE-DRAIN(10) peer state = DISABLED(1)
00:03:29 RF_PROG_ACTIVE_DRAIN(201) First Slave(0) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(6290) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(6292) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(6311) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(12121) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(12122) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Slave(12126) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_DRAIN(201) EICORE HA Client(20002) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Installer HA Client(20007) op=0 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Table Manager Client(24001) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) SNMP SA HA Client(20010) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_CAPWAP(24100) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM RRM HA(24101) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM QOS HA(24103) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_MOBILITY(24105) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_DOT1X(24106) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_APFROGUE(24107) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_CIDS(24110) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_NETFLOW(24111) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) WCM_MCAST(24112) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) wcm_comet(24120) op=0 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Redundancy Mode RF(29) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) IfIndex(139) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Persistent Variable(3300) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) CHKPT RF(25) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) IIF-shim(20005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) QEMU Platform RF(10001) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Event Manager(77) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Network RF Client(22) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch VTP VLAN(501) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) XDR RRP RF Client(71) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) CEF RRP RF Client(24) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) FFM RF(2900) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) RFS RF(520) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Config Sync RF client(5) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) NG3K OIR Rf client(10002) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) NG3K SES Rf client(10003) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) NGWC FEC Rf client(10007) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch Port Manager(502) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Mac address Table Manager(519) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) DTLS Data Plane Mgr(523) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Wireless Client Database(524) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Wireless L2 Multicast(525) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) DHCPD(101) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) SNMP RF Client(34) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) History RF Client(35) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) ARP(57) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Smart Install RF(1112) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Config Verify RF client(94) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Platform Inline Power(10005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Platform Manager SPI(10008) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Inline Power rf client(505) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Port Security(508) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Switch IP Device Tracking(509) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) SISF table(515) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) CRYPTO RSA(130) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) IP Admission RF Client(400) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) ISSU Test Client(4005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Network RF 2 Client(93) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) IOS Config ARCHIVE(4020) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) IOS Config ROLLBACK(4021) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Online Diag HA(4056) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) NG3K CFG MGR(10004) op=0 rc=11
00:03:29 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_DRAIN(201) Last Slave(65000) op=0 rc=11
00:03:29 *my state = ACTIVE_PRECONFIG(11) peer state = DISABLED(1)
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) First Slave(0) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6290) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6292) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(6311) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(12121) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(12122) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Slave(12126) op=0 rc=23
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Redundancy Mode RF(29) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) IfIndex(139) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Persistent Variable(3300) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) IIF-shim(20005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) QEMU Platform RF(10001) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Event Manager(77) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Network RF Client(22) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch VTP VLAN(501) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) XDR RRP RF Client(71) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) CEF RRP RF Client(24) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) FFM RF(2900) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) RFS RF(520) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Config Sync RF client(5) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) NG3K OIR Rf client(10002) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) NG3K SES Rf client(10003) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) NGWC FEC Rf client(10007) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch Port Manager(502) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Mac address Table Manager(519) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) DTLS Data Plane Mgr(523) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Wireless Client Database(524) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Wireless L2 Multicast(525) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) DHCPD(101) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(34) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(35) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) ARP(57) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Smart Install RF(1112) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Config Verify RF client(94) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Platform Inline Power(10005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Platform Manager SPI(10008) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Inline Power rf client(505) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Port Security(508) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Switch IP Device Tracking(509) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) SISF table(515) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(130) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) IP Admission RF Client(400) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) ISSU Test Client(4005) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Network RF 2 Client(93) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ARCHIVE(4020) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) IOS Config ROLLBACK(4021) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Online Diag HA(4056) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) NG3K CFG MGR(10004) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) EICORE HA Client(20002) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) SNMP SA HA Client(20010) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Installer HA Client(20007) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_CAPWAP(24100) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM RRM HA(24101) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM QOS HA(24103) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_MOBILITY(24105) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_DOT1X(24106) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_APFROGUE(24107) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_CIDS(24110) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_NETFLOW(24111) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) WCM_MCAST(24112) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) wcm_comet(24120) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Table Manager Client(24001) op=0 rc=11
00:03:29 RF_PROG_ACTIVE_PRECONFIG(202) Last Slave(65000) op=0 rc=11
00:03:30 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) First Slave(0) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6290) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6292) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(6311) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(12121) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(12122) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(12126) op=0 rc=23
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Installer HA Client(20007) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_CAPWAP(24100) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM RRM HA(24101) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM QOS HA(24103) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_MOBILITY(24105) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_DOT1X(24106) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_APFROGUE(24107) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_CIDS(24110) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_NETFLOW(24111) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) WCM_MCAST(24112) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) wcm_comet(24120) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(29) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) IfIndex(139) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Persistent Variable(3300) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) IIF-shim(20005) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) QEMU Platform RF(10001) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Event Manager(77) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF Client(22) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch VTP VLAN(501) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) XDR RRP RF Client(71) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) CEF RRP RF Client(24) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) FFM RF(2900) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP SA HA Client(20010) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) RFS RF(520) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Config Sync RF client(5) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K OIR Rf client(10002) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K SES Rf client(10003) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) NGWC FEC Rf client(10007) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch Port Manager(502) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Mac address Table Manager(519) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) DTLS Data Plane Mgr(523) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Wireless Client Database(524) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Wireless L2 Multicast(525) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) DHCPD(101) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(34) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(35) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) ARP(57) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Smart Install RF(1112) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Config Verify RF client(94) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Platform Inline Power(10005) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Platform Manager SPI(10008) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Inline Power rf client(505) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Port Security(508) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Switch IP Device Tracking(509) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) SISF table(515) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(130) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) IP Admission RF Client(400) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) ISSU Test Client(4005) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Network RF 2 Client(93) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Table Manager Client(24001) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ARCHIVE(4020) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) IOS Config ROLLBACK(4021) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Online Diag HA(4056) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) NG3K CFG MGR(10004) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) EICORE HA Client(20002) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:03:30 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:03:30 RF_PROG_ACTIVE_POSTCONFIG(203) Last Slave(65000) op=0 rc=11
00:03:30 *my state = ACTIVE(13) peer state = DISABLED(1)
00:03:30 RF_PROG_ACTIVE(204) First Slave(0) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Slave(6290) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) Slave(6292) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) Slave(6311) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) Slave(12121) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) Slave(12122) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) Slave(12126) op=0 rc=23
00:03:30 RF_PROG_ACTIVE(204) EICORE HA Client(20002) op=0 rc=0
00:03:30 RF_PROG_ACTIVE(204) SNMP SA HA Client(20010) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) SNMP SA HA Client(20010) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_CAPWAP(24100) op=0 rc=0
00:03:30 RF_PROG_ACTIVE(204) Table Manager Client(24001) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) Table Manager Client(24001) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) Installer HA Client(20007) op=0 rc=0
00:03:30 RF_PROG_ACTIVE(204) Redundancy Mode RF(29) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) IfIndex(139) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Persistent Variable(3300) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) IIF-shim(20005) op=0 rc=11
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_CAPWAP(24100) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) QEMU Platform RF(10001) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM RRM HA(24101) op=0 rc=0
00:03:30 RF_PROG_ACTIVE(204) Event Manager(77) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Network RF Client(22) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) LAN-Switch VTP VLAN(501) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) XDR RRP RF Client(71) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) CEF RRP RF Client(24) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) FFM RF(2900) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) RFS RF(520) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Config Sync RF client(5) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) NG3K OIR Rf client(10002) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) NG3K SES Rf client(10003) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) NGWC FEC Rf client(10007) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) LAN-Switch Port Manager(502) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Mac address Table Manager(519) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) DTLS Data Plane Mgr(523) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Wireless Client Database(524) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Wireless L2 Multicast(525) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) DHCPD(101) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) SNMP RF Client(34) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) History RF Client(35) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) ARP(57) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Smart Install RF(1112) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Config Verify RF client(94) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Platform Inline Power(10005) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Platform Manager SPI(10008) op=0 rc=11
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM RRM HA(24101) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) Inline Power rf client(505) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Port Security(508) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Switch IP Device Tracking(509) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) SISF table(515) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) CRYPTO RSA(130) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM QOS HA(24103) op=0 rc=0
00:03:30 RF_PROG_ACTIVE(204) IP Admission RF Client(400) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) ISSU Test Client(4005) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Network RF 2 Client(93) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) IOS Config ARCHIVE(4020) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) IOS Config ROLLBACK(4021) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) Online Diag HA(4056) op=0 rc=11
00:03:30 RF_PROG_ACTIVE(204) NG3K CFG MGR(10004) op=0 rc=11
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM QOS HA(24103) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_MOBILITY(24105) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_MOBILITY(24105) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_DOT1X(24106) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_DOT1X(24106) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_APFROGUE(24107) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_APFROGUE(24107) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_CIDS(24110) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_CIDS(24110) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_NETFLOW(24111) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_NETFLOW(24111) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) WCM_MCAST(24112) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) WCM_MCAST(24112) op=204 rc=11
00:03:30 RF_PROG_ACTIVE(204) wcm_comet(24120) op=0 rc=0
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) Installer HA Client(20007) op=204 rc=11
00:03:30 RF_EVENT_LOCAL_PROG_DONE(505) wcm_comet(24120) op=204 rc=11
00:03:31 RF_EVENT_LOCAL_PROG_DONE(505) EICORE HA Client(20002) op=204 rc=11
00:03:31 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:03:31 RF_PROG_ACTIVE(204) Last Slave(65000) op=0 rc=11
00:03:32 client added: Auth Mgr(210) seq=158
00:03:32 client added: LLDP(208) seq=207
00:03:32 client added: Switch Backup Interface client(507) seq=324
00:03:32 client added: PASSWD RF Client(4058) seq=419
00:03:35 client added: AAA(69) seq=239
00:03:36 client added: IPROUTING NSF RF client(20) seq=218
00:03:36 client added: IOS Config SHELL(4022) seq=414
00:03:36 client added: Tableid HA(75) seq=125
00:03:36 client added: Spanning-Tree Protocol(503) seq=296
00:03:36 client added: Igmp Snooping(506) seq=347
00:03:36 client added: MLD Snooping(521) seq=452
00:03:37 client added: DHCP Snooping(105) seq=327
00:03:39 client added: SNMP HA RF Client(54) seq=271
00:03:39 client added: Call-Home RF(1510) seq=333
00:03:39 client added: FH_RF_Event_Detector_stub(50) seq=280
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) First Slave(0) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=405 rc=7
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6290) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6292) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(6311) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12121) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12122) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Installer HA Client(20007) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_CAPWAP(24100) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM RRM HA(24101) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM QOS HA(24103) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_MOBILITY(24105) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_DOT1X(24106) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_APFROGUE(24107) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_CIDS(24110) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_NETFLOW(24111) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) WCM_MCAST(24112) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) wcm_comet(24120) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP SA HA Client(20010) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Slave(12126) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Table Manager Client(24001) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6290) op=405 rc=7
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12121) op=405 rc=7
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) EICORE HA Client(20002) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6311) op=405 rc=7
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12122) op=405 rc=7
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6292) op=405 rc=7
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Redundancy Mode RF(29) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IfIndex(139) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Persistent Variable(3300) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CHKPT RF(25) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IIF-shim(20005) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) QEMU Platform RF(10001) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Event Manager(77) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Network RF Client(22) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Tableid HA(75) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch VTP VLAN(501) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) XDR RRP RF Client(71) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CEF RRP RF Client(24) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FFM RF(2900) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Auth Mgr(210) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Sync RF client(5) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K OIR Rf client(10002) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NG3K SES Rf client(10003) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) NGWC FEC Rf client(10007) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch Port Manager(502) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Mac address Table Manager(519) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CAPWAP Data Plane Mgr(522) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DTLS Data Plane Mgr(523) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Wireless Client Database(524) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Wireless L2 Multicast(525) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IPROUTING NSF RF client(20) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCPD(101) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SNMP RF Client(34) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) AAA(69) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) History RF Client(35) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ARP(57) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) FH_RF_Event_Detector_stub(50) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Smart Install RF(1112) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Spanning-Tree Protocol(503) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch Backup Interface client(507) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) DHCP Snooping(105) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Call-Home RF(1510) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Config Verify RF client(94) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Inline Power(10005) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Platform Manager SPI(10008) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Inline Power rf client(505) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Igmp Snooping(506) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Port Security(508) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Switch IP Device Tracking(509) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) SISF table(515) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) CRYPTO RSA(130) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IP Admission RF Client(400) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) ISSU Test Client(4005) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config SHELL(4022) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ARCHIVE(4020) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) IOS Config ROLLBACK(4021) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) PASSWD RF Client(4058) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) MLD Snooping(521) op=7 rc=0
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Online Diag HA(4056) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12126) op=405 rc=7
00:04:01 RF_STATUS_REDUNDANCY_MODE_CHANGE(405) Last Slave(65000) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Last Slave(65000) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) First Slave(0) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6290) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6292) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(6311) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(12121) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(12122) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Slave(12126) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Installer HA Client(20007) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6290) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP SA HA Client(20010) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6311) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_CAPWAP(24100) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM RRM HA(24101) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM QOS HA(24103) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_MOBILITY(24105) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_DOT1X(24106) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_APFROGUE(24107) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_CIDS(24110) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_NETFLOW(24111) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) WCM_MCAST(24112) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) wcm_comet(24120) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12121) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Table Manager Client(24001) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12122) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) EICORE HA Client(20002) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6292) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Redundancy Mode RF(29) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IfIndex(139) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Persistent Variable(3300) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CHKPT RF(25) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IIF-shim(20005) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) QEMU Platform RF(10001) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Event Manager(77) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Network RF Client(22) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Tableid HA(75) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch VTP VLAN(501) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) XDR RRP RF Client(71) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CEF RRP RF Client(24) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FFM RF(2900) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Auth Mgr(210) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Sync RF client(5) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NG3K OIR Rf client(10002) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NG3K SES Rf client(10003) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) NGWC FEC Rf client(10007) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch Port Manager(502) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Mac address Table Manager(519) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CAPWAP Data Plane Mgr(522) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DTLS Data Plane Mgr(523) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Wireless Client Database(524) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Wireless L2 Multicast(525) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IPROUTING NSF RF client(20) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCPD(101) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SNMP RF Client(34) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) AAA(69) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) History RF Client(35) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ARP(57) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) FH_RF_Event_Detector_stub(50) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Smart Install RF(1112) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Spanning-Tree Protocol(503) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch Backup Interface client(507) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) DHCP Snooping(105) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Call-Home RF(1510) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Config Verify RF client(94) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Platform Inline Power(10005) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Platform Manager SPI(10008) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Inline Power rf client(505) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Igmp Snooping(506) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Port Security(508) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Switch IP Device Tracking(509) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) SISF table(515) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) CRYPTO RSA(130) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IP Admission RF Client(400) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) ISSU Test Client(4005) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) LAN-Switch PAgP/LACP(510) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config SHELL(4022) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ARCHIVE(4020) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) IOS Config ROLLBACK(4021) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) PASSWD RF Client(4058) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) MLD Snooping(521) op=7 rc=0
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Online Diag HA(4056) op=7 rc=0
00:04:01 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12126) op=406 rc=7
00:04:01 RF_STATUS_OPER_REDUNDANCY_MODE_CHANGE(406) Last Slave(65000) op=7 rc=0
00:04:26 System initialization complete
00:06:32 RF_STATUS_PEER_PRESENCE(400) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) First Slave(0) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(6290) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(6292) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(6311) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(12121) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(12122) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Slave(12126) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Installer HA Client(20007) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=400 rc=1
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6290) op=400 rc=1
00:06:32 RF_STATUS_PEER_PRESENCE(400) Table Manager Client(24001) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_CAPWAP(24100) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM RRM HA(24101) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM QOS HA(24103) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_MOBILITY(24105) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_DOT1X(24106) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_APFROGUE(24107) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_CIDS(24110) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_NETFLOW(24111) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) WCM_MCAST(24112) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) wcm_comet(24120) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Redundancy Mode RF(29) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12122) op=400 rc=1
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12121) op=400 rc=1
