Multi Site-Site VPNs question
Hi Guys,
So I'm working on a proof concept in PT and learning a lot on the way! I just have a question regarding site-site VPNs, Is it at all possible to have a router at the HQ configured with multiple tunnels to various branches? (see image)
I know that the image depicts the branches being connected to the HQ on separate IP interfaces, but obviously in the real-world it would all be happening over a single interface on the HQ site, the internet connection of course. The problem is I know there is a limit of a single crypto map on a single interface...
Any ideas?
Thanks in advance for any advice!
Topology exampleTopology example
Something like:
crypto map CRYPTO 10 ipsec-isakmp
crypto map CRYPTO 10 match address FOO-01
crypto map CRYPTO 10 set peer 1.1.1.2
crypto map CRYPTO 10 set transform-set BAR-01
crypto map CRYPTO 20 ipsec-isakmp
crypto map CRYPTO 20 match address FOO-02
crypto map CRYPTO 20 set peer 2.2.2.3
crypto map CRYPTO 20 set transform-set BAR-01
crypto map CRYPTO 30 ipsec-isakmp
crypto map CRYPTO 30 match address FOO-03
crypto map CRYPTO 30 set peer 3.3.3.4
crypto map CRYPTO 30 set transform-set BAR-01
crypto map CRYPTO interface outside
cheers,
Seb.
7 Replies 7
Seb Rupik
Hi there,
Yes, it is pretty stand configuration to have multiple VPNs terminated on a single interface. As you mention this would be achieved using a single crypto map with multiple sequences/ peers defined.
You should be able to mock it up in PT. Add a switch in bewteen all of the routers and have their 'outside' interfaces connected to a common subnet.
cheers,
Seb.
Hi Seb,
Thanks for the reply, I figured there'd be a way to do this with a single crypto map...
Would you be able to provide a quick / simple example for how to configure "A single crypto map with multiple sequences / peers defined", is it done in a similar way to an ACL with multiple permit / denies?
Yanni
Something like:
cheers,
Seb.
Okay, similar to what I was thinking, thanks for the response!
You just change the sequence number.  So you can have a single crypto map with 4 VPNs for example.
crypto map cm-cryptomap 100 ipsec-isakmp
crypto map cm-cryptomap 101 ipsec-isakmp
crypto map cm-cryptomap 102 ipsec-isakmp
crypto map cm-cryptomap 103 ipsec-isakmp
If these are routes and are all your own sites I would tend to use DMVPN/iWAN instead.  Even using DVTI tunnel interfaces is likely to be easier.   Using crypto maps seems so "old school" now.
Hi Philip,
Thanks for the advice, I'll definitely research DMVPN for future consideration!
Thanks!
I'd agree with Phillip and go for DMVPN type solution using multiple Tunnel interfaces with IPSEC protection for each P2P (assuming that the remote peers dont want or dont have reachability with each other. You're going to get more flexibility with regards to routing, no encryption domain definition, etc....
ie..
interface Tunnel0
 tunnel protection ipsec profile P2P-PROFILE
