In/out behavier of ACL's
rteglgaa
When configuring something like "ip access-group ACL in" does the "in" mean in-going traffic, or inner side of the port/vlan on which the access-group is added?
Rgds,
Rasmus
steve
Hope this helps:
When applying an accesslist 'out' tell the router to compare outgoing packets and not inbound packets and 'in' the other way round of course.
Out to a router means packets leaving its interface and in means packets arriving at the interface.
cheers
Steve
steve
Hope this helps:
cheers
Steve
Thanks for your answer. Just what I needed.
You might wonder why I'm asking such a question. The thing is that I'm not actually configuring a Cisco device. I configuring a HP ProCurve routing switch which a kind of a Cisco-wannabe. Same CLI, same command, ACLs etc.
The thing is that in HP's terms IN stands for innner side, and OUT stands for outer side. This did confuse me, since I rememered (as you just told me) that in Cisco terminology the in stands for ingoing.
This coursed my ACLs to stop working, and when I found the cause, I suddenly couldn't remember, what Cisco's way to do it was.
Anyway - thanks.
Rasmus
No problem...actually I'll make a mental note of how the HP does it!
cheers
Steve