00:06:32 RF_STATUS_PEER_PRESENCE(400) IfIndex(139) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Persistent Variable(3300) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) CHKPT RF(25) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IIF-shim(20005) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) QEMU Platform RF(10001) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Event Manager(77) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Network RF Client(22) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Tableid HA(75) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) LAN-Switch VTP VLAN(501) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) XDR RRP RF Client(71) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) CEF RRP RF Client(24) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) FFM RF(2900) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) EICORE HA Client(20002) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Auth Mgr(210) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Config Sync RF client(5) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) NG3K OIR Rf client(10002) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) SNMP SA HA Client(20010) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) NG3K SES Rf client(10003) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) NGWC FEC Rf client(10007) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) LAN-Switch Port Manager(502) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6292) op=400 rc=1
00:06:32 RF_STATUS_PEER_PRESENCE(400) Mac address Table Manager(519) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) CAPWAP Data Plane Mgr(522) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) DTLS Data Plane Mgr(523) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Wireless Client Database(524) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Wireless L2 Multicast(525) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IPROUTING NSF RF client(20) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) DHCPD(101) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6311) op=400 rc=1
00:06:32 RF_STATUS_PEER_PRESENCE(400) SNMP RF Client(34) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) AAA(69) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) History RF Client(35) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) ARP(57) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) FH_RF_Event_Detector_stub(50) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Smart Install RF(1112) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Spanning-Tree Protocol(503) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Switch Backup Interface client(507) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) DHCP Snooping(105) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Call-Home RF(1510) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Config Verify RF client(94) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Platform Inline Power(10005) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Platform Manager SPI(10008) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Inline Power rf client(505) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Igmp Snooping(506) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Port Security(508) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Switch IP Device Tracking(509) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) SISF table(515) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) CRYPTO RSA(130) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IP Admission RF Client(400) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) ISSU Test Client(4005) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) LAN-Switch PAgP/LACP(510) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IOS Config SHELL(4022) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IOS Config ARCHIVE(4020) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) IOS Config ROLLBACK(4021) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) PASSWD RF Client(4058) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) MLD Snooping(521) op=1 rc=0
00:06:32 RF_STATUS_PEER_PRESENCE(400) Online Diag HA(4056) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12126) op=400 rc=1
00:06:32 RF_STATUS_PEER_PRESENCE(400) Last Slave(65000) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Last Slave(65000) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) First Slave(0) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(6290) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(6292) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(6311) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(12121) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(12122) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Slave(12126) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) First Slave(0) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) SNMP SA HA Client(20010) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6311) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) Installer HA Client(20007) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Table Manager Client(24001) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_CAPWAP(24100) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6290) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) WCM RRM HA(24101) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM QOS HA(24103) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_MOBILITY(24105) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_DOT1X(24106) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12122) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) WCM_APFROGUE(24107) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_CIDS(24110) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_NETFLOW(24111) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) WCM_MCAST(24112) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) wcm_comet(24120) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12121) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) EICORE HA Client(20002) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(6292) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) Redundancy Mode RF(29) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IfIndex(139) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Persistent Variable(3300) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) CHKPT RF(25) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IIF-shim(20005) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) QEMU Platform RF(10001) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Event Manager(77) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Network RF Client(22) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Tableid HA(75) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) LAN-Switch VTP VLAN(501) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) XDR RRP RF Client(71) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) CEF RRP RF Client(24) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) FFM RF(2900) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Auth Mgr(210) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Config Sync RF client(5) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) NG3K OIR Rf client(10002) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) NG3K SES Rf client(10003) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) NGWC FEC Rf client(10007) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) LAN-Switch Port Manager(502) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Mac address Table Manager(519) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) CAPWAP Data Plane Mgr(522) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) DTLS Data Plane Mgr(523) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Wireless Client Database(524) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Wireless L2 Multicast(525) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IPROUTING NSF RF client(20) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) DHCPD(101) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) SNMP RF Client(34) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) AAA(69) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) History RF Client(35) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) ARP(57) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) FH_RF_Event_Detector_stub(50) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Smart Install RF(1112) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Spanning-Tree Protocol(503) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Switch Backup Interface client(507) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) DHCP Snooping(105) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Call-Home RF(1510) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Config Verify RF client(94) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Platform Inline Power(10005) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Platform Manager SPI(10008) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Inline Power rf client(505) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Igmp Snooping(506) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Port Security(508) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Switch IP Device Tracking(509) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) SISF table(515) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) CRYPTO RSA(130) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IP Admission RF Client(400) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) ISSU Test Client(4005) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) LAN-Switch PAgP/LACP(510) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IOS Config SHELL(4022) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IOS Config ARCHIVE(4020) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) IOS Config ROLLBACK(4021) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) PASSWD RF Client(4058) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) MLD Snooping(521) op=1 rc=0
00:06:32 RF_STATUS_PEER_COMM(401) Online Diag HA(4056) op=1 rc=0
00:06:32 RF_EVENT_SLAVE_STATUS_DONE(523) Slave(12126) op=401 rc=1
00:06:32 RF_STATUS_PEER_COMM(401) Last Slave(65000) op=1 rc=0
00:06:32  my state = ACTIVE(13) *peer state = UNKNOWN(0)
00:06:32  my state = ACTIVE(13) *peer state = STANDBY COLD(4)
00:06:32 RF_EVENT_PEER_COMM_DONE(517) First Slave(0) op=0 rc=0
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) First Slave(0) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(6290) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(6292) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(6311) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(12121) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(12122) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Slave(12126) op=0 rc=23
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) EICORE HA Client(20002) op=0 rc=11
00:06:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) SNMP SA HA Client(20010) op=0 rc=11
00:06:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Installer HA Client(20007) op=0 rc=11
00:06:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Redundancy Mode RF(29) op=0 rc=0
00:06:32 RF_EVENT_CLIENT_PROGRESSION(503) Redundancy Mode RF(29) op=30 rc=0
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_CAPWAP(24100) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Table Manager Client(24001) op=0 rc=11
00:06:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM RRM HA(24101) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM QOS HA(24103) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_MOBILITY(24105) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_DOT1X(24106) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_APFROGUE(24107) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_CIDS(24110) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_NETFLOW(24111) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) WCM_MCAST(24112) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) wcm_comet(24120) op=0 rc=11
00:06:32 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:06:32 RF_EVENT_PEER_PROG_DONE(506) Redundancy Mode RF(29) op=350 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) IfIndex(139) op=0 rc=0
00:06:32 RF_EVENT_CLIENT_PROGRESSION(503) IfIndex(139) op=30 rc=0
00:06:32 RF_EVENT_PEER_PROG_DONE(506) IfIndex(139) op=350 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Persistent Variable(3300) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) CHKPT RF(25) op=0 rc=0
00:06:32 RF_EVENT_CLIENT_PROGRESSION(503) CHKPT RF(25) op=30 rc=0
00:06:32 RF_EVENT_PEER_PROG_DONE(506) CHKPT RF(25) op=350 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) IIF-shim(20005) op=0 rc=0
00:06:32 RF_EVENT_CLIENT_PROGRESSION(503) IIF-shim(20005) op=30 rc=0
00:06:32 RF_EVENT_PEER_PROG_DONE(506) IIF-shim(20005) op=350 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) QEMU Platform RF(10001) op=0 rc=11
00:06:32 RF_PROG_ISSU_NEGOTIATION(350) Event Manager(77) op=0 rc=0
00:06:32 RF_EVENT_CLIENT_PROGRESSION(503) Event Manager(77) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) Event Manager(77) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) Network RF Client(22) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) Network RF Client(22) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) Network RF Client(22) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) Tableid HA(75) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) LAN-Switch VTP VLAN(501) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) XDR RRP RF Client(71) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) CEF RRP RF Client(24) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) FFM RF(2900) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) RFS RF(520) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) RFS RF(520) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) RFS RF(520) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) Auth Mgr(210) op=0 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) Config Sync RF client(5) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) Config Sync RF client(5) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) Config Sync RF client(5) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) NG3K OIR Rf client(10002) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) NG3K OIR Rf client(10002) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) NG3K OIR Rf client(10002) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) NG3K SES Rf client(10003) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) NG3K SES Rf client(10003) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) NG3K SES Rf client(10003) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) NGWC FEC Rf client(10007) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) NGWC FEC Rf client(10007) op=30 rc=0
00:06:33 RF_EVENT_PEER_PROG_DONE(506) NGWC FEC Rf client(10007) op=350 rc=11
00:06:33 RF_PROG_ISSU_NEGOTIATION(350) LAN-Switch Port Manager(502) op=0 rc=0
00:06:33 RF_EVENT_CLIENT_PROGRESSION(503) LAN-Switch Port Manager(502) op=30 rc=0
00:06:35 RF_EVENT_PEER_PROG_DONE(506) LAN-Switch Port Manager(502) op=350 rc=11
00:06:35 RF_PROG_ISSU_NEGOTIATION(350) Mac address Table Manager(519) op=0 rc=0
00:06:35 RF_EVENT_CLIENT_PROGRESSION(503) Mac address Table Manager(519) op=30 rc=0
00:06:36 RF_EVENT_PEER_PROG_DONE(506) Mac address Table Manager(519) op=350 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) DTLS Data Plane Mgr(523) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) Wireless Client Database(524) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) Wireless L2 Multicast(525) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) LLDP(208) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) IPROUTING NSF RF client(20) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) DHCPD(101) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) SNMP RF Client(34) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) AAA(69) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) History RF Client(35) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) SNMP HA RF Client(54) op=0 rc=11
00:06:36 RF_PROG_ISSU_NEGOTIATION(350) ARP(57) op=0 rc=0
00:06:36 RF_EVENT_CLIENT_PROGRESSION(503) ARP(57) op=30 rc=0
00:06:37 RF_EVENT_PEER_PROG_DONE(506) ARP(57) op=350 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Smart Install RF(1112) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Spanning-Tree Protocol(503) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Switch Backup Interface client(507) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) DHCP Snooping(105) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Call-Home RF(1510) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Config Verify RF client(94) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Platform Inline Power(10005) op=0 rc=0
00:06:37 RF_EVENT_CLIENT_PROGRESSION(503) Platform Inline Power(10005) op=30 rc=0
00:06:37 RF_EVENT_PEER_PROG_DONE(506) Platform Inline Power(10005) op=350 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Platform Manager SPI(10008) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Inline Power rf client(505) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Igmp Snooping(506) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Port Security(508) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Switch IP Device Tracking(509) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) SISF table(515) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) CRYPTO RSA(130) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) IP Admission RF Client(400) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) ISSU Test Client(4005) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Network RF 2 Client(93) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) IOS Config SHELL(4022) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) IOS Config ARCHIVE(4020) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) IOS Config ROLLBACK(4021) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) PASSWD RF Client(4058) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) MLD Snooping(521) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Online Diag HA(4056) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) NG3K CFG MGR(10004) op=0 rc=11
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:06:37 RF_PROG_ISSU_NEGOTIATION(350) Last Slave(65000) op=0 rc=0
00:06:37 RF_EVENT_CLIENT_PROGRESSION(503) Last Slave(65000) op=30 rc=0
00:06:37 RF_EVENT_CONTINUE_PROGRESSION(504) op=0 rc=0
00:06:37 RF_PROG_PLATFORM_SYNC(300) First Slave(0) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(6290) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(6292) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(6311) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(12121) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(12122) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) Slave(12126) op=0 rc=23
00:06:37 RF_PROG_PLATFORM_SYNC(300) EICORE HA Client(20002) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) SNMP SA HA Client(20010) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_CAPWAP(24100) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM RRM HA(24101) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM QOS HA(24103) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_MOBILITY(24105) op=0 rc=11
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_DOT1X(24106) op=0 rc=11
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_APFROGUE(24107) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_CIDS(24110) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) Table Manager Client(24001) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_NETFLOW(24111) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) WCM_MCAST(24112) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) wcm_comet(24120) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) Redundancy Mode RF(29) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) IfIndex(139) op=0 rc=11
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) Persistent Variable(3300) op=0 rc=0
00:06:37 RF_PROG_PLATFORM_SYNC(300) Installer HA Client(20007) op=0 rc=11
00:06:37 RF_EVENT_CLIENT_PROGRESSION(503) Persistent Variable(3300) op=100 rc=0
00:06:37 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:06:37 RF_EVENT_PEER_PROG_DONE(506) Persistent Variable(3300) op=300 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) CHKPT RF(25) op=0 rc=11
00:06:37 RF_PROG_PLATFORM_SYNC(300) IIF-shim(20005) op=0 rc=0
00:06:37 RF_EVENT_CLIENT_PROGRESSION(503) IIF-shim(20005) op=100 rc=0
00:06:37 RF_EVENT_PEER_PROG_DONE(506) IIF-shim(20005) op=300 rc=11
00:06:38 RF_PROG_PLATFORM_SYNC(300) QEMU Platform RF(10001) op=0 rc=11
00:06:38 RF_PROG_PLATFORM_SYNC(300) Event Manager(77) op=0 rc=11
00:06:38 RF_PROG_PLATFORM_SYNC(300) Network RF Client(22) op=0 rc=11
00:06:38 RF_PROG_PLATFORM_SYNC(300) Tableid HA(75) op=0 rc=11
00:06:38 RF_PROG_PLATFORM_SYNC(300) LAN-Switch VTP VLAN(501) op=0 rc=0
00:06:38 RF_EVENT_CLIENT_PROGRESSION(503) LAN-Switch VTP VLAN(501) op=100 rc=0
00:06:39 RF_EVENT_PEER_PROG_DONE(506) LAN-Switch VTP VLAN(501) op=300 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) XDR RRP RF Client(71) op=0 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) CEF RRP RF Client(24) op=0 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) FFM RF(2900) op=0 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) RFS RF(520) op=0 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) Auth Mgr(210) op=0 rc=11
00:06:39 RF_PROG_PLATFORM_SYNC(300) Config Sync RF client(5) op=0 rc=0
00:06:39 RF_EVENT_CLIENT_PROGRESSION(503) Config Sync RF client(5) op=100 rc=0
00:06:40 RF_EVENT_PEER_PROG_DONE(506) Config Sync RF client(5) op=300 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) NG3K OIR Rf client(10002) op=0 rc=0
00:06:40 RF_EVENT_CLIENT_PROGRESSION(503) NG3K OIR Rf client(10002) op=100 rc=0
00:06:40 RF_EVENT_PEER_PROG_DONE(506) NG3K OIR Rf client(10002) op=300 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) NG3K SES Rf client(10003) op=0 rc=0
00:06:40 RF_EVENT_CLIENT_PROGRESSION(503) NG3K SES Rf client(10003) op=100 rc=0
00:06:40 RF_EVENT_PEER_PROG_DONE(506) NG3K SES Rf client(10003) op=300 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) NGWC FEC Rf client(10007) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) LAN-Switch Port Manager(502) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) Mac address Table Manager(519) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) DTLS Data Plane Mgr(523) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) Wireless Client Database(524) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) Wireless L2 Multicast(525) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) LLDP(208) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) IPROUTING NSF RF client(20) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) DHCPD(101) op=0 rc=11
00:06:40 RF_PROG_PLATFORM_SYNC(300) SNMP RF Client(34) op=0 rc=0
00:06:40 RF_EVENT_CLIENT_PROGRESSION(503) SNMP RF Client(34) op=100 rc=0
00:06:43 RF_EVENT_PEER_PROG_DONE(506) SNMP RF Client(34) op=300 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) AAA(69) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) History RF Client(35) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) SNMP HA RF Client(54) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) ARP(57) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Smart Install RF(1112) op=0 rc=0
00:06:43 RF_EVENT_CLIENT_PROGRESSION(503) Smart Install RF(1112) op=100 rc=0
00:06:43 RF_EVENT_PEER_PROG_DONE(506) Smart Install RF(1112) op=300 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Spanning-Tree Protocol(503) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Switch Backup Interface client(507) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) DHCP Snooping(105) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Call-Home RF(1510) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Config Verify RF client(94) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Platform Inline Power(10005) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Platform Manager SPI(10008) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Inline Power rf client(505) op=0 rc=0
00:06:43 RF_EVENT_CLIENT_PROGRESSION(503) Inline Power rf client(505) op=100 rc=0
00:06:43 RF_EVENT_PEER_PROG_DONE(506) Inline Power rf client(505) op=300 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Igmp Snooping(506) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Port Security(508) op=0 rc=0
00:06:43 RF_EVENT_CLIENT_PROGRESSION(503) Port Security(508) op=100 rc=0
00:06:43 RF_EVENT_PEER_PROG_DONE(506) Port Security(508) op=300 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Switch IP Device Tracking(509) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) SISF table(515) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) CRYPTO RSA(130) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) IP Admission RF Client(400) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) ISSU Test Client(4005) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Network RF 2 Client(93) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) IOS Config SHELL(4022) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) IOS Config ARCHIVE(4020) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) IOS Config ROLLBACK(4021) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) PASSWD RF Client(4058) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) MLD Snooping(521) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Online Diag HA(4056) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) NG3K CFG MGR(10004) op=0 rc=11
00:06:43 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:06:43 RF_PROG_PLATFORM_SYNC(300) Last Slave(65000) op=0 rc=0
00:06:43 RF_EVENT_CLIENT_PROGRESSION(503) Last Slave(65000) op=100 rc=0
00:07:01 RF_EVENT_START_PROGRESSION(501) op=0 rc=0
00:07:01 RF_EVENT_STANDBY_PROGRESSION(502) First Slave(0) op=35 rc=0
00:07:01  my state = ACTIVE(13) *peer state = STANDBY_ISSU_NEGOTIATION_LATE(35)
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) First Slave(0) op=0 rc=0
00:07:01 RF_EVENT_CLIENT_PROGRESSION(503) First Slave(0) op=35 rc=0
00:07:01 RF_EVENT_FIRST_CLIENT_ACK(516) First Slave(0) op=0 rc=0
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(6290) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(6292) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(6311) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(12121) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(12122) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Slave(12126) op=0 rc=23
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Installer HA Client(20007) op=0 rc=11
00:07:01 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) EICORE HA Client(20002) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Table Manager Client(24001) op=0 rc=11
00:07:01 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:07:01 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Redundancy Mode RF(29) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IfIndex(139) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Persistent Variable(3300) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) CHKPT RF(25) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IIF-shim(20005) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) QEMU Platform RF(10001) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_CAPWAP(24100) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Event Manager(77) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Network RF Client(22) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM RRM HA(24101) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Tableid HA(75) op=0 rc=0
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM QOS HA(24103) op=0 rc=11
00:07:01 RF_EVENT_CLIENT_PROGRESSION(503) Tableid HA(75) op=35 rc=0
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_MOBILITY(24105) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_DOT1X(24106) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_APFROGUE(24107) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_CIDS(24110) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_NETFLOW(24111) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) WCM_MCAST(24112) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) wcm_comet(24120) op=0 rc=11
00:07:01 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) SNMP SA HA Client(20010) op=0 rc=11
00:07:01 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:07:01 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:07:02 RF_EVENT_PEER_PROG_DONE(506) Tableid HA(75) op=107 rc=11
00:07:02 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) LAN-Switch VTP VLAN(501) op=0 rc=11
00:07:02 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) XDR RRP RF Client(71) op=0 rc=0
00:07:02 RF_EVENT_CLIENT_PROGRESSION(503) XDR RRP RF Client(71) op=35 rc=0
00:07:02 RF_EVENT_PEER_PROG_DONE(506) XDR RRP RF Client(71) op=107 rc=0
00:07:02 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) CEF RRP RF Client(24) op=0 rc=0
00:07:02 RF_EVENT_CLIENT_PROGRESSION(503) CEF RRP RF Client(24) op=35 rc=0
00:07:03 RF_EVENT_PEER_PROG_DONE(506) CEF RRP RF Client(24) op=107 rc=0
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) FFM RF(2900) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) RFS RF(520) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Auth Mgr(210) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Config Sync RF client(5) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) NG3K OIR Rf client(10002) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) NG3K SES Rf client(10003) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) NGWC FEC Rf client(10007) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) LAN-Switch Port Manager(502) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Mac address Table Manager(519) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) DTLS Data Plane Mgr(523) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Wireless Client Database(524) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Wireless L2 Multicast(525) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) LLDP(208) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IPROUTING NSF RF client(20) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) DHCPD(101) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) SNMP RF Client(34) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) AAA(69) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) History RF Client(35) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) SNMP HA RF Client(54) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) ARP(57) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Smart Install RF(1112) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Spanning-Tree Protocol(503) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Switch Backup Interface client(507) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) DHCP Snooping(105) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Call-Home RF(1510) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Config Verify RF client(94) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Platform Inline Power(10005) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Platform Manager SPI(10008) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Inline Power rf client(505) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Igmp Snooping(506) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Port Security(508) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Switch IP Device Tracking(509) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) SISF table(515) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) CRYPTO RSA(130) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IP Admission RF Client(400) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) ISSU Test Client(4005) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Network RF 2 Client(93) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IOS Config SHELL(4022) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IOS Config ARCHIVE(4020) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) IOS Config ROLLBACK(4021) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) PASSWD RF Client(4058) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) MLD Snooping(521) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Online Diag HA(4056) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) NG3K CFG MGR(10004) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:07:03 RF_PROG_STANDBY_ISSU_NEGOTIATION_LATE(107) Last Slave(65000) op=0 rc=0
00:07:03 RF_EVENT_CLIENT_PROGRESSION(503) Last Slave(65000) op=35 rc=0
00:07:03 RF_EVENT_CONTINUE_PROGRESSION(504) op=0 rc=0
00:07:03 RF_EVENT_STANDBY_PROGRESSION(502) First Slave(0) op=5 rc=0
00:07:03  my state = ACTIVE(13) *peer state = STANDBY COLD-CONFIG(5)
00:07:03 RF_PROG_STANDBY_CONFIG(102) First Slave(0) op=0 rc=0
00:07:03 RF_EVENT_CLIENT_PROGRESSION(503) First Slave(0) op=5 rc=0
00:07:03 RF_EVENT_FIRST_CLIENT_ACK(516) First Slave(0) op=0 rc=0
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(6290) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(6292) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(6311) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(12121) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(12122) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Slave(12126) op=0 rc=23
00:07:03 RF_PROG_STANDBY_CONFIG(102) Installer HA Client(20007) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Table Manager Client(24001) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) SNMP SA HA Client(20010) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Redundancy Mode RF(29) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) IfIndex(139) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Persistent Variable(3300) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) CHKPT RF(25) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) IIF-shim(20005) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) QEMU Platform RF(10001) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Event Manager(77) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Network RF Client(22) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) Tableid HA(75) op=0 rc=0
