issue with RDP
ManjuSijo7572
Windows 7 System unable to RDP . Network disconnection error happens at the time of local session manager. Cisco any connect is installed in the system, Can anyone say, the solution ?
balaji.bandi
You need to provide more information about the problem ?
1. what is the ASA, what ASA code you running.
2. how is your Setup configured.
3. are you able to connect any connect to VPN ?
4. what is the exactly error you getting while you RDP.
If you having issue with RDP after connecting any connect connection established, worth looking below link :
https://www.petenetlive.com/KB/Article/0000546
if not explain more.
BB
Thanks for your reply.
We have some cctv appliances setup in few locations, and we are trying to RDP them from the jump host server. The  authentication is successful but at the time of loading local session manager there will be a popup saying network disconnection error. If we put a continuous ping, there will be RTO at this time, and the screen will come back to the original one , which means RDP wont happen.
