11-19-2001 09:47 AM - edited 03-08-2019 09:12 PM
Hello
Is it possible to set the global (PAT) to the same IP that is on my outside interface. I believe this is how the small SOHO devices work such as the Linksys. This would be very cool for us at home who only have one IP address. Tell me if you have done it. Thanks
Mscaggs
11-19-2001 09:52 AM
Yes, it is possible with the following:
global (outside) 1 interface
Ramesh
11-19-2001 09:55 AM
Is that the complete command or do I state "interface outside"
11-19-2001 11:03 AM
that is the complete "global" command you need. By saying "global (outside) 1 interface" you are telling it use the outside interface.
Then you need your nat command, something like this:
nat (inside) 1 192.168.0.0 255.255.0.0
keep in mind that you must be using PIX version 5.2 or higher I believe.
-mike