00:07:03 RF_EVENT_CLIENT_PROGRESSION(503) Tableid HA(75) op=5 rc=0
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_CAPWAP(24100) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM RRM HA(24101) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM QOS HA(24103) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) EICORE HA Client(20002) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_MOBILITY(24105) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_DOT1X(24106) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_APFROGUE(24107) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_CIDS(24110) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_NETFLOW(24111) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) WCM_MCAST(24112) op=0 rc=11
00:07:03 RF_PROG_STANDBY_CONFIG(102) wcm_comet(24120) op=0 rc=11
00:07:03 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:07:04 RF_EVENT_PEER_PROG_DONE(506) Tableid HA(75) op=102 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) LAN-Switch VTP VLAN(501) op=0 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) XDR RRP RF Client(71) op=0 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) CEF RRP RF Client(24) op=0 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) FFM RF(2900) op=0 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) RFS RF(520) op=0 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) Auth Mgr(210) op=0 rc=0
00:07:04 RF_EVENT_CLIENT_PROGRESSION(503) Auth Mgr(210) op=5 rc=0
00:07:04 RF_EVENT_PEER_PROG_DONE(506) Auth Mgr(210) op=102 rc=11
00:07:04 RF_PROG_STANDBY_CONFIG(102) Config Sync RF client(5) op=0 rc=0
00:07:04 RF_EVENT_CLIENT_PROGRESSION(503) Config Sync RF client(5) op=5 rc=0
00:07:21 RF_EVENT_PEER_PROG_DONE(506) Config Sync RF client(5) op=102 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) NG3K OIR Rf client(10002) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) NG3K SES Rf client(10003) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) NGWC FEC Rf client(10007) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) LAN-Switch Port Manager(502) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) Mac address Table Manager(519) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) DTLS Data Plane Mgr(523) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) Wireless Client Database(524) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) Wireless L2 Multicast(525) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) LLDP(208) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) IPROUTING NSF RF client(20) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) DHCPD(101) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) SNMP RF Client(34) op=0 rc=11
00:07:21 RF_PROG_STANDBY_CONFIG(102) AAA(69) op=0 rc=0
00:07:21 RF_EVENT_CLIENT_PROGRESSION(503) AAA(69) op=5 rc=0
00:07:22 RF_EVENT_PEER_PROG_DONE(506) AAA(69) op=102 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) History RF Client(35) op=0 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) SNMP HA RF Client(54) op=0 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) ARP(57) op=0 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) Smart Install RF(1112) op=0 rc=11
00:07:22 RF_PROG_STANDBY_CONFIG(102) Spanning-Tree Protocol(503) op=0 rc=0
00:07:22 RF_EVENT_CLIENT_PROGRESSION(503) Spanning-Tree Protocol(503) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) Spanning-Tree Protocol(503) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Switch Backup Interface client(507) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) DHCP Snooping(105) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) DHCP Snooping(105) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) DHCP Snooping(105) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Call-Home RF(1510) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) Call-Home RF(1510) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) Call-Home RF(1510) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Config Verify RF client(94) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Platform Inline Power(10005) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Platform Manager SPI(10008) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Inline Power rf client(505) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Igmp Snooping(506) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) Igmp Snooping(506) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) Igmp Snooping(506) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Port Security(508) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Switch IP Device Tracking(509) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) Switch IP Device Tracking(509) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) Switch IP Device Tracking(509) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) SISF table(515) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) SISF table(515) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) SISF table(515) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) CRYPTO RSA(130) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) IP Admission RF Client(400) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) IP Admission RF Client(400) op=5 rc=0
00:07:25 RF_EVENT_PEER_PROG_DONE(506) IP Admission RF Client(400) op=102 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) ISSU Test Client(4005) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) Network RF 2 Client(93) op=0 rc=11
00:07:25 RF_PROG_STANDBY_CONFIG(102) LAN-Switch PAgP/LACP(510) op=0 rc=0
00:07:25 RF_EVENT_CLIENT_PROGRESSION(503) LAN-Switch PAgP/LACP(510) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) LAN-Switch PAgP/LACP(510) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) IOS Config SHELL(4022) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) IOS Config SHELL(4022) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) IOS Config SHELL(4022) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) IOS Config ARCHIVE(4020) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) IOS Config ARCHIVE(4020) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) IOS Config ARCHIVE(4020) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) IOS Config ROLLBACK(4021) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) IOS Config ROLLBACK(4021) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) IOS Config ROLLBACK(4021) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) PASSWD RF Client(4058) op=0 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) MLD Snooping(521) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) MLD Snooping(521) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) MLD Snooping(521) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) Online Diag HA(4056) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) Online Diag HA(4056) op=5 rc=0
00:07:26 RF_EVENT_PEER_PROG_DONE(506) Online Diag HA(4056) op=102 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) NG3K CFG MGR(10004) op=0 rc=11
00:07:26 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:07:26 RF_PROG_STANDBY_CONFIG(102) Last Slave(65000) op=0 rc=0
00:07:26 RF_EVENT_CLIENT_PROGRESSION(503) Last Slave(65000) op=5 rc=0
00:07:47 RF_EVENT_CONTINUE_PROGRESSION(504) op=0 rc=0
00:07:47 RF_EVENT_STANDBY_PROGRESSION(502) First Slave(0) op=6 rc=0
00:07:47  my state = ACTIVE(13) *peer state = STANDBY COLD-FILESYS(6)
00:07:47 RF_PROG_STANDBY_FILESYS(103) First Slave(0) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) First Slave(0) op=6 rc=0
00:07:47 RF_EVENT_FIRST_CLIENT_ACK(516) First Slave(0) op=0 rc=0
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(6290) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(6292) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(6311) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(12121) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(12122) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Slave(12126) op=0 rc=23
00:07:47 RF_PROG_STANDBY_FILESYS(103) Installer HA Client(20007) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Table Manager Client(24001) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Redundancy Mode RF(29) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IfIndex(139) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Persistent Variable(3300) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) CHKPT RF(25) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IIF-shim(20005) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) QEMU Platform RF(10001) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Event Manager(77) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Network RF Client(22) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Tableid HA(75) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) LAN-Switch VTP VLAN(501) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) XDR RRP RF Client(71) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) CEF RRP RF Client(24) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) FFM RF(2900) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) RFS RF(520) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Auth Mgr(210) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Config Sync RF client(5) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) NG3K OIR Rf client(10002) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) EICORE HA Client(20002) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) SNMP SA HA Client(20010) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_CAPWAP(24100) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM RRM HA(24101) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM QOS HA(24103) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_MOBILITY(24105) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_DOT1X(24106) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_APFROGUE(24107) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_CIDS(24110) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_NETFLOW(24111) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) WCM_MCAST(24112) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) wcm_comet(24120) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) NG3K SES Rf client(10003) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) NGWC FEC Rf client(10007) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) LAN-Switch Port Manager(502) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Mac address Table Manager(519) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) DTLS Data Plane Mgr(523) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Wireless Client Database(524) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Wireless L2 Multicast(525) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) LLDP(208) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IPROUTING NSF RF client(20) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) DHCPD(101) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) SNMP RF Client(34) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) AAA(69) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) History RF Client(35) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) SNMP HA RF Client(54) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) ARP(57) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Smart Install RF(1112) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Spanning-Tree Protocol(503) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Switch Backup Interface client(507) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) DHCP Snooping(105) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Call-Home RF(1510) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Config Verify RF client(94) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Platform Inline Power(10005) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Platform Manager SPI(10008) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Inline Power rf client(505) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Igmp Snooping(506) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Port Security(508) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Switch IP Device Tracking(509) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) SISF table(515) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) CRYPTO RSA(130) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IP Admission RF Client(400) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) ISSU Test Client(4005) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Network RF 2 Client(93) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IOS Config SHELL(4022) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IOS Config ARCHIVE(4020) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) IOS Config ROLLBACK(4021) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) PASSWD RF Client(4058) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) MLD Snooping(521) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Online Diag HA(4056) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) NG3K CFG MGR(10004) op=0 rc=11
00:07:47 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:07:47 RF_PROG_STANDBY_FILESYS(103) Last Slave(65000) op=0 rc=11
00:07:47 RF_EVENT_STANDBY_PROGRESSION(502) First Slave(0) op=7 rc=0
00:07:47  my state = ACTIVE(13) *peer state = STANDBY COLD-BULK(7)
00:07:47 RF_PROG_STANDBY_BULK(104) First Slave(0) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) First Slave(0) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(6290) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(6292) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(6311) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(12121) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(12122) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) Slave(12126) op=0 rc=23
00:07:47 RF_PROG_STANDBY_BULK(104) SNMP SA HA Client(20010) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) SNMP SA HA Client(20010) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) Table Manager Client(24001) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) Table Manager Client(24001) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_CAPWAP(24100) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_CAPWAP(24100) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) EICORE HA Client(20002) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) EICORE HA Client(20002) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) Installer HA Client(20007) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) Installer HA Client(20007) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) SNMP SA HA Client(20010) op=104 rc=11
00:07:47 RF_EVENT_PEER_PROG_DONE(506) Installer HA Client(20007) op=104 rc=11
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_CAPWAP(24100) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM RRM HA(24101) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM RRM HA(24101) op=7 rc=0
00:07:47 RF_PROG_STANDBY_BULK(104) Redundancy Mode RF(29) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) IfIndex(139) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) Persistent Variable(3300) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) CHKPT RF(25) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) IIF-shim(20005) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) QEMU Platform RF(10001) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) Event Manager(77) op=0 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) Network RF Client(22) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) Network RF Client(22) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) Table Manager Client(24001) op=104 rc=11
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM RRM HA(24101) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM QOS HA(24103) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM QOS HA(24103) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM QOS HA(24103) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_MOBILITY(24105) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_MOBILITY(24105) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_MOBILITY(24105) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_DOT1X(24106) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_DOT1X(24106) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_DOT1X(24106) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_APFROGUE(24107) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_APFROGUE(24107) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_APFROGUE(24107) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_CIDS(24110) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_CIDS(24110) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_CIDS(24110) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_NETFLOW(24111) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_NETFLOW(24111) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_NETFLOW(24111) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) WCM_MCAST(24112) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) WCM_MCAST(24112) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) WCM_MCAST(24112) op=104 rc=11
00:07:47 RF_PROG_STANDBY_BULK(104) wcm_comet(24120) op=0 rc=0
00:07:47 RF_EVENT_CLIENT_PROGRESSION(503) wcm_comet(24120) op=7 rc=0
00:07:47 RF_EVENT_PEER_PROG_DONE(506) wcm_comet(24120) op=104 rc=11
00:07:48 RF_EVENT_PEER_PROG_DONE(506) EICORE HA Client(20002) op=104 rc=11
00:07:48 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:07:48 RF_EVENT_PEER_PROG_DONE(506) Network RF Client(22) op=104 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) Tableid HA(75) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) LAN-Switch VTP VLAN(501) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) XDR RRP RF Client(71) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) CEF RRP RF Client(24) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) FFM RF(2900) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) RFS RF(520) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) Auth Mgr(210) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) Config Sync RF client(5) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) NG3K OIR Rf client(10002) op=0 rc=0
00:07:48 RF_EVENT_CLIENT_PROGRESSION(503) NG3K OIR Rf client(10002) op=7 rc=0
00:07:48 RF_EVENT_PEER_PROG_DONE(506) NG3K OIR Rf client(10002) op=104 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) NG3K SES Rf client(10003) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) NGWC FEC Rf client(10007) op=0 rc=0
00:07:48 RF_EVENT_CLIENT_PROGRESSION(503) NGWC FEC Rf client(10007) op=7 rc=0
00:07:48 RF_EVENT_PEER_PROG_DONE(506) NGWC FEC Rf client(10007) op=104 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) LAN-Switch Port Manager(502) op=0 rc=11
00:07:48 RF_PROG_STANDBY_BULK(104) Mac address Table Manager(519) op=0 rc=0
00:07:48 RF_EVENT_CLIENT_PROGRESSION(503) Mac address Table Manager(519) op=7 rc=0
00:07:49 RF_EVENT_PEER_PROG_DONE(506) Mac address Table Manager(519) op=104 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) DTLS Data Plane Mgr(523) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) Wireless Client Database(524) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) Wireless L2 Multicast(525) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) LLDP(208) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) IPROUTING NSF RF client(20) op=0 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) DHCPD(101) op=0 rc=0
00:07:49 RF_EVENT_CLIENT_PROGRESSION(503) DHCPD(101) op=7 rc=0
00:07:49 RF_EVENT_PEER_PROG_DONE(506) DHCPD(101) op=104 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) SNMP RF Client(34) op=0 rc=0
00:07:49 RF_EVENT_CLIENT_PROGRESSION(503) SNMP RF Client(34) op=7 rc=0
00:07:49 RF_EVENT_PEER_PROG_DONE(506) SNMP RF Client(34) op=104 rc=11
00:07:49 RF_PROG_STANDBY_BULK(104) AAA(69) op=0 rc=0
00:07:49 RF_EVENT_CLIENT_PROGRESSION(503) AAA(69) op=7 rc=0
00:07:51 RF_EVENT_PEER_PROG_DONE(506) AAA(69) op=104 rc=0
00:07:51 RF_PROG_STANDBY_BULK(104) History RF Client(35) op=0 rc=11
00:07:51 RF_PROG_STANDBY_BULK(104) SNMP HA RF Client(54) op=0 rc=11
00:07:51 RF_PROG_STANDBY_BULK(104) ARP(57) op=0 rc=0
00:07:51 RF_EVENT_CLIENT_PROGRESSION(503) ARP(57) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) ARP(57) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Smart Install RF(1112) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Smart Install RF(1112) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Smart Install RF(1112) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Spanning-Tree Protocol(503) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Switch Backup Interface client(507) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) DHCP Snooping(105) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) DHCP Snooping(105) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) DHCP Snooping(105) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Call-Home RF(1510) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Call-Home RF(1510) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Call-Home RF(1510) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Config Verify RF client(94) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Platform Inline Power(10005) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Platform Inline Power(10005) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Platform Inline Power(10005) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Platform Manager SPI(10008) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Inline Power rf client(505) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Inline Power rf client(505) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Inline Power rf client(505) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Igmp Snooping(506) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Igmp Snooping(506) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Igmp Snooping(506) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Port Security(508) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Port Security(508) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Port Security(508) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Switch IP Device Tracking(509) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Switch IP Device Tracking(509) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Switch IP Device Tracking(509) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) SISF table(515) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) SISF table(515) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) SISF table(515) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) CRYPTO RSA(130) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) CRYPTO RSA(130) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) CRYPTO RSA(130) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) IP Admission RF Client(400) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) IP Admission RF Client(400) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) IP Admission RF Client(400) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) ISSU Test Client(4005) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Network RF 2 Client(93) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) IOS Config SHELL(4022) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) IOS Config ARCHIVE(4020) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) IOS Config ROLLBACK(4021) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) PASSWD RF Client(4058) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) MLD Snooping(521) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) MLD Snooping(521) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) MLD Snooping(521) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Online Diag HA(4056) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Online Diag HA(4056) op=7 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Online Diag HA(4056) op=104 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) NG3K CFG MGR(10004) op=0 rc=11
00:07:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12126) op=0 rc=11
00:07:52 RF_PROG_STANDBY_BULK(104) Last Slave(65000) op=0 rc=11
00:07:52 RF_EVENT_CONTINUE_PROGRESSION(504) op=0 rc=0
00:07:52 RF_EVENT_STANDBY_PROGRESSION(502) First Slave(0) op=8 rc=0
00:07:52  my state = ACTIVE(13) *peer state = STANDBY HOT(8)
00:07:52 RF_PROG_STANDBY_HOT(105) First Slave(0) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) First Slave(0) op=8 rc=0
00:07:52 RF_EVENT_FIRST_CLIENT_ACK(516) First Slave(0) op=0 rc=0
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(6290) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(6292) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(6311) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(12121) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(12122) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Slave(12126) op=0 rc=23
00:07:52 RF_PROG_STANDBY_HOT(105) Installer HA Client(20007) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Installer HA Client(20007) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Installer HA Client(20007) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Table Manager Client(24001) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) Table Manager Client(24001) op=8 rc=0
00:07:52 RF_PROG_STANDBY_HOT(105) EICORE HA Client(20002) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) EICORE HA Client(20002) op=8 rc=0
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_CAPWAP(24100) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_CAPWAP(24100) op=8 rc=0
00:07:52 RF_PROG_STANDBY_HOT(105) SNMP SA HA Client(20010) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) SNMP SA HA Client(20010) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) SNMP SA HA Client(20010) op=105 rc=11
00:07:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6290) op=0 rc=11
00:07:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6311) op=0 rc=11
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_CAPWAP(24100) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM RRM HA(24101) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM RRM HA(24101) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM RRM HA(24101) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM QOS HA(24103) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM QOS HA(24103) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM QOS HA(24103) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_MOBILITY(24105) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_MOBILITY(24105) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_MOBILITY(24105) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_DOT1X(24106) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_DOT1X(24106) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_DOT1X(24106) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_APFROGUE(24107) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_APFROGUE(24107) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_APFROGUE(24107) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_CIDS(24110) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_CIDS(24110) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_CIDS(24110) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_NETFLOW(24111) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_NETFLOW(24111) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_NETFLOW(24111) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) WCM_MCAST(24112) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) WCM_MCAST(24112) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) WCM_MCAST(24112) op=105 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) wcm_comet(24120) op=0 rc=0
00:07:52 RF_EVENT_CLIENT_PROGRESSION(503) wcm_comet(24120) op=8 rc=0
00:07:52 RF_EVENT_PEER_PROG_DONE(506) wcm_comet(24120) op=105 rc=11
00:07:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12121) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Redundancy Mode RF(29) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IfIndex(139) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Persistent Variable(3300) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) CHKPT RF(25) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IIF-shim(20005) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) QEMU Platform RF(10001) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Event Manager(77) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Network RF Client(22) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Tableid HA(75) op=0 rc=11
00:07:52 RF_EVENT_PEER_PROG_DONE(506) Table Manager Client(24001) op=105 rc=11
00:07:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(12122) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) LAN-Switch VTP VLAN(501) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) XDR RRP RF Client(71) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) CEF RRP RF Client(24) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) FFM RF(2900) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) RFS RF(520) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Auth Mgr(210) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Config Sync RF client(5) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) NG3K OIR Rf client(10002) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) NG3K SES Rf client(10003) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) NGWC FEC Rf client(10007) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) LAN-Switch Port Manager(502) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Mac address Table Manager(519) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) CAPWAP Data Plane Mgr(522) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) DTLS Data Plane Mgr(523) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Wireless Client Database(524) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Wireless L2 Multicast(525) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) LLDP(208) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IPROUTING NSF RF client(20) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) DHCPD(101) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) SNMP RF Client(34) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) AAA(69) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) History RF Client(35) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) SNMP HA RF Client(54) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) ARP(57) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) FH_RF_Event_Detector_stub(50) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Smart Install RF(1112) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Spanning-Tree Protocol(503) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Switch Backup Interface client(507) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) DHCP Snooping(105) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Call-Home RF(1510) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Config Verify RF client(94) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Platform Inline Power(10005) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Platform Manager SPI(10008) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Inline Power rf client(505) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Igmp Snooping(506) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Port Security(508) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Switch IP Device Tracking(509) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) SISF table(515) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) CRYPTO RSA(130) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IP Admission RF Client(400) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) ISSU Test Client(4005) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Network RF 2 Client(93) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) LAN-Switch PAgP/LACP(510) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) DATA DESCRIPTOR RF CLIENT(141) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IOS Config SHELL(4022) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IOS Config ARCHIVE(4020) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) IOS Config ROLLBACK(4021) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) PASSWD RF Client(4058) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) MLD Snooping(521) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) Online Diag HA(4056) op=0 rc=11
00:07:52 RF_PROG_STANDBY_HOT(105) NG3K CFG MGR(10004) op=0 rc=11
00:07:53 RF_EVENT_PEER_PROG_DONE(506) EICORE HA Client(20002) op=105 rc=11
00:07:53 RF_EVENT_SLAVE_PROG_DONE(522) Slave(6292) op=0 rc=11
00:07:53 RF_PROG_STANDBY_HOT(105) Last Slave(65000) op=0 rc=0
00:07:53 RF_EVENT_CLIENT_PROGRESSION(503) Last Slave(65000) op=8 rc=0
07:55:05 RF_EVENT_PEER_PROG_DONE(506) NG3K OIR Rf client(10002) op=104 rc=11
------------------ show redundancy states ------------------
         my state = 13 -ACTIVE
       peer state =  8 -STANDBY HOT
             Mode = Duplex
          Unit ID = 1
  Redundancy Mode (Operational) = SSO
   Redundancy Mode (Configured) = SSO
               Redundancy State = SSO
                      Manual Swact = enabled
   Communications = Up
     client count = 74
   client_notification_TMR = 360000 milliseconds
            keep_alive TMR = 9000 milliseconds
          keep_alive count = 1
      keep_alive threshold = 9
             RF debug mask = 0
------------------ show redundancy switchover history ------------------
------------------ show ipc nodes ------------------
There are 34 nodes in this IPC realm.
