isa to login to domain inside from outside
cfajardo1_2
hello,
is there any way an isa server on the outside of the pix can login to the domain which is inside of the pix?
note that we could only put a single default gateway on the isa which i have currently on the external interface and pointing to the router.
if i remove the default gateway on the external, and put a def gateway on the internal interface and point it to the outside interface of the pix, the i could login. But we can not do that coz we need the def gateway at the external interface.
thanks alot
johnd2310
Level 8
Level 8
Have you tried adding a static route on the ISA.
**Please rate posts you find helpful**
ya, actualy that has already solved the problem. we have added a route add command.
thanks a lot.
