ip redirection in FWSM in routed mode.
p.revi
How do i enable IP redirection in FWSM ? when I mean traffic coming from one interface nedds to be redirected to some other device in the same interface its not happening in the normal scenario.Is redirection supported in routed mode?
johansens
Level 4
Level 4
It depends,
If you are running <2.2, then you can't, ref. the Q&A question "Can I operate the PIX in a "one armed" configuration?" (The 1.1.x runs on a derivative of PIX 6.0 and 6.2) :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_qanda_item09186a0080094874.shtml#add
If you are running >=2.3, then you can by enabling the "same-security-traffic permit intra-interface" feature:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00802c6417.html#wp1052504
johansens
Level 4
Level 4
It depends,