   ID       Type               Name                             Last   Last    Bundle Support   MTU
        Sent   Heard   Session/Seat
 1.900100   Local      SEAT-10900100                            0      0       off/off             1376
 0.10000    Local      IPC Master                               0      0       on/on              4096
 1.10000    Seat_to_Se IPC Master: -Zone#1                      0      0       on/on              1376
 1.900181   To-SERVER                                           0      0       on/off             1376
 1.1100E00  Seat_to_Se SPI MTS Seat                             16     16      on/off             1376
 1.900B00   Seat_to_Se SPI MTS Seat                             14     14      on/off             1376
 1.1900C00  Seat_to_Se SPI MTS Seat                             16     16      on/off             1376
 1.900182   To-SERVER                                           0      0       on/off             1376
 1.900183   To-SERVER                                           0      0       on/off             1376
 1.900184   To-SERVER                                           0      0       on/off             1376
 1.900185   To-SERVER                                           0      0       on/off             1376
 1.900186   To-SERVER                                           0      0       on/off             1376
 1.900187   To-SERVER                                           0      0       on/off             1376
 1.1100D00  Seat_to_Se SPI MTS Seat                             4      4       on/off             1376
 1.1900900  Seat_to_Se SPI MTS Seat                             4      4       on/off             1376
 1.901400   Seat_to_Se SPI MTS Seat                             2      2       on/off             1376
 1.900188   To-SERVER                                           0      0       on/off             1376
 1.1100C00  MTS        SEAT-11100c00                            3      3       on/off             1376
 1.900189   To-SERVER                                           0      0       on/off             1376
 1.90018A   To-SERVER                                           0      0       on/off             1376
 1.90018B   To-SERVER                                           0      0       on/off             1376
 1.1900B00  MTS        SEAT-11900b00                            3      3       on/off             1376
 1.90018C   To-SERVER                                           0      0       on/off             1376
 1.90018D   To-SERVER                                           0      0       on/off             1376
 1.90018E   To-SERVER                                           0      0       on/off             1376
 1.90018F   To-SERVER                                           0      0       on/off             1376
 1.1101100  Seat_to_Se SPI MTS Seat                             3      3       on/off             1376
 1.1901D00  Seat_to_Se SPI MTS Seat                             3      3       on/off             1376
 1.1101D00  MTS        SEAT-11101d00                            3      3       on/off             1376
 1.1101B00  MTS        SEAT-11101b00                            3      3       on/off             1376
 1.1901800  MTS        SEAT-11901800                            3      3       on/off             1376
 1.1902000  MTS        SEAT-11902000                            3      3       on/off             1376
 0.20000    Seat_to_Se Slave                                    200    5734    on/on              1376
 1.1100100  MTS        SEAT-11100100                            3      3       on/off             1376
------------------ show ipc ports ------------------
                             IPC ACTIVE PORT TABLE
There are 57 ports defined.
Port ID        Type       Name                    (current/peak/total)
   10000.1     unicast               IPC Master:Zone
   10000.2     unicast               IPC Master:Echo
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 27600
     rcv pending/peak/total       = 0/1/814043
     stateful_mode = 0     peer_port = 0,    peer_seat = 0
     seq-window size              = 128   number of messages in window = 0
     maximum out-of-seq received  = 0     maximum pending in window    = 0
     number of messages dropped   = 0     number of window resets      = 11
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/814043/0
   10000.3     unicast               IPC Master:Control
10900100.2     unicast               SEAT-10900100:Echo -Zone#1
10900100.3     unicast               SEAT-10900100:Control -Zone#1
10010000.3     unicast               IPC Master:Control -Zone#1
   10000.4     unicast               ERP Agent Port #0
10900100.4     multicast             SPI:10900100:2F5E
  port_index = 0  seat_id = 0x11100C00last sent = 0     last heard = 101
     rcv pending/peak/total       = 0/2/101
     number of messages dropped   = 0     number of window resets      = 0
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/101/0
  port_index = 1  seat_id = 0x11900B00last sent = 0     last heard = 100
     rcv pending/peak/total       = 0/2/100
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/100/0
  port_index = 2  seat_id = 0x11100E00last sent = 0     last heard = 2784
     rcv pending/peak/total       = 0/119/11794719
     maximum out-of-seq received  = 0     maximum pending in window    = 1
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/11794719/0
  port_index = 3  seat_id = 0x11900C00last sent = 0     last heard = 43208
     rcv pending/peak/total       = 0/154/11373308
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/11373308/0
  port_index = 4  seat_id = 0x11900900last sent = 0     last heard = 40562
     rcv pending/peak/total       = 0/44/23043698
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/23043698/0
  port_index = 5  seat_id = 0x11100D00last sent = 0     last heard = 57967
     rcv pending/peak/total       = 0/48/22536815
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/22536815/0
  port_index = 6  seat_id = 0x11101100last sent = 0     last heard = 17456
     rcv pending/peak/total       = 0/3/270875
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/270875/0
  port_index = 7  seat_id = 0x11901D00last sent = 0     last heard = 17450
     rcv pending/peak/total       = 0/3/270872
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/270872/0
  port_index = 8  seat_id = 0x11101D00last sent = 0     last heard = 1
     rcv pending/peak/total       = 0/1/1
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1/0
  port_index = 9  seat_id = 0x11101B00last sent = 0     last heard = 4
     rcv pending/peak/total       = 0/1/4
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/4/0
  port_index = 10 seat_id = 0x11901800last sent = 0     last heard = 1
  port_index = 11 seat_id = 0x11902000last sent = 0     last heard = 2
     rcv pending/peak/total       = 0/1/2
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/2/0
  port_index = 12 seat_id = 0x11100100last sent = 0     last heard = 25
     rcv pending/peak/total       = 0/6/25
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/25/0
   10000.5     unicast               ERP Agent Port #1
   10000.6     unicast               Master : TTY Server Port
   10000.7     unicast               RTTYEnh Master Port
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 0
     rcv pending/peak/total       = 0/0/0
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/0/0
   10000.8     unicast               Primary RFS Server Port
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 11
     rcv pending/peak/total       = 0/1/11
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/11/0
   10000.9     unicast               Primary Old RFS Server Port
   10000.A     unicast               IPC-Apps:Active
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 10
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/10/0
   10000.B     unicast               RF : Active
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 19
     rcv pending/peak/total       = 0/2/19
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/19/0
   10000.C     unicast               Prst Vbl IPC: Active Port
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 14
     rcv pending/peak/total       = 0/2/14
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/14/0
   10000.D     unicast               RED MODE: Active Port
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 6
     rcv pending/peak/total       = 0/1/6
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/6/0
   10000.E     unicast               ifindex_sync_active_port
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 12
     rcv pending/peak/total       = 0/2/12
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/12/0
   10000.F     unicast               CF : Active
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 1164
     rcv pending/peak/total       = 0/9/1164
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/1164/0
   10000.10    unicast               Config Sync ISSU nego active
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 40
     rcv pending/peak/total       = 0/2/40
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/40/0
   10000.11    unicast               ISSU TEST::same port 1 0
   10000.12    unicast               ISSU TEST::shared msg port 1 0
   10000.13    unicast               ISSU TEST::same port 1 1
   10000.14    unicast               ISSU TEST::shared msg port 1 1
   10000.15    unicast               ISSU TEST::shared nego port 1 0
   10000.16    unicast               FIB Master: DFS.process_level.msgs
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 244
     rcv pending/peak/total       = 0/10/244
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/244/0
   10000.17    unicast               FIB Master: DFS.interrupt.msgs
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 14011
     rcv pending/peak/total       = 0/1/8140475
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/8140475/0
   10000.18    unicast               OBFL Master Port
   20000.3     unicast               Slave IPC:Control
   20000.2     unicast               Slave IPC:Echo
   20000.5     unicast               ERP Agent Port #2
   20000.14    unicast               RTTYEnh Client Port 00020000
   20000.7     unicast               Slave : TTY Client Port
   20000.15    unicast               issu:rfs:Secondary RFS Server Port
   20000.8     unicast               Secondary RFS Server Port
   20000.9     unicast               Secondary Old RFS Server Port
   20000.16    unicast               Config Sync ISSU nego standby
   20000.17    unicast               Prst Vbl IPC: Standby Port
   20000.A     unicast               Secondary Services Port
   20000.B     unicast               Standby Cfgsync Port
   20000.C     unicast               IPC-Apps:Standby
   20000.D     unicast               RF : Standby
   20000.E     unicast               ifindex_sync_standby_port
   20000.F     unicast               ISSU TEST::same port 0 0
   20000.11    unicast               ISSU TEST::same port 0 1
   20000.10    unicast               ISSU TEST::shared msg port 0 0
   20000.12    unicast               ISSU TEST::shared msg port 0 1
   20000.13    unicast               ISSU TEST::shared nego port 0 0
   20000.18    unicast               RED MODE: Standby Port
   20000.19    unicast               CF : Standby
   10000.19    unicast               issu:rfs:65536
  port_index = 0  seat_id = 0x20000   last sent = 0     last heard = 118
     rcv pending/peak/total       = 0/2/118
     rcv bundling related msgs bdl/sub/nonbdl/err = 0/0/118/0
   20000.1B    unicast               OBFL Slave Port 20000
   20000.1C    unicast               Remote TTY Test 00020000
   20000.1D    unicast               Slot 2: DFS.control.IL
   20000.1E    unicast               Slot 2: FAST.control.RIL
   20000.1F    unicast               Slot 2: DFS.control.PL
   20000.20    unicast               issu:rfs:131072
RPC packets: current/peak/total
                                                            0/3/136667
                            IPC STANDBY PORT TABLE
There are 0 ports defined.
                                                            0/3/136667
------------------ show ipc queue ------------------
There are 5 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ[0].
There are 0 IPC messages currently on the IPC inboundQ[1].
There are 0 IPC messages currently on the RX controller inboundQ.
There are 0 IPC messages currently on the TX controller inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         56
Message cache size                            :       6000
Maximum message cache usage                   :       6000
0  times message cache crossed       9000 [max]
Emergency messages currently in use           :          0
There are 34 messages currently reserved for reply msg.
Cache low watermark           [default/new]: [100/100]
         No of low watermark reached           :         0
         Total get cache after low watermark   :         0
         No of times zero cache reached        :         0
         No of times one cache added           :         0
         No of times cache chunk added         :         0
         Max no of get cache between wake2grow :         0
IPC Retransmission Table:
Source                         Destination                    Size  Tries  Seq  Msg
10900100.0     SEAT-10900100   11100D00.4     Unknown         805   0      62450 0x32F7CEEC
10900100.0     SEAT-10900100   11100D00.4     Unknown         805   0      62451 0x32F6A63C
10900100.0     SEAT-10900100   11100D00.4     Unknown         151   0      62452 0x330495CC
10900100.0     SEAT-10900100   11900900.4     Unknown         151   0      6589 0x33050798
   10000.0     IPC Master         20000.19    CF : Standby    116   0      28273 0x33013928
------------------ show ipc status ------------------
                            IPC System Status
 Time last IPC stat cleared all zones : 00:00:00
 This processor is the IPC master server in zone 0 (default).
 Do not drop output of IPC frames for test purposes.
 6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
 Total Frames                                        168105763   320738936
 Total from Local Ports                               78383346   275461185
 Total Protocol Control Frames                             222          85
 Total Frames Dropped                                     1846           0
                             Service Usage
 Total via Unreliable Connection-Less Service                4           0
 Total via Unreliable Sequenced Connection-Less Svc          0           0
 Total via Reliable Connection-Oriented Service       90209660   261299897
 Total Messages via Fragmentation                     10969364      958080
 Total Fragments                                      22795465     6668384
 Total Internal IPC Messages                               179           0
 Total Messages Flushed                                      0           0
                      IPC Protocol Version 0
 Total Acknowledgements                              267864600    39568517
 Total Negative Acknowledgements                             0           0
                             Device Drivers
 Total via Local Driver                                      0           0
 Total via Platform Driver                            90211693   320738936
 Total Frames Dropped by Platform Drivers                    0           0
 Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
 Re-Transmission                                                  14161288
 Re-Tx Timeout                                                          23
          Rx Errors                              Tx Errors
 Unsupp IPC Proto Version          0  Tx Session Error                  0
 Corrupt Frame                     0  Tx Seat Error                     0
 Duplicate Frame                1846  Tx No Send Vector                 0
 Unrel Out-of-Seq Frame            0  Tx Driver Failed                  0
 Rx IPC Transform Errors           0  Tx IPC Transform Errors           0
 Unable to Deliver Msg             0  Tx Test Drop                      0
 Rx Msg Callback Hog               0  Ack Alloc Failed                  0
 Rel Out-of-Seq Frame              2
 Dest Port does Not Exist          0
 Rx IPC Msg Alloc Failed           0
 Rx IPC Frag Dropped               0
 Rx Bootstrap Delivered            4
 Rx Bootstrap Dropped              0
          Buffer Errors                          Misc Errors
 IPC Msg Alloc                     0  IPC Open Port                     2
 Emer IPC Msg Alloc                0  No HWQ                            0
 IPC Frame PakType Alloc           0  Hardware Error                    0
 IPC Frame MemD Alloc              0  Invalid Messages                  0
                                      IPC Backup Open Port              0
                                      IPC Fragment Errors               0
                                      Message Timer Errors              0
                                      Messages no xmt pending flag      0
          Tx Driver Errors
 No Transport                      0
 MTU Failure                       0
 Dest does not Exist               0
          IPC Message Bundling Statistics
 Seat-level    Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/281170419/0/0
 Seat-level    Rx Bundling (bdl/sub/nonbdl/err)         0/0/90211693/0
 Session-level Tx Bundling (bdl/sub/nonbdl/urgent/err)  0/0/261299897/137666/0
 Session-level Rx Bundling (bdl/sub/nonbdl/err)         0/0/78246901/0
------------------ show pds buffergroup all ------------------
Global PDS buffergroups
  Handle       Name
  3149824      oobnd_netdrv
  3150080      dpd_oob_pds_group00
  3150336      SM Buf Group TX
  3150592      dpd_punject_pds_group00
  3150848      FED PUNJECT RX Buffer Group 0
  3151104      MMN Client
  3151360      NG3K punt tx queue tag(65571)
  3151616      NG3K punt tx queue tag(65572)
  3151872      NG3K punt tx queue tag(65573)
  3152128      NG3K punt tx queue tag(65574)
  3152384      NG3K punt tx queue tag(65575)
  3152640      NG3K punt tx queue tag(65576)
  3152896      NG3K punt tx queue tag(65577)
  3153152      NG3K punt tx queue tag(65578)
'*' denotes the buffergroup is reserved
------------------ show pds buffers ------------------
PDS public buffers
Public buffer pools:
PDS Buffer Pool 0, 2048 bytes (total 2048, permanent 2048, transient 0
     peak 1380 @ 150139815):
     986 in free list (2048 max allowed)
     1712338096 hits, 0 misses, 1712337034 free hits, 0 free misses
PDS Buffer Pool 1, 12288 bytes (total 341, permanent 341, transient 0):
     341 in free list (341 max allowed)
     0 hits, 0 misses, 0 free hits, 0 free misses
Header pools:
Packet Header Memory, 176 bytes (total 4681, permanent 4681, transient 0
     peak 336 @ 150139815):
     4663 in free list (4681 max allowed)
     2726571169 hits, 0 misses, 2726571151 free hits, 0 free misses
Buffer Header Memory, 88 bytes (total 16384, permanent 16384, transient 0
     15322 in free list (16384 max allowed)
     1712338098 hits, 0 misses, 1712337036 free hits, 0 free misses
------------------ show pds client all ------------------
PDS clients
Handle       PID      Desc     HA Role  Name
5770976      5636     44       ALWAYS   GOLD Client
5795584      5638     62       ALWAYS   oobnd_netdrv
5820192      5638     63       ALWAYS   dpd_oob
5844800      5638     70       ALWAYS   SM Client TX
5869408      6300     10       ALWAYS   liin tap
5894016      6289     11       ALWAYS   mgmte tap
5918624      6283     65       ALWAYS   PDSd Pktrc Dump clnt
5943232      5636     116      ALWAYS   dpd_punject
5967840      5636     121      ALWAYS   FED PUNJECT Event Handling
5992448      5636     122      ALWAYS   FED PUNJECT Rx Thread SRC Client
6017056      5636     125      ALWAYS   FED PUNJECT Tx Low Latency Sink
6041664      5636     126      ALWAYS   FED PUNJECT TXQ 0 Sink Client
6066272      5636     127      ALWAYS   FED PUNJECT TXQ 1 Sink Client
6090880      5636     128      ALWAYS   FED PUNJECT TXQ 2 Sink Client
6115488      5636     129      ALWAYS   FED PUNJECT TXQ 3 Sink Client
6140096      5636     130      ALWAYS   FED PUNJECT TXQ 4 Sink Client
6164704      5636     131      ALWAYS   FED PUNJECT TXQ 5 Sink Client
6189312      5636     132      ALWAYS   FED PUNJECT TXQ 6 Sink Client
6213920      5636     133      ALWAYS   FED PUNJECT TXQ 7 Sink Client
6238528      5636     134      ALWAYS   FED PUNJECT Show Forward Client
6263136      5636     135      ALWAYS   Show Forward Client
6287744      5636     138      ALWAYS   FNF distributed exporter
6312352      5636     151      ALWAYS   MMN Client
6336960      12121    85       ALWAYS   Transport Classifier(3)
6361568      12121    86       ALWAYS   Transport Classifier(4)
6386176      12121    87       ALWAYS   Transport Classifier(5)
6410784      12121    88       ALWAYS   Transport Classifier(6)
6435392      12121    89       ALWAYS   Transport Classifier(7)
6460000      12121    90       ALWAYS   Transport Classifier(8)
6484608      12121    91       ALWAYS   Transport Classifier(9)
6509216      12121    92       ALWAYS   Transport Classifier(10)
6533824      12121    93       ALWAYS   Transport Classifier(11)
6558432      12121    94       ALWAYS   Transport Classifier(0)
6583040      12121    95       ALWAYS   Transport Classifier(1)
6607648      12121    97       ALWAYS   Transport Classifier(2)
6632256      12126    68       ACTIVE   IOSd-PDS Client
6656864      12126    72       ACTIVE   Punt Rx Wireless Prio Q1
6681472      12126    73       ACTIVE   Punt Rx Wireless Prio Q2
6706080      12126    74       ACTIVE   Punt Rx Wireless Prio Q3
6730688      12126    75       ACTIVE   Punt Rx Wireless Prio Q4
6755296      12126    76       ACTIVE   Punt Rx RPF Failed
6779904      12126    77       ACTIVE   Punt Rx Mcast Data
6804512      12126    153      ACTIVE   Punt Rx Mcast Snoop
6829120      12126    154      ACTIVE   Punt Rx L2 Protocol
6853728      12126    155      ACTIVE   Punt Rx STP
6878336      12126    156      ACTIVE   Punt Rx Logging
6902944      12126    157      ACTIVE   Punt Rx Learning
6927552      12126    158      ACTIVE   Punt Rx ICMP Gen Redirect
6952160      12126    159      ACTIVE   Punt Rx ICMP Gen TTL
6976768      12126    160      ACTIVE   Punt Rx ICMP Gen Unreach
7001376      12126    161      ACTIVE   Punt Rx L3MTU Fail
7025984      12126    162      ACTIVE   Punt Rx V6Scope Fail
7050592      12126    163      ACTIVE   Punt Rx Routing Protocol
7075200      12126    164      ACTIVE   Punt Rx Forus Addr Reso Ctrl
7099808      12126    165      ACTIVE   Punt Rx Host
7124416      12126    166      ACTIVE   Sisf Intercept
7149024      12126    171      ACTIVE   NG3K Punt Tx
7173632      12126    172      ACTIVE   Resume Signal
7198240      12126    173      ACTIVE   Punt Rx Sw Fwd
7222848      12126    174      ACTIVE   Punt Rx Broadcast
7247456      12126    175      ACTIVE   Punt Rx Proto Snoop
7272064      12126    177      ALWAYS   Raw library
7296672      12126    178      ALWAYS   TCP library
7321280      12126    179      ALWAYS   UDP library
7345888      12126    182      ACTIVE   Punt Rx Auth
7370496      12121    154      ALWAYS   UDP Client Library
7395104      12121    170      ALWAYS   Raw IP Client Library
7419712      12121    171      ALWAYS   L2 Raw Client Library
7444320      13365    69       ALWAYS   TCP Client Library
7468928      12121    175      ALWAYS   TCP Client Library
------------------ show pds memory ------------------
PDS memory
Header pools:
     2726571303 hits, 0 misses, 2726571285 free hits, 0 free misses
     1712338163 hits, 0 misses, 1712337101 free hits, 0 free misses
Buffergroup Memory, 212 bytes (total 4096, permanent 4096, transient 0
     peak 14 @ 21541):
     4082 in free list (4096 max allowed)
     14 hits, 0 misses, 0 free hits, 0 free misses
TLV Memory, 512 bytes (total 1927, permanent 1927, transient 0
     peak 4294967294 @ 108651314):
     1927 in free list (1927 max allowed)
     2691724990 hits, 0 misses, 2691724990 free hits, 0 free misses
Event Memory, 72 bytes (total 4096, permanent 4096, transient 0
     peak 1 @ 30070):
     4096 in free list (4096 max allowed)
     487 hits, 0 misses, 487 free hits, 0 free misses
Client Memory, 24576 bytes (total 127, permanent 127, transient 0
     peak 70 @ 27679):
     57 in free list (127 max allowed)
     70 hits, 0 misses, 0 free hits, 0 free misses
Tag Memory, 212 bytes (total 4096, permanent 4096, transient 0
     peak 65 @ 27679):
     4031 in free list (4096 max allowed)
     65 hits, 0 misses, 0 free hits, 0 free misses
Alloc Tracking Memory, 16 bytes (total 8192, permanent 8192, transient 0
     peak 19 @ 27679):
     8173 in free list (8192 max allowed)
     19 hits, 0 misses, 0 free hits, 0 free misses
Pakhandle Memory, 8 bytes (total 16384, permanent 16384, transient 0):
     16384 in free list (16384 max allowed)
Global Info Memory, 4096 bytes (total 0, permanent 0, transient 0):
     0 in free list (0 max allowed)
------------------ show pds statistics ------------------
PDS global statistics
KLM version: 0-1-11
Basic statistics
Total PDS Clients                       : 70
Total PDS Clients cleanup               : 0
Total PDS Tags (dynamic/total)          : 5/65
Total PDS Buffergroups                  : 14
Source statistics
Total delivery attempts                 : 1704555216
Success delivery attempts               : 1704554715
Total buffers sent                      : 1704554715
Total bytes sent                        : 2807037992
Failed attempts due to unregistered tag : 14
Failed attempts due to full queue       : 487
Sink statistics
Total consumed count                       : 1704554707
Total buffers recv'd                       : 1704554707
Total bytes recv'd                         : 2807042141
Packets Received, No Signaling Required    : 1199253956
Packets Received, Not signaled             : 1011900710
Alloc statistics
Total buffer allocation count   : 1712338183
Success buffer allocation count : 1712338183
Current buffer allocation count : 1062
Current bytes allocation count  : 2023074133
------------------ show pds tag all ------------------
'*' denotes the tag is dynamic
TDA: total delivery attempts
SDA: successful delivery attempts
FDA: failed delivery attempts
TBufD: total buffers delivered
TBytD: total bytes delivered
   Active   Client Client
     Tags   Handle Name                                         TDA             SDA             FDA           TBufD                TBytD
    65579  5770976 GOLD Client                                    0               0               0               0                    0
       14  5869408 liin tap                                 5353022         5353022               0         5353022            372741240
       10  5894016 mgmte tap                                      0               0               0               0                    0
        2  6017056 FED PUNJECT Tx Low Latency Sink                0               0               0               0                    0
    65571  6041664 FED PUNJECT TXQ 0 Sink Client          226931249       226931249               0       226931249          -1618257652
    65572  6066272 FED PUNJECT TXQ 1 Sink Client                  0               0               0               0                    0
    65573  6090880 FED PUNJECT TXQ 2 Sink Client                  0               0               0               0                    0
    65574  6115488 FED PUNJECT TXQ 3 Sink Client                  0               0               0               0                    0
    65575  6140096 FED PUNJECT TXQ 4 Sink Client                  0               0               0               0                    0
    65576  6164704 FED PUNJECT TXQ 5 Sink Client                  0               0               0               0                    0
    65577  6189312 FED PUNJECT TXQ 6 Sink Client                  0               0               0               0                    0
    65578  6213920 FED PUNJECT TXQ 7 Sink Client          961752291       961752291               0       961752291          -1683650184
    65570  6238528 FED PUNJECT Show Forward Client                0               0               0               0                    0
       15  6336960 Transport Classifier(3)                        0               0               0               0                    0
       16  6361568 Transport Classifier(4)                        0               0               0               0                    0
       17  6386176 Transport Classifier(5)                        0               0               0               0                    0
       18  6410784 Transport Classifier(6)                        0               0               0               0                    0
       19  6435392 Transport Classifier(7)                        0               0               0               0                    0
       20  6460000 Transport Classifier(8)                        0               0               0               0                    0
       21  6484608 Transport Classifier(9)                        0               0               0               0                    0
       22  6509216 Transport Classifier(10)                       0               0               0               0                    0
       23  6533824 Transport Classifier(11)                       0               0               0               0                    0
       24  6558432 Transport Classifier(0)                        0               0               0               0                    0
       25  6583040 Transport Classifier(1)                        0               0               0               0                    0
       26  6607648 Transport Classifier(2)                        0               0               0               0                    0
    65562  6656864 Punt Rx Wireless Prio Q1                       0               0               0               0                    0
    65563  6681472 Punt Rx Wireless Prio Q2                       0               0               0               0                    0
    65564  6706080 Punt Rx Wireless Prio Q3                       0               0               0               0                    0
    65565  6730688 Punt Rx Wireless Prio Q4                       0               0               0               0                    0
    65545  6755296 Punt Rx RPF Failed                             0               0               0               0                    0
    65547  6779904 Punt Rx Mcast Data                             0               0               0               0                    0
    65542  6804512 Punt Rx Mcast Snoop                      1873614         1873614               0         1873614            162613482
    65537  6829120 Punt Rx L2 Protocol                     11526440        11526440               0        11526440           1855172444
    65536  6853728 Punt Rx STP                            192101093       192101093               0       192101093            129154396
    65544  6878336 Punt Rx Logging                                0               0               0               0                    0
    65538  6902944 Punt Rx Learning                               0               0               0               0                    0
    65559  6927552 Punt Rx ICMP Gen Redirect                      0               0               0               0                    0
    65558  6952160 Punt Rx ICMP Gen TTL                           0               0               0               0                    0
    65560  6976768 Punt Rx ICMP Gen Unreach                       0               0               0               0                    0
    65556  7001376 Punt Rx L3MTU Fail                             0               0               0               0                    0
    65557  7025984 Punt Rx V6Scope Fail                           0               0               0               0                    0
    65546  7050592 Punt Rx Routing Protocol                35076495        35076495               0        35076495            789989734
    65548  7075200 Punt Rx Forus Addr Reso Ctrl                   0               0               0               0                    0
    65539  7099808 Punt Rx Host                             1481964         1481964               0         1481964            183293326
       27  7124416 Sisf Intercept                                 0               0               0               0                    0
        9  6632256 IOSd-PDS Client                                0               0               0               0                    0
       13  6632256 IOSd-PDS Client                          5217399         5217399               0         5217399            378588862
    65580  7173632 Resume Signal                                  0               0               0               0                    0
    65540  7198240 Punt Rx Sw Fwd                                 0               0               0               0                    0
    65541  7222848 Punt Rx Broadcast                       55543211        55543211               0        55543211           1930384940
    65561  7247456 Punt Rx Proto Snoop                    207697934       207697934               0       207697934            307007044
       28  7272064 Raw library                                    0               0               0               0                    0
       29  7272064 Raw library                                    0               0               0               0                    0
       32  7272064 Raw library                                    0               0               0               0                    0
       33  7272064 Raw library                                    0               0               0               0                    0
       30  7296672 TCP library                                    0               0               0               0                    0
       31  7296672 TCP library                                    0               0               0               0                    0
       11  7321280 UDP library                                    0               0               0               0                    0
       12  7321280 UDP library                                    3               3               0               3                  360
    65551  7345888 Punt Rx Auth                                   0               0               0               0                    0
*  131072  7370496 UDP Client Library                             0               0               0               0                    0
*  131073  7395104 Raw IP Client Library                          0               0               0               0                    0
*  131074  7419712 L2 Raw Client Library                          0               0               0               0                    0
*  131075  7444320 TCP Client Library                             0               0               0               0                    0
*  131076  7468928 TCP Client Library                             0               0               0               0                    0
------------------ show stack-power ------------------
Power stack name: Powerstack-1
    Stack mode: Power sharing
    Stack topology: Standalone
    Switch 1:
        Power budget: 1720
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Port 1 status: Not connected
        Port 2 status: Not connected
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: 0000.0000.0000
Power stack name: Powerstack-11
    Switch 3:
        Power budget: 1720
Power stack name: Powerstack-12
    Switch 2:
        Power budget: 1720
------------------ show crypto key mypubkey rsa ------------------
% Key pair was generated at: 04:12:56 PDT Mar 25 2015
Key name: TP-self-signed-703301369
 Storage Device: private-config
 Usage: General Purpose Key
 Key is not exportable. Redundancy enabled.
 Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 008DFE6D
  2448D681 6A86B585 DCF8F365 D0E3854E 300D1B5E 1A8754E5 147C8CFE 4EC2AA76
  83D8B6F9 56BA0A70 985393FE F659C0D4 805E2429 74132095 885493F6 2FD4ECDE
  C9671AB4 1E498BED 75355B43 43A848DB 682934D4 E428D4CD E1D0354E 57E2A0BB
  5814C502 C1B9F538 4641DB82 A3F6E554 F991EA7F 7C2F71CE 83B79569 AF020301 0001
% Key pair was generated at: 06:07:39 PDT Mar 25 2015
Key name: HBSEASWIP38.CSB.COM
 Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00E3CA60
  FF0CC993 24A527AC 1960E7E8 2E0B51F8 E2D7E7CB 4FDAD881 BC845785 F1530756
  376E73BF CA3A3D9F E207869F D4713466 919D6299 CCED76A5 00846278 B73FC631
  B402C091 29D2DAD8 5C8B3997 75B3B556 82966EAC 861FF89B 321EDCF5 78BA147E
  D36C4483 8C15AA02 F7B1E6CC BB68ADB3 13C4231A 4A25C00D 3E7D5E4F 17020301 0001
% Key pair was generated at: 03:01:30 PDT Apr 12 2015
Key name: HTTPS_SS_CERT_KEYPAIR
 Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00CA853F 412F1A3F
  D779570A 0C8CC036 9DB44437 36B02081 8E875D39 E70AD437 FF62E1AE 9FCD8221
  4782E0A3 DBFDC442 FAAA695B DCD38868 C8AACCD7 22394036 4E8F1CCF E6ADD326
  5BC9E1A5 3063B117 EF62E6D5 A6DF964E 15C672FB C952AC27 53020301 0001
% Key pair was generated at: 19:41:44 PDT Oct 10 2015
Key name: TP-self-signed-703301369.server
Temporary key
 Usage: Encryption Key
 Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00F7B4B8 92550D64
  A5D7111C ED78FC13 AB971B61 BFD5FE75 8D0A7D7D B68946F2 147BCD8B EAA8E55F
  C6596740 B4146A10 B53ED38B 5B803895 A0AA0F1D 4B4E6CE6 011B3BCD 9F5FE7A3
  D0E1EF11 32D5BCB4 A738C962 DA021A36 118C00C5 C4D3B202 59020301 0001
% Key pair was generated at: 19:42:12 PDT Oct 10 2015
Key name: CISCO_IDEVID_SUDI
 Storage Device: not specified
 Key Data:
  30819F30 0D06092A 864886F7 0D010101 05000381 8D003081 89028181 00C9651A
  7552C56E 6D19C88E 9CB6C819 03E7A82F 154DA6B4 DF27C53B 12A8E834 0F8BFA3F
  3B9EB2B4 C266B4A2 7AC07433 C19F30B1 5163E4BD 026CA538 C2F551AB 88C6A140
  27245D95 D2C13730 07E4E2EE 509D8E51 DAB97332 123D19B3 EE451D5F 0F79727A
  50FA806C 7BD6D6A0 933C4BEC 7F0522A7 9B382A66 1FDED867 72BDF928 BF020301 0001
------------------ show buffers ------------------
PDS public buffers
     1712338286 hits, 0 misses, 1712337224 free hits, 0 free misses
Header pools:
     2726571552 hits, 0 misses, 2726571534 free hits, 0 free misses
     1712338287 hits, 0 misses, 1712337225 free hits, 0 free misses
IOSd private buffers:
Buffer elements:
     943 in free list (500 max allowed)
     1990292668 hits, 0 misses, 617 created
Small buffers, 104 bytes (total 600, permanent 600):
     600 in free list (100 min, 1250 max allowed)
     976048435 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 450, permanent 450):
     446 in free list (50 min, 1000 max allowed)
     583734156 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 450, permanent 450, peak 1038 @ 4w3d):
     449 in free list (25 min, 1500 max allowed)
     57052439 hits, 1838 misses, 5841 trims, 5841 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 15 @ 7w0d):
     10 in free list (0 min, 300 max allowed)
     2392 hits, 2 misses, 5 trims, 5 created
Large buffers, 5024 bytes (total 10, permanent 10, peak 11 @ 7w0d):
     10 in free list (0 min, 30 max allowed)
     8 hits, 0 misses, 1 trims, 1 created
VeryLarge buffers, 8232 bytes (total 50, permanent 50):
     50 in free list (0 min, 150 max allowed)
     3 hits, 0 misses, 0 trims, 0 created
Huge buffers, 18024 bytes (total 5, permanent 5, peak 100 @ 7w0d):
     5 in free list (0 min, 13 max allowed)
     1908925 hits, 47 misses, 95 trims, 95 created
Interface buffer pools:
ng3k_rx29 buffers, 1 bytes (total 1, permanent 1):
     1 in free list (0 min, 1 max allowed)
     0 hits, 0 misses
ng3k_rx17 buffers, 5 bytes (total 5, permanent 5):
     5 in free list (0 min, 5 max allowed)
     0 hits, 0 misses
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 7w0d):
     101 in free list (100 min, 200 max allowed)
     6 hits, 0 misses, 839 trims, 840 created
BIPC small buffers, 128 bytes (total 251, permanent 250, peak 251 @ 7w0d):
     251 in free list (250 min, 250 max allowed)
     1297 hits, 0 misses, 135676 trims, 135677 created
BIPC middle buffers, 600 bytes (total 301, permanent 300, peak 301 @ 7w0d):
     301 in free list (300 min, 300 max allowed)
     7569 hits, 0 misses, 135676 trims, 135677 created
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 7w0d):
     2295956 hits, 0 misses, 839 trims, 840 created
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 7w0d):
     101 in free list (132 min, 132 max allowed)
     364132 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 7w0d):
     26 in free list (25 min, 50 max allowed)
     7097856 hits, 0 misses, 839 trims, 840 created
ng3k_rx6 buffers, 1600 bytes (total 512, permanent 512):
     512 in free list (0 min, 512 max allowed)
     0 hits, 0 misses
ng3k_rx7 buffers, 1600 bytes (total 512, permanent 512):
     0 hits, 0 misses
ng3k_rx8 buffers, 1600 bytes (total 512, permanent 512):
     0 hits, 0 misses
ng3k_rx9 buffers, 1600 bytes (total 512, permanent 512):
     0 hits, 0 misses
ng3k_rx10 buffers, 1600 bytes (total 96, permanent 96):
     96 in free list (0 min, 96 max allowed)
     0 hits, 0 misses
ng3k_rx11 buffers, 1600 bytes (total 96, permanent 96):
     0 hits, 0 misses
ng3k_rx13 buffers, 1600 bytes (total 768, permanent 768):
     768 in free list (0 min, 768 max allowed)
     19206086 hits, 0 misses
ng3k_rx14 buffers, 1600 bytes (total 512, permanent 512):
     11526442 hits, 0 misses
ng3k_rx15 buffers, 1600 bytes (total 1024, permanent 1024):
     1024 in free list (0 min, 1024 max allowed)
     192101111 hits, 0 misses
ng3k_rx16 buffers, 1600 bytes (total 96, permanent 96):
     0 hits, 0 misses
ng3k_rx18 buffers, 1600 bytes (total 16, permanent 16):
     16 in free list (0 min, 16 max allowed)
     0 hits, 0 misses
ng3k_rx19 buffers, 1600 bytes (total 16, permanent 16):
     0 hits, 0 misses
ng3k_rx20 buffers, 1600 bytes (total 16, permanent 16):
     0 hits, 0 misses
ng3k_rx21 buffers, 1600 bytes (total 16, permanent 16):
     0 hits, 0 misses
ng3k_rx22 buffers, 1600 bytes (total 16, permanent 16):
     0 hits, 0 misses
ng3k_rx23 buffers, 1600 bytes (total 512, permanent 512):
     35076498 hits, 0 misses
ng3k_rx24 buffers, 1600 bytes (total 512, permanent 512):
     0 hits, 0 misses
ng3k_rx25 buffers, 1600 bytes (total 2048, permanent 2048):
     2047 in free list (0 min, 2048 max allowed)
     1481982 hits, 0 misses
ng3k punt fallback pool buffers, 1600 bytes (total 1500, permanent 1500):
     1500 in free list (0 min, 0 max allowed)
     0 hits, 0 misses
ng3k_rx30 buffers, 1600 bytes (total 128, permanent 128):
     128 in free list (0 min, 128 max allowed)
     0 hits, 0 misses
ng3k_rx31 buffers, 1600 bytes (total 128, permanent 128):
     55543282 hits, 0 misses
ng3k_rx32 buffers, 1600 bytes (total 512, permanent 512):
     511 in free list (0 min, 512 max allowed)
     212598306 hits, 0 misses
ng3k_rx34 buffers, 1600 bytes (total 512, permanent 512):
     0 hits, 0 misses
ng3k_rx26 buffers, 2048 bytes (total 1024, permanent 1024):
     0 hits, 0 misses
BIPC buffers, 4096 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     1 hits, 0 misses, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 7w0d):
     3 in free list (2 min, 4 max allowed)
     0 hits, 0 misses, 839 trims, 840 created
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 7w0d):
     2 in free list (1 min, 2 max allowed)
ng3k punt jumbo pool buffers, 9300 bytes (total 128, permanent 128):
     128 in free list (0 min, 0 max allowed)
     0 hits, 0 misses
BIPC Medium buffers, 16384 bytes (total 6, permanent 5, peak 6 @ 7w0d):
     6 in free list (5 min, 5 max allowed)
     0 hits, 0 misses, 135676 trims, 135677 created
BIPC Large buffers, 65535 bytes (total 3, permanent 2, peak 3 @ 7w0d):
     3 in free list (2 min, 2 max allowed)
IPC small buffers, 128 bytes (total 1200, permanent 1200):
     1149 in free list (400 min, 1200 max allowed)
     92687613 hits, 0 fallbacks, 0 trims, 0 created
     0 max cache size, 0 in cache
     0 hits in cache, 0 misses in cache
IPC middle buffers, 600 bytes (total 1200, permanent 1200):
     1196 in free list (400 min, 1200 max allowed)
     137698912 hits, 0 fallbacks, 0 trims, 0 created
IPC Emergency buffers, 4096 bytes (total 301, permanent 300, peak 301 @ 7w0d):
IPC buffers, 4096 bytes (total 1200, permanent 1200):
     1197 in free list (400 min, 1200 max allowed)
     77127559 hits, 0 fallbacks, 0 trims, 0 created
IPC Medium buffers, 16384 bytes (total 46, permanent 40, peak 46 @ 00:00:15):
     46 in free list (20 min, 40 max allowed)
     4531710 hits, 4 fallbacks, 0 trims, 6 created
Private Huge IPC buffers, 18024 bytes (total 1, permanent 0, peak 1 @ 7w0d):
     1 in free list (0 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 1, permanent 0, peak 1 @ 7w0d):
IPC Large buffers, 65535 bytes (total 104, permanent 104, peak 105 @ 7w0d):
     102 in free list (20 min, 104 max allowed)
     6 hits, 0 misses, 1 trims, 1 created
Header pools:
Header buffers, 0 bytes (total 266, permanent 256, peak 266 @ 7w0d):
     10 in free list (10 min, 512 max allowed)
     253 hits, 3 misses, 0 trims, 10 created
     256 max cache size, 256 in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 384, permanent 384):
     128 in free list (128 min, 1024 max allowed)
     256 hits, 0 misses, 0 trims, 0 created
Normal buffers, 512 bytes (total 512, permanent 512):
     384 in free list (128 min, 1024 max allowed)
     128 hits, 0 misses, 0 trims, 0 created
     128 max cache size, 128 in cache
------------------ show inventory ------------------
NAME: "c3xxx Stack", DESCR: "c3xxx Stack"
PID: WS-C3850-48P      , VID: V03  , SN: FOC1832X15V
NAME: "Switch 1", DESCR: "WS-C3850-48P"
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT18310ZR
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT1831102
NAME: "Switch 1 FRU Uplink Module 0", DESCR: "4x1G Uplink Module"
PID: C3850-NM-4-1G     , VID: V01  , SN: FOC18064GA2
NAME: "GigabitEthernet1/1/1", DESCR: "1000BaseSX SFP"
PID:                    , VID:      , SN: AGA1612L38B
NAME: "GigabitEthernet1/1/2", DESCR: "1000BaseSX SFP"
PID:                    , VID:      , SN: FNS16072E1R
NAME: "Switch 2", DESCR: "WS-C3850-48P"
PID: WS-C3850-48P      , VID: V03  , SN: FOC1832U143
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT183110A
NAME: "Switch 2 - Power Supply B", DESCR: "Switch 2 - Power Supply B"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT18310MA
NAME: "Switch 3", DESCR: "WS-C3850-48P"
PID: WS-C3850-48P      , VID: V03  , SN: FCW1832C11U
NAME: "Switch 3 - Power Supply A", DESCR: "Switch 3 - Power Supply A"
PID: PWR-C1-1100WAC    , VID: V01  , SN: LIT1831111
NAME: "Switch 3 - Power Supply B", DESCR: "Switch 3 - Power Supply B"
PID: PWR-C1-1100WAC    , VID: V01  , SN: DTN1841V0X
------------------ show region ------------------
Region Manager:
      Start         End     Size(b)  Class  Media  Name
 0x100484F0  0x12E48D43    48236628  IText  R/W    text
 0x13DDE5B0  0x1433436F     5594560  IData  R/W    data
 0x14334370  0x14F0ACEF    12413312  IBss   R/W    bss
 0x2B304000  0x2B323207      127496  IText  R/W    /lib/ld.so.1
 0x2B333D30  0x2B334D03        4052  IData  R/W    /lib/ld.so.1
 0x2B335000  0x2B4088EB      866540  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libmatm.so
 0x2B419000  0x2B42F7AF       92080  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libmatm.so
 0x2B430000  0x2B58B543     1422660  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngpm.so
 0x2B59C000  0x2B5CFEB7      212664  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngpm.so
 0x2B5D0000  0x2B684A0B      739852  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libifm_ctrl.so
 0x2B695000  0x2B6A69D3       72148  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libifm_ctrl.so
 0x2B6A7000  0x2B6DDE83      224900  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngthermal.so
 0x2B6EE000  0x2B6F41F3       25076  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngthermal.so
 0x2B6F5000  0x2B728E5B      212572  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_capwap.so
 0x2B739000  0x2B73EA57       23128  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_capwap.so
 0x2B73F000  0x2B75B43B      115772  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2_control.so
 0x2B76B43C  0x2B76DABF        9860  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2_control.so
 0x2B76E000  0x2B7DCB73      453492  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libbackup_int.so
 0x2B7ED000  0x2B7F95B7       50616  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libbackup_int.so
 0x2B7FA000  0x2B84F783      350084  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngspan.so
 0x2B860000  0x2B869B3F       39744  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngspan.so
 0x2B86A000  0x2B872E23       36388  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_cdp.so
 0x2B883000  0x2B8844F7        5368  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_cdp.so
 0x2B885000  0x2B88DEA3       36516  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_udld.so
 0x2B89E000  0x2B89F4F7        5368  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_udld.so
 0x2B8A0000  0x2B8A8EA3       36516  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_lldp.so
 0x2B8B9000  0x2B8BA4F7        5368  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng_lldp.so
 0x2B8BB000  0x2B8DAE63      130660  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dai.so
 0x2B8DB000  0x2B8DFE03       19972  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dai.so
 0x2B8E0000  0x2B99F73B      784188  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2m.so
 0x2B9A0000  0x2B9B699F       92576  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libl2m.so
 0x2B9B7000  0x2B9E5783      190340  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libedison_dhcpsn.so
 0x2B9F5784  0x2B9FCD23       30112  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libedison_dhcpsn.so
 0x2B9FD000  0x2BA2777B      173948  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_ipsg.so
 0x2BA38000  0x2BA3CB27       19240  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_ipsg.so
 0x2BA3D000  0x2BA80123      274724  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsecurity_ctrl.so
 0x2BA90124  0x2BA9482F       18188  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsecurity_ctrl.so
 0x2BA95000  0x2BAAF7EB      108524  IText  R/W    /tmp/sw/rp/0/0/drivers/mount/usr/binos/lib/libbspconfig.so
 0x2BABF7EC  0x2BB19D23      369976  IData  R/W    /tmp/sw/rp/0/0/drivers/mount/usr/binos/lib/libbspconfig.so
 0x2BB1A000  0x2BBEC2C3      860868  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dtls.so
 0x2BBFD000  0x2BC0EE87       73352  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_dtls.so
 0x2BC0F000  0x2BCACEE3      646884  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_stats.so
 0x2BCBD000  0x2BCCF227       74280  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_stats.so
 0x2BCD0000  0x2BCF05A3      132516  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/liblearning.so
 0x2BD01000  0x2BD03C17       11288  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/liblearning.so
 0x2BD04000  0x2BD5B48B      357516  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sc.so
 0x2BD6B48C  0x2BD73A87       34300  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sc.so
 0x2BD74000  0x2BE216AB      710316  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_security_utils.so
 0x2BE316AC  0x2BE429DF       70452  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_security_utils.so
 0x2BE43000  0x2BE746EB      202476  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpths.so
 0x2BE85000  0x2BE89BAF       19376  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpths.so
 0x2BE8A000  0x2BF0A14B      524620  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libiosd_qos.so
 0x2BF1A14C  0x2BF27657       54540  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libiosd_qos.so
 0x2BF28000  0x2BF66D73      257396  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_l3m.so
 0x2BF77000  0x2BF7C7D7       22488  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_l3m.so
 0x2BF7D000  0x2BFE20EB      413932  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sm.so
 0x2BFF20EC  0x2BFFAD2B       35904  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_sm.so
 0x2BFFB000  0x2C03365B      231004  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_lic_hbl.so
 0x2C04365C  0x2C047CEB       18064  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngwc_lic_hbl.so
 0x2C048000  0x2C05EADB       92892  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libtm_monitor.so
 0x2C06F000  0x2C070E6F        7792  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libtm_monitor.so
 0x2C071000  0x2C0884C3       95428  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libem_ha.so
 0x2C099000  0x2C09AF2F        7984  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libem_ha.so
 0x2C09B000  0x2C0E31FB      295420  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr.so
 0x2C0F31FC  0x2C0F8C4F       23124  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr.so
 0x2C0F9000  0x2C12AA93      203412  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_misc.so
 0x2C13B000  0x2C1406F3       22260  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_misc.so
 0x2C141000  0x2C182003      266244  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngilp.so
 0x2C192004  0x2C19A273       33392  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngilp.so
 0x2C19B000  0x2C1A88DB       55516  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngcfg_mgr.so
 0x2C1B9000  0x2C1BAB4F        6992  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngcfg_mgr.so
 0x2C1BB000  0x2C1DCA43      137796  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpm_ifm_ctrl.so
 0x2C1ED000  0x2C1F0F93       16276  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libpm_ifm_ctrl.so
 0x2C1F1000  0x2C2613CB      459724  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngfep.so
 0x2C2713CC  0x2C27C997       46540  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngfep.so
 0x2C27D000  0x2C28B383       58244  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngusb.so
 0x2C29B384  0x2C29CBD3        6224  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngusb.so
 0x2C29D000  0x2C2D6A5B      236124  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng3k_wireless.so
 0x2C2E7000  0x2C2ECCC7       23752  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libng3k_wireless.so
 0x2C2ED000  0x2C339793      313236  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngstkpwr.so
 0x2C349794  0x2C351F2F       34716  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngstkpwr.so
 0x2C352000  0x2C36D59B      112028  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngled.so
 0x2C37E000  0x2C380F8B       12172  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngled.so
 0x2C381000  0x2C38CCBB       48316  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_ha.so
 0x2C39D000  0x2C39E66B        5740  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngplatform_mgr_ha.so
 0x2C39F000  0x2C3B69A3       96676  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libplatform.so
 0x2C3C7000  0x2C3C8F3B        7996  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libplatform.so
 0x2C3C9000  0x2C3CCA33       14900  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsdm.so
 0x2C3DD000  0x2C3DD7FF        2048  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libsdm.so
 0x2C3DE000  0x2C3F5B2B       97068  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngemp.so
 0x2C406000  0x2C40887B       10364  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libngemp.so
 0x2C409000  0x2C40AA7B        6780  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/librtu_lic.so
 0x2C41AA7C  0x2C41AD67         748  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/librtu_lic.so
 0x2C41B000  0x2C460CCB      285900  IText  R/W    /usr/lib32/libssl.so
 0x2C470CCC  0x2C477D0F       28740  IData  R/W    /usr/lib32/libssl.so
 0x2C478000  0x2C5E1C93     1481876  IText  R/W    /usr/lib32/libcrypto.so
 0x2C5F2000  0x2C62684F      215120  IData  R/W    /usr/lib32/libcrypto.so
 0x2C627000  0x2C62BCCB       19660  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuld.so
 0x2C63C000  0x2C64EADF       76512  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuld.so
 0x2C64F000  0x2C65191B       10524  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinitcii.so
 0x2C66191C  0x2C661CFF         996  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinitcii.so
 0x2C662000  0x2C6665F3       17908  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrashinfo.so
 0x2C6765F4  0x2C677BBF        5580  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrashinfo.so
 0x2C678000  0x2C67DAFB       23292  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuiutil.so
 0x2C68DAFC  0x2C68DF8F        1172  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuiutil.so
 0x2C68E000  0x2C6B4F2B      159532  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer.so
 0x2C6C5000  0x2C6CE42F       37936  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer.so
 0x2C6CF000  0x2C6FF5A3      198052  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlcore.so
 0x2C70F5A4  0x2C7156B7       24852  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlcore.so
 0x2C716000  0x2C71E7C3       34756  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos.so
 0x2C72E7C4  0x2C7349FF       25148  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos.so
 0x2C735000  0x2C735AE3        2788  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref.so
 0x2C745AE4  0x2C765C13      131376  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref.so
 0x2C766000  0x2C766C4B        3148  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtppiosrp.so
 0x2C776C4C  0x2C776D1F         212  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtppiosrp.so
 0x2C777000  0x2C77FB7B       35708  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_msg.so
 0x2C78FB7C  0x2C790CBF        4420  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_msg.so
 0x2C791000  0x2C7A85EB       95724  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte.so
 0x2C7B9000  0x2C7BBC4B       11340  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte.so
 0x2C7BC000  0x2C7EECA3      208036  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte_relay.so
 0x2C7FF000  0x2C803D1B       19740  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmgmte_relay.so
 0x2C804000  0x2C80A65B       26204  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem.so
 0x2C81A65C  0x2C81AC3F        1508  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem.so
 0x2C81C000  0x2C81DB8B        7052  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem_spi.so
 0x2C82DB8C  0x2C82DD5F         468  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcpumem_spi.so
 0x2C82E000  0x2C895FEB      425964  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libif_common.so
 0x2C8A6000  0x2C8B34DB       54492  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libif_common.so
 0x2C8B4000  0x2C8EB303      226052  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libccb_commands.so
 0x2C8FB304  0x2C90196B       26216  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libccb_commands.so
 0x2C902000  0x2C97CB8B      502668  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libgold.so
 0x2C98CB8C  0x2C998D9F       49684  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libgold.so
 0x2C99A000  0x2C9B125B       94812  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_diag_test.so
 0x2C9C125C  0x2C9C3EAF       11348  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcp_diag_test.so
 0x2C9C4000  0x2C9E84CB      148684  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_msg.so
 0x2C9F84CC  0x2C9FC75F       17044  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_msg.so
 0x2C9FD000  0x2CB4395B     1337692  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos.so
 0x2CB54000  0x2CB77EBF      147136  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos.so
 0x2CB78000  0x2CB80DA3       36260  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_cefmfi.so
 0x2CB91000  0x2CB9250F        5392  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_cefmfi.so
 0x2CB94000  0x2CB9B5A3       30116  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef.so
 0x2CBAB5A4  0x2CBAC68F        4332  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef.so
 0x2CBAD000  0x2CBD72FB      172796  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_messages.so
 0x2CBE8000  0x2CBECF7F       20352  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_messages.so
 0x2CBED000  0x2CC06FB3      106420  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha.so
 0x2CC17000  0x2CC1A27B       12924  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha.so
 0x2CC1B000  0x2CC1F2B3       17076  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi.so
 0x2CC2F2B4  0x2CC2FA4F        1948  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi.so
 0x2CC31000  0x2CC439C3       76228  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_messages.so
 0x2CC539C4  0x2CC55BAF        8684  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_messages.so
 0x2CC56000  0x2CCEA573      607604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef.so
 0x2CCFA574  0x2CD0A9AF       66620  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef.so
 0x2CD0B000  0x2CD1CD4B       73036  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef_common.so
 0x2CD2CD4C  0x2CD2ED7F        8244  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_cef_common.so
 0x2CD2F000  0x2CD33FAB       20396  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_common.so
 0x2CD44000  0x2CD449AF        2480  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_common.so
 0x2CD46000  0x2CD5D52B       95532  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_obj.so
 0x2CD6D52C  0x2CD6E56F        4164  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_obj.so
 0x2CD6F000  0x2CE58A5B      957020  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target.so
 0x2CE69000  0x2CE866EF      120560  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target.so
 0x2CE87000  0x2CEB9953      207188  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l2target.so
 0x2CECA000  0x2CED089F       26784  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l2target.so
 0x2CED1000  0x2D3CC2D3     5223124  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_classify.so
 0x2D3DD000  0x2D462F17      548632  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_classify.so
 0x2D464000  0x2D4A905B      282716  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf.so
 0x2D4B905C  0x2D4C098F       31028  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf.so
 0x2D4C1000  0x2D4DBCB3      109748  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l3intf.so
 0x2D4EC000  0x2D4EEBC7       11208  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_l3intf.so
 0x2D4EF000  0x2D4F4ADB       23260  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ack_types.so
 0x2D505000  0x2D505AAF        2736  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ack_types.so
 0x2D506000  0x2D50C88B       26764  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_stat_types.so
 0x2D51D000  0x2D51D83F        2112  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_stat_types.so
 0x2D51F000  0x2D54BA9B      182940  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_reply_service.so
 0x2D55C000  0x2D56087F       18560  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_reply_service.so
 0x2D561000  0x2D5A065B      259676  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf.so
 0x2D5B065C  0x2D5B7DD7       30588  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf.so
 0x2D5B8000  0x2D5CD58B       87436  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_urpf.so
 0x2D5DD58C  0x2D5DFFDF       10836  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_urpf.so
 0x2D5E0000  0x2D60606B      155756  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl.so
 0x2D61606C  0x2D61C433       25544  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl.so
 0x2D61E000  0x2D76ECB3     1379508  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_sdo.so
 0x2D77F000  0x2D7A9B2F      174896  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_sdo.so
 0x2D7AA000  0x2D7BC283       74372  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl.so
 0x2D7CC284  0x2D7CE5FF        9084  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl.so
 0x2D7CF000  0x2D826F73      360308  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr.so
 0x2D837000  0x2D840D1B       40220  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr.so
 0x2D841000  0x2D86E48B      185484  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun.so
 0x2D87E48C  0x2D883867       21468  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun.so
 0x2D885000  0x2D8B0693      177812  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_tun.so
 0x2D8C0694  0x2D8C4DF3       18272  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_tun.so
 0x2D8C5000  0x2D8E9333      148276  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm.so
 0x2D8F9334  0x2D8FF93F       26124  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm.so
 0x2D900000  0x2D90D32B       54060  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_source_spi.so
 0x2D91E000  0x2D91EDDF        3552  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_source_spi.so
 0x2D91F000  0x2D93620B       94732  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpeer_reg.so
 0x2D94620C  0x2D948E8B       11392  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpeer_reg.so
 0x2D94A000  0x2D980B13      224020  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_om.so
 0x2D991000  0x2D997D4F       27984  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_om.so
 0x2D998000  0x2D9C6133      188724  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libupexp.so
 0x2D9D6134  0x2D9DD907       30676  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libupexp.so
 0x2D9DE000  0x2DA27CEB      302316  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuiexp.so
 0x2DA38000  0x2DA42CAF       44208  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuiexp.so
 0x2DA43000  0x2DA66D0B      146700  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaccess_policy.so
 0x2DA77000  0x2DA7DD87       28040  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaccess_policy.so
 0x2DA7F000  0x2DAC1D93      273812  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvty_mgt.so
 0x2DAD2000  0x2DAD9513       29972  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvty_mgt.so
 0x2DADA000  0x2DAEBAAB       72364  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrypto_types.so
 0x2DAFC000  0x2DAFDE83        7812  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcrypto_types.so
 0x2DAFE000  0x2DB48B1B      305948  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer_comm_ui.so
 0x2DB58B1C  0x2DB62E2F       41748  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libuipeer_comm_ui.so
 0x2DB63000  0x2DBE6F0B      540428  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui.so
 0x2DBF7000  0x2DC086DF       71392  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui.so
 0x2DC0A000  0x2DC38093      188564  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui_shr.so
 0x2DC48094  0x2DC4C9C7       18740  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libui_shr.so
 0x2DC4D000  0x2DC87E43      241220  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfru_stats.so
 0x2DC98000  0x2DC9CF87       20360  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfru_stats.so
 0x2DC9D000  0x2DCC93E3      181220  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmem_stats_ui.so
 0x2DCD93E4  0x2DCDF457       24692  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmem_stats_ui.so
 0x2DCE0000  0x2DD5782B      489516  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmcp_comm.so
 0x2DD68000  0x2DD74E27       52776  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmcp_comm.so
 0x2DD76000  0x2DD93AEB      121580  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsvc_defs.so
 0x2DDA3AEC  0x2DDA6F33       13384  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsvc_defs.so
 0x2DDA7000  0x2DDB2BF3       48116  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcisco_tunnel.so
 0x2DDC3000  0x2DDC4AD7        6872  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcisco_tunnel.so
 0x2DDC5000  0x2DDCE603       38404  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc.so
 0x2DDDE604  0x2DDDFD2F        5932  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc.so
 0x2DDE0000  0x2DDF8493       99476  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_messages.so
 0x2DE09000  0x2DE0BE6F       11888  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_messages.so
 0x2DE0D000  0x2DE53CDB      290012  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuism.so
 0x2DE64000  0x2DE6C6FB       34556  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuism.so
 0x2DE6D000  0x2DE9C623      194084  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_ack.so
 0x2DEAC624  0x2DEB2953       25392  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_ack.so
 0x2DEB3000  0x2DEB8F83       24452  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbsess.so
 0x2DEC8F84  0x2DEC9FDF        4188  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbsess.so
 0x2DECA000  0x2DED678B       51084  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libapp_sess.so
 0x2DEE678C  0x2DEE7E63        5848  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libapp_sess.so
 0x2DEE9000  0x2DF62B13      498452  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuidc.so
 0x2DF73000  0x2DF7F8A3       51364  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuidc.so
 0x2DF80000  0x2DF856DB       22236  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuismrp.so
 0x2DF96000  0x2DF96C6F        3184  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libuismrp.so
 0x2DF97000  0x2E01062B      497196  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbshell.so
 0x2E021000  0x2E030FB7       65464  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbshell.so
 0x2E031000  0x2E060593      193940  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libapp_sess_ios.so
 0x2E070594  0x2E075ABB       21800  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libapp_sess_ios.so
 0x2E077000  0x2E15B9E3      936420  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libethernet.so
 0x2E16B9E4  0x2E183CD3       99056  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libethernet.so
 0x2E184000  0x2E1A3853      129108  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosrp_ui.so
 0x2E1B3854  0x2E1B7E77       17956  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosrp_ui.so
 0x2E1B8000  0x2E1DBFAB      147372  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplogd_msgs.so
 0x2E1EC000  0x2E1EF4AB       13484  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplogd_msgs.so
 0x2E1F0000  0x2E21F02B      192556  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrace.so
 0x2E22F02C  0x2E235AD7       27308  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrace.so
 0x2E237000  0x2E278D4B      269644  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libprocmib_slave.so
 0x2E288D4C  0x2E28FE2F       28900  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libprocmib_slave.so
 0x2E290000  0x2E29F453       62548  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libhwcfg.so
 0x2E2A0000  0x2E2A1E0B        7692  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libhwcfg.so
 0x2E2A2000  0x2E2A2AD7        2776  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libip_match_entry.so
 0x2E2B2AD8  0x2E2B2BAF         216  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libip_match_entry.so
 0x2E2B3000  0x2E2D689B      145564  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libiif.so
 0x2E2E7000  0x2E2E9DDF       11744  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libiif.so
 0x2E2EB000  0x2E2FC95B       72028  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxtf.so
 0x2E30C95C  0x2E30DF1F        5572  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxtf.so
 0x2E30E000  0x2E30F0C3        4292  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcilogger.so
 0x2E31F0C4  0x2E31F21F         348  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcilogger.so
 0x2E320000  0x2E3F16E3      857828  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho.so
 0x2E402000  0x2E412C6F       68720  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho.so
 0x2E413000  0x2E43BBCB      166860  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho2.so
 0x2E44C000  0x2E44F8F3       14580  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libecho2.so
 0x2E451000  0x2E461323       66340  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test.so
 0x2E471324  0x2E47276F        5196  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test.so
 0x2E473000  0x2E4833F3       66548  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test2.so
 0x2E4933F4  0x2E49483F        5196  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libappparam_test2.so
 0x2E495000  0x2E53B06B      680044  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpltest.so
 0x2E54B06C  0x2E558347       53980  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpltest.so
 0x2E559000  0x2E838C63     3013732  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libentity_manager.so
 0x2E839000  0x2E87DABB      281276  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libentity_manager.so
 0x2E87F000  0x2E913F13      610068  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libif_manager.so
 0x2E924000  0x2E93251F       58656  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libif_manager.so
 0x2E933000  0x2E981683      321156  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liboirservice.so
 0x2E991684  0x2E9988EF       29292  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liboirservice.so
 0x2E999000  0x2E9BAE8B      138892  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblcsrservice.so
 0x2E9CB000  0x2E9CE27F       12928  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblcsrservice.so
 0x2E9CF000  0x2EA0FC6B      265324  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_cmn.so
 0x2EA20000  0x2EA2786F       30832  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_cmn.so
 0x2EA29000  0x2EA63893      239764  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_client.so
 0x2EA74000  0x2EA77B3F       15168  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_client.so
 0x2EA78000  0x2EB22BDB      699356  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_iosd.so
 0x2EB33000  0x2EB42A93       64148  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstaller_iosd.so
 0x2EB43000  0x2EC037A3      788388  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpki_ssl.so
 0x2EC14000  0x2EC24F1F       69408  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpki_ssl.so
 0x2EC25000  0x2ECABD7B      552316  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libehttps.so
 0x2ECBC000  0x2ECC8C4B       52300  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libehttps.so
 0x2ECCA000  0x2ECF8ABB      191164  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdhcp_ipc.so
 0x2ED08ABC  0x2ED0CE17       17244  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdhcp_ipc.so
 0x2ED0D000  0x2ED580CB      307404  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libnmsp_spi.so
 0x2ED680CC  0x2ED6EC57       27532  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libnmsp_spi.so
 0x2ED6F000  0x2EFAD1F3     2351604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/librsmp.so
 0x2EFBD1F4  0x2EFF9543      246608  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/librsmp.so
 0x2EFFA000  0x2F03EE93      282260  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtactic_nova.so
 0x2F04F000  0x2F055723       26404  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtactic_nova.so
 0x2F057000  0x2F1D868B     1578636  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libqos_tam.so
 0x2F1E868C  0x2F20E6C7      155708  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libqos_tam.so
 0x2F20F000  0x2F2F4633      939572  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcdb_ios.so
 0x2F305000  0x2F319EDF       85728  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcdb_ios.so
 0x2F31A000  0x2F3B086B      616556  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcs_ios.so
 0x2F3C1000  0x2F3CEE5F       56928  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcs_ios.so
 0x2F3CF000  0x2F3E54DB       91356  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcmntp.so
 0x2F3F6000  0x2F3F7DBB        7612  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcmntp.so
 0x2F3F9000  0x2F47CDA3      540068  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdtls_ios.so
 0x2F48CDA4  0x2F497F8F       45548  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdtls_ios.so
 0x2F498000  0x2F4F9F4B      401228  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaa.so
 0x2F50A000  0x2F50F8CF       22736  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaa.so
 0x2F510000  0x2F5C0D1B      724252  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libauth_mgr.so
 0x2F5D1000  0x2F5E0AFF       64256  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libauth_mgr.so
 0x2F5E1000  0x2F63606B      348268  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcast_wcm.so
 0x2F64606C  0x2F64ECBB       35920  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libmcast_wcm.so
 0x2F650000  0x2F74CF8B     1036172  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicli_spi.so
 0x2F75D000  0x2F774523       95524  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicli_spi.so
 0x2F775000  0x2F791D33      118068  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_ipc.so
 0x2F7A2000  0x2F7A466B        9836  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_ipc.so
 0x2F7A5000  0x2F7E13C3      246724  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfiletrans_svc.so
 0x2F7F13C4  0x2F7F7547       24964  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfiletrans_svc.so
 0x2F7F8000  0x2F810D13      101652  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_event_ipc.so
 0x2F821000  0x2F822FEB        8172  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libeicore_event_ipc.so
 0x2F824000  0x2F88A0DB      418012  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libdebugflag.so
 0x2F89A0DC  0x2F8A2CCB       35824  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libdebugflag.so
 0x2F8A3000  0x2F927BE3      543716  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap.so
 0x2F938000  0x2F944B37       52024  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap.so
 0x2F945000  0x2F98868B      276108  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap_fed.so
 0x2F99868C  0x2F99E737       24748  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcapwap_fed.so
 0x2F99F000  0x2F9C763B      165436  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdemo.so
 0x2F9D763C  0x2F9DAA57       13340  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libdemo.so
 0x2F9DC000  0x2F9F4FB3      102324  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha.so
 0x2FA05000  0x2FA0811F       12576  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha.so
 0x2FA09000  0x2FACDEF3      806644  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_msif.so
 0x2FADE000  0x2FAF26FF       83712  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_msif.so
 0x2FAF3000  0x2FB9835B      676700  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_plif.so
 0x2FBA835C  0x2FBB85AB       66128  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_plif.so
 0x2FBB9000  0x2FC3927B      524924  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_library_cli.so
 0x2FC4927C  0x2FC53FCF       44372  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libha_library_cli.so
 0x2FC55000  0x2FCC61AB      463276  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libepm.so
 0x2FCD61AC  0x2FCDF7F7       38476  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libepm.so
 0x2FCE0000  0x2FD4C8BB      444604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp.so
 0x2FD5D000  0x2FD63DBF       28096  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp.so
 0x2FD64000  0x3008FA33     3324468  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblicense_service.so
 0x300A0000  0x300E662B      288300  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liblicense_service.so
 0x300E7000  0x30103F63      118628  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libshutdown.so
 0x30114000  0x301167F7       10232  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libshutdown.so
 0x30118000  0x3013A863      141412  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats.so
 0x3014B000  0x3014EACF       15056  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats.so
 0x3014F000  0x3015422B       21036  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats_types.so
 0x3016422C  0x30164BDF        2484  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ip_traffic_stats_types.so
 0x30165000  0x3016A2EB       21228  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ip_traffic_stats.so
 0x3017A2EC  0x3017AC9F        2484  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ip_traffic_stats.so
 0x3017B000  0x301A9213      188948  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_ha_role.so
 0x301B9214  0x301BCE0F       15356  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_ha_role.so
 0x301BE000  0x301CAE73       52852  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_transport.so
 0x301DB000  0x301DBC2B        3116  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libipc_transport.so
 0x301DC000  0x302C4F6B      954220  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobfl.so
 0x302D5000  0x302EB8E3       92388  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobfl.so
 0x302EC000  0x3031A7CB      190412  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libparser_spi.so
 0x3032A7CC  0x3032DECF       14084  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libparser_spi.so
 0x3032E000  0x3036E9B3      264628  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_fed.so
 0x3037F000  0x30384B7F       23424  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_fed.so
 0x30386000  0x303BE81B      231452  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_platform.so
 0x303CE81C  0x303D3C8F       21620  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libwcm_platform.so
 0x303D4000  0x303F4733      132916  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libosinfo.so
 0x30404734  0x304077DB       12456  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libosinfo.so
 0x30408000  0x30412E3B       44604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr.so
 0x30423000  0x3042453F        5440  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr.so
 0x30425000  0x304E997B      805244  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr_cl.so
 0x304F997C  0x3050AEAF       70964  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsysmgr_cl.so
 0x3050C000  0x3051CB93       68500  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libconsole_relay.so
 0x3052D000  0x3052E51B        5404  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libconsole_relay.so
 0x3052F000  0x30539DD3       44500  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libwcmha.so
 0x3054A000  0x3054ABCF        3024  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libwcmha.so
 0x3054B000  0x3059298B      293260  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfnf_fed_spi.so
 0x305A298C  0x305A8F5F       26068  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfnf_fed_spi.so
 0x305A9000  0x305EB9BB      272828  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpds_perftest.so
 0x305FC000  0x3060165F       22112  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libpds_perftest.so
 0x30603000  0x3061C8D3      104660  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystem_config.so
 0x3062C8D4  0x3062EC3F        9068  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystem_config.so
 0x3062F000  0x30644173       86388  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib.so
 0x30654174  0x30656F8F       11804  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib.so
 0x30657000  0x306585F3        5620  IText  R/W    /usr/binos/lib/libbsdlib.so
 0x306685F4  0x3066874F         348  IData  R/W    /usr/binos/lib/libbsdlib.so
 0x30669000  0x3066E613       22036  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdllib.so
 0x3067E614  0x3067EB0F        1276  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdllib.so
 0x30680000  0x3068290B       10508  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlutil.so
 0x3069290C  0x30692B4F         580  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcdlutil.so
 0x30693000  0x306A8BAB       89004  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevlib.so
 0x306B9000  0x306BAC4F        7248  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevlib.so
 0x306BB000  0x306CA953       63828  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevutil.so
 0x306DA954  0x306DFF7F       22060  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libevutil.so
 0x306E0000  0x306F580B       88076  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmts.so
 0x3070580C  0x307078E7        8412  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmts.so
 0x30709000  0x3071D61B       83484  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmqipc.so
 0x3072D61C  0x3072FA2F        9236  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmqipc.so
 0x30730000  0x30736CA3       27812  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbipc.so
 0x30747000  0x307477AF        1968  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbipc.so
 0x30748000  0x3074C06B       16492  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib_c.so
 0x3075C06C  0x3075C50F        1188  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtdllib_c.so
 0x3075D000  0x3075DC77        3192  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvs_lock.so
 0x3076DC78  0x3076DDCF         344  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvs_lock.so
 0x3076F000  0x30772AF3       15092  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_avl.so
 0x30782AF4  0x30782E9F         940  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_avl.so
 0x30783000  0x30787B5B       19292  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvista.so
 0x30798000  0x30798677        1656  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libvista.so
 0x30799000  0x307A04A3       29860  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfile_alloc.so
 0x307B04A4  0x307B0E0F        2412  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libfile_alloc.so
 0x307B1000  0x307B75C3       26052  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libchasfs.so
 0x307C75C4  0x307C7E7F        2236  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libchasfs.so
 0x307C9000  0x307D748B       58508  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos_svcs.so
 0x307E748C  0x307E8ACF        5700  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbinos_svcs.so
 0x307E9000  0x307EA25F        4704  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystime.so
 0x307FA260  0x307FA46F         528  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsystime.so
 0x307FB000  0x308065F3       46580  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbtrace.so
 0x308165F4  0x30824DCF       59356  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbtrace.so
 0x30825000  0x308297B3       18356  IText  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libflash.so
 0x3083A000  0x3083AEBF        3776  IData  R/W    /tmp/sw/rp/0/0/rp_platform/mount/usr/binos/lib/libflash.so
 0x3083C000  0x3083FCD3       15572  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_flashlib.so
 0x30850000  0x308538FF       14592  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libplatform_flashlib.so
 0x30854000  0x3085B2CB       29388  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtime.so
 0x3086B2CC  0x3086BF8F        3268  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtime.so
 0x3086C000  0x308A9FA3      253860  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libpds.so
 0x308BA000  0x308BE47F       17536  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libpds.so
 0x308BF000  0x308BFDA7        3496  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg_stubs.so
 0x308CFDA8  0x308CFFBF         536  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg_stubs.so
 0x308D1000  0x308D1D63        3428  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcfsp.so
 0x308E1D64  0x308E1E7F         284  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libcfsp.so
 0x308E2000  0x308EBCB3       40116  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlib.so
 0x308FC000  0x308FCFBF        4032  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlib.so
 0x308FD000  0x308FD823        2084  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsyspage.so
 0x3090D824  0x3090D8DF         188  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsyspage.so
 0x3090E000  0x3094063B      206396  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosd_unix.so
 0x30951000  0x3099DD9B      314780  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libiosd_unix.so
 0x3099F000  0x309D8DBB      236988  IText  R/W    /lib32/libgcc_s.so.1
 0x309E9000  0x309E9DBF        3520  IData  R/W    /lib32/libgcc_s.so.1
 0x309EA000  0x30B42983     1411460  IText  R/W    /lib32/libc.so.6
 0x30B53030  0x30B60FBF       57232  IData  R/W    /lib32/libc.so.6
 0x30B61000  0x30BFFE43      650820  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libspilib.so
 0x30C10000  0x30C198B7       39096  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libspilib.so
 0x30C1A000  0x30C27873       55412  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_common.so
 0x30C38000  0x30C398DB        6364  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_common.so
 0x30C3B000  0x30C469EB       47596  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha_types.so
 0x30C57000  0x30C586BF        5824  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ha_types.so
 0x30C59000  0x30D3A01B      921628  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_types.so
 0x30D4A01C  0x30D6271F      100100  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cce_types.so
 0x30D63000  0x30E07ACB      674508  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_qos.so
 0x30E18000  0x30E29BD7       72664  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_qos.so
 0x30E2A000  0x30E63903      235780  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_types.so
 0x30E73904  0x30E79BF7       25332  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_types.so
 0x30E7B000  0x30EA9C73      191604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_adj_macstr_common.so
 0x30EBA000  0x30EBF81F       22560  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_adj_macstr_common.so
 0x30EC0000  0x30F238EB      407788  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_types.so
 0x30F34000  0x30F3E8B3       43188  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_types.so
 0x30F3F000  0x3101675B      882524  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target_types.so
 0x3102675C  0x3103AFFF       84132  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l2target_types.so
 0x3103B000  0x3105291B       96540  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf_types.so
 0x3106291C  0x31064E7F        9572  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_l3intf_types.so
 0x31066000  0x3109038B      172940  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf_types.so
 0x310A038C  0x310A4C67       18652  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_urpf_types.so
 0x310A5000  0x31126F0B      532236  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_types.so
 0x31137000  0x31146A8F       64144  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_acl_types.so
 0x31147000  0x31158563       71012  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl_config.so
 0x31169000  0x3116AE37        7736  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_punt_acl_config.so
 0x3116B000  0x3117E81B       79900  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_pbr.so
 0x3118E81C  0x31190B9F        9092  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_pbr.so
 0x31192000  0x311C1DAB      196012  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr_types.so
 0x311D1DAC  0x311D6E4B       20640  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_pbr_types.so
 0x311D7000  0x312171E3      262628  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun_types.so
 0x312271E4  0x3122E423       29248  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_tun_types.so
 0x3122F000  0x3124D6DB      124636  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ipmc.so
 0x3125D6DC  0x31260F1F       14404  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_ipmc.so
 0x31261000  0x3128A40B      168972  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_types.so
 0x3129A40C  0x3129EE3B       18992  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_types.so
 0x312A0000  0x312AA643       42564  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_types.so
 0x312BA644  0x312BB95F        4892  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_types.so
 0x312BC000  0x312C3F3B       32572  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_msg.so
 0x312D4000  0x312D4C0F        3088  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_msg.so
 0x312D5000  0x312FEE63      171620  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_wccp.so
 0x3130F000  0x31313A9F       19104  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_wccp.so
 0x31314000  0x3137469B      394908  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_types.so
 0x3138469C  0x3138EF57       43196  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_types.so
 0x31390000  0x313AD0DB      119004  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_msg.so
 0x313BD0DC  0x313C02AF       12756  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_msg.so
 0x313C1000  0x31430A93      457364  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_types.so
 0x31431000  0x3143D717       50968  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_types.so
 0x3143E000  0x3145B343      119620  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_msg.so
 0x3146B344  0x3146E6BF       13180  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_msg.so
 0x3146F000  0x31517D43      691524  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp_db.so
 0x31528000  0x315387DF       67552  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libsnmp_db.so
 0x3153A000  0x3154B36B       70508  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfman_rp_obj.so
 0x3155C000  0x3155CE0F        3600  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libfman_rp_obj.so
 0x3155D000  0x3155E45B        5212  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcef_config_common.so
 0x3156E45C  0x3156E63F         484  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libcef_config_common.so
 0x3156F000  0x3156F6AF        1712  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_queue.so
 0x3157F6B0  0x3157F72F         128  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_queue.so
 0x31580000  0x31581113        4372  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_hash.so
 0x31591114  0x3159129F         396  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_hash.so
 0x31593000  0x315936AF        1712  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_rb.so
 0x315A36B0  0x315A372F         128  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libtrans_rb.so
 0x315A4000  0x315ADC53       40020  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libslclient.so
 0x315BE000  0x315BECCF        3280  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libslclient.so
 0x315BF000  0x316099C3      305604  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxos.so
 0x316199C4  0x316239FF       41020  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libxos.so
 0x31624000  0x3175C8F3     1280244  IText  R/W    /usr/lib32/libxml2.so.2
 0x3176D000  0x31772A63       23140  IData  R/W    /usr/lib32/libxml2.so.2
 0x31774000  0x31776BEB       11244  IText  R/W    /usr/binos/lib/lib4arglib.so
 0x31787000  0x3178B93F       18752  IData  R/W    /usr/binos/lib/lib4arglib.so
 0x3178E000  0x317A3D5B       89436  IText  R/W    /lib32/libpthread.so.0
 0x317B443C  0x317B73FF       12228  IData  R/W    /lib32/libpthread.so.0
 0x317B8000  0x317C1CBB       40124  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libngd.so
 0x317D2000  0x317D3E0F        7696  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libngd.so
 0x317D5000  0x317DD2E3       33508  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libds.so
 0x317ED2E4  0x317EE68F        5036  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libds.so
 0x317EF000  0x317F006B        4204  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liberrmsg.so
 0x3180006C  0x318001AF         324  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/liberrmsg.so
 0x31801000  0x31803CCB       11468  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbmalloc.so
 0x31813CCC  0x31815DEF        8484  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libbmalloc.so
 0x31816000  0x3181FFD3       40916  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libavl.so
 0x31830000  0x318308DB        2268  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libavl.so
 0x31832000  0x3183399B        6556  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlite.so
 0x3184399C  0x31843B5F         452  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinstallerlite.so
 0x31844000  0x3184A86B       26732  IText  R/W    /usr/binos/lib/libjson.so
 0x3185B000  0x3185BB0F        2832  IData  R/W    /usr/binos/lib/libjson.so
 0x3185C000  0x3185CEFB        3836  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref_posix.so
 0x3186D000  0x3186D16F         368  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libobjref_posix.so
 0x3186F000  0x31884E33       89652  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_common.so
 0x31895000  0x318977C7       10184  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_common.so
 0x31899000  0x3189DD2B       19756  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_common.so
 0x318AE000  0x318AE78F        1936  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_qos_common.so
 0x318AF000  0x318B4AFB       23292  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_dwtv.so
 0x318C5000  0x318C5AAF        2736  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_dwtv.so
 0x318C6000  0x3197D733      751412  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_tables.so
 0x3198D734  0x319A285F       86316  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_cef_tables.so
 0x319A4000  0x319CCD93      167316  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_fed_api_mfi.so
 0x319DD000  0x319E170F       18192  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_fed_api_mfi.so
 0x319E2000  0x31A0B4AB      169132  IText  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_tables.so
 0x31A1B4AC  0x31A1F58F       16612  IData  R/W    /tmp/sw/rp/0/0/rp_iosd/mount/usr/binos/lib/libffm_mfi_tables.so
 0x31A22000  0x31A301D3       57812  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv_types.so
 0x31A401D4  0x31A41D1B        6984  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv_types.so
 0x31A42000  0x31AFA95B      756060  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_tables.so
 0x31B0B000  0x31B1FF43       85828  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_ipmc_tables.so
 0x31B21000  0x31B26CF3       23796  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_vrf.so
 0x31B37000  0x31B37A83        2692  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_vrf.so
 0x31B38000  0x31B57AA3      129700  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_tbl.so
 0x31B58000  0x31B5B943       14660  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_vrf_tbl.so
 0x31B5C000  0x31C0DEEB      728812  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_tbl.so
 0x31C1E000  0x31C319D7       80344  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_wccp_tbl.so
 0x31C32000  0x31C46143       82244  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv.so
 0x31C56144  0x31C585A7        9316  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_recv.so
 0x31C5A000  0x31C6B90B       71948  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_uth.so
 0x31C7C000  0x31C7DF7F        8064  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_uth.so
 0x31C7E000  0x31C83E73       24180  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_incomplete_target.so
 0x31C94000  0x31C94A2F        2608  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_incomplete_target.so
 0x31C95000  0x31CA1F6B       53100  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_incomplete_target.so
 0x31CB2000  0x31CB387B        6268  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_incomplete_target.so
 0x31CB4000  0x31CF8F53      282452  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_fnf.so
 0x31D09000  0x31D1054F       30032  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_fnf.so
 0x31D12000  0x31DCCF93      765844  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_table.so
 0x31DDD000  0x31DF217F       86400  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf_table.so
 0x31DF3000  0x31DF829B       21148  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf.so
 0x31E0829C  0x31E08C5F        2500  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fnf.so
 0x31E09000  0x31E2B823      141348  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_test_obj.so
 0x31E3C000  0x31E3FC2F       15408  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_fed_api_test_obj.so
 0x31E40000  0x31E5378B       79756  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj_types.so
 0x31E64000  0x31E65F4F        8016  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj_types.so
 0x31E67000  0x31E90593      169364  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj.so
 0x31EA0594  0x31EA4C57       18116  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libffm_test_obj.so
 0x31EA7000  0x31EC1E0B      110092  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinfra.so
 0x31ED2000  0x31ED65B7       17848  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libinfra.so
 0x31ED9000  0x31F69E6B      593516  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaacommon.so
 0x31F7A000  0x31F8B583       71044  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libaaacommon.so
 0x31F8E000  0x31F96B43       35652  IText  R/W    /lib32/librt.so.1
 0x31FA6DB4  0x31FB201F       45676  IData  R/W    /lib32/librt.so.1
 0x31FB4000  0x31FBD523       38180  IText  R/W    /usr/lib32/libunwind.so.7
 0x31FCD524  0x32008B3B      243224  IData  R/W    /usr/lib32/libunwind.so.7
 0x32009000  0x3200AE0B        7692  IText  R/W    /lib32/libdl.so.2
 0x3201AFE4  0x3201B0EF         268  IData  R/W    /lib32/libdl.so.2
 0x3201F000  0x320308F3       71924  IText  R/W    /usr/lib32/libz.so.1
 0x320408F4  0x32040B2F         572  IData  R/W    /usr/lib32/libz.so.1
 0x32041000  0x321140FB      864508  IText  R/W    /lib32/libm.so.6
 0x32124FEC  0x321257DF        2036  IData  R/W    /lib32/libm.so.6
 0x32126000  0x3213011B       41244  IText  R/W    /usr/lib32/libsafelibc.so
 0x3214011C  0x3214089F        1924  IData  R/W    /usr/lib32/libsafelibc.so
 0x32143000  0x321643CB      136140  IText  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg.so
 0x321743CC  0x3217749F       12500  IData  R/W    /tmp/sw/rp/0/0/rp_infra/mount/usr/binos/lib/libmemdbg.so
 0x32400000  0x523FFFFF   536870912  Local  R/W    heap
 0x52400008  0x53400007    16777216  Local  R/W    IOS Process stack
 0x7FC72000  0x7FC87FFF       90112  Local  R/W    stack
Free Region Manager:
The configuration currently has a set of local usernames and the devices is set to use those local usernames and their configured privilege level (all currently "15" = full admin privileges) for authentication and authorization per the following lines:
username disaster privilege 15 secret 5 <removed>
username svc-kiwi privilege 15 secret 5 <removed>
username admjkude privilege 15 secret 5 <removed>
username admprime privilege 15 secret 5 <removed>
username svc-prime privilege 15 secret 5 <removed>
username admpsing privilege 15 secret 5 <removed>
username admkgen privilege 15 secret 5 <removed>
username admtmcco privilege 15 secret 5 <removed>
aaa new-model
aaa authentication login default local line enable
aaa authorization console
aaa authorization exec default local
If any new users were defined with a lower privilege level (say "3" or "4") they would be restricted to the commands that appear in the following section of the config file:
privilege interface level 3 duplex
privilege interface level 3 speed
privilege interface level 4 power inline never
privilege interface level 4 power inline static
privilege interface level 4 power inline auto
privilege interface level 4 power inline consumption
privilege interface level 3 shutdown
privilege interface level 4 ip address
privilege interface level 3 switchport
privilege interface level 3 description
privilege configure level 3 interface
privilege configure level 4 ip domain-name
privilege configure level 4 clock summer-time
privilege configure level 4 clock timezone
privilege configure level 4 hostname
privilege exec level 4 copy running-config startup-config
privilege exec level 4 crypto
privilege exec level 4 tclquit
privilege exec level 4 connect
privilege exec level 4 telnet
privilege exec level 4 mtrace
privilege exec level 4 mstat
privilege exec level 4 mrinfo
privilege exec level 4 tunnel
privilege exec level 4 access-enable
privilege exec level 4 power
privilege exec level 4 enable
privilege exec level 15 disable
privilege exec level 3 configure terminal
privilege exec level 4 resume
privilege exec level 4 name-connection
privilege exec level 4 disconnect
privilege exec level 4 reload
privilege exec level 4 terminal
privilege exec level 3 show startup-config
privilege exec level 3 show running-config
privilege exec level 4 show interfaces
privilege exec level 4 set
privilege exec level 4 lock
privilege exec level 4 logout
privilege exec level 3 clear counters
privilege exec level 4 clear
THANKS!
